View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Y8 camshaft in a Z6 head...what results?
- JDM D15B or JDM D16A SOHC VTEC Motor?
- Wiring Question. 92 EX vs 93 CX main wiring help please
- cheap strut bars yes they are almost free come in
- bend lcas
- b16 gap
- Greddy header or DC Sports header...both 4-2-1
- manual door locks rattling *already searched*
- Whats the ECU code for a 5spd HX?
- Rattling clutch/tranny??...maybe throwout bearing? I dont know!?
- header question
- ok don't know now
- P2M: 96+ OBD-2 NZ Civic SOHC VTEC= What the?
- My 93 Civic needs an engine and...
- my ecu fuse keeps blowing
- -- WHAT CAMS SHOULD I CHOOSE?? --
- need radio code
- 92 hatch, swap with 94 ls
- itr fuel rail work on p30 IM?
- Fuses keep poppin
- need newer radio wiring diagram
- Please help!!!!My 1993 cx civic hatchback keeps pulling me when i hit bumps and holes
- newb needs help
- What is this?
- NEED HELP!!!!!!!!! D15B 3 STAGE VTEC
- HELP! newbie with 97 civic.
- cracked ring, wat to do now?
- how do i properly replace my slave clutch master cylinder?
- JDM H22A EF8?
- 2000 civic dx air intake box w/ sensor
- CEL, O2 Sensor, and IACV...O2 didn't fix problem, need help fast.
- Bad axel? Read for more info.
- axle backs... need help
- NIPPON racing pistons for b16/b18 any good!
- burning oil?!
- Can I use the JRSC fmu?
- ticking coming from the head [searched]
- jdm h22a swap in eg6 [need info,help]
- Plug and wires??
- Setting timing without cover
- NEED HELP CAR WONT START INGNITION PROBLEMS!!!!!!!!!!!!!
- suspension help hurry
- EX door panels, power windows & locks???
- '96 integra eibachs in '00 civic coupe?
- IS THERE A DIFFERENCE BETWEEN LS AND GSR REAR MOTOR MOUNT
- New Shop!!!!!
- Im New to Honda Tech
- no start problem
- body kit help !
- B20VTEC...What octane to use?
- I need a P28 or P30 shipped to 36117. How much?
- SCCA Suspension Set Up Feedback
- 1995 teal bubble never on the site so email me sick deal just read the post!!!!!!
- Steering column question
- Ebay Fog lights
- HELP...needed on a Civic Hatch!!!
- installing sparco EVO seat to civic ex 95...
- Anyone have a set of 96-2000 Civic Rear Endlinks Available?
- How do i install front speakers? Im looking at the connection, and it looks like i might have to cut
- Purpose of Knock Sensor?
- exhaust gaskets
- vtech wires
- Sprint Springs on EG 2 door
- Code 19 GRRRR
- Stripped tranny mount threads.
- d16y8 engine?
- Anybody have illum. window switches on 92-95?
- Broken Rocker Arm Assembly
- Buddy club seats? Which rails/sliders?
- retarding ignition timing with nitrous ?
- Jumpy speedo. VSS, dash harness, or gauge cluster problem?
- Common interior water leak sources in an eg hatch?
- To fix up this EG or not?
- Ne one in bay area read... my baby got stolen..
- How Do i Send A PM to a member
- blockheater
- Q about hooking up rmf header to ex-mag exhaust
- Is there any other heads i can put on my D16Z6?
- jacson racing supercharger.
- Have i been worrying about nothing?
- lubercation on the window tracks?
- ebay power mirrors
- Calling all Kenji P28 user's
- eg dash problems
- AC Help
- Soft Clutch Pedal...
- Homemade Intake Manifold
- those with hasports and b series motors
- What is V-TEC E
- bronze windows not jdm?
- spark problems
- valve cover trivia
- stock LS exhaust on EG swapped
- Emission inspection question.....
- MOTOR POLL
- Manual Trans fluid, what to buy and where?
- waht is different? eg2-del sol
- 94 civic coupe with 0bd1 jdm b16 swap...what kind of tranny cable or hydro?
- 3" catbacks
- HID retro finished!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- AXEL QUESTION (SEARCHED)
- ride height
- light bulbs
- Air Intake
- bad valve seal??
- Just bought my third civic... 1995 EX Coupe
- forgot how rear seats mount?
- will suspension from ek fit a eg?
- guage pod?
- Question about tranny mounts..
- Need Help!!!! Pics inside....
- goobye ef8, hello eg2!
- CP intakes?
- timing mark
- ls rebuild manual
- STICK SHIFT
- Car Bogs Out WTF?
- how much would a b20/vtec worth?
- skunk2 camber kts
- shift boost install
- Sensor on Clutch assembly??
- auto p28 used in 5spd d16z6 possible?
- why is my clutch all messed up?
- b16a2 intake manifold
- Need a new transmission??
