View Full Version : Honda Civic / Del Sol (1992 - 2000)
- need help my car idel
- how do i clean my stainless steal header?
- 2001-2006 civic oxygen sensor compatibility
- cold air intake after mini swap
- wet kit on b16a2
- ClAMP OR WELD TEST PIPE?
- TOO hot TOO quick + additional problems
- Transmission Question.
- joined the stolen civic club
- Will a EK header cause on a EG cause o2 CEL?
- D16Z6 & D16Y8 VTEC Soelnoid
- Exhaust rattling
- *smog question....
- RPM Connecting Rods...
- B20 help in a 92 hatch si.
- Oil pressure sensor d16y8
- where can I get a conversion harness?
- Blown shocks? (searched...)
- Questions about the Coolent lines going to the TB
- Need help with Integra dash?
- D16A6 Troubles - Fresh Rebuild - Wont Turn Over... Crank... Crank... Crank *VIDEO*
- z6-b7 mini me question
- 99 Gsr Walbro 255LPH Fuel Pump
- what to turbo 1996 civic hx d16y5
- CIVIC si 99 (swap a GSR or get a B20 BLOCK)
- Check engine problem.....
- lsvtec question
- WTF!?: Please help me fix my door... It doesn't close
- calling all suspension/brake guru's...
- Eg-4door Trunk Release
- hood doesnt shut.
- Cam Gear question
- I have a 92 hatch. need a d16z6 or b16a or b18 chicago NW indiana.
- auto ls in gsr shell
- 1994 Hond eg hatch proble (bad idle)
- quick DELSOL question PLZ HELP!!!
- Have a 95 civic eg, looking for a b16a or b18 for sale
- zex 59300 cam ? about valve lash adjustment
- water temp sender on B16
- quick cel question
- 93 civic transmission... noises?
- o2 sensor problems need help
- d16 tranny question
- Clicking & Hesitation?
- My car is SPUTTERING...after i put on intake its more noticable...WHY
- Keyless Entry Antenna Location
- illinois: blue si with pink DOHC sticker
- Power window conversion questions for an EK
- D15B7 Vtec Conversion
- Dyno day May13th@1320 performance
- Master Cylinder Question
- Need Help with Exhaust System
- 50" or 55" harness better fit for eg?
- Replacement rear quarter panels for a 1993 Honda del sol?
- Important! - How much amperage (amps) does b16a2 alternator produce
- question on 98 ex pinouts
- vtec ?
- Leaking oil
- A/C install to an EG
- Engine mount question...
- B18c into Civic CX O2 wiring code 41
- b16 swap major oil leak!!!!
- no start... help...
- Too much to pay? *NEED* opinions on purchase! Please help!
- People with RHD experience
- I NEEED A GOOD INTAKE
- would a b20b with vtec be reliable?
- People with CF hoods...if you don't have holes for your squirters...
- Civic Bumper Material - 94 Hatch?
- OBDII to OBD1 Conversion Help EK
- Skunk2 2 throttle body, or any other after market.. please look!!
- HELP-Code 91 - Fuel Tank Pressure Sensor low input
- Is 92 Civic Si airbox the same as any 92-95 Civic cx,dx,vx,si. Wanted in the ottawa area.
- Golden Eagle Sandwich Adapter Oil Filter types
- J'S Racing Intake installation
- gearstick shakes at high revs, only in 3rd gear.
- Misfire?
- headlight housing
- bumper modification
- new exhaust help
- 2000 civic si - need help
- s2k seat install - need help with hog rings please
- Honda Civic DXI, compatible with what american civic?
- Need help with 00 EX
- What to do with my civic??
- EK JDM 18C5 idle problems
- FUSE PANEL ON EG
- b18c1 problem
- EK with type r suspension?
- Skunk2 Intake Manifold 99 CIVIC SI
- ctr swap? just to double check
- Please help I have searched...99 si Resistor box wiring and DSM 450's!!!!
- denji headlight installation
- Bolt size for rear lower control arms...
- piston rods/motor
- Dumb Question...well kinda
- need help w/ mini me
- del sol front conversion
- Temperature Problems
- P0142 - O2 Sensor Low Voltage
- good cheap clutch set
- auto ecu vtec
- replaced radiator, now fan wont work...
- Sylvania Silverstars 9003 ST
- upgrade on a ls
- Ek Hatch Vent Visor help
- NO REVERSE
- D-SERIES DIY ITBS
- how to make a civic housing brighter
- *ALRDY SEARCHED* Passing State Ref: Civic DX 1992 w/B16A JDM
- difference on a cx? or dx?
- chipped ecu?
- Eibach sportline fitment
- GSR Cluster In Hatch
- is there a list for bulb numbers for 92-95 civics on the net?
- engine code p0171-fuel metering too lean
- What car is this... Picture of a right hand car... of WHAT?
- B16A.. parts needed to keep A/C
- Code 17 (VSS) and Code 41 (O2 Sensor Heater) Issues
- quick question about ls engine
- RSX steering wheel in 00 Ek ???
- No Power ANYWHERE!!!
- 95 ex coupe did gsr motor need a cat-back exhaust
- Is there a DIY for cleaning a head??? Searched
- Still need help with keyless entry, have checked for loose wires...
