View Full Version : Honda Civic / Del Sol (1992 - 2000)
- How long will auto tranny last without being oil cooled?
- Prepping for auto z6 swap into 5sp dx.
- Looking to relocate battery to trunk
- B18b wiring issues. (different plugs than my old b18...didn't know what to search for)
- Rubbing Grinding Noise From Front
- Eh2 vs dc2 brake (swap) questions
- is the 1.5 non-vtec flywheel the same as the 1.6 vtec flywheel?? 92-95
- Rear License Plate holder removal
- idle problems...help please??
- Newbie
- Crappy gas mileage in '95 Civic
- Obd1 d16z6 into obd2 d16y8 quick question
- B18B1 Bad Gas Milage
- vtec kickin in
- newbie question!!!
- power windows
- Another place to put the DVD indash player
- Whats your opinon?
- Changed Oil Now No V-Tech?
- new motor few quick questions
- Need help on how to align HIDs
- Adjustable Sproket on Stock Cam
- Wich one is better for a mini-me?
- mini me swap
- Big Electrical Problem Please HELP!!!
- Mini-Me Question
- I need your guys opinions on my EG.
- LS Swap.
- b20 problems
- Del Sol Roof Latch
- I locked my only set of keys in my h22 hatch...please help!!
- ABS ERROR CODES!
- shifter assembly
- aftermarket cams in b16a
- ECU Fuse?
- Tranny gone in under 18k
- replaced head gasket wont start HHHEEELLLP!!!!!!!
- Used Tranny Help
- d15b
- question about my d16z6
- Code 9, help please
- What type of A/C bracket is my Sol supposed to have?
- defi gauge install??
- door swap question
- Another Dowel Question
- Good radiators for a B18 swap?
- anyone good with wiring ?
- Need a couple of measurements from a 99 Civic Si wunroof, please help.
- d16a1 swap - starter doesnt engage
- SKUNK2 IM vacume line questions?
- I love my EG
- Help about leather enterior
- header ???
- 92 Si Rolling Chassis...
- why is my speedometer acting crazy
- No Brakes...
- how can i make the a/c colder?
- exhaust is popping allot.wtf????
- possible gas leak?
- identifying vtec
- need help with b18 swap
- EG sidemarker location
- will da seats fit eg hatch
- questions on motor swap..
- Car won't start?
- NITROUS
- all these posts about cars getting stolen.....is there prevention?
- Dizzy cap bolt snapped...safe or not???
- i need your opinion
- Valvoline Synpower Full Syntehtic oil.
- 16" Rotas for Del Sol ?
- Low Idle Porblemo!!
- gsr b18 swap NEEED HELP
- need help with my swap
- Sterling silver Honda necklace on ebay
- shaving door moldings
- need help with gsr swap
- Toda B16A stroker kit, any good?
- b20vtec
- Instruction on how to install ASR kit on EG/DC
- Car is Bucking acting harsh when I left off the gas...
- Stock clutch slipping with nitrous...any sugs/recs for new clutch and flywheel???
- del sol carbon fiber targa top - anyone tried it?
- "clickaty clak, clickaty clank, why does my car, sound like a tank?
- D-series Transmission weights
- f23 vtec swap in a 92 bubble
- CAR STOLEN!! ECU'S Possibly swapped, please help!!
- 96-2000 auto tranny fits on a 92-95 auto ????
- A/C question. Please help!
- Need info for doing a GSR swap into an eg
- Y8 internals
- Quick Mugen Lip question.
- Beeping Noise?
- d16y8 vs. d16y7 intake
- b16a OBd2b Secondary O2
- Quick headlight question
- Swap Help: Auto H22 Into 2000 EX? Even Possible?
- Problem seating my axle rollers
- need help!!!! civic idle is really bad
- Driver Side Axle / Driveshaft removal
- What IM & TB gasket to use??? Searched but couldn't find.
- Plz guys answer the questiong I am very stressed.
- front end options
- Civics in Australia
- check engine light after hi flow cat?
- Question: wiring a 97 H22A4 into 97 EK Civic Coupe
- is this worth it?
- anyone have a writeup on changing a headgasket?
- Car Alarm
- chipping a p28
- low rpm jerking
- 00ex exhaust on a 97 ex
- what kind of kit is on this civic?
- stock intake
- Fuel pressure?
- Koni shocks help?!?!
- smogging a jdm intake manifold with evap purge on firewall. vx hatch
- radiator fan not working
- how high can i boost on stock gsr turbo?
- iacv fix for d16z6 in 96 civic cx
- video request!!
- Whcih out of the three???
- JDM EK 98 type R headlights
- k20 type r into a eg 93 civic si hb
- B7 to Z6 swap. Map sensor?
