View Full Version : Honda Civic / Del Sol (1992 - 2000)
- uh oh...CEL
- 92 eg gsr with type r cams
- hondata tuner in MD-VA DC Area?
- wat should i do about damping the noise inside my civic?
- Best head for mini-me?
- Holy wierd overheating problem
- WTF, conflicting part numbers and prices!
- dx rpm question
- Hard-wiring secondary O2 sensor
- IACV problem, please read
- y7 to y8 IM
- clips
- strut bars
- digital climate controll
- Tired of Being slow
- harness swap?
- open header question
- Mini me question,(i searched)
- which repair manual?
- SS Brake Line Question, who has Technafit lines???
- *HELP* Injector Trouble
- Fuse box help (pic)
- adding a/c in a eg cx?
- switching from vtec to non vtec
- RHD to convert or not???
- what kind of exhaust will make ym vtec sound the best
- TDC Positioning
- attention so cal honda drivers
- Can someone look at their car for me? $Money$ is in it 4 you!
- Need help ASAP! Stripped Block, Timeserts (So. Cal)
- what spoiler did my hatch come with?
- Question about OBD-1 and Emissions test
- tuning help
- some question about motors
- what are these sensors? (d16y8)
- tighter steering. what are my options?
- Lowering my 97Civic
- loud walbro pump
- New setup on my d16z6...now it won't start...HELP!
- Just put A/C in 94 civic hatch........ Weird CEL problem
- CEL 78??? WTF is this?
- NEED HELP BADLY!!!!
- chirping sound from inside dizzy, d16z6 wth???
- [REQ-DIY] How to install a NRG quick release/Bride Steering wheel/Hub
- Coolant on the run!
- idling problem
- Carsound Car Problem, Is this familiar?
- header to exhaust gap after swap...
- EG civic VX model with hesitation problems
- how do i know if my air conditioner compressor is working.
- Car died and now it won't start...
- OT: after reading alot of stolen threads, i realized that...
- Delsol radiator
- Q: cusco roll cage in 92-95 hatch si????
- 99-00 civic ex catylitic converter???
- install on a carbon hatch !! EK4
- door prob.'s
- moto1320
- wanting to install eg si gauge cluster into cx model
- D series tranny swap.
- matching exaust problem
- Intake and Headers for a SOHC 1.6 fit on an B16?
- Hondata Gasket - B16B
- PLEASE HELP
- Need Picture of 96-00 EX evap sticker under hood
- CEL 15 - Ignition Output Signal
- B16 with built head
- i have a 96 ek with 00 Si under dash harnes triying to put ls motor
- Going to check out a used '96 hatch (DX) tomorrow, anything to look for?
- HELP PLEASE
- throttle body d16y7
- port and polish.. good or bad idea?
- do you need to unhook the IACV when setting tps? (b18c)
- 00 si brakes clear my 97 ek hatch stock 14" wheels?
- Locking the hood down.
- Will a 92 civic 4 door passenger window regulator (manual) fit in my 94 hatch ??
- DA dash in EG?
- Need help w/ swap. Pin/Shift linkage
- AFTERMARKET STEERING
- slim fan install help
- Will 96-98 Sedan Wing work w/ 96-98 Coupe?
- where can i buy aftermarket oem fenders and bumpers in san diego?
- Where to buy JDM eg sidemarker and harness w bulb?
- CTR front grill Replica Question .
- Project micro brake pads, info.
- GSR or ITR in del Sol
- Good bolt on cat for Z6 powered EG?
- In The Market For a New Motor
- D16Z6 > B16A1 Swap (is it worth it?)
- psst sound.
- just blew my motor. b18b1 into 99 civic si questions
- Carpet Dye
- can't find a old topic (search owns me) EK radio relocation
- get rid of vtec
- cleaning tip anyone?
- A/c Problems
- Coolant Leak on Hondata Gasket
- What is the different between b16a 1st generation, 2nd, 3rd, and the Si 2000.?
- My thoughts
- h22 tranny problems explaination plz
- Exedy Clutch Problems - Lots & Lots Of Heat !!
- body kits
- civic engine question
- wirning harness
- Del Sol Engine tapping
- Evap solonoid wiring help
- fuel injectors not opening
- grounded knock sensor pin, but still throws cel 23? help
- K2 motor foglight install(wire diagram)
- factory cd player and cd changer
- Question about ES shifter bushings
- URGENT Radiator and Intake tube busted
- Headunit question *posted in audio, but that section is dead*
- How much for CTR rims
- GSR OR TYPE R
- temperature guage
- Do You Think Bras Are Really Needed On EGs or Del Sol?
- what low-cost tires and rims for '96 Civic DX
- timing and waterpump
- Anybody have any experience with 22mm Progress sway bars?
- pics anyone?
- ls/vtec help
- GSR brake swap- into eg hatch
- need help... please read if purchased auto to manual mount
- 96 civic seat rails on 98 gsr seats?
- wow!, clutchless transmission! old news to many but pretty new to me...
- a little floor board problem...
