View Full Version : Honda Civic / Del Sol (1992 - 2000)
- vtec solenoid wire?
- issue with 98 Civic sometimes not starting
- rotors or bearings
- clutch fitment
- 97 Civic EX Exedy clutch issues
- 95 EG Cruise Control Troubleshooting
- Skunk2 Magnetic Drain Bolt
- ****ej1 with gsr swap blowing ecu fuse HELP!
- 97 Hatch Issue's
- Limit rotation of cam and crank after removal of timing belt?
- 95 Civic hatch -- climate control light/ steering column problems
- 92 civic hatch cx - what is this box under the intake pipe????
- 93 civic - where can I get an oem dash wiring harness??
- Is it possible to pass smog with a non-california catalytic converter?
- D16Y7 transmission - rattling (Is is common?)
- Driver Outside Door Handle... Metal Bracket
- Where to find cabin harness block off plugs (EH/Ej/EG Chassis)
- 93 hatch randomly won't start sometimes(usually when I get gas)
- Lower radiator hose doesn't heat up? No overheating though.
- 93 civic gsr swap problems! PLZ HELP!!!!
- 99 Civic sedan -- Is stock alarm sensitive/loud enough to keep away thieves?
- Stock eg d15b7 bogging until 3000 rpm
- 95 Civic - back sits really high and front is low (solved)
- Very Low Gas mileage, Lumpy Idle & Power Loss
- 94 Civic coupe - Electrical help with connector pin outs?
- Can i use a Sohc vtec clutch on a Sohc non-vtec motor?
- HELP, 95 civic dx hatch - very rough idle, obvious lack in power, and burning oil
- 99 civic ex/CTR swap/00 Si engine harness/PCT ECU - starting problem
- [Video] 93 Hatch - clutch pedal adjustment - possible bad spring?
- Black substance under radiator cap
- Honda Lifetime Warranty on seatbelts?
- Cylinder Head Cover Bolt Broke! Help!
- 98 EX 10k miles 1 owner value?
- 93 Civic Speedometer Problems
- 97 Civic LX sedan - Rear passenger side door won't open
- 96 civic b20b lost power
- want to get rid off the aircon guide?
- oil leak or leaking head gasket
- What is this on my D16Y7 Intake Manifold
- K&N Cone filter on stock intake?
- rear disc brake conversion question..
- 97 Del Sol Si - need help with cable reel / clock spring
- DOHC ZC in OBD1 EG Cutting out
- 98 Civic EX - bubbling noise? coming from front passenger wheel area
- 00 Civic DX auto - need opinions on build
- HELP NEEDED REGARDING FUSES
- 99-00 Si climate conversion HELP!!
- Speed Chip
- b16 in eg8 no start probem
- Integra mirrors on Civic coupe
- Chewing noise under the hood
- A/C Installation in 96 Civic CX - List of what I need to get?
- 97 Civic EX won't start -- what could it be?
- 00 Si/01 Gsr swap - What's needed to get car smogged and passed by the state ref?
- Stuck rear seat in 94 civic hatch?
- obd1 distributor test ? ? ?
- clouds of white smoke
- Can I use the d16y8 distributor guts in a LS distributor housing??
- compression test civic d16y8 videos please look
- Possibly picking up a salvage em1...What is and is not compatible?
- dry carbon (pre-preg) targa roof for our del Sol's...
- 00 civic y7 to y8 swap questions
- Touchy Takeoff
- Car died on me. Radiator problem?
- 98 civic sputters/shakes. help!
- Civic won't crank with key
- IACV Code 14 after replacing crankshaft --> (Solved) - swapped sensor connectors
- Function and form type II 96 civic interchangeable to an eg?
- EG HB Project-Auto to 5 Speed
- interior painting question?
- y7 distributor on z6 head?
- slave cylinder/master cylinder
- EJ8 Seat Belt Chime/Light
- Where can I get a carbon fiber cluster dual gauge pod?
- Cleaned IACV and now high idle?
- blown head gasket or blown engine?
- Oem b16 part number
- 96 ek civic hatch elecrical problem
- Mini-me Vtec Problem
- ebrake problem..
- Coolant temp fan switch not grounded??
- Misfire, high NOx
- Compression test results. Need help! 95 Civic EX
- SOLD MY B18 SWAPPED EG HATCH TODAY
- Brake booster/Master Cylinder questions
- 94 Del sol Starter wiring
- 02 sensor help // power window help
- iac valve CEL code after swap
- b16 VTEC - should i go with oem or msd distributor cap
- Y8 block with z6 head???
- 96 Civic hatch/B16 swap - What ECU do I need to pass inspection?
- 92-95 civic coupe door lock question
- 2000 Civic Ex Cloudy headlight
- 93 Del Sol windshield - what fits?
- economy mods: 1997 Civic
- What cars can i find a b16a throttle body in local junk yards?
- manual window regulator in power door?
- B16b -- Performer X IM vs Skunk2 Pro IM
- 96 ek instrument panel lights
- 2000 Civic B18 w/ Problem HELP!!
- Help: Timing Belt on D16
- Doing rear disc conversion ek coupe would I need teg springs in rear?
- B16 Information on Head Gasket
- Low but Steady Idle and Jumpy Takeoff
- EG Cupholder Swap
- b18b swap in civic bog help!
- 93 del sol si wierd noise
- Weird noise from my jdm b16a please help
- Have a question looking to change my dash
- OBD2 swapped into OBD1 EG, fuel spark but wont run
- coolant in cylinders
- please help!
- tach problems
- What is this Knocking/Tapping Noise
- Replace 92..95 Spindle with 96
- need to find me d15b vtech engine
- trying to install Ac
- 97 civic ex speed sensor location
- Aftermarket header B16 - Check Engine Light.
