View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Will H4H bulbs fit into USDM housings?
- Poking hole in cat to make v-tec louder
- 2000 Honda Civic Si Engine wiring diagram help.
- Need help possible bad clutch
- Eg hatch wiring for 3rd brake light
- Bad Wheel Bearing, No Play/ Movement ?!
- basic instrument cluster question
- Will 88-91 Civic Ground Control sleeves fit 92-00 Civics as well?
- 96 Civic DX -- p0302,0304,1399,1300 HELP!!!!
- Differences between Del Sol LHD lights and RHD ones?
- ej8 wont start!!
- New here...need advice on Honda specs
- Still no Spark to Plugs
- Clutch pedal stays on floor
- JDM Del Sol VXi new owner, and dash light on for overheating cat converter?
- Help with weird start up noise
- EG/EK/DC Fuel Tank
- ek throttle cable replacement for zc non-vtec swap
- Civic Noise When Driving: Please Help Diagnose
- Car jerks when I let off the gas
- O2/Idle problems/codes with a 1999 Civic EX
- Brand new engine, 0 miles and horrible MPG!
- Can I wire power doors without harness?
- 97 Civic coupe - I need power window help!
- 92 Civic hatch with GSR swap -- in need of help
- EBP Si - Need new headlights
- D16z6 piston rings in a D16Y8?
- 1992 civic dx headlight issue
- daytime running lights question...
- D17
- eG WITH B16a transmission wont engage???
- my new eg build
- So how many miles are on your Honda?
- Failed Smog - 92 Civic DX - HC:244, CO:0.75, NOx:3154
- 94 eg hatch si spark plugs wire help
- Honda Civic Door Removal
- Idle Air issues and headaches
- del sol bucking at 1500 rpm
- Fuel Injectors
- Window Regulator/motor problem
- Miss fire P0300- P-1399
- 92 civic dx 4 door - What can I do to my d15 to give it more power?
- Sticking injectors?
- Anyone pass Cali SMOG with a non-Cali manifold/cat?
- mpfi to oem carb help!!!
- Experience on aftermarket locks (security tech)
- 95 Civic 5-speed - sudden shifting issue preventing driving
- HELP storing My Resurfaced Cyl Head. is it warped?
- Door lock actuators
- Aftermarket Keyless Entry
- New 00 Civic DX Hatch - questions about mods
- Weird noise from tranny
- Wire tuck/Intermittent Electrical/Main relay
- 2000 Civic SPRINGS SI vs LX
- Possible Flooding?
- 92 Civic Front Wiper Motor
- D16z6 in 95 coupe horrible MPG
- are these the correct mounts for my del sol?
- OEM Steering Wheel Diameter?
- Cranks but won't start after control arm replacement
- H22 to b16 swap
- Starting Problem
- 00 Sedan Trunk Latch
- Intake Manifold
- eg coupe tail lights
- HELP, Brake light problem
- Changed clutch master ad this piece fell out ???
- Catalytic Converter for Emissions
- My 98 Civic coupe ex - Need pointers to upgrade the car
- Downforce on my EG Hatch race car
- What engine does my EG Hatch have?
- Rebuild after a-hole wrecked my Sol
- 6th gen coupe electric (remote) trunk release mod
- del sol suspension?
- 93 del sol bucking at 1500 rpm need help asap
- So my SI got totaled parked on the street, what to expect now ?
- iacv problem with performer x intake
- ek b20b1, stock air filter help
- 92-95 Civic Aftermarket Tail Lights
- EM1 w/ b16b throwing CEL
- Which civic should I buy?
- tuned my car and it just died on the way home! please help!
- Project 99 SI
- [EG 92] Where Can I find Gauge Cluster?
- 1992 CIVIC DX sedan overheating!! HELP ME!
- EF Tein S-tech on EG sedan 4dr?
- Keeps blowing radio fuse, backup fuse is ok
- Timing at 17 Degrees
- Grinding oversized piston rings.
- Power window wont go up
- Is my car backfiring? And is it the engine receiving damage?
- Keep my EM1?
- help with temp gauge!
- b16 3rd gear grind, What to do?
- Do I have bad dizzy?
- [FAQ] Your Guide to Buying Quality Aftermarket Maintenance Parts for your Civic
- 94 sol doing nothing!
- smok
- Rear main seal on 1998 Honda Civic EX?
- will not turn over
- 98 dx resonator box aka mouse house
- P0141 on 96 Civic LX
- Speedometer and Odometer not working
- JDM vs USDM Cluster question.
- Stupid question regarding replacement brake shoes
- Changed Thermostat/Spark Plug Wires Now Car Wont Start
- Ek 96 hatch y8 head z6 block idles
- crooked wheel question
- hey guys have a 2000si question!
- P0505 code! D16y7
- clutch pedal adjustment
- Metal Head Gaskets dont show blown part?
- How to Remove Stock Intake on D16y7
- door ticking while on highway
- HEADLIGHT PROBLEM NEED HELP ASAP
- Help, 1992 Civic Si white smoke from exhaust when reved and smells like gas.
