View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Should i get an Eg or an Ek?
- Civic si 2000 won't start after removing plug wire
- eg suspension
- How to beat MK6
- cel code 22 and 43
- white smoke under full throttle.
- 1998 Civic Misfiring and Hesitating
- 4dr exhaust system on coupe?
- bought a 94 hatch
- D16y8 ODD and serious problem....pictures!!
- 99-00 Civic Climate Conversion...
- 95 Civic won't start! HELP!
- 98 Civic/97 ITR swap -- crank no start
- Transmission Compatibility Help Please!
- 92 Civic 4DR DX - B18 OBD2 CYP CEL (solved)
- QUICK QUESTION DX AND SI HOODS
- D16Z6 mini me swap help
- Car stalls when clutch is pushed in.
- Rear Wheel bearings Civic Si fitment on 95 Integra
- Head gasket Q?
- 99-00 harness/ecu/dist into 98 civic (Future problems?)
- Budget ej1 build
- Worn Crankshaft question
- tubular style civic lock cylinder?
- no fuel pump and spark HELP!!
- 98 civic: Ignition, over heating, and cooling fan problems. Help!
- Ignition switch and cooling fan problems
- Gsr vtec comes and goes no CEL..help
- 2000 Civic ex temp controlled vaccum switch
- stuck rear disc brake (pad/rotor), not sure what to do next
- 00 civic Front Bumper
- 92 EG Idle problem
- d16z6 - Idle surge and high pressure in radiator
- Will 4dr doors fit 2dr civic?
- A/C belt slipping only when A/C is on, belt not too tight or too loose
- Shifter problem
- bent valves. pistons ok?
- 2000 civic si 1800$
- 1996 EK Dildo Shifter Problem
- Need help with soft clutch pedal
- 96 hatch - engine problem and check engine light is on all the time
- EK gsr swap Idle goes up and down
- 93 civic lx - Cluster lights don't work.
- Knocking noise.
- 98 civic EX - power loss, bogging and stalling
- help identifying motor
- 1997 Civic HX Steering Wheel Play
- A/C in LS swapped CX Hatch
- Cigarette Lighter Repair
- 95 EG6 Hatch/B18C Type R 96 Spec - bogging and CEL
- 96 Civic Sedan quarter glass
- ek coupe LSV - running rich, oil leak, high idle, and bad VTEC wiring
- how can i get temporary power out of a b16!
- 00 LX - No start fixed and now fluctuating idle problem (1500-2000 rpm)
- over heating honda civic 1997 auto
- My 1995 Civic Coupe Build
- Overheat question
- License Lights/ Tail Lights fuse keeps blowing .... HELP
- What to look for in a used EK civic
- d16y8 into 00si wire help
- replacing ac compressor
- 93 Del Sol - intermittant crank no start
- D15 block and D16 head - what head gasket?
- Forged Turbo B16A2 help
- What JDM Ek cluster is this
- Is my ECU on its way out?
- Running Lights/ License plate lights not working with my headlights??
- Engine thumping noise - How to make Lemons out of Lemonade
- wsp inspection/srs issue
- 93 dx coupe won't start
- EK factory options?
- HELP! 94 Civic - stalls and complete electrical power loss
- Code 15, car randomly died?
- transmission/cv shaft help
- no more vtec crossover?! HELP!
- oil in cylinders
- 00 civic ex coupe runs slower when ac is on
- no power to condensor/compresor. need help troubleshooting
- help with timing marks?
- Ball Joint Mileage
- D16Z1 Roller Rocker VTEC
- Advice on Rebuilding the B16a2
- integra shifter in civic hitting exhaust.
- cruise control slow disengage
- JDM D15B Tune Up -- Research Report Review
- car will not fire
- Knocking sound..!!
- A/C compressor clutch starts spazzing out and almost making car stall
- Wiring E cutout, gauges, 94 civic
- Outputshaft replacement - same thing as axle shaft seal?
- Z6 water pump / tensioner on a Y8
- Ek hatch/b20b swap - CEL codes, idle problem, and misfires
- 1996 Civic ex/stock d16y8 starting problems
- Honda dealership used car inspection laundry list
- 94 civic 2 door hatch won't start
- Corner weighed my H22 eg
- What is this unused wire connector for?
- gotta do my headgasket saturday
- 95 Civic - no Vtec engagement (searched)
- need insight on 93 ex coupe build
- 95 Civic D15B7 Headgasket / D16y8 pt #
- Clutch grinds while engaging. Also Two clutch points...help!
- 95 civic misfire/rough idle keeps coming back. HELP!!
- OBD1 B16 - What IACVs are compatible?
- D16 mini me questions
- hypa's 96' (new to me) project civic. Opinions, tech questions, and the odd pic.
- Strange CEL occurances, code 67.
- HELP needed! Fan wont turn on, but car's not overheating!
- Will a JDM ek ignition switch work in a 93 Civic vx?
- do catalytic converter cleaners work? (stock b16a3 with stock cat)
- 96 honda civic cx knocking noise
- Stuttering problems D15B7/Manual when driving throughout the revs
- 95 eg coupe hesitation/now weird idle surge
- Connecting Rod & Main Bearing Torque Specs?
- Harness question
- honda del sol smog help
- 1996 Del Sol small idle help?! (Project)
- where to get thin radiator fan...
- CEL & D3 Shift Indicator Light Stays On
- Cel question
- need driver door for 92 civic dx. other years/models compatible?
- 1994 Del Sol Si Driver Window Problem
- 94 Civic EG having starting and stalling problems *HELP*
- what header for ls in a 93 hatch?
- Bent ignition coil/spring.
- 98 ITR lip on civic?
