View Full Version : Honda Civic / Del Sol (1992 - 2000)
- D15 Swap
- skunk2 pro intake manifold
- Del Sol T-Top Issues...Noisy Top
- anyone know specs for 99 civic hx cam???
- new engine, original ecu..last thing to change
- Ek hatch resonator on a EJ8?
- B16a2 blox tb/im
- I just replaced axle seals, so why is it still leaking?
- why would a front end bounce??
- Rear main seal R/I
- 93 honda civic turning off when stepping on gas
- Exhaust Adapter help please
- 96-98 Civic Foglights
- 93 civic ignition switch?
- 1993 civic running rough under 3000rpms
- my first civic!! :D How get more power from 97 Civic with LS swap?
- How's the a/c in your 5th gen civic?
- civic steering colum/shaft
- 1st to second shift hard....
- Civic sounds like a Subaru... Help!
- 1992 HONDA CIVIC 1.5DX WILL NOT START
- skinny nuts
- Engine overheating after motor replacement
- possible bad ignition switch?
- Idle Surge Tests my patience with 97 coupe.
- How to find out what year/type of b-series head
- 1995 del sol cluster - bulb sizes?
- Crank and Cam Shaft Oil Seals removal
- Power Steering still possible?
- vtec help......
- Engine suddenly lost power and died, rpm guage jumped about
- Cam question replacement
- HELP WITH SLAVE CYLINDER!!
- Putting together cylinder head, had some q's
- Typical Starter amprage draw???
- 00 si intake question
- NEED LUGNUT SUGGESTIONS FOR DRAG DR20
- Pulled off 2 ignition wires to kill engine, now car wont start.
- JDM Sport Rear upper and lower strut bars
- best amp mount location
- Idle Hunting, Leaking Coolant, HELP!
- 92 4dr GSR swap question....
- Picking up a b18b tomorrow! Excited!
- Help!!!! Constant power without the key
- motor bogs wher vtec pops need help please
- What can a tune do?
- 93 D16 - B18c1 swap?
- Best cams for what ive built
- eg6 rear seats. remove fabric? upholster on usdm seats? will it work?
- 97 civic ex - lights surge and the speedometer goes crazy
- How far do you compress the spring on the exhaust?
- p1457 code
- 2000 civic lips
- 96-00 Civic Fuel line Sizing
- 0 Ohm Resistor for OBD1 ECU
- b20b Missfire/flooding/lumpy idle issue
- buying a car through copart?
- DIY: 92-95 EH/EG/EJ Low fuel sender installation and wiring
- **BRAKE GURUS... Enter here**
- P1033 sensor 1 slow response won't go away...Tried everything
- Gas Mileage issues with Bonestock D16Z6 in Civic Si? Help please.
- swapping my engine
- Can I use these? 95si W b18c
- idle problems by bent valve ???
- Which seats are a direct fit in a 2000 coupe?
- how much does it cost to paint your engine bay
- By going rhd does it increase any value to the car?
- 92 si, jdm eg6 rear conversion, worth it? / help...
- Swapping A D16Y5
- Removing stripped frozen bolt on exhaust pipe. Please help!
- 1993 civic no oil pressure
- trannsmission problem...hard to get in and out of reverse
- 94 civic ignition ?
- CV joint popped out :cringe:
- Diamond Racing Tire Size
- swapping out struts question
- 2000 front end help
- Any DIY's on modifying clusters?
- Crank Pulley Bolt issue
- Del Sol Starting Problem- Help!
- 92-95 Civic Hatch replacement carpet
- where to buy nardi replica steering wheel and hub.
- s2000 master cylinder in civic?
- Timing problems on my Del Sol need help
- BDL hose clamps
- 00 Civic tokico shocks and coilovers - scrubbing on right rear during left hand turns
- Dash Lights Flickering KOEO
- tranny swap easy both ways?
- fresh, rebuilt D15B engine. What oil should I run?
- VTEC not working
- PO8 in JDM B16A?
- Tachometer help
- HID Flickering problem
- to chip or not to chip p28?
- b16a vs b16a3 head
- sunroof wont open on tilt
- Civic makes a rattle can noise..
- 96 ITR swap in a EG
- Think my civic might have a bad tune?
