View Full Version : Honda Civic / Del Sol (1992 - 2000)
- My em1 dies when clutch is pushed in?
- EBP EM1 WHEEL SUGGESTIONS ?!??! EVERYONE WELCOME
- Mystery part? *pic*
- Refinishing OEM Alloy Wheels (Paint or PC)
- Fuel pump not priming
- 93 si gsr cluster and dieing issue
- Ek4 Sedan won't start (EU Model)
- Clutch Issue - 00' Civic EX
- 94 civic ex aftermarket throttle body
- Fuel gauge
- 1993 Del Sol Manual?
- Slow to crank when warm , advice needed
- Adding power to a D15B7
- 93 civic wont pass smog
- rad fan issue
- Motor Mount question
- R12 vs 134a opinion
- Electrical issue?
- Cel flashing and car losing power at higher rpms
- B18 in eg,BOGS
- Idle drops, rough shifting, MPG hit
- Eg not starting
- ecu question
- D15B Timing belt.
- Idle problem
- About to Travel Cross-Country - Tips for Reducing Changes of Car Getting Stolen?
- 98 civic pulls to right
- Clutch steel braided line?
- HELP PLEASE!
- Smoke from vent/ Will NOT start
- How does this compression test look?
- Somebody help!!!!!
- 2000 civic dx..issues
- it's all about the money
- 99 DX will not crank.
- d16y7 engine problem helpp
- Rattle/clunking from front end replaced and checked stuff still no luck
- Coolant leak B16A2 :/ Where is it coming from?
- Keyless entry issues
- very low idle sometimes turns off
- Battery or Bad harness? Temp gauge aswell?
- lsvtec code15 recurring after clearing
- D16y8 Clutch slave cylinder bolts?!
- Eg hatch rides worst than my truck.
- Car wont start....Series of clicks under dash
- Middle of tire getting shredded
- So you've just bought a...
- 2000 Civic DX manifold replacement
- S300 setup
- Cylinder Misfire and Engine Leak
- 8200 RPM
- B18c engine swap no start
- Del Sol Low Pedal Help
- 98 obd2 gsr into eg coupe?
- New Calipers, rotors, pads, and hoses and brakes are still dragging.
- Verdict is in - Y7block/Y8 Head - Adjustable cam gear manditory
- Help 94 civic d16y8 swap wont start
- Need to pass safety - Canada - srs light
- Antenna block off doesn't fit
- Pic request; Ek skirts/flaps on eg
- complete civic b16a motor rebuild
- Write up for del Sol to S2000 antenna conversion?
- Why in the world is my 99 LX still getting hot????
- 99 Civic Si bad gas millage/weird power problems
- 98 civic hatch y7 with 2000 y7 engine harness
- 93 civic cranks but wont start, has fuel and spark
- What OBD is my B16A SiR-II?
- which injector do i use?
- 99 d16y7 civic no start
- vibration from passenger side when accelerating fast
- Ej8 Sedan flickering oil light then shuts off on the fwy...smoke from breather filter
- Cheap Civic/Del Sol cat? Won't pass emissions
- Correct mount for hood to close eg/gsr
- 93 eg 4 door,Transmission noise
- D15B7 Harness
- Maximum allowable spark advance d16y8.
- Carb Sticker Help!
- Best brake calipers to buy for '97 del sol?
- Ammonia smell at high rpms
- EJ6 Build (97 Civic DX)
- 99-00 Civic OEM Foglight switch install: Have PDF but still confused. Any help?
- Honda Civic Ex hard to start
- EK Cluster
- Rear t bracket b series swap
- D15B VTEC swap
- p28 vs p08 ecu for d15b vtec obd1 graphs
- No charge from alternator to battery
- High NOx Emissions
- DC2 Mugen on a 99 Coupe?
- 96 ek hatch engine cradle write up?
- Cheaper Quarter panel replacement
- Fog light switch for a 97 del sol without fogs
- Who's got D15B2/B7 Vitara rods? This guy!
- How to make gauges illuminate when I turn on my lights? 97 del Sol...
- ls a/c on 99 b16
- how to fit prelude seats into my ek sedan?
- NRG hub/quick release wiring issues due to age
- Jdm vtec oil pressure switch bypass help
- 93 d16z6- No dash lights or running lights
- D16Z6 vs. ZC DOHC
- main relay
- B16a2 hesitation
- 98 gsr obs2 dizzy convertion ???
- convert b16a from auto to manual tranny
- need help with resverse lights not working
- 1998 Honda Civic Dx Bogging Issue.
- D series vtec dizzy on a b16a motor
- D15B vs D15B VTEC (HELP!)
- Logic Motorsports OMNI POWER TACH PRODUCT REVIEW WITH DIY INSTALL!!
- Where to wire Vtec to harness- 92 civic vx
- HB 95' EG Civic: what windows/regulators/doors interchange(hb/coupé/sedan)?
- 1999 Civic Died On Side of Road
- AC Replacement - NEED HELP!!
- 97 Civic LX Engine Light Codes
- D16y7 with y8 manifold
- civic only starts in limp mode
- tuning/break in
- is a d15b7 an interference motor?
