View Full Version : Honda Civic / Del Sol (1992 - 2000)
- RonJ@HT HELP!!! Swapped distributors, now it won't start.
- How many quarts for transmission
- Swap for D15B ek3 Vi Sedan..
- frame measurements
- Passanger Tranny Mount Help!
- What performace radiator are you running?
- Dont know where this plugs into? (Picture)
- question about shocks
- sensor on tranny will not plug in?
- is tranny fork suppose to be loose?
- to swap or not to swap
- d15b on a y8 head .Oil pan gasket what can i use?
- 94 Civic cx wont start
- Help, BLOX or SKUNK2
- Decent spring rate for daily?
- timing off one tooth
- RC injectors
- Horrible Gas Mileage (EG/B16A)
- Where Does THis Plug Plug In To
- Got my honda up to past 120, then.......,Fml
- Newbie!
- Shock Torque Spec?
- Radiator fan not working!
- need help..swapping problem
- Fuel Injectors for Supercharger
- shaking problem?
- will a 2000 si cluster fit a 95 ej?
- ugent ac help needed. r12 to r134 which lines/compressor needed?
- New on HondaTech, Hi everyboby !!
- what do you guys think about tein ss????
- Ek front bumper??????(might be dumn)
- ek si tach diameter
- PW:JDM 3 Point Front Strut Tower Bar
- Would this be a dumb thing to do?
- Don't ya hate it when...
- help with brakes
- oil leak
- Where to buy a honda engine?
- Average temp of turbo downpipe?
- HELP!!! Swapping 2000 HX into 2000 EX!
- crazy ek tach issue
- LS B18b power plant
- power windows are poppin fuses
- 94 del slo VTEC swap options for the ultimate sh!t... plz help!
- Turbocharging a D series motor?
- D16 motor swap
- sway bar or tie bar problem or something different alltogether?
- cam adjustment?
- NEW TIRE SUGGESTIONS - 00 Si wheels
- anyone wanna trade my cf hood for stock
- DC2/EG JDM cusco rear upper strut bar?
- Mishimoto Radiators opinions anyone?
- SI ttranny problem
- Trying to name Del Sol rear bumper part
- My spark plug cables are all messed up!
- 95 civic ex 1.6 liter having issues.
- My new ride LMK what ya think
- b20 turbo question
- A.C. DELETE electrical question.
- Shift Linkage problem
- ECU trouble codes/ Need some help
- How make aftermarket spoon steering wheel fit in my 96-00 coupe?
- axle question
- Blinker issue
- would it be a ricer or not
- b16a1 earth fault...???
- Steer me in the right direction!
- Which Igniton coil to buy?....
- Installing Shift Linkage
- code 20 ek swap
- EG civic JDM interior swap?
- Axle question for a EG Hatch, swap or aftermarket?
- Skunk2 camber kit removal
- speed sensor?? opinions...
- Do i judge either the title or the state i live in when it comes to needing a notary?
- Another vibation problem
- del sol interior in a Civic?
- Radiator problems help!
- need help w/starter
- 92-95 civic compressor questions
- a message to HONDA
- That Clicking Noise...
- Hella Supertone horn
- a good muffler shop around south gate
- Remove heater core?
- Rebuilding supercharged D16y8
- Turbo or no?!
- b18a1 valve specs
- Coverting a 93 civic from auto to manual
- avid mounts ?
- compression ration question on what i shouId use
- motor mounts. which ones?
- I NEED HELP!!!!CAR BOGS IN BOOST!!
- D16 HELP motor rebuild!!!!!!!!!!!
- Rim size and Offset...
- Annoying Miss
- Turbo Sizing Question for B16A2
- 97 or 98+ spec type r B18c
- Looking for a turbo kit for my d15b
- d16z6 opinions?upgrade
- 98 civic with Power lock issues
- 1996 CX Hatch- 49mpg and 0-60 in 12 seconds, wth?
- Stock D series Manifold Intake Size
- Eg Hatch No Start (No Spark)
- Condenser Fan Question
- EK Side Skirts
- oil leak
- New to the fourm and i got a 95 EJ
- ball joint question
- ctr conversion
- Help. Speedo trouble.
- How do I stop my car from running so rich????? 150 Miles to the tank FTL
- Headgasket for b16a2
- HD RSB wheels
- Where can I find washers for Prelude lma's in a b16
- Heater Hose b18b 99 EK
- EG Cluster Odometer Sync / Roll Back
- iat sensor help?
- Does 95 Civic Hatch Si Come with ABS Brakes?
- Help! my VX wont pass smog
- The official "What you did to your eg/ek today" thread
- Tell Us What You Did To Your EG/EK/Del Sol Today
- Supercharge Single Cam
- 92 civic dx wb18c1 94-95 gsr
- Del Sol 4 lug
- Odd Electrical Issues
- distributor help? TIMING ISSUE? BOGGING?
