View Full Version : Honda Civic / Del Sol (1992 - 2000)
- wiring for 93 civic cx hatch with b16
- Overheating problem help
- code 45 and some more
- HELP!!! Car Won't start!!!
- Ok, I need some expert help here...
- HELP!! installing engine harness...
- 98 EX door panels?
- has anyone bought from hybridrevolution
- could someone post the helms ecu pinout?
- How much can I get for this?
- which motor??... the hardest decision
- mustang throttle body can fit a civic???
- does anyone have rota attacks in gold
- rear disk conversion question
- Searchy NO worky!! PM8 is for?
- Cams For My Car?
- Half Red/Clear Tails for 92-95 Hatch? Where to get them?
- AEM short intake to cold air?
- Reverse Lights Not Working... 95 Coupe...
- Fender alignment
- Painting Wheels???
- Anyone ever rip the hole tab thing on their front bumper? Best way to fix?
- main ecu fuse problem!! please help
- What's the best place to get an OEM 96-98 lip?
- will a 88-91 si final drive go into my ex tranny
- Short Shifter
- Need idea for fixing fender...
- Exhaust Piping Size on a N/A JDM B16A?
- Wheel Well Flap
- Tranny??
- eg gun metal corner lights?
- code 22 help
- Anybody ever buy from flashoptions.com?
- Exhaust Fitment ?
- OK having fuel pressure problems. Fuel Pressure reading 100 PSI...WTF
- ls pistons in a jdm type r block????
- how do i...
- getting a new car. can't decide: Eg or Ek
- changine timing belt, waterpump, and tensioner.
- removing intake parts
- 99-00Si 1/4 times
- Dying Interior
- what mounts for a b18b into an EK
- help need on type r manifold install...
- C.F. hood ( 5th gen hatch )
- Spoon N1 Exhaust
- Anyone know the color of fuel pump power wire? (1993 DX)
- What tools do you suggest?
- JR Supercharger with D15 VTEC motor... please help.
- Header Collector size for SOHC
- walbro fuel pump...howmuch?
- I CRASHED MY CIVIC LAST NIGHT!! what to get now??
- Civic swap help
- pic request please..........
- A/C bracket for EG with B-series swap?
- To those w/ no A/C: what to do about fogging windows?
- Falken Azenis ... ??Pressure??
- F-Word I crashed my hatch last night!*LONG*
- Skunk2 rear strut bar install tips
- B18B Valve cover, will it fit a B16?
- Part Number for SI Grill???
- anybody got a hatch
- dle rough. Engine shutting off.
- cruse control light turns on when steeping on brakes?
- What kinda short shifter?
- D16 Throttle Body Swap Question
- Where is the fuel relay on a 92 civic Hatch?????
- thinking of getting 92-95 HB...Have basic questions.
- Stack gauge cluster
- HorsePower Tv?
- Ground Control?
- temp needle goes high after hard driving?
- Mugen Twin Loop fit on my car?
- Sway Bar Question
- Need some help, cant do a search
- Y8 IM on Y7 . . . new throttle cable?
- Vtec controlers
- VSS, Speed sensor problem. Need help.
- throttle body sizes
- Sudden idle problem after obd1 p28 ecu install. Car bogs then idles erractically. 56k
- Any tips on installing a short shifter in my SI?
- Interior Destripage
- HOw do I take off my bumper????
- Huge turning circle: why??
- question about the Rota circuit 8 rims on my EG
- Del Sol Si Fuel Cut Off???
- Replacing part of dash (instrument panel?)
- Does any one in this forum have a mini me? dx/vtec???
- Question about JDM ITR Cluster in EK
- need advice on mounts in a eg civic.
- need answer FAST!! 00 civic hood on 97 civic???
- what car do i order parts for b16a2
- What should I get?
- Type R intake mani in a 99 si
- how do I make EK coilovers fit EG?
- need a 5g civic power window part
- EG Integra Front End Conversion
- Cheap oem PARTS???
- 96-00 jdm cluster in 5g hatch? how hard..fair price??
- Install of del sol seats in a eg?
- Light Bulb Condoms????
- engine bogs at full throttle?
- Horn making click sound
- Mugen QT
- party with your hatch
- can a hydro clutch release point be adjusted?
- Wheel Offset
- Putting in my motor (from under the car)....not too 56k Friendly
- Brake fluid?
- neuspeed or eibach springs for 00 EBP SI?
- pics of my new bulbs *56k Warning* - Osram
- Since I see alot of SOHC interest lately
- bought a totalled gsr for a swap
- WE WON.....my version....
- HX Center Cap Question?
- Heat Shields
- b20/vtec in EG hatch
- EG Model
- ok to run stock spark plug wires with msd 6a, blaster coil and cap?