- what goes here?
- sunroof prob -- never seen before ~Searched~
- need to know whats the best route for my 97 del sol si
- what color wheels
- D15 v-tec engine question and ecu part # question
- HELP PLS, MY TYPE R WONT RUN
- DC or Tsudo
- Feed Back H22A1 --In to a 92" Civic->
- coversion si seats 2 93
- Need help on some DIY's
- TEST DRIVE: 2000 CIVIC SI BOGGING?, EXPLAINATION IF YOU KNOW
- Need URGENT help with exedy lightweight flywheel and clutch kit from gripforce!
- Rear Disc swap on del Sol from 1990 integra questions
- jdm EG coupe 1/4 panel molding?
- Quick response please DIY air fuel gauge help
- just a quick EG fogs question
- underhood number 44 fuse keeps popping
- OBD1 b16 swap question
- Front Lower Tranny mount bolts
- some easy hatch q's for you civic guys
- Anyone have info on honda's d13b???
- Finally it's alive again.
- Is a K20 a good engine or a piece of shit
- Civic Ball bearing turbo (Shaft Play)
- full forum access, having problems. Sorry for posting here but don't know who to ask
- Intake Manifold help
- keep or sell my 95 Civic
- radio ON w/ no keys
- Could i hard wire my VSS signal going to the ecu to a constant power source?
- O2 Simulators...
- codes on mini me swap need help to fix it
- trunk question for a 5th gen civic
- ek wing???
- 99-00 civic si door removal problem
- is there a difference between ek4 and ek9 climate control / navigation unit?
- ecu que
- D16Y7 exhaust manifold options?
- transmission knocking?
- JIC Spartan DE Type 1 SUS Exhaust on EG Hatch
- EK swap, axle question...
- 99-00 ex,si,lx ctr powerfolding mirrors
- anyway to unfreeze brake calipers?
- Timing Belt Wear normal?
- what kind of piping should i get for a d16 and not lose power??
- jdm gather help
- how to remove hood latch?
- SOMEONE STOLE MY CAR
- Do The CTR headlights Use The H4 Bulbs still?
- OIL Catch Can
- Check engine light problem!
- car shakes help please.
- z6 head with y8 header? what gasket do I use?
- Oil pan compatibiblity (sp?)
- Question about 96-00 Civic Ex Tranny....
- ECU chipping question already searched?
- Big problem
- popping from exhaust when i start car
- Coolant Reservior overflow causing overheating...
- hmmmm?
- !!!GOOD NEWS!!! EG COUPE CARPET FITS IN A 4DR EG
- I need some EK9 Help, Fog Lights
- What's next to be done? D16Z6 engine and current mods =>
- Ion Yellow Turn Signal Bulbs
- valve adjuster screw
- lsd for $300
- does a ek muffler fit a coupe ?
- High Idle
- Car Bogs/Hesitates after shifting gears. Not ecu related, what could it be?
- why is my cv axel poping out help please
- who wants to give me a 1/4 mile time
- B series swap to a Civic EK 96-00 shift linkage
- 1/4 mile info
- rev limiter P28 ~Searched~ ~Easy Q~
- need some wiring help
- EK STOLEN IN VEGAS!!!!
- Does anyone know anything about b16 blocks warping?
- New Si Tranny and 8lb flywheel, installed.
- Rev-limiting too soon and car extra weak!!! need help
- difference between d16z6 and d16y8 pistons
- OEM LSD?
- Fuel pump doesnt prime after switch install (see inside)
- header bolt torque?
- Can anybody tell me more abt my car? 1997 Civic GLi
- Mini-Me throwing Code 68
- Integra dash wiring one wire left (searched found nothing about my problem)
- 92 Si- Wont Start-need help
- TECH HELP!!! Possible Axle or Tranny Problem! Help!!!!!!!!!!!!!!
- 96 ek civic vs 00
- auto to manual??? help searched shift linkage bolts
- U guys know if a 99/00 Si 4-2-1 header will bolt up tp the z6 head and then the cat
- eg swap header fitment
- Dead travel on accelerator pedal
- cant find engine harness!!
- Quick question. Will 94-01 Integra Springs fit the 92-95 Civic? i think so...
- motor mounts
- i heard there was a guy who didauto to manual swap in oregon
- timing belt package question(searched)
- Question for those of you with Autopower cages
- 99-00 Si abs or no?
- i know 92's are wired for vtec but......anyone got the answer
- differences in exhaust between eg and ek hatch backs
- SRS Light Question
- Searched, researched... Door honge pins?
- Cranks.
- Power window (Searched)
- Daily driver suspension
- Engine Oil as Transmission Fluid!?
- Ctr thin side moldings
- Timing issue! Help!
- Wiring problem NEED HELP ASAP
- spark plugs
- crazy idle! drop as soon as car comes to a complete stop HELP!
- fast and furious 3?
- cluster clock problem
- Quick question need answer ASAP
- battery died
- Question abuot intake manifold??
- Need help hit curb!!
- Clutch Pedal Adjustment on '00 Si
- Retro-Fit TSX projector hids into 92 hatch with stock headlights?
- SPARKPLUG WIRES HELP
- I Need Help
- prelude and type R brake clearance...
- What Ignitor Will Work In My Civic?
