View Full Version : Honda Civic / Del Sol (1992 - 2000)
- tranny diff question? b series
- Damn Power Doorlocks
- Why do I have to pull on the inside door handle to lock the door. Is that how its supose to be
- d16 on a b16
- Rear Disc conversion
- rear bushing options
- just installed new injector plugs .. now i have a weird problem
- Running Rough. 99 Turbo Hatch
- Whats the best way to cut off LCA/Trailing Arm Bolt?
- clutch install ?'s
- need help 93 civic ex ignition switch
- Damn CEL!
- new to civics, vtec conversion
- What axle's do i buy?
- need the famous honda-tech input/support on my next build
- Can someone tell me how I wire a custom tachometer to my 1992 civic hatch?
- want to share pics of your eg
- fuel capacity for a 94 civic lx?
- ep3 seats in eg hb
- B16 engine
- CODE 16 Please help!!
- help: power window conversion on 2000 ek
- I NEED HELP ASAP
- what to do with manifold exhaust???
- B16a2 map sensor wiring?
- how to get better gas milage
- new motor
- pistons
- CEL help
- vtec
- redline problem
- B16 gas mileage???
- idle problem
- help please
- question about weather stripping
- Swapguide: 00-01 B18C1 into 99-00 Civic. LOTS OF PICS
- Bad spark plug tube seals..??
- CAR WONT START
- It never ends, Knock Sensor Code 23
- New guy
- HOW hard do i have to shake it-------tranny(get ur mind out the gutter)lol
- Carbon Fiber Trunk!!!!!!!!
- AC Removal
- My civic redlines at 5K need help!
- question about Apexi safc2.
- help
- CODE 19 Help please??
- please help car wont start
- 1996 Honda civic LX modified to year 2000 with SI engine for sale $4600 Clean Title
- knockin sound(vdeo)
- Compression test 92 civic 180 160 160 180?
- 97 civic/ h22 swap
- 95 ex speed sensor ground?
- no reverse?
- idle/leak problem help!!!
- a Power steering question
- Header Dented How much it cost to Repair?
- 93 hatch SI. changed rear calipers now brakes on don't stop. HELP!
- Help With Referee O2sensor Evap. system catalyst
- obd2 to obd1 jumper harness HELP!!!
- Difference between 98 and 99 EK
- hondata s300
- Clutch?Flywheel?Short shifter?
- ek hatch starting problem
- Help..Recaro seats
- ctr ek9 mirrors troubleshoot
- A/F CEL
- 97 vtec valve
- 4 Mount Applications?
- stock suspension
- keeps fouling cylinder 2 spark plug?????
- o2 sensor wire Q
- Can Someone Please Help??????
- VSS Trouble shooting
- mini me with p28 ecu run fine?
- Help w/ B16 swap into EJ
- What EK Spoiler/Wing Is This?
- 92 Civic with B18c1 Starting Issue
- OBD1 GSR motor into OBD2 98 EK
- Please help. Need to replace my lower oxygen sensor.
- I need a little help...
- Pulling Battery Cable while car is running.
- d15b2 compatible with my 1992 cx ????
- CAN I CHECK IGNITION COIL
- Map Sensor......Doubts????
- leaking oil after turbo installation
- 1994 Honda Del Sol: how to change brake light?
- whats the best way to make your bumper line up straight?
- Where to buy Fuel Gauge Sending Unit?
- Possible to have a bad map sensor and no CEL?
- correct me if i'm wrong...b20v build this weekend.
- Mysteriously disappearing radiator fluid
- 97 ex pilot bushing
- header questions, need help bad..?
- battery or alternator problems....
- B16 and gsr dizzy...are they interchangeable?
- Serious stutter (& Other questions)
- 95 civic CX vtec and 4 wire pin out??????
- y8 and z6 arp head studs the same?
- Can anyone please help with this..
- no power to my distributor and fuel pump
- S8g Transmission
- Broke off valve cover bolt.. AHHHH!!!!!
- I've searched...need some experts on a swap in a VX.
- 92 civic CX
- Blox Throttle Body Question??
- 92 honda civic LX clutch problems
- a/c issue on eg
- Camber arm hitting Shock tower and going through engine bay?
- E-Brake PROBLEM!
- adjust timing without service jumper jumped
- good auto stores in or lando
- Questions on Torquing! Plz Answer Gurus!
- rough idle when o2 sensor is plug in....
- Man im STUCK!!!!
- front end question?
- Clutch Repair Question
- how to open a tranny to see gears
- New to Honda-Tech, pics!
- 97 civic will not start have checked pretty much everything in the book but this is my first OBD2 sw
- ngk iriduim vs ngk v-power
- b18b questions
- List of d-series engines and their specifications
- tune up time...seafoam?
- blox camber kit any good
- Car wont rev past 3000rpm and feels like a studder box!
- OBD2B to OBD2A Question ; Civic 99-00 with engine 96-98
- HELP PLEASE:spark plugs not sparking
- Any alternatives to hood pins?
- Having Engine Problem with my delsol
- What exhaust???
- Honda Del Sol Condensor and A/C Lines ?
- japanese translation please?
