- ek with circuit 10's
- b20 tune up Q's.
- average oil consumption for a 2000 EM1
- car lags after 2500
- really bad idle no response
- vin# on 96-98 ej8
- How do I remove the lower door side panel?
- interior
- hydro to cable tranny question
- b18a into eg ??
- need help with some wiring, please help!!!
- Engine throws random misfire code, need help of the experts.
- What material
- Happy Holidays H-T civic heads
- gas gauge problem
- Rims on EG6
- Housing color for actual OEM 99-00 fogs?
- 92 si civic/b18b1 question
- springs and shocks off a 96 fit my civic 92
- 2000 civic 1.6L pings, CEL p0420
- what sensor?
- car vibrates when stoped??
- d15 tranny on a d16?
- Wierd low speed Jerking! Maybe need right throttlecable.
- searched.. Is there a FAQ for steering wheels in an EM1????
- ??? map sensor circut??
- map sensor circut
- Stripped out sound insulation on ek used with dry ice.
- 92 civic VX starts but wont run! help!!
- Merry Christmas!!!
- ek main relay problem
- which model p28 computer is vtech
- need to know
- O2 sensor cost and installation?
- sir2 gauge cluster
- LS OR LS VTEC is there much difference???
- Error Code help
- ek with h22. can i run p72
- Shimming bad while at high speed
- please help
- The last A/C Question
- Girlfriend buying a 97 DX Coupe - just a few questions
- stuck bolt???
- gsr swap in a 93 si wiring problem!!!!!!!!!!!!!!
- exhaust
- impatient noob
- TSUDO VS ZR RACING
- Engine not above 3500RPM
- Vacuum hose question
- front end question??
- b16 power steering help PLZ
- Bought hids for my ek civic what bulb size should i tell them to give me?
- Throttle positioning sensor (Cel 7)
- Quick question.
- ex exhaust----dx exhaust
- Thought somebody might get a kick out of this....LOL The VTEC guage....
- engine problem......help!
- b16 99 ek swap need help with finding bracket
- My radiator is leaking
- I'M THINKING OF BUILDING A B20/VTEC [ OPEN ]
- Gauge mounting.. aftermarket gauges not in the A-pillar.
- what will be the best set up dohc vtec?
- I WANNA MAKE A LS/VTEC [ HELP.!!! HELP.!!! HELP.!!! ]
- Unknown Wheels....help
- Newbie question?!?
- 2000 SI stolen!!!
- desperately need to fix this idle
- 00 SI Check Engine Light Problem
- b20b running like poo
- ignition timing + adjustment question
- PS & cruise control removal
- what kids of trannys can i use
- Rust-free, non-modified, 92-95 Honda civic Si's extinct?
- 00 si check engine light problem
- DC dash in EG
- 2000 civic projection question!!! HID
- brake calipers
- D-Series Manifold Question
- tuning with crome!
- Z6 or jdm D15b. ( help!)
- intake for ek civic with gsr motor
- 2 Problems *HELP*
- ELECTICAL HELP PT II
- xs-power cams
- casting numbers
- Bushing remover installer
- noob from millington tn
- What kind of seats are these?
- 93 civic si sunrrod
- quick question about gauges
- Drag Spoiler
- P/F mirror actuator
- got alignment done, but car still pulls to the right
- auto-man. help
- Help anyone>> stock 97 dx o2 sensor. into 98 gsr cat?
- ni everyone speed sensor!
- Where is the pgm-fi main relay?
- paiting carpet
- Clutch or Slave cylinder problem- Please lend me your ears
- d16y8 to d16y7 swap ek
- !!!!!!95 civic coupe with a CTR!!!!!!
- gsr swap?? help
- i need to smog my car help pls.
- Noob from Holland
- TPS Issue. Help is greatly appreciated.
- idle issue
- NRG Short hub and quick release install (Pics inside)
- Starting Problems 98 Honda Civic 1.8 Vti V-tec 5Door
- rsx-s muffler
- NEW here
- anyone want to race a d series in the cincy area
- post up pics of sweet systems in ek coupes
- LOSTTTT on CROME
- injector problem
- redo interior?
- 94 vx srs removal
- B-Series Tanny
- which pistons
- EG GSR oil leak
- d16z6 turbo q
- B series Longblock with D series transmission. Anyone heard of it?
- need some help civic eg4
- Tie Rods Question
- My shift knob sits crooked...