- NEED HELP with engine wiring 94 integra ls into 98 civic with HX engine wiring need diagram
- New Clutch install,anything else?
- Distributor help-Z6 into 96 dx hatch
- 92 civic hatchback help!
- eg/eh/ek/ej
- car slowly dies?
- Anyone have Pics of OEM EK AND EG Foglights ??
- EG Foglights: wiring issue...
- alternater belt problem?need to know by 10.00am
- Please Help. Power Steering Question?
- Girlfriend just bought a 96 Lx
- clutch install on 93 ex, no pedal goes to floor
- antenna block off
- clutch master cylinder......
- mini me: b7 with y8 head. do i use z6 or y8 timing belt?
- need help NOW!
- Anyone running on BFGoodrich Traction T/A H?
- HELP: removing door handles from 98 4dr civic
- I need help putting my motor back together
- Please help with tranny.
- new here...
- throttle body question?////????///???//???
- 600 for ctr cluster and more!!!
- HONDA TATTOO
- Ugh, CEL's after rebuild
- registering a non-operable vehicle?
- Some question about my civic
- civic type r pistons in d16 motor?
- need help............stupid check engine light
- which headgasket for mini-me? y8 head on b7 block
- itr center caps on si wheels
- B Series Tranny output
- MSD 2STEP BLEW MY MUFFLER OFF
- Best auto cross set up?
- D2 coilovers vs. omni coilovers...
- Rotors/Pads Are on the way out
- paint code for itr gm wheels
- testing waters: Volk Racing GTP 17" Rims.
- Turbonator?
- NO POWER
- ENGINE WONT CRANK SOMETIMES
- Grinding/buzzing noise in Tranny (d15)
- Civic Problems
- B16a Help
- Blown CV boot
- Need help on suspension Setup
- Question about rear lower strut bar?
- disappearing vtec? some gears i have it some gears i dont...
- will a d15b7 dizzy fit on a d16y8 head with modification??
- what swap should i do on a 95 dx coupe?
- Anyone had fitment problem on PWR radiator on 99-00 Si & Delsol with b16??
- Results on 93 Civic DX overheating on idle problem
- I HATE THE TPS!!
- What wire harness can I use for a b20b
- need help on a 99 civic si
- d16y8
- Opinion on ECU services?
- Differences between Engine Harnesses - D15 and B16A2
- Manual to Power Steering
- C-Pillar in a 96-00 Coupe
- 1993 ex sohc turbo??????
- my white hatch was stolen this morning...
- Sputter under boost
- Headgasket
- D series oil amount in tranny
- maintenance required went from green to red. what happened?
- ***Tokico Warranty????****
- Eg w/ b18c header question...
- d16ya
- 90-93 da integra seats compatibility
- transmission oil leak, have searched and can't figure out where it is coming from! possibly half sha
- did tune up....old plugs gap was .56-.58 in
- door handle probs!
- B16 Help Please!!!
- B series parts
- which headgasket for d15b7/Y8 mini-me?
- if my engine has 217k miles on it, will my car be sucked out and powerless
- eg horn doesnt work
- proportioning valve question
- ?????posiible theft attempt?????
- finding license plate number
- oem headgasket thinkness ?
- which plugs wont be used when wiring a 00 ex harness onto 96 b18c1 swap
- Door problem on 99 Civic
- distributer question
- Who in HT has a.....?
- del sol vs. civic
- caliper question EX vs GSR
- WTB civic hatch for cheap.
- Autozone Turbo II Muffler
- Difference between Coupe/Sedan handling?
- which oil viscosity to run????
- Will the coil from a D16Y8 distributor work in a D16Z6 distributor?
- what size radiator hose?
- RSX seats in Del Sol?
- eg/ek camber kit
- ls motor.....all motor or boost?????
- Extended question for ek9 climate into a ej6 hatch
- Got a conversion harness, now A/C won't work.
- *93 CIVIC B18C CHIPET P28 ECU* Should i keep my stock gsr intake maniflod or change it?
- Motor Swap details...
- Radio won't turn off, car is in limp mode, blown fuse. All after cleaning car and WB install.
- converting auto to stick 96 hb
- HELP!!!!!!!! CAR WON'T START!!!!
- Mufflers
- megan racing c-pillar bar?!
- A/C swap in a 92 civic hatchback
- Engine rebuild questions
- strut bars interchange?
- A\C wiring OBD specific?
- best d series motor?
- WTB 92+ civic (hatch or coupe)
- Fit question on Tsudo catback for EJ
- NEED SOME SERIOUS SEAT TIME!!!!!!!!!!
- Spoon ECU for B16 OBD1, any opinions???
- intake temp code
- Mechanic in Northeast PA, NJ, or NYC
- Gas or oil? (quicky)
- D16Y8 WANTS BOOST
- i have a 96 ek with Si under dash harnes triying to put ls motor
- Alternators...quick question
- i have a 1st gen safc and no wiring harness do you know were i can get a diagram
- JDM DC2 Integra Type-R Engine