- Ek parts on a Eg
- 94 civic fuel pump sometimes won't prime
- 2000 civic si w/ b16a2 hesitation/bog at low rpm
- d15b swap - When buying auto parts, what car should I say that I have?
- Del sol b swap intermediate shaft question
- 98 civic ex with new b18c type-r swap - no spark
- EG hatch rear qtr plastic question
- ECU Problems
- 98 civic LX power windows/locks issue
- 94 Ej CV Axle Swap??
- Eg hatch glass shocks
- Air Intake Noise When Accelerating in First
- 92 Civic 4 Door - What's Missing Here?
- 93' Si hatchback, CX motor?
- Tranny swap
- 1992 honda civic antenna help
- Swap or turbo?
- 93 Civic coupe - Is D15b2 block and pm9-5 head stock?
- Climate Control bulb removal help
- whats the head bolt pattern for a d16 y8
- Power windows not working???
- 92 civic idle problem
- bad vss b16 tranny
- EK Honda Civic 97 - Window Weather Strip Clips Help - (PICS)
- JDM ZC engine: Help! Water Pump and Timing Belt??
- Running out of coolant when AC is on & AC issues! Help heat is killing me d16y7
- 95 Civic/D16Z6 swap - tach does not read RPM
- Cracked bumper.Still able to install front lip over it?
- D16Y7 bracket torque spec
- timing belt questions
- Odd shake
- spare engine - rebuild questions
- Time-sert D16Z6 Headbolt Repair
- Power Windows are jacked please tell me what's wrong
- Lug studs snapped off
- question trans auto ?
- How to add HID on to foglights?Honda Civic LX 1998
- 99-00 civic airbag reinstall: anything else?
- Speedometer and Odometer Problem
- 92 civic best 12v location??????
- shake at 80+ mph
- White smoke when cold start and oil in spark plugs
- green wire on eg ECU jumper clip
- Wiring Pinouts Engine bay connectors 98 civic
- d16y7 timing belt all done, mechanically timed but low compression??? ran fine before
- car won't start. CEL went on, then car died
- mph gauge tweaking out?
- Battery not fully charging
- FRONT ROTOR SIZE QUESTION!
- d15b7 with a check engine light
- Basic questions about intake on stock d16y8
- 98 civic ex 2d brake conversion help.
- na b7y8 mini me build
- Put new distributor in my VX, car nearly stalls after applying gas
- Squeaking noise when pressing the clutch pedal
- my EJ6 build
- need help y8 with 3 stage vtec head in 99 ex
- 1993 Del Sol restore project
- '96 Civic Ex Code 15 Ignition Output Signal
- Del Sol door help!!!!
- Function>Form build. My first complete resto
- Mechanic says switch to 10-40 semi synthetic - Should i trust him?
- Stereo Issues.
- 97 del sol. strut blown?
- Car won't start, but can push start.
- switching to headers?
- 98 hatch, high idle/accelerates on its own
- spoon rigid collar kit english instruction
- need help with tail light wire harrnes
- Effects of straight pipe exhaust on performance ?
- Just came to the dark side (airbags)
- Stumped with No start problem
- P1457 code, can it damage my car?
- 93 minime no spark!
- 99 civic coupe - Where do I buy replacement wire harnesses?
- EG AWD Conversion - Does anyone know of a good AWD Drivetrain that fits on an EG?
- Does anyone have the procedure to timing? belt
- Check Engine Light Bulb Replacement
- Del Sol subframe in EG?
- 93 Del Sol Clutch pipe?
- DIY door glass molding removal and painting for 96-00 Civics
- Anyone running DB8 rear seats in their 96-00 EK Coupe?
- 96 CX to HX swap Probs
- no speedo after driving with vss unclipped?
- 00 Civic - How do I remove the door molding clips without breaking them?
- Shift rod seal for 93 Civic Ex coupe
- How much to get headliner redone?
- Aftermarket headers, only have 1 o2 sensor bung? help please.
- Ignition problem
- Electrical/Radio Problems 94 si coupe
- Wiring Harness compatibility
- Stumped on 99 Civic Coupe Passenger Power Window Failure
- 97 civic shaking/cupping
- B20b engine problems..... Help!!
- Starting issue "one click" at starter AND idle drops using accessories. Same issue?
- HELP ME PLEASE I HAVE CODES P0302 P0304 P1300 P1399
- 96 ls motor fuel problems
- what is the point in cutting your civic's engine bay?
- 98 civic want to convert rear disc brake
- Replacement screws for D15Z1 Civic VX coil wire screw
- 93 civic Vx b20 - wobbling noise and vibration when turning left
- Civic making never before heard sounds (video)
- 2000 Automatic Transmission Acting like it has 5th gear
- DIY proportioning valve disassembly
- max bore
- b16 exhust heat sheild painting
- 1996 Civic Transmission Questions
- Converting a HX O2 sensor plug to 4 pin?
- stock 99-00 si fuel pumps
- 93 Del Sol Si D16Z6 Completely Stock Smog Question
- Timing mark question
- Weird Turn Signal Problems, Out of Ideas
- Auto Trans stuck in 4th?
- 98 civic ex problem engine shut off
- my sunroof and power locks and mirrors dont work anymore?
- CRV Cluster in Civic - A Few Questions
- Issue with b series t bracket
- HELP: 97 civic hb ls/vtec ecu ????
- What is the difference between japanese civic 1.6 ils and UK version (d16y3)?
- aftermarket wiper arms
- 93 Civic: American D16 to Japanese B16 engine swap - need advice
- A/C problem
- Tranny bracket doesnt line up??? FRUSTRATION!!!!!
- valve cover paint question
