View Full Version : Honda Civic / Del Sol (1992 - 2000)
- ignition upgrades
- First time at the track
- EK springs
- del sol rear lower control arm question
- Rear Disk Breaks
- generic chips
- Headlight bulb question???
- quick question will gsr short throw fit in a single cam shiftlinkage?
- Question about removing side molding
- race harness on del sol seats
- US Spec 96-00 hatches
- Manual to auto harness help
- drunk driver kills my car, i need advice... 56k no no
- need pic help
- Window crank gluey stuff!! HELP
- starting problems with '97 Civic LX
- What Ecu u guning on your B18C gsr powered EG ?
- 96-98 Ebay OEM Style Foglights?
- viper 1000 remote start
- 94 CX wiper problems
- What is the sensor right next to the oil filter on a JDM B16A?
- just ordered a pair of side markers and bulbs =/
- Looking for shop to help diagnose suspension/break issues...
- H-Techers in Jacksonville area!
- civic ek consol swap?
- Header clearance question:
- Tuning With APEX'I V-AFC???
- Isane Loud Clicking Sound!
- Which Brakes For My 95 Si?
- ???HOW DO I POST PICS???
- Venom Intake Manifold
- Engine + tranny swap...automatic?
- n e body ever order a door glass from honda?
- intake Q
- 1992 civic dx hatchback VTECH??
- Oil Pan Tap
- Y21 explodes??
- Curious about Civic HX vs Civic EX
- Fake Si wheels
- SRS Light On in my Civic 94
- HELP!!!!!!! B18b (ls swap) into 1997 Civic EX. Airbags are not working..
- Does this head look good?
- ***HELP!*** Underdrive pulley/Clank pulley
- Where to go for d16z6 turbo kit??
- SAFE TO START AND IDLE?
- bore question
- p29pistons
- 1995 Del Sol Dyno
- is a mini swap good??
- ecu and wire diagram
- OHIO CIVIC OWNERS
- Air Conditioning removal, just unbolt it and go?
- idle problems
- how do you take out the alternator???
- parting out gsr motor in my hatch
- throttle angle sensor
- VAFC II install on a 2000 ex
- 99 Civic Lip Question???
- Back from the mustang dyno [N/A D16Z6]
- Is it worth it to rip the dash out?
- Good swap on wheels?
- 99 Civic mirrors???
- b18c break in
- Hard to shift into gears in the morning, help!!
- B-series obd1 interchangeable?
- Link to download 92 eg factory service manual??
- Will the Spoon DC2 N1 exhuast fit into EG hatch?
- Rear Axle Wheel Bearing Swap for 98 honda civic DX (can)
- will an exhaust for a '92-95 coupe/4 door fit a '92-95 hatch w/o much modifications?
- My b16 is failing NOx readings, HELP
- Where is the EGR Valve on a B16
- vtec harness question
- auto tranny worth it?
- how does this head look? aem cam gear help too.
- problem with over heating and more........
- help on mini-me swap
- Performance shops in upstate ny??
- B series omnipower valvetrain??
- Anyone got a set of buddy club cam gears??
- one wire o2 sensor
- obd II codes?
- 2000 Civic SOHC to DOHC Swap
- someone please help
- cams or LS/VTEC
- My Car is Broke :( HELP !!!!
- civic raditor support
- Need help With b18b in an Eg
- Car Idles At About 2500 When It Starts
- help chipped glass.........
- intercooler on a ej
- Low Idle help!!!
- D15B8 vs. D16Z6
- GSR fuel rail on a b16?
- what size are the flywheel cover bolts
- 2nd gear bad syncro...
- sucked up water in intake.
- * Where does this hose go? Game.*
- 05 civic exhaust on EJ?
- HELP BROKEN BOLT pic inside
- Rear Speaker size
- VAFC 2 HELP. Already SEARCHED!!!+++++++
- JDM ITR CLUSTER INTO EG NEED WIRING DIAGRAM
- ITR fuel rail and FPR on B16a?
- Which axles to buy?
- quick question on rear upper strut bar....
- ECU upgrade vs VAFC 2?
- Anyone in PA?
- Decline in Gas mileage, what is the cause?
- Bad ECT???
- my car wont start , please help!!!!!!!!!!!!!
- is this a good deal??
- any experience of fastbrakes
- :URGENT: need clutch help....
- Engine limiting at 7500rpm. . .
- Byebye front lip :(
- can someone please help ASAP
- ack. brake fluids came pouring out while swaping brake pads
- ITR or GSR springs into a 93 EX coupe?
- was proponent of clutchmasters but now a little sketchy.
- Custom Door Panels
- Winding back milage
- 2000 civic front and rear conversion for a 94 dx possible?
- B SERIES TRANNY IDENTIFICATION
- Engine swap woes
- I need to do a motor swap on my 93 civic in Los Angeles area!!
- 5spd Conversion?
