View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 68mm RPM Throttle Body WTT!!!
- HELP!!! car starts then dies
- Need HID help, PLEASE!
- 16"work RSZ-R 4X100
- cheapest reputable place fora b16 for 99 civic swap
- Good sites?
- Help with LEDs
- Help a fellow Honda Tech-er !!!!!!!
- Brakes for 93 civic hatch
- 4 swaps 14 hours.....
- Fan wont quit running!
- I want to up grade my brakes for my 93 si
- Intake manifold worth it for 99 si?
- Swapping a ITR suspension into a 99-00 Civic Si or EK civic??
- IM: stock b16 vs. skunk2 itr
- D16 Arp head stud install
- 2nd Annual Englishtown Honda Day... POST your TIMEs
- My DIY Black headlight project (EG)
- first time at the track...r these good times
- Which hybrid would you want?
- Honda meet in Madison WI
- Picture request 94 Integra B18B1
- finally went put some #'s down with the little b16!!!
- Tein SS Install... how to, anyone?
- 00 si compression results. opinions?
- 95 hatch.. REAREND HELP **WHAT WILL FIT**
- Broken LCA bolt!
- Do you all think this is a decent deal?
- The end all DIY Side Marker Post
- Please list h22 quarter mile times and horsepower
- a/c leak at the valves... can i just put in new valves?????
- help ls swap into eg and no spark!!!!!
- Need 96-00 Civic part numbers from Honda? I can help...
- Buddyclub spec III question
- 92 civic hatch h22 swap help in Maryland!
- Anybody make te-37 wheels knockoffs?
- valvetrain and cam install.......anyone......
- who else makes these besides toda
- Honda Civic 92 misfire or out of timing or both?
- help..steering problems?
- bondo to fill holes of 3 piecs spoiler?
- What the heck???
- CLUSTER TECH DIFFICULTIES???
- Tire Clearence on a del sol
- Help: code 41 on a stock d16z6
- HONDATA PROBLEM!!!!! PLEASE HELP!!!!!!
- anyone in Gainesville, Florida knows
- Anyone got a pic of....or tell me where.....
- Problem With Sticker.
- couple of questions
- Tokico Blues W/H&R Sports or Tokico kit springs???
- Eg Suspension help
- HUB HELP ASAP!!
- Air bag Question
- 99 Si ABS?
- OIl light problem
- swapping odometers
- ecu mix up
- Does anyone have pics of OEM engine mounts...
- DIY... 96-98 Civic Headlights...Getting the yellow out...
- Aiming headlights on 99-00 Civic
- Tech help: B18C R in 00 ex coupe
- Can AEM Big Brake Rotors fit my car?
- i need the EK n EG power mirror wiring diagram..
- OMG, PLEASE PLEASE HELP!!! - Honda Gurus I need you! - Timing belt issues
- Hydrualic or Cable
- Stripped Seat Bolt Thread. Help.
- Problems with 01 ITR cams in b16.....
- Need as transmission
- WHATS THE DIFFERNCE?
- Tire load rating? UHP rating lower than OE rating?
- CEL Code (yes I did a search)
- Honda ecu help
- troubleshooting help...
- what do i need for a B20 Swap in a 98 Civic?
- Anyone had their side moulding removed and holes filled up? how much did it cost?
- OT: But caught some thieves last night :)
- will a 92-95 SI cluster plug on my 92-95 CX
- Price of Custome SR Ground Controls
- I Have a Question About My Muffler???
- SI gauge panel to light up white?
- minor idle surge, and choppy throttle down low?
- 93 ec coupe: instrument night lights not working! Please HELP!!!
- Civic Vtech swap to different Vtech Question
- del sol trim level ?
- What size tire for a 15" rim
- Intake and Exhaust or a lowered ride
- Where to buy a complete d15b?
- Has anyone ever tried NEX coilovers?
- drop civic, what to go with, any help appreciated.
- Just BOUGHT LS MOTOR...
- Exhaust heatshield issues!
- Good or Normal?
- Suspension Help - 1999 Honda Civic EX
- comptech sway/tie bar and exhaust question
- what are the lights called that are tinted or dark?
- Body Parts...Jacksonville,FL
- Inoperable gas guage - 99 civic si (new-b)
- Wheel Rubbing
- fast question: what car does "A6" pistons come off of?
- Expecting too much out of my swap >?
- Amber lights?
- 96 Hatch + Del Sol Drum Brakes = Change E-brake Cables?
- piston questions
- add another one to the 13 sec club for b16
- not sure what im talking about
- wtf? No.
- Sparco hardware kit
- How to remove taillights????1997 Honda civic please help..
- EK door visors with which side mirrors- CTR or SPOON??
- crooked skunk2 exhaust?
- Cam gear was spun while engine at TDC w/ no timing belt on.
- Ek auto 2 manual Q? can you use?????
- b20 into a hatch
- 5 lug Type r Suspension
- What I need to look for...
- engine breakin?
- popping in my exhaust???
- Clutch Install ?