- Mini-Me Swap question (Searched)
- Y8 Crank
- Advise on modding my Civic eg9/B16a swap
- 98+ spec type r b18c into civic hx - What needs to be done?
- 00 EX Cel
- D16y8 after market cam
- RHD question
- 97 LX won't start. Electrical
- Idle problem someone please help me!!!
- Quick hatchback & coupe question......
- How much does it cost machine shop to do head?
- S2k Start engine button for EG PROBLEM
- hatch vs coupe trunk cable
- Civic 99 1.4i liter petrol is running rich
- Doing a new project...have some questons on vtec-e
- Water Leak Interior, Driver Side
- eg hatch vx/gsr swap will not idle
- 5pt harness bar - need help with installation in eg
- Oil Leak after Cleaning The Engine?
- bad wheel bearing after new wheels?
- Car just dies after about 15 mins of running
- Headlight Bulbs
- Honda Civic Ex 1998 electric/wire problems
- Sedan third brake light removal
- Flickering lights and weird speedo behavior
- Broke the block where the thermostat housing attaches too...PICS
- OBD1 h22a1 distributor to OBD2 96 civic harness Diagram
- b16a2 acting up near vtec
- 93 civic interior
- 95 del sol vitara
- B&M Short Shifter Questions
- EK window wont close (not off track)
- Can't get starter back together!!!
- 94 Sol Si failed smog- high HC
- 97 civic ex speedometer help
- Timing belt?
- Car dies when pulling spark plug boot.
- Need a refresh or swap ?
- 96 EX P0138 CEL HELP
- Exhaust port
- Car only blowing hot/cold no warm
- 97 Civic - need help fixing cut taillight cables
- CEL Del Sol 94'
- car wont crank!!!
- starting b16 turbo build suggestions and help!!!
- 98 civic EX swap to B18A1 Vaaccum help!
- '98 Civic EX - New owner looking for guidance.
- Engine for 2000 EX
- SRS light question
- 1992 Civic si No-Low brake pressure *HELP*
- Check engine light flashed and now its on for good??
- Head Gasket / 1994 Civic CX
- Engine cutting out with high RPM
- '96 - 00 EX calipers vs '99 - '00 Si calipers.
- Need tips on doing a compression test
- eg6 hks silent hi power exhaust on a 98 civic sedan
- 97 civic - spark plug broke and I don't know how to get the rest out
- Blower Motor Stopped working after front end collision
- Msd modified distributors
- B16 - which header would be best?
- help! b16a smoking BADDDD!
- intermittent smoke from exhaust at random times?
- Eg IACV help
- Rear Top Hat
- Daily Driver - options for upgrading the engine of an automatic?
- 98 Civic ex/b18b1 swap - Could my timing belt have slipped a tooth on the crank gear?
- 1995 vtec del sol - what engine do I have?
- Top End/TB/WP kit sourcing advice
- VTEC Del sol 94' fluctuating Revs
- hub assembly help
- b18c1 swapped ej8 problem
- Adding stock truck horn to eg civic
- Blox intake + Omni TB?
- Rhd comes with rhd problems lol.
- engine mount problem :(
- No fuel getting to cylinder #3
- 95 Del Sol bumper install problem...not aligned correctly
- Modding a 1998 civic EX need good item references
- Replacing a 1996 D16Y8 with a 2000 D16Y8
- Belt whine
- is this a 92-93 or 94-00 a/c compressor??
- rebuilding my b16 - where should I look for a decent rebuild kit
- Is Service Bulletin 98-081 still effective or is it too late?
- Sold My DA, bought a Eg - need swap ideas
- 99/2000 Civic SI pushing water out of radiator at hight rpm?
- oem eg air box . what hose for b series?
- Need help... New 92 EH and looking for engine swap input
- 95 GSR won't rev to stock rev limiter and smokes
- Best 2 Gauges to get for EM1!?
- Help: del sol/D16y8 swap - won't rev past 4k rpm after replacing distributor
- Del Sol fog light delete?
- Stock air box removal question, 99 si
- 2000 Civic B18b1 Turbo w/ Speedo Problems..
- Will 92-95 civic ex manual dash harness working on 92 hatchback si
- How do you tell if an Oil Pump is bad?
- Can a new fuel filter increase MPG?
- 99 ex D16Y8 not shifting
- B16 head - What mm is my piston bore for my head gasket. Pr3-2.
- What year is my Engine
- Worries about smog in EK hatch
- Do you think this nick on the head a problem
- B16a2 random plug
- compression and leak down test
- bogging sounds
- 93 Del Sol How to wire IACV to the ecu
- Dimmer switch 95 Civic
- 93 Del Sol Si slow to start off
- new cluster rpm off
- B16a2 built-in oil-cooler?
- compression testing
- Will 02 civic hatch yakima roof rack fit 99 civic 2 door?
- What was last year cars had vin on firewall and top of radiator support bracket?
- Tips on seperating obd2 ecu safety clips
- Need to replace 00 civic sir intermediate shaft - Will any b series shaft work?
- What Muffler to go with? (Deep Tone)
- Positive battery terminal keeps building corrosion
- door lock doesnt work
- JVT Radiator/Fan 94 sol VTEC
- obd1 engine swap into 00 civic questions???
- sohcturbo92vx's vouch thread
- 96 HX won't start
- Need dimensions of 00 civic EX spoiler
- What axle do I need? EG coupe b16 swap
- dash light out
- looking for a Del sol
- 94 civic ex lock problem?
- transmission rumbling from 1-2nd?
- D16Y7 Swap Questions
- Is the 96-00 Civic hood fuse box the same for manual and auto transmissions?
- 99 EM1 interior lights, chimes, int and low wipers don't work