- new mugen intake for sale
- Pics of my totalled hatch
- B16 tranny
- how do i check engine codes? (engine swap)
- busted window motor...sorta
- EG daily driver/weekend DRAGGER
- pics of...... THE RIDE. j/k
- system to lean or too rich (code 45) and some more
- Hey all new guy in the cool parameter
- car overheated is this a complete no no
- Bulbs in guage cluster for del sol
- ignition
- 2001civic, no manual, set clock?
- Pics of a 92-95 hatch with any lip on the front
- Quick Question ---Eibach Sportline Springs
- EG shock/springs fit EF???
- spark plug seals?
- Plugs and wires
- jdm headlight bulbs
- aem pulley kit
- idlen too low
- new exhaust, sticking out too far!! anyone using civic cat w/swap??
- OVERALL lightest 92-95????
- Eg hb camber question
- Fastbrakes question and also What is usual cost to machine a rotor?
- civic dc sport short shifter fit an integra?
- B18c1 Baseline
- Just bought 1992 milano red hatchback si
- car runs like a raped ape
- 99-00 si wheels vs. replica rnr's
- NE1 had a problem with their AC idler pulley?
- Link to my topic concerning kyokugen lug nuts and a vendor on groupbuycenter.com
- front itr brake setup
- cheapest way to get into 13's?
- need advice on stock brake setup on 93 civic cx
- kgmm springs
- Hasport mount or poly inserts?
- surging lights.. what's the problem?
- Decisions, decisions....
- what kind of lip is this ?
- cheap mans itr question
- ecu smoking
- Looking for a how to site on converting for 96 climate to 00 climate control..
- Integra radiator swap in an EK...
- info on IAC Valve (Idle Air Control)
- buying a motor off thepartstrader
- any good news about the Tanabe SuberMedalion Hyper Spec?
- has anyone put prelude seats in a 92 hatch
- 92-95 oem front lip
- Bert-O (56 GAY beware)..........
- What is a cylinder misfire code?
- Swap Shops and the 'start up wattanty'
- Sunroof for 4 door civic?
- auto to manual pics?
- fast blinking left corner light, how to fix?
- is it worth it??? help me out
- Why is there oil in my intake??
- Exhaust size for my setup?
- Progress group camber Kits for EK (did search)
- FS soon: 99 Civic Si complete b16a2 head, 43k miles
- places to buy parts?
- need help! what's the part # for this??
- CTR replica headlights?
- Fucking thieves got to me >;(
- wiring EX/SI 96+ side mirrors to a DX....
- anyone have pics of fiber glass dashes?
- Clutch Grinding Noise
- B16 in 92 vx hatch..
- Heart Transplant. (56K run)
- Weight reduction
- JDM gsr valve clearance
- Quick ? about 92-95 Civic Mudflaps
- squeek in the brakes?
- my bday present.
- pic of my newly boosted snowplow
- Wiring problems - Help Please
- Color on 98 dx hb?
- exhaust question?
- Zex any good?
- Ls/vtec timing-piston compatabilty
- interior light doesnt come on...
- Has anyone tried Tokico HP spring/shock kit?
- Integra Type R Steering Wheel Into EK
- Is This a Good Price for a B20Z?
- 250hp is needed
- how to take off the rear windshield wiper arm
- is this a obd 2 gsr harness
- New wheels and tires??
- Springs
- Monroe Shocks
- honda bond alternative?
- Elegante One Piece Civic Projectors
- what size tweeters in a 5th gen?
- idle problems
- Is it possible to make ITR shocks to fit a 96-00 Civic
- b18c flywheel
- Special Edition 93 SI
- front ITR shocks on EK
- is a air breather good for you car
- carfax help
- Carfax Help Please
- finished exhaust install, got some questions
- turbo question.
- ls head gasket
- lookin for a VTEC engine
- gorilla lug nuts for civic with slipstreams
- 205/45/16 or 215/40/16 or 225/40/16
- 13" steelies...
- What's the best jack to purchase to get under a slammed EG?
- 89-91 EF Shocks into and EG?
- OBD2-OBd1 conversion harness GB!
- instalation of a sway bar on a non swaybar equiped car
- Popping noise when i turn my wheel?
- My untuned dyno chart
- no leathers in Si...
- Hasport mounts + HCP a/c kit..clearance?
- Kinda dumb question . . . how to install tach?
- What intake for EK w/ b18c1 swap?
- Painted intake
- anybody have carfax?
- Honda Camp
- ECG O2 Simulator
- map light question
- Which shocks to go with Neuspeed sports?
- 91 ex 15/16 master cylinder swap...............swap please help
- WHy H22a is cheaper than B18C1???
- removing a/c??
- money reward
- Just got my brake rotors, pads..Have questions..
- D16y8 manifold swap.........
- cost of type-r five lug conversion?