- I have a Full Built Motor with a Turbonetic turbo and my car doesnt want to go anywhere. Does any1 k
- 97 Integra Brake Calipers fit on a 99 Si
- CTR manifold 99 SI HELP!!!
- Need Input: I tuned the crank clockwise!!
- K20a2 swap EG; The other camp is talking the chit!
- what bumpers will fit a Civic 2000 ? 96-00 ?
- VAFC install on 00 si
- oem EG SEDAN colors?
- what size tires can i rock on a civic as well as an accord
- GATOR axles??
- Titainum Exhaust
- civic and itr brake hard line diamter?
- Need serious help!!!
- (searched) ek dash in a eg
- DIY: 96 civic head lights
- ecu?
- shifting problems
- Venting!!!
- Need some help...
- usdm and canadian..?? ne difference
- E-Brake adjustment help
- damnit i know what swap im gonna do in my ek
- Check Engine Light on problems....
- sk2im anyone in wa installed this before??
- competition clutch
- NEED HELP!!!!!!!
- headlight keeps flickering on and off
- Engine Overheats after swap......TELL ME WHAT CONNECTS HERE PLEASE
- 92-95 EX and RS is there different between the body ?
- What exatly is it ......????
- domani/1.6 EL question
- d16y8 into a 96 civic ex
- My I/H/E h22 dyno sheet
- cnai plug up the vacuum hose that goes from the PCV canister to the manifold?
- need help with new seats
- Is there any way to tell the year of an engine.
- EK(EJ) hatch exhaust on EG(EH) hatch.
- need help with o2 sensor, showing code 41 --del sol--
- k20 into a 2004 dx?
- 94 Ex won't start suggestions?
- Got my car already for summer today! also motor mount question
- stiffer spring rates
- How do I change Automatic Transmission Fluid? 93 Civic DX
- Will these fit? Integra - Civic
- dyno test for my sol
- h22a or b16a?
- Need Help bad!! Auto tranny help??
- how to get bolt off of 94 civic
- Rear sway bar on 00 HX
- mini me done. car just keep on cranking
- Doing rear disc conversion... dont have Master Cyl and Prop Valve.
- Will these springs work on my hatch?
- suspension question
- oil pressure sender
- need help !!!
- Energy Suspension Grease
- Expected cost of installing 99-00 B16 into a 1998 Civic LX auto in bay area
- Civic Automatic Transmissions
- BARd today...
- EG 1/4 Mile LAUNCHING PROCESS
- Engine Swap Question
- Rear Bumper
- What to do first?
- Need help with vtec
- B&M Regulator Question..
- SRR Pedal Install Question...
- h4 head light question
- B&M Short shifter - position & rattle
- b16a rod info????
- New cat for buying a header?
- Question: ITR rear LCA on 96 civic with GSR brake swap?
- I NEED HELP NOW PLEASE WITH THE DRIVER UPPER CONTROL ARM!!!!!
- Look @ the carange!!!
- coolant leak!!!!!!!!!!!!!
- Can stock integra rims fit my 98 hatch? Also get or not to get?
- safely revving out a z6.
- Need some help guys..
- noise coming from front
- CELs
- under axle exhaust?
- Installing a Carbing rear strut bar
- Car won't start--yea i know but i've searched and no one has my symptoms
- coldair with intercooler?
- Where to find Car-bing
- Fan Switch q
- fitment question for 01-03 Civics
- SPI Power Excel...NJ
- speed sensor problem
- Limited
- B16 swap help!
- how do i contact moderators
- Car won't start after headgasket install
- who's runnin a fields vtec controller
- help in need of your opinion on KS
- Rotor Size Question
- where to buy stainless lines?
- brand new after market B series heads
- shaved body panel removal
- oil light doesnt go on after new longblock install
- ls motor in hatch
- Difference between Header Types???
- speedeo=no workie???
- how to wire fields vtec controller
- Integra Rear Disc Conversion on an EG hatch. (lots of pics)
- Paint questions ..
- auto to manual conversion----inspection problems?
- What should i do? (Civic Ex 2004)
- ITR manifold on B16a head!!!
- CARB legal Header?
- intakes and throttle bodies
- fitment question
- is the 4dr sunroof compatible with the coupe and SI sunroofs?
- eg condensor compatible with ek?
- removing dizzy and cam for head work... help!
- What the hell is this plug?
- valve cover smoke...
- steering rack boot question.
- can generation 2 integra suspension and brakes fit in eg hatchbacks!??
- Cold air intake
- Honda Question.....
- ZC that wont start
- I put a GS-R motor in my hatchback cx but I have a check engine light on,
- Gas mileage on D16Z6
- ****b series powered del sol owners I NEED YOUR HELP mount compatibility****
- DIY/How to: JDM ITR 4x114.3 brakes onto an EK
- Holy Poop!!! please give advice...
- my eg22 hatch vs a lincoln mark 8 96-up
- fuel pump fuse
- I have a 99 Civic Ex automatic and I'm purchasing a B16a Sir II engin auto. also
- ek JDm questions
- Car running rich...help me out...