- h22 EG problems
- is my clutch shot?
- Door Panel Fitment Question PLEASE HELP!!!
- hood wont close helpp
- 97 del sol vtec engine wiring
- Gas in my oil?
- B series swap questions
- Good place to buy a new gauge cluster
- F/S:EK Civic Coupe Si (EM1)
- Selling 1993 Civic w/ 1.6 v-tech
- distributor
- Questions About Replacing Side Moldings
- ZC block with Z6 head
- Check Engine Light
- Oil All Over Motor / Leak? Were? How much to Fix? How Hard?
- 95 civic coupe ex Wheel hub assembly
- Did I bid too much on 2000 civic with 4 ACCIDENTS (ebay)
- EG cx exhaust options?
- Deciding Exhaust
- civic vti help
- d16y8 in eg hatch
- Clunk clunk clunk!
- civic b16 swapped b17 computer issues
- 92-95 Side Skirt Question
- can i install a transtop mechanism?
- I feel bad for any honda lovers in cali!
- D16Z6 cam seized in head -- help please!
- EG front lip options
- post your pictures of you customized del sols, civic, and preludes
- EX Front swaybar question
- jumper harness question obd2 to obd1
- Brembo brake caliper installaion? will they fit?
- 99-00 front end parts on a 96-98. How is the CORRECT way to do it?
- Trans leak
- Ls Vtec Build Suggestion
- Mysterious noise?
- boosting or supercharging my 1.3 civic
- 27151(A) exhaust Ticket
- rough idle when rev(no iacv)
- How do You install a 5 point harness
- B16 swap ran great untill I put it in reverse
- Sexy B18C
- Gsr rotor front rotor coversion...
- Loud Noise and Egine Vibrating
- car kind of feels like it's jerking on highway driving
- B pillar bar as harness bar
- Finally finished my Si build!
- Alternator/Battery Light on HELP...
- calling all black 99-00 civics with rims!!!!!!
- Civic Engine Help! Swap...
- d15z1 help
- obd2a-obd1 d16y7
- rev limiter
- Coolant Disappearing
- anybody have sugestion on what full coilovers to buy?
- EG- Auto to manual Converted. Brake Pedal Help!
- DB8 ITR SEATS IN EK COUPE
- trunk closeing mechanisim
- Have question concerning ls vtec need help!
- Climate control relocation
- Car problem...
- side moldings
- Noise in engine
- help!!! fuel pump cutoff switch/no prime
- Anybody rolling on Rota Speed 5's?
- im trying to find alot of ways to upgrade the car i want and
- tein 2nd hand coilovers
- Are Rays CE28N 10 spoke too big for my EG6?
- Different civic weights?
- ebay parts? yay or ney?
- d15b8 wont start
- timing belt tensioner
- anyone with a 92-95 civic wiring pinout?
- How to get these Lugnut locks?
- Attention! 96 del sol in honk yard
- EG Cluster Issue
- is this true about eg foglights?
- Headlight adjustment
- new speedometer discovery!
- Actual Location of MES Connector On 1993 Honda Del Sol
- integra front end
- Need help, about the brakes
- Looking to purchase an EM1 '00
- having suspension problem with my 00 civic cx
- OBX 4-1 sohc civic's header fits on del sol?
- gauge cluster working intermittently. have it narrowed down a little?
- usdm gsr engine harness on jdm b18c question
- Q about A stock P28 running a b series
- Help B18C swap in 2000 Hatch
- Need Help timing belt D16y7
- Trouble with Replacing Fuel Filiter.
- I HAVE THREE CIVCI BUT WANNA MAKE IT INTO ONE CIVIC NEED HELP!!
- im trying to find out what to add to a engine of a 1998 ex civic coupe
- Easy Help. 96 Civic GSR swap
- 95 rear disc conversion question.
- 1996 Del Sol S Model D16Y8 Swap
- tranny problem!!!
- 93 ls motor in 95 civic?
- Rear brakes lock up after driving...
- Need Help On Water outlet Cover
- radiator fan not working after b18 swap
- im trying to find a pattern for this car
- speed sensor issue
- clutch line replacement
- how do you get the lower timing belt cover off d16y8
- Swapping a d16y7 into EG questions.
- Throttle Body Spacer
- oxygen sensors
- LS swap in 4 door in CA
- Dseries ITBs
- altenator power wire guage
- Do you think it was dropped?
- running colder spark plug ?
- I need help fixing a few things...
- Changing to Synthetic
- how to clean k&n flat filter
- EG Climate Control?
- 94 Sol Si, SRS Light won't go off!
- civic towing a....civic
- What Engines can I fit into my 97 ex coupe?
- '92 B18 Swapped CX.
- Question On Honda Motors?
- Mono hub horn issues
