View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Z6 Block/Y7 Head Questions
- brake light on 2000 ex coupe
- A/C parts for eg6 with b16?
- so I had the AC checked...need a new compressor.
- car stolen, rims,stereo ect gone
- HELP! d16z6 block d16y7 head oil question
- 95 civic EX project need help
- I need a pic of a b16 out of the car....
- crankshaft pulley? B18c1
- mini-me swap ?
- 2000 Civic Ex engine died/blew
- Y8 no compression please help
- EK Hatch w/ JDM GSR swap knock Question.
- civic build..what do you guys think?
- Skunk2 intake... purge control soleinoid removal question...
- '94 CX w/ H22 charging problems
- Y7/Y8 mini me questions
- 96 Civic CX B16A2 Wiring Issues
- 93 civic code 6?
- 93 del sol si burning oil.
- pic request rear dc suspension on ek
- Is Installing a Lower Ball Joint difficult?
- 99 civic dx blower motor issue
- How Important is this in rear suspension.92-95 eg
- 96-98 and 99-00 civic sedan taillight help.
- Del Sol Harness Bar help!!!!!!!
- 97 Civic hatch upgraded piping
- Proper engine break in for a new car?
- failed HC at idle help 94 civic EX
- arp flywheel bolts
- Any user reviews for Nippon Racing?
- what does battery light mean?
- Realistically, if you take care of your car, how many miles can you get...
- 93 civic b18b1 - timing off.
- boss steering wheel hub cracked?
- Where is the transmission filter on a 1998 Honda Civic EX?
- tranny problem it wont go in reverse
- Thinking about buying rebuilt USDM d16y7
- Started Interior
- Need help with swap...please look
- I need the drive belt numbers on the belts
- Time to replace the engine??
- 93 civic hatch only getting one click from my main realy.
- Purchasing motor online Any Recommended Sites?
- Tapping sound from intake, #1 area?
- High Pitch Squeaky Noise....Please Identify
- my car is bucking..help!! :(
- idle problems???
- Timing Issues
- GSR motor help
- Power Steering/ HELP
- New Headlight Buld ideas
- Rear fog light question
- what bearings are these
- Is my Block Shot ?
- b16 crappy acceleration
- eg hatch, jdm b16a cold start, high rev??
- power surging in dx hatch
- ek wont start clickin from under hood fuse box..
- 97 hx overheating
- energy suspension insert help needed
- Help me go fast
- Aftermarket Radiator Question
- would a headgasket leak cause loss of power?
- d16y7 and y8 interchangeability??
- "New" OEM parts vs. "Original" OEM parts..
- My first wire-tuck EG Coupe
- busted msd spark plug wire
- Adjusting wing window on a Sol?
- b16 vtec
- 1995 Civic LX - Trunk Latch SEPARATED
- Check engine light comes on after driving for 5-10min
- new GSR swap will not rev above 3500 rpm.
- dropping engine from underneath
- who makes that retardedly big strut bar for EG's thats gusseted?
- Camshaft killing my Dizzy?
- 1992-1995 Auto Transmission Fluid
- need help building H2b
- what engine?
- eg 4dr ignition ?
- Idle problem. Only way to fix is by pressing throttle to WOT. Tuned on s300
- Headliner starting to sag...
- OEM & Walbro Fuel Pump Sock Difference?
- d16y7 head on d16z6 block
- Excessive fuel consumption???
- Shifter moves side to side when in gear..help!
- EK- rear camber kit install... broken bolt, Help!
- 95 ls/vtec turbo hesitation
- cylinder 3 has oil on it what's the issue?
- What is this ripping/tearing sound?
- Intercooler Pipe Routing Question
- Walbro 340 Myth?
- Roof Wing
- when to oil and tranny change?
- Replacing the connecting pipe (thermostat to water pump)
- Where can I get s2000 seats
- Jdm eg6 rear speaker question
- Poormans type r running like shit? no check engine light need help!
- Head Gasket Install . ??
- key way on d-series?
- oil leak worsens to 1/2qt every 2-3days...
- valvetrain
- EG wire tuck must haves
- What is this plug for ? (pic inside)
- Best 62mm Intake (B18C) on EG chassis?
- Need quick help with 1 radio wire...
- b17
- EK Civic rear upper control arms, any differences between years
- 98 civic hx loud shuddering/vibration
- Recharged ac. Still no cold air
- 99-00 Heater Valve/Hose Pics Needed
- after market gauge cluster 2 colors
- 93 VX Part throttle hesitation NOT the 02 sensor!!? wtf??
- Need synchro information plz
- Accord 5spd on d16?
- reverse issues in 00 Si EM1
- ek and eg carpet
- EM1: Checking VSS sensor
- Buddy club spec 2
- Flywheel Cover for JDM GSR?
- Ek turboed gsr help please - starting, cranking, CEL, and vtec problems
- Timing belt noise
- CEL P0420....
- dx power windows and lock conversion
- sound deadening weight
- D15B7 NOISE [[HELP]]
- 2000 ex - headlight & taillight compatibilty questions
- 92-95 coupe exhaust..
- Where does L-Bracket attach to motor???
