View Full Version : Honda Civic / Del Sol (1992 - 2000)
- GSR Question
- My h22 engine will not crank over.
- are vtec valve cover bolts 8mm?
- d16z6 swap into 99 ek dx..
- Honda Parts Catalog
- what year del sol p30 ecu would fit in my eg6
- BS problem !! Any suggestions?
- b16a rods??
- Y8 bottom end with a Y7 head.
- Stupid Q!
- Sorry for posting this here..
- How to remove cluster on a 1994 Honda Civic coupe?
- size of del sol vtec master cylinder?
- B18C1 Civic valve problem
- 37mm offset
- Greddy Head Gasket
- from a B to a D in my 00 EK hatch need to know some things!
- how to remove
- Swappin b16a2 into a 99-00 ex...mount ?
- car wont start
- Replacing D16Y8 Short block
- EX tranny on a HX??
- my car keeps cutting out! Why!!
- walbro 255 fuel pump
- Car hit Vtec. Then throws code 8?
- preferences and differences in EK hatches?
- how to0 install hids
- Cheap LSVTEC build
- Help with Greddy SM Integrate
- Overheating problem that baffles
- HID question
- B18B1 build & swap some n00b questions
- where to get 400grit honing tool?
- Steering Wheel..SRS SYSTEM PROBLEM...
- EJ1 ABS Brake Trouble...complicated...
- Autometer Tach Mounting Position
- Del Sol Wing - Part number
- Quarter Panel help..
- Sleeve a B20 for B20-vtec applications or just for boost?
- no start no engine light...check my logic.
- is the EM1 Si Climate/AC controls different then 99-00 regular civic climate/AC controls
- exhaust gsr
- I want to but this P75 computer off of someone but I need it to be OBD1 how can I tell if its an OB
- Stripped Nut on Exhaust Mani
- 99 ek swapped 92 si motor
- n00b brake bleeding question....searched and read all posts in archive
- yyExhaust system
- Air/Fuel Gauge Install Question
- 95 Civic Dx center console and door panels
- fuel pump ?'s
- What would YOU choose?
- B18a1 and B18b1 what is the difference?
- Distributor problems...
- what are my options to make horsepower
- Power window only down
- Alternator Fuse - Running car?
- b18c gsr delsol question
- poof gas mileage
- Any downside to going plus size rotors...?
- EK rear seats install
- Brake pedal pop?
- Coilover Sleeves
- abs light?
- smog and not to get jipped
- B20B/LS Head swap... Possible? Beneficial?
- Sick EDM FOGS.
- Waste Of Money
- 1997 Del Sol Fog Lights
- Dc2 springs on a EK??
- Random Check Engine Light
- EK dash color question
- Door panel liner putty...what to buy
- no power
- GSR in EG Intake Manifold Fitment Question
- H Swap into de Sol-Weight Question
- bent flange?
- Just swapped in my b20 vtec and car idles at 3k....any inputs??
- Length of the ES Oval?
- 92 dx four door rear sway bar?
- vtec pressure valve? (vid) need help
- cobalt suppliers on htech ?
- who lives or is in myrtle beach
- Need the lower rear LCA bolt and bushing. Is this it?
- exhuste cans
- any one know who Kenichi Nagahiro is?
- engine stalls out when braking
- life time replacement seatbelt for honda
- Anyone in the West TN area?
- HKS Hi-Power Help
- reat t-bracket?
- i just got a 93 civic ex for $500!!!!!!!!!!
- engine boggs and dies
- Will an obd1 b16 dizzy work on a obd2 ls?
- Fog lights question
- Injector help
- speedo going crazy!!
- a/c compressor and lines fitment ? eg only, checked an em1 for reference
- wondering if any one can help (wide body kit)
- Suspension for my swap
- D15B2 mini me swap into EG coupe, searched....can anyone help clear up some things?
- b20 vtec
- Scraping Sound From Rear When Turning 94 Hatch Stock
- stroker kit = higher compression?????
- does/has anyone else had this problem with a b16 VIDEO LINK inside...
- Air Conditioning problem
- lowering question
- h22 civic swap...Quick help
- suspension question
- what lip is this? (for eg)
- Suggestions, Info, Help
- So whats hot on the market right now for the 92-00 Civic?????
- Tranny leaking here, please tell me how to fix it.
- how far to tighten top strut nut?
- ls/vtec bulid
- odometer jump?
- Intake and test pipe
- K20a2 working with S2000 Cluster
- Whats needed for a K20a2 Swap Into A 1994 Coupe?
- JDM CITY LIGHTS WIRING
- Studder Problem
- IAT trouble
- Help on headers to test pipe
- CARBING Front Upper strut bar VS. Password JDM 3 Pt. front upper strut
- same p/s topic
- Civic HX
- Civic Ek / Em1 - Sunroof Cover Fell of track , sunroof cant open!