- EK Suspension
- acura mounts for del sol swap
- Posible or Not? S2000 swap to civic
- code 41 on a d15y8
- Crankshaft question
- O2 Sensor Question
- just got a new car!!
- EG hatch- best swap for 200whp
- cransor on jdm d16y7 replacement???? can someone help
- Skunk 2 Pro Series Cam Gears
- ignition switch
- breaks loose and shaking Help!!!!!!!!!!
- No Engine Check Light And Car wont Start!
- A question for those who have a double din in a 5th gen
- How Healthy is the Motor?
- I'm going to buy 92 Honda HB Si w/ GSR, worth it or I should buy 92 HB w/o GSR?
- thinkin of gettin this 2000 civic. few q's for yall
- i want air conditioning, what do i need?
- CODE 23
- knock sensor problem
- Snow chains Q'S!!!!!
- b20 vtec boosted or gsr boosted?
- windshield wipers went chunk!
- where to shave weight
- would i be able to out the steering column of a rsx into my civic?
- need help
- How to wire OEM foglights independently?
- Were rear foglights actually an original part on 96-00 hatches?
- ferio seats
- 2nd gen b16 throttle cable bracket
- please help a girl out
- trans axle Q
- Installing Spark Plug Seals
- Civic VX Efficiency
- ITR EG problem....
- Heater Controls
- car wont start
- camshaft
- Comptech sway/tie hardware question
- windshield wipers dont work!! replaced motor and they still dont **HHHELLLPPP***
- canadian SI's?
- alignment after suspension what do i ask for
- Need Help With Rims!
- '96 Civic Sedan Engine
- Help engine won't start.
- Got a question for u honda-tech freaks
- TRANSMISSIONS
- Gude
- D15B valve cover gasket...
- stock injector size?
- to boost or not to boost is the question
- 93 civic hb shakin/chokin
- NEED HELP !!
- real quick distributor question
- Marry Christmas To Honda-Tech
- LS ek coupe
- itr header on a eg
- Leaking transmission fluid
- Civic will not start
- brake bleeders for wilwood rotors
- swapping exhaust
- Installing cams b16
- changing 92-95 civic door handles.
- b16 head with gsr cams and gsr block with type r pistons.
- wide fenders!
- tires
- What is this extra plug? CX b16 swap
- OBD2B to OBD1 Idle Problems
- pic request: Buddy club rear bumper on 99-00 si
- 99-00 si cluster in eg??
- VTECH WIRING
- St. May shot gun exhaust?
- 93 CIVIC WITH D15 B VTECH
- Need an opinion on K20a3 buy it? also suspension question
- Camshaft
- 92CX: Overheating :(
- atmel chips - are they reburnable-reprogramble
- rear brake problems 96 civic
- How much you think?
- EG Window Regulator Question
- Stripped tranny side mount studs???
- new guy
- Canada eh?
- Gas Tank Issue
- is it a vtec?
- what type of eg cluster is thiss ????
- would this cut though the floor?
- Engine Overspeeding!!!! Lend me your ears!!
- hey how the heck?
- Hey honda boys from sacramento!!!!!!!!!!!!!!!!
- Since you guys know everything, please help.
- Transmission Removal
- HELLLPPPPZ. with LCA castle nut!!!
- B16a2 pricing question
- Fuse blowing problem!!!
- Which struts work with which cars..
- H22a or B16a
- NSX rear discs on del sol?
- Safe boost level on stock D16Z6?
- compression test results!
- EF hatch d15b1 into a 95 civic hatch? help
- Radiator question
- Thinking of doing a new exhuast setup.. Opinions needed.
- throttle body
- tach wiring?
- eBay intake manifold w/ velocity stacks?
- WHAT GREEN SHOULD I PAINT MY EK
- crome tuning question
- new h-t account restriction
- b16 no vtec need some ideas
- transmission
- wheel/brake size
- Tranny side stud for engine mount strips 17mm nut????
- skunk 2 intake manifold
- vtec Valve cover fit a y5 head?
- oil pressure sending unit
- Hey Again
- window motor
- A/C blower motor question
- HELP!!!!!!!!!!!!! CAN ANYONE NAME THIS RIM!!!!
- CA Smog question...
- Password JDM motors
- civic rear brakes PLz help
- 99 si headlight question
- Engine misfires in any throttle position but idle
- Losing clutch fluid and clutch is slipping - ideas?