- 93CivicEgHatch won't start need help
- Del sol Lower Fog light Install - HELP!
- gas issue
- Sway Bar Options
- Cant get my eg started!
- oem optional ashtray? 96-00 civic's?? where to buy!
- obd1 running y8 on p28 map
- '98 Overheated and won't start
- 95 honda del sol auto to manual conversion
- p1456 code?
- i have oil in my radiator what to do
- Dead no spark cx
- Engine heats up when idle
- crossed 2 ecu wires... help
- Help! My 99 Honda civic dx sounds high in rpm or accelerated
- Speedometer off by 10 MPH...
- zc dohc swap problem
- 1998 civic dx engine swap ideas/pointers
- Low idle and rises when tapping the brakes HELP
- sand paper
- Free Launch Control with Ignition Cut
- 92' VX Hatch Torque Specs.
- Engine mounts
- 1996 EJ6 Coupe build thread - from Germany
- GSR Rear Disk Brakes.
- Power steering fluid
- Looking for a hose diagram
- Civic starts but won't stay on
- starter problem...i think
- Alternator bolt snapped. Suggestions?
- D15Z6 valve clearance
- Stage 4 Racing clutch adjustment...
- Locking issue
- "1997 civic hx gas needle stuck on full"
- Em1 door problem!
- Airbags deployed from mucked up SF streets!
- Power draw
- 02 sensor
- Burns oil and now coolant?
- F this F'ing oil leak
- need help with fixing a map sensor code
- 1997 Civic DX Coupe roof drains.
- 2000 hatch bogging at lo RPM
- Stock fuel pump has high-pitched annoying whine - is this normal?
- nickle n dime del sol build
- 1999 Civic Grounding/ windows/locks HELP!!!
- WHAT IS THE BEST CAR FOR ITS POTENTIAL AND STREET RACING ?
- Engine swap in my del sol
- skunk 2 valve train
- What shifter bushing's for del sol?
- Remove Windshield Washer Motor from Reservoir
- Best TB and ITM & Pulleys ECU?
- HELP!! H22 SHIFT LINKAGE IN EK
- 1999 Civic SI EM1 black
- Ek civic coupe buyers guide?
- 98 d16y8 auto to manual IM CEL 54 and wacky idle (solved)
- 97 Honda civic won't fire
- muffler thief
- 92 civic auto help !!!!!!!
- crank shaft genio was broken
- Are These Tubes Necessary?
- axle help for civic
- h22 to single cam question
- b16a1 wont start got fuel and spark
- 99 Civic Si issue
- hondata s200 box not connecting
- JDM B20 swap running issues
- Gas smell and no pressure in gas tank, please help!
- 95 civic DX idle hunting
- h22a swap into 99 ek info?????
- Can someone tell me what kind of lip this is?
- BuMM's Ej6 Build
- GSR Rear Sway Bar D-Brackets on EK
- Seats
- Is this a deal or not?
- Tweeter wire harness?
- is 96-98 factory stereo harness exact same as 99-00 stereo harness?
- cooling system issues
- fuel pump not priming/no power to starter
- Someone explain VTEC
- 95 civic h22a swap code 8 question
- D to B air condition question. 99 ex
- is this an aftermarket fender?
- Carbon fibre Upgrade
- Need C419 Under dash Blue plug pinout 94 delsol
- ek door hinges on eg
- Clock won't keep time and Stereo won't power up.
- timing issue on mini me help
- Locating LCA to Trailing arm nut
- Ignition Kill switch won't initiate
- Charcoal canister delete question
- plz help
- exhaust question?
- civic really low idle
- Should I go with head gasket set or just gasket?
- GSR Brake Conversion into 99 Civic Cx
- please help me
- Cluster question
- Motor swap no coolant moving.
- 94 del sol si problem.
- Stolen 95 Civic CX STOCK Wont Crank Buzz Loudly
- Civic Axle - Splines won't line up
- Will full size spare tire fit in a 6th gen civic trunk?
- d15z1 swap into dx/si
- 2000 em1 CEL number 8? Nothing seems to be wrong but the code?
- break light not working please help!
- need help with ej6 wiring
- Sputters and Bogs Down at Accelrating
- 93 civic driver wheel wobble
- Wilwood Manual brakes wont pass brake test
- 97 ek 0BD1 B16 swap problem :s
- Coolant Temp Drop During Idle
- Del sol CEL + lacks power
- 18 yo SRS Car Airbags
- Warm Engine Consistant Stalling
- Clutch and gear problem
- NO START 92CIVIC
- sunroof drains civic
- Please Help! Del Sol tranny
- headliner
- Verifying stolen engine
- jumpy idle,stalling, and no power
- Power steering parts list
- Stalling Out at Idle, Gutless
- valve cover hose?
- 2000 Civic LX manual transmission
- '95 Civic won't start...
- Cooling plate?
- fg seats fit into ek !!!
- Radio fizzled out, not working
- 98 civic type r front an rear lips
- civic/water leaking in
- 1998 Honda Civic DX Sedan exhaust help!
- Ek4 Bumpers on Ek9