- help .
- getting my car back and putting a thief in jail.
- Head gasket set question?
- racing seats, need help!
- OK. guys.. Helms manual for free 92-95 civic and del sol..
- Just replaced IAT Sensor - Still throwing Code #10 HELP!
- 1999 Civic Si won't start - OBD0 B16A, wiring is done - code 6, 10, and 22....
- single cam swap
- How do i know which b16 head i have? - Help ASAP
- Where do you buy yours!!??
- ok.. how good is this set of dampers??
- cant figure it out
- 98 civic d16y8 idle at 2500rpm, when driving clutch in 3-4k rpm anybody know why??
- 93 Civic 1.5 wont run
- Coolant problem
- delsol 96-97 mirror and doorlock wiring
- Help me if you own a 92-95 civic...please
- lowering with stock UCA's 97 ex
- door/ door handle problem?
- D15B vtec swap into a 00' EX
- 2000 civic coupe...will these slicks work?
- Scuttle shake is there a cure ??? lol
- skunk2 IM on D16Y8
- eg2 with eg front
- [97 Del Sol] FlyWheel + Clutch
- front brake problem
- ? about my eg's suspension
- delsol ashtray lightbulb
- need help getting the civic back on the road asap!!!!!!!!!!
- power steering...
- CTR Rear Seats Bottom Half
- AUTOmatic OBD2A to OBD1 convertion harness.... got some questions,
- IDK what they did!
- best bang for your buck....drag racing wise..what motor?
- del sol STEERING RACK....
- NOOB pics of my civic.
- Flywheel Question?
- Speedo jumps around - VSS plug, speedo screws, or speedo circuit board?
- No0b to Honda...My 98 vsm
- F22 to replace H22?
- Del Sol Dies when Brakes Applied?
- Does the cigarette lighter auto power off?
- i have a wieard problem
- Stolen CIVIC 1 HOUR AGO IN TORRANCE!!!!
- Spark Plugs, your $.02 and reccommendations
- 1998 Honda Civic - Rough Idle until A/C compressor kicks on....hesititation in 1st
- Integra Clutch Slave?
- FAQ: Ground Control + Koni install
- HT i need your help gas problem!
- honda tech newb
- CLUTCH NOISES??? VERY CONFUSING!!!
- 92 civic EX CEL 17 spped sensor question
- Starting/Running Problem Please Help!
- engine type
- B18A/GSR Sex Change
- B16a2 Engine Pinging and Hesitation under load and WOT
- Permatex on thermostat gasket? ['95 Civic EX]
- new head gasket or re torque head studs??
- D15 TRANNY D16 MOTOR WILL IT WORK
- stock exhaust?
- What cat to buy for Y8 exhaust mani on Y7 96 CivicDX ?
- z6 head on y7
- b16 torque specs
- new project civic hatch 95
- need help...ecu trouble...ANYBODY!!
- vibration at 50mph+ + while turning?
- What would cause an automatic to stall?
- Del Sol Vtec Timing Belt B16A
- FAQ: Tie Rod End Replacement
- 00 ITR Floor Mats fit 96 EK Civic?
- Best sounding Exhaust for B16a EK Civic
- car tranny
- lags when under a load?? help
- civic fog lights and legend yellow cover..will this work
- Transmission prob
- OEM 96 Civic Steering wheel, or compatible?
- transmission bell housing leak
- Car wont start, need some help on where to begin
- jdm del sol gauge cluster
- help asap d16y8 cylinder 3 has 28 psi compression no oil leak can it be saved
- b18b 94 civic vw 02 sensor question
- USDM knowledge needed for kiwi in NZ
- how to shaved honda delsol front bumper foglight holes!
- camber questions
- EG rear disc conversion gone wrong!! HELP!
- Suggestions on installing a turbo kit for a 98 civic SiR.
- Del sol ouline/sticker?
- del sol lips
- help! MY CIVIC WONT START!!!
- 1st Habanero red pearl SIR. --------->enjoy
- Rear discs on a del sol
- Koni Yellows or Tokico Illuminas? Cant Decide!!
- ebay ctr replica grill
- '95 Honda Civic EX - Where is the water coming from?
- civic capet
- car dies when a/c is turned on.
- torque specs for d16a6 eagle rods p.n. 5394
- 2000 Civic LX Short Ram Air Intake Question
- Third gear "jumping" out , S80 gear in 98 hatc
- My hatch build, single cam slam, body and motor! (56k be warned)
- What tap size for b18b1 crank flywheel side?
- buzzing coming from fusebox car not starting.
- side moldings on 99 ek hatch...
- more [freak]ing problems: car wont start
- ecu hunt
- The K20 Type s, and the work along with it
- bleed a brake master cylinder by the caliper?
- my civic sounds like a truck?
- jdm k20 on EK!!!!!!!!!
- 99-00 EK: Cant get the dang door harness disconnected!!!!
- idle problem,.....continued.
- this is urgent. seriously
- Motor swap
- BOGG-A-PALOOZA on a b18c1
- Fuel pump wont stop!!
- del Sol EG2 wheelbase question.
- 93 Honda Civic dx air conditioner help