- delete abs help
- 00 civic b20 =1 me=0
- Civic vx owners - what rpms is your vx tranny reading in 5th gear at 60 mph?
- power steering questions?
- DC2 column in ek
- Honda Civic 99, start up turn off
- Looking for someone with ideas
- Honda parts # question look picture!
- HELP PLEASE ASAP FRONT RIGHT SUSPENSION
- Help Here once again Please!
- '96 HX Coupe receiving D16Y7, and 99-00 HVAC
- Front Tire Rubs..Dirver side only??
- worth it skunk 2 iM d16z6
- clutch master cylinder reservoir empty, help bleeding
- Civic wont start
- How do I make my stock 99 civic ex coupe faster and more stylish
- ek w/ b16 smoking
- Will 1995 Del Sol springs and shocks fit 1995 Civic?
- 1992 honda crankshaft pulley,bolt
- d16z6 swap question
- Eg suspension the same as a Integra suspension?
- Spare tire hardware + OEM decals questions?
- Defi Gearbox Oil Temp Sender.
- OBD1 jdm b18b ecu question
- Spongy clutch pedal after new clutch.
- tow hooks? are they functional or just show?
- vtec not working right?
- pics of new paint and rear window seal question
- 16z6 with zc pistons h3lp!
- Dizzy problems!! 1998 ex sohc
- Quieter exhaust upgrade 97 dx
- 1993 Del Sol - Check Engine Light (code 20) - I need your expertise!!!!!
- 94 civic ex wirh 92 d15b7 motor need help get 80 miles to the tank !!!!!
- Easily increase WHP for a D16
- $500 Dollars Starts a dream Del sol
- Couple problems after Suspension change Help -____-
- 93 civic si squeels
- weird start up
- How much does a factory JDM ITR Recaro rail go used for?
- How do I order B16 parts?
- 92 eg 4 door no power on acceleration?
- High Idle
- IACV Question
- 1995 Civic EX ABS Cel
- d15b real quick question. in a 93 dx hatch
- Dead cylinder!!??
- S2K starter button mod question...
- H2B question
- cold air intakes(aem or k&n)
- Wanting To Build 400+hp
- Somebody please help me!!! 2000 civic Si No Start, has fuel,spark
- results from compression test whats the next step?
- what b16 head is this(searched and still confused)
- Key ignition switch removal?
- My first B16A2 Build please give me comment
- Dc2 ITR Guage In EG
- Flooding after Swap HELP No Start
- D15b reving high after installing Skunk2 intake manifold
- arp head studs wont go all the way down-93 civic b18b1
- Do you HAVE to have the stiffer trunk springs for OEM spoilers?
- cel light stuck on
- what oil pan gasket do i need?
- aftermarket fuel gauge
- Cam Timing vs Ignition Timing
- JDM P30 ecu specs...vtec @ ? rev limit ?
- quart of oil every 2 weeks?!?!
- b16a2 trans belhousing bolts
- 93 Del Sol Steering Wheel
- D15B Running rich!
- D16Y8 Clutch Problem
- If you had to choose between these transmissions???
- will a k20 long block fit in back seat of eg sedan
- just ordered a megan racing header for my d16
- What wheels and tires should i get?
- Camber kit?
- 99 civic hx turboed...just pulled dipstick and there is white pasty crap on it
- what is the 95 civic like to drive?
- timing belt question
- 00 Civic dash lights and lights-on chime won't work after new stereo install
- 1996 itr 4x114.3 - What does the 23T caliper bracket come off of?
- 94 Civic Foglight Question
- Instrument cluster went out? '96 del Sol
- where can i buy?
- civic ex with b16 swap high reving
- 97 civic ex
- 97 civic with b16a what usdm clutch
- 1993 civic steering problems
- D16Z6 OD/ID sizes of vacuum hoses
- need serious help on installing new roof on 95 civic hatch
- Help, fuel issue...EFI Relay and IGN Switch question....
- Compression and leak down test: hot or cold engine?
- Ek civic - Surging idle Searched
- 98 civic ex 3rd gear grinding
- 1997 HONDA CIVIC LX (Won't Start!)
- Any nifty little tricks to get the valve seals out of PR3 head?
- CEL blinking at low RPMs
- Difference between jdm and usdm
- A/c acting weird
- wiring vtec
- LS swap in my 99 civic
- accel coil
- Plugging Coolant Line Going into Intake Manifold/Head?
- What is this part?
- 98 dx hatch 28 MPG whats wrong
- b20 help
- D15B8 Block with D15B7 Head Question
- Civic EG with B18c7 stutters and hesistates when cold or slightly cold
- Build From beginning to present!!
- ek front signal problem .
- d16y8 limp mode
- Noisy When Heater is On?
- Si vs type r?
- Need info or wiring diagram
- I need quick advice about a rhd civic!!
- popping problem/shaking issue
- In Need Of A Rearview Mirror!
- car dies when i step on gas and let go
- b16a3 full drop for 1200 is it a good buy??
- DelSol F20b1
- 1993 v-tec del sol was runing then shut off and turns over but start please help!!
- I have a 1993 del sol with a v-tec motor