- 97 Civic AC Problem
- Need bolt in muffler replacement
- skunk 2 stage 2 tuner cams knock alot
- Bad wire/short??????
- Stupid to buy 1996 Civiv EX with 240K? $3K
- Huge problems with this website
- When your honda Oil Dummy light comes on its way too late.
- Port and Polished Mini Me W/P2P running lean. . .any suggestions.
- Oil Pressure Light, possible issues?
- Any way to make my d15b7 vtec ?
- 4 Point Harness???
- Exhaust questions.
- 96 00 civic door panels fall apart?
- Aftermarket steering wheel, fog lights not working
- EJ6 Build thread...Give me ideas!
- B Series just dies after revving past 2-3k / sluggish feeling
- 20amp ac fuse pop
- D16Y7 3k RPM noise
- JDM gauge cluster
- d16y7 catalytic converter question.
- speedometer not working
- b16a2 eg swap
- Crotch Rocket Exhaust on Civic?
- Need help with CTR head build. (cam caps related)
- My relationship...(eg)
- Car wont start, wont jump, weird popping sound passenger side
- Del Sol wide mirror?
- Misfire in cylinder 2
- my partner wont start ;(
- i may have jumped timing idk
- Do replica Mugen del Sol front bumpers and wings exist?
- Transmission Help..
- a shakey feeling
- Drivers side sun visor is hard to move
- Driver window wont wrk but passenger does wtf?
- ls vtec problem HELP
- '92 Hatch--Scraping noise when accelerating
- 93 civic ex power lock problem.
- Snapped Motor Mount Bolts Question
- Half Shaft bearing replacement
- 1993 Civic SI project
- bad coil tested ok with ohmmeter
- Rare USDM parts?
- 91 Civic Si wheel question
- Conflicting info: does Skunk2 manifold require aftermarket throttle body?
- Transmission swap B4RA with a A4RA
- Steering Wheel Help
- 96 civic hatch y8 engine swap.
- JDM D15B Code 43 Fuel System
- 96 Civic b16a swap idle issues
- Retaining horn function with SRS delete?
- need help ek coupe swap obd1
- 4-2-1 downpipe gasket salvage
- 94 civic hard start HelP!
- running open head
- 92 h22 hatch: fixer upper
- No start 94 Del Sol
- BEST PLACE TO BUY OEM PARTS/GASKETS?
- Car died while driving
- Making my horn work with out the SRS harness is making me feel retarded...???
- rhd ej sedan
- MAIN BRAKE LINE -UNDER THE BODY- HELP
- B16A2 camshaft holders
- 1999 Civic Won't Start!
- Loud clacking noise when letting off the clutch
- 93 civic dx brake problems
- B18b1 issues.
- Osaka JDM Motors legit?
- 2000 Civic SI power steering rack & pinion question.
- 2000 civic ek auto shuts off after like a minute
- Wiring second o2 sensor
- help with my wheels please
- Second o2 sensor plug
- My 1999 Civic si rebuild story
- Rear lower control arm outer bushing NEEDED!
- 96 EX, AC not working + Weird noise (Video)
- 93 Eg with 96 itr Disk Brakes
- 94 civic lx doesn't start when it sits in the sun during the summer.
- Cruise Control + Idle Tech Question
- Help! experiencing weird electrical or alternator problems! (95 Civic)
- Help...Need EK9 VIN
- Cel P0117
- taillight cover?
- Wheel Bearing ?
- Buying a 93 Del Sol tomorrow.
- ECT (Engine Coolant Temp) Sensor HELP!
- First time swapping my engine (ej2 gsr swap)
- Where to find a del Sol antenna block off plate?
- i think i blew out part of my harness..
- what is this hose called guys? 93 del sol si
- low dust brake pads
- 93 Honda Civic 1.5L not turning over w/o starter fluid
- Re ring motor
- 93 Eg with 96 itr disk brake conversion
- 99 civic ls/vtec no crank no start
- quick vacuum question.
- 98 running a z6 help
- no start problem 97 honda civic non vtec
- 95 Del Sol, Mystery Problem?
- 95 honda civic
- Tried Every Trick...Axle will not release
- 1999 Ek Couple Engine Rebuild Problems :/
- ek4 b16a2 takes ages to warm up
- Paint stock rims thought experiences?
- a/c Idle problem
- civic will not prime fuel pump... fuel pump/wires work
- 92 eg driver side front squeaking
- del sol issues
- Just spun a bearing. Smartest way to fix this?
- B16A2 Cam marks when installing?
- Idle Problem D16z6, IACV and FITV good
- 92 Civic Fuse problems?
- 98 civic b16a swap, no spark
- Questions regarding tuning a 98 civic
- Question about swapping current mini me z6 head to y8 head
- Cutting out at highway speeds? Need advice
- New Plug Time
- Need Help! P/S LS swap in an EK hatch
- Timing issue
- PCV Valve Broken Wire Question
- Frame rail come in one piece? *pic*
- B16 no spark
- problem during vtec
- Traction bar.... need your opinions
- Compression/Injector Help
- single turbo set up have a few questions
- Rat in HVAC
- best swap for application
- Question on b16a2 torque specs
- del Sol Main Relay Ground Kill Switch Question
- R12 to R134a A/C Swap Questions