- Broke the Temp gauge Needle on 99 Si Cluster
- d16z6 camshaft in a d16y8
- A HALF ASS TIMING JOB
- ef civic front control arm/knuckle fit in 92 eg hatch?
- Safe boost for built b16a3
- Will 92-95 2Door civic Fenders,bumpers,mirrors, and head lights go right on a four door civic 92-95
- EG Seat Backs.... Are they really this hard to get out?
- Cooling Passages
- adding front and rear sway bar to my 93 DX?
- EF CIVIC AND EG WHEEL BEARINGS ARE THE SAME?
- wiring harness question
- b18- tranny suggestion
- ignition question
- Exedy clutch and fly installed, now strange humming....
- individual throttle body
- 6th Gen CF trunks
- wheres your sedan gauges at?
- 94 integra axle back bolt up to 96 civic hatchback?
- About Auto Tranny?
- Will 99-00 SI rear seats fit in a 98 hatch?
- 94 integra brake system into 96 ek?
- first time at the track
- 89 rear koni yellows Vs. 89 rear civic wagon shocks
- ECU problems...Need help!
- loss of electrical power... short somewhere?
- newb question on power steering
- what exaust for b18 swap?
- racing seats.
- b18 swap. what all do i need?
- tranny-Gear oil OR motor oil
- k20R o b16 turbo and more goodies.
- CABIN AIR FILTERS
- 3.2 TL swap in a Ek......
- EG hatch= crap engine
- why would the motor start but not go in gear?
- where to get fiberglass hood?
- Short geared d-series tranny?
- beaks sway bar and neuspeed tie bar
- Ebay boy
- Will a 1" m/c and booster benifit stock brakes?
- Si & type r
- Dx to Si tranny swap
- 99-00 Coupe Tailight Driver Side Exterior
- !!Need Help!! STARTING PROBLEMS 93 CivicEX
- green light on bumper
- just saying whats up
- EG w/itr front end? anyone got those pics?
- 92-95 civic b16a2 w/ cable tranny kit, passenger side half shaft? which one to use?
- brake mods
- What is the magic trick to get the exhaust to seal?
- Hybrid civic, need helps with radiator fans
- header questions!
- B16 SOHC?
- :does a 2" radiator question??:
- K20 swap info needed!!
- radiator support welds
- auto to manual swap
- how to make orange corner bulbs shine EXTRA BRIGHTLY? (EG)
- Where can i get 92 95 civic interior peices???
- Half a VTEC?!?!?
- Changing drum brake pads?
- white hatch from 96-98???
- FS: Integra interior pieces needed for a conversion
- need some help if you live in san diego
- wheel hop?
- 1992 Honda Civic LX 2 Door Sedan Engine Problem
- 94 ex coupe throwing CEL 41 (primary oxygen sensor heater)
- New gauge faces, need help with electrical
- b20 is faster or b16 w/ turbo is faster?
- wut ya guys think of this
- NOOB HERE TO SWAPS NEED INFO ON B18B SWAP IN 93 CIVIC EX WAS TURBO
- Really annoying problem!!! can some1 plz help me????
- Question Regarding Sunroofs!
- Is composite brake pads gonna give more dust/noise?
- Should i be worried?
- jdm city lights
- OT: Kenwood vs. Alpine vs. Pioneer
- AEM bypass valve for intake...how does it work??
- Integra axleback on EG?
- itr petrol tank under eg civic?
- Dynamat
- rebulid a tranny
- **Tranny Question**
- Track Times (First Try with the B)
- Ex Coupe exhaust on DX sedan
- ECU Swap to OBD1... Low Fuel Light?
- Should I take this 1996 CX opportunity?
- HEAD BOLT LOOSENING AND TIGHTENING SEQUENCE
- hello all
- 94 civic coupe : whats next?
- Simple Question....What is.....
- Governor...JDM B16 SiR II
- engine dress up and AEM CAI problem!
- will these LCAs fit?
- question about PW PL AC PM
- Quick Question
- Quick Axel question
- Please help, what is the maximum wheel/tire size I can fit? THANKS FOR YOUR HELP!!
- exhaust pics
- will i need a a/f gauge when tuning an apexi vafc?
- replaceing windshield?
- Need input on turbo parts
- tranny?
- how to?
- B18 and D16 VSS Interchangeable?
- broke!
- motor not running good, need help.
- are CF hoods street legal?
- car's temp gauge goes WAYYYY up at idle
- D16Z6 engine flush
- engine code ???
- Axles...
- should i trade?
- LS vs. B20VTEC swap
- Exhaust horsepower loss
- EG Coupe SEAT INTO HATCH
- Finally LS/VTEC Turbo what do you guys think.....
- what is the difference?
- help with a f20b swap into a 93 ex.
- b16a3 into vx hatch wiring question
- will this work?
- D16z intake manifold on D15 engine
- Del sol shift linkage from B series to D series
- can a p72 gsr obd1 ECU be chipet?