- Pic Request: Si rear sway bar endlinks on car
- Shit bought a JDM LS motor on accident for boost,help.........
- help, 96 civic valve tap
- weatherstripping around windows fading?
- Turbo setup and need advice with setup
- does this look bad?
- Need a little help
- Is the y7 MT IACV same as...
- Where Do You Get Del Sol DOHC VTEC Shift linkage?
- 2006 VW R32 LOOKS LIKE 92-95 HONDA CIVIC HATCHBACK
- Parts list for B16 swap into 95 coupe si.
- 98 honda civic EX ( GSR swapa ) fuel cut maybe???
- dx to ex cluster
- fuse block
- civic or integra coilover/shocks?
- 92 hatch
- Need Help Asap.
- :Carbon Fiber Intakes???:
- ? about gsr throttle cable
- HelP! b16 tranny problems
- B16 won't start!!!
- lsvtec help car Starts but wont say on!!
- HOW To: HOOD LIFT?
- EG hatch: Front strut bar fit rear?
- GSR rear sway bar for my 2000 Civic Sedan
- tail light seal
- EG hatch
- <^ !FuX0r'd! '00 hatch needs a face lift after crash...HELP ME! ^>
- Questions for anyone road racing their ek, need help with upgrades
- Mugen Curiousity
- amber cluster and c/c?
- 92 hatch with b18 swap... smoking bad when it acclerates ..... ??????????
- strut bars
- 93 honda civic Coupe 5 speed Tranny probleme!
- ideal problem?
- Auto to Manaul Swap help please! need pics.
- how to install 2004 civic si seats to 2000 civic si........
- JDM Shit Smoked Amber Corners?
- Bad miss fire, car ran fine and then another miss fire.
- Hondata question
- Coilovers
- Deck Height of B18a1 Vs. b16a2, height of b16 and b18 head
- Size exhaust
- Intakes difference
- who makes tsudo?
- cams ?
- Oil Trouble!!!! Honda-Tech we have a problem!!!!
- 98 w/B20 swap has idle problem, looking for advice
- How do i change out the bushings for my clutch master cylinder?
- pics of ek 4 door
- Ignition Timing???
- Pictures Are In!!!!!!!!!
- what else do i need for my turbo kit?
- 00 Civic EX rear disc conversion
- exhaust note
- experts please
- pinout for dimmer 96 coupe
- KYB GR-2
- Smoke coming out of exhaust... emarissing!
- Gas meter
- GSR rear sway bar...bolts on to EK hatch?
- dizzy install fee
- stupid del sol top leaks near visors a lil . why?
- Brakes
- 91 si tranny head and dizzy for sale
- with respect to cai, and short air intake ?
- What is leaking??
- about black civic interior
- Need Help with removing front and rear bumper
- darton sleeves or aebs sleeves
- Stripped 02 sensor......any crazy help ideas?
- 2000 civic si/ snowboard rack?
- stock ecu or chipped p28?
- running like sh#t
- just swapped a b16, idle is too high/unsteady
- Cyl No. 2 misfiring, speedometer and tramsmission speed sensor not working.
- VTEC not working... (and yes, i searched and i did everything i was told and running out of ideas)
- Halo Headlights
- civic exhausts
- running on 2 cylinders, cel 7 & 14
- Reading helms circuit diagram help
- 99 D16Y8 cam torque specs request
- back fire
- serious wiring help
- main bearing cap removal
- Password:JDM Front end conversion options
- What could this be?? Timing belt?
- dizzy model#
- Do i need a camber kit?
- 99 GSR gauge cluster into my 00 civic ex
- hmmm...Del Sol seat covers?!
- Burning smell coming from intake...
- auto->5speed swap cost?
- what cams should i get
- 93 Del sol Drivers Side window isn't sterdy
- Windshield washer sprayers don't go on CF hood, where do i put them?
- o2 Heater element circuit question--
- Injector not firing..
- Free Passenger Air Bag for EG
- where is the rad fan switch located?
- Anyone make a catalytic convertor modded.....
- 2000 civic tranny problem. (automatic)
- once and for all. OBD1 vs OBD2
- will stock pistons work?
- Stumped Car wont start unless its on fire! tried everything need new ideas!!!
- engine problems
- Size Question
- car wont rev
- H22 Swap For Sale
- B16/B16A2
- Gsr Dash/Cluster in 94 Hatch
- 95 Urethane Engine mounts
- Question about the 96-98 coupe/sedan
- If anyone has H22 problems e-mail me !!!
- how do i get rid of my rev/speed limiter?
- clutch help requested
- eg9 foglights
- WRX seats in an EK, Possible?
- jdm d15b and usdm d16z's and d16y's
- HELP!!! Need Tranny Bolts: M12x1.25 Fine Grade 8 - Where to find these!? [Bay Area] HELP!!!
- New Ride.
- How much does it...
- y8 and z6 intake/exhaust gaskets.... are they the same?
- KBY AGX and ____ spring...
- shocks? need help!