- ALTERNATOR FUSE PROMBLEM AND ECU JUMPER HARNESS PROBLEM
- want your info on 1.5l
- Tranny leaking fluid from seals
- where to buy srr products?
- JDM B20 Fuel rail for 95 gsr
- JDM B20 fuel rail on gsr
- Idle Air Control Valve...how do you take it off to clean it?
- Looking for 92-95 civic bumper
- 96-2000 Civic Omni Power Camber arm owners look at this!!
- 94 Civic Si ride height Qs!
- Help From The DFW area
- Cusco rollcage?
- Still overheating...WHY?????
- Maintenance Required light
- Problem with Brake Lights
- CEL at 5500 rpm
- New to the forum
- car: em1 mileage:91,500 .. bad idea?
- Just bought a wrecked Ek Hatch, Plans Plans Plans!!
- type r alignment
- any tips while pulling my first tranny?
- part number for del sol vtec a/c bracket P54
- **Is it okay to mix GM syncromesh w/ Gm syncromesh FM?**
- Clutch safety switch
- First post , howdy yall
- crank pulley?
- auto to manual swap question....**
- Need help, i new to hondas
- K20 into a 92-95 or CRX 88-91 advice
- need some advice
- will a front bumper made for a 94 2-dr civic fit on my 94 4-dr?
- Car not starting
- B18C will not hold constant speed!
- wiring harness issues
- Throwing Code 61 in my 2000 em1
- Quick question ?
- how to check intermittent check engine light (CEL)?
- B16a swap bogging???
- 00 honda accord F23 vtec
- I'm wanting to buy a wrecked or blown engine Del Sol
- Best B series motor
- bitch pin*****
- power window conversion on civic
- somebody help me out...
- What makes engine rev till 5000 ONLY ?
- Dowel Questoin
- Will 94 Teg Side mirrors fit a 93 hatch?
- Integra tranny in a EG
- Inner Tie Rod Replacement
- WTB vision amber corners nor cal/bay area
- tire question, n00b 17's
- Where to buy replacement gauge cluster for 99 civic
- Moth balls for higher octane?
- Coolong system problem...please help!!
- Looking for a so cal EG hatch/suspension question
- where can i get
- would this hurt my block??
- Want to get a new steering wheel, what about safety though?
- suspension problem?
- EF oem springs on EG. Lower spring rate into heavier car = lower?
- Dekalb, IL area
- will a 92-95 passenger airbag fit in a 94 teg pasenger airbag?
- Removing White Side Stripe
- Crower cams in 00 si
- White/Clear Blinkers
- D16y8?
- How do you do a RHD Conversion?
- OBD-1 ZC in 93 SI HB
- can anybody identify this part?
- Need Help Please----p13 or p28 or p72
- squeeking sound when i push/let off clutch, as well as gas?
- Is it true SOHC vtec dont have VIN??
- Wierd noise from rear when it rains
- civic H22 problems
- code 43 what needs replaced??
- 200 itr authentic swap or no?
- Anyone ever heard of jacknife rims?
- d16z6 running rich in vtec
- (need help): is this a b16 obd-1 dizzy ???
- B16 Sluggish Stutter......part 2
- spark plugs?
- How much does a hood weigh?
- 5 Lug conversion on EG
- 2001 Integra Type R exhaust fit on a 2000 civic si?
- AC installationg - What bracket - please help
- 92-95 dash- another question
- Questions about what wiring harness I need to use?
- 96-00 Honda Civic Air Conditioner Installation
- Tow Hooks
- d16z6 swap price
- all motor
- has anyone heard of a 4WD civic?
- HElp is needed with EM1
- yea....stupid question...b seires to EK swap info.
- Bent valve?
- My car has been broken into twice
- need a high volume fuel pump for a 93 civic
- Emanage install, help!!
- Boosted B7 to N/A Mini-me, WONT START!
- PCV system
- Pictues of the 92-95 SI HB Seats
- wiring harness question
- No Spark, Running out of Ideas
- Please HELP! Another stolen car!
- headstuds and rodbolts necessary?
- Venom400 Performance Module
- trans problem, It might be jammed
- CPU Tuning?
- can you help me
- overheated and shut off!! Help me out!
- Fuse Panel Pic
- Foglight Lighting Problem
- minime Q
- CAR STOLEN TONIGHT IN DUBLIN @ THE IMAX 6 HOURS AGO 92 Honda Civic VX Hatchback with GSR Motor RED *
- What are the biggest front brake calipers and brackets that will fit on an EG?
- WTF Idleing like crazy???
- wat up wit the airintake on the 96 lx?
- What kind of grease do I use for slave cylinder?
- Okay Something weird about a B18B I bought.
- 96-98 and 99-00 engine harness
- leaky clutch resevoir or something
- type-r headers...
- REF ticket...Want to get BAR approved...
- help!!! clicking from tranny
- lookin for a swap for my del sol