- Fuel pump???
- swap question, brain fart
- Vtec Solenoid
- Irratic Idle B16
- where can i find a p/s removal kit.
- s2000 steering wheel cover
- Car wont star after swap!!!!HELP ASAP!!!!!!
- Need some advice.
- D series rear T bracket question
- car moves in neutral.
- what oxygen sensor please help!!!!!!!!
- GSR in 94 EX coupe, AC question...
- ECU help..
- racing harnesses? help
- Steering rack replacement... 93 EX.. power to manual.
- supercharger? D16 does anybody hav any input????????
- Engine won't fire - Any ideas?
- yellow H4 bulbs. ?
- d15b2 into 97 cx
- Weak starting car, Wont turn over?
- help
- wire harness for fuel pump
- 94 eg hatch dash?
- Car seems faster when not ran for a while
- Now the clutch won't engage at all!
- D16Y7 Coolant Hose Routing
- my car won't engage vtec in second gear only...
- need help wiring tach
- type r intake
- A/F gauge install FAZE
- POWER WINDOW MOTOR
- b&m short shifter
- Question about Duel Exhaugst.
- Is it normal to smell gas at the evaporative canister when it's hot?
- Coolant leak
- 98 ex d16y8 for a 2000 gsr b18 we need some help with mount problem
- alternator....???
- rear wheal disk brakes on EJ2
- Door Lock Problems
- Aito Flywheel Stuck? wont turn over
- Cannot do a self CEL diag... light just WILL NOT blink.
- Tach not reading properly, bounces around and rests at zero a lot. <VIDEO>
- timing???
- map sensor help!!!
- Car Wont Start after Engine Harness Swap Please Help
- distributer question
- intake hose question
- hmotorsonline questionare!? b16a
- Picture of Front Brake Lines? 1992?
- A little fun with sheet metal
- transmission leak
- 97 Civic Sunroof gear noise at close only
- Y7 swap into 92 civic complete but wont run. any ideas??
- tach go all the way to 5k and then it shut off
- best way to remove seized bolt- rear camber kit install
- Help with my EK B18 swap
- Need help diagnosing turn signal problem - yes I searched.
- OEM Si Lip--How Did You Install It?
- del sols in junkyards thread
- would a si tranny fit on a b18a1 block
- Help! gsr swap problem
- eg5 exhaust fumes
- Motor Swap Questions
- IAT problem
- 99 Si Problem. **Searched**
- d16z6 running like shit
- exhaust piping and exhaust tip
- how much would you pay for a 93 civic coupe with a blown headgasket?
- IM IN BIG TROUBLE GUYS HELP ME!!
- EG d16z6 swap
- GSR Swap passing smog?
- What do i need from a 99-00 si for a rear disc conversion on a 99 dx
- My EJ8 problems never end - Help 4 CEL's :(
- just curious what the EK civic SI airbox looks like. is it the one with the three chambers??
- cheapest place to get fal fan
- Time for a new motor mount.. easy stuff or let the pros do it?
- Where's dougie_pants
- Coral Orange Pearl Metallic - Is it rare?
- civic swap?
- state ref h22 in a ek?
- idle problems
- Looking for a brake setup.... for 15" tracklite rims.... on my 00 SI
- ef shocks and struts fit onto an eg?
- just bought an ek, some questions about gas mileage and model
- Anyone know what this rear lip goes to? 71511-S04-0000
- Is this rear garnish sold in the US?
- wierd clicking noise
- can i put a/c in my dx
- Need a eG6!!!!
- help identifying this spoiler. i would like to sell but i dont know what it is!!
- H-swap mount question
- radiator losing fluid, no drips
- Anybody Have Mounting Instructions for an OEM Si Lip?
- ecu buying question
- Boosting a Y7/Auto tranny??
- Transmission Mount missing?
- Wow! What's up now?
- Help me identify this part
- buying a former supercharged motor, what do you think?
- Projector or blackhousing headlights for 96 civic??
- 92-95 sedan sway bar
- Eg fuel doors interchangeable?
- im new
- Hot rotors and rims. Normal?
- clutch pedal noise.. help..
- 1999 si head
- 95 civic ex
- whos thr tranny man
- Gimmie your opinion on these rims, thanks.
- penzoil synchromesh
- weird overheating problem HELP!!!!!
- making my stock ek engine faster
- Must be a common problem Dust Boot Caliper Piston
- ATTN ANY ONE BUYING FROM JDM OF MIAMI
- how much HP wil;l i ghain?
- I need a lilttle help..........please
- 1999 civic hatchback dx problem
- Can't deside on an exhaust here are some sound clips
- budweiser commerical featuring jeniffer aniston funny video
- Wiring problems 96 hatch D16Z6 mini-me
- shift linkage feels funny
- why are all these civics built in north america?
- D15B Dual Vtec
- Blown Short Block