- 2 1/16 Gauge Pod Ideas.
- New to H/T and need help EJ6 C-Pillar
- koni shocks
- Yes another Vtec problem thread
- sohc shift link question
- 93 Del sol fixed thanks to you all
- B18b in 95 hatch won't start
- oem axle part?
- 1992 Civic LX Cranks, No Start
- my a/c blows hot
- thumping driver side wheel
- transmission issue? help please
- 94 integra abs delete. parts list?
- what type of headlight and grill is this?
- 93 civic si starting
- motor mount ?
- New to the Em1 scene - convert to OEM suspension?
- honda civic d16y6
- jerry built b20 vtec
- hesitation problem
- starter problem please help
- Smokes at high RPMS
- Help, My trunk is leaking
- Cam question
- MINI ME HELP ASAP!
- Where to find Stealth Grey Pearl (rp24p)?
- My odometer stopped working need help!!!
- 94 civic: hazard, horn and brake light problem..possible connection?
- 98 EK GSR having problems starting and i smell fuel....
- 93 Del Sol hood latch problem
- teaching how to drive stick
- 98 hx obdII port & check engine light dont work?
- Questions about full 98 integra brake swap into 93 hatch
- center console in ej1 need help????
- cluster problems .... help
- changing my spark plugs their oil on them??
- 92 Civic sedan backup lights not working
- fuel tank pressure sensor install????
- 95 Civic EX Gas Pedal Feels Hard
- 99-00 Civic Where do you hide/Tuck the Hid Kit?
- Just bought a JDM EG9 cluster... DID I get the shaft?
- 99 Civic recipient and 96 Accord donor - Question about F22 swap followed by H22 swap
- 95 Civic flash code read? Car starts intermittently
- Which intake manifold?
- 99 ex HIDs not coming on
- Jdm B16 Sputters at Certain RPMs
- head gasket
- B16b swap in ek coupe help
- Taillights stay on?
- ****Foglight Switch Wiring Help****
- MoMo Hub
- Questions about what you use to lube your poly bushings and spherical endlinks.
- Rough Idle, Hesitation, And Poor Gas Mileage. No Check Engine Light.
- Aftermarket headlight problem
- Bolt on Catalytic converter for EG w/ B18B1 swap
- 99 EK Civic sedan problems. *HELP NEEDED*
- Check light is on, jumped it. This is what I got
- Coolant in cylinder?
- 94 EX Clutch Problem!
- need help quick..please!! starting problem
- NeedHelp-distributer wiring 98 civic lx
- Vafc 1 possible to install with VTEC E
- D16Y7 Rebuild Question
- Any problems with importing a RHD 96 ek4 from Japan?
- Black specks in radiator on 95 honda
- 92 Civic - idles rough and loses power in higher gears
- newbie here needing help with b16 build
- QSD H2B with B16 ??
- 99 front clip what fits
- Tire Noise?
- Engine starting problems, and idle problems, need help
- PLEASE HELP!!! TRANSMISSION PROBLEM
- B16 shooting oil
- B18b in eg hatch overheats at idle
- Cold Air?
- d15b engine mounts for civic 95 ex
- Allow me to introduce myself...need ideas for my $100 95 Civic CX
- vtec problems, need help
- 99-00 climate control mounting?
- 92-95 EG Cluster help
- 95 shell with a B16A2 swap revs only to 4K rpm in neutral
- Need help! Possibly vac. Leak?
- how to remove quarter panel glass?
- Sending a Block to Benson's
- Can you refurb an exhaust system?
- so my ek coupe and my da integra are gone.fml...any one got a clean body ef sedan?...
- help wheel not centered
- 1994 civic has no power like half the power it should have
- D16Z6 turbo problem
- question about MPGs 92-95 vx/si
- ac charge and fail....
- Do automatic engine/tranny swaps exist?
- 99 Civic bogging down please help!!
- Can't Get Into Trunk
- D15b bearing
- 1995 civic steering question
- Gauge cluster is dim at idle
- t body issues
- speedo opinions
- 06 rsx seats in my del sol.
- CAR GOT BROKEN INTO, CLIMATE CONTROL WAS STOLEN NOW CAR WONT START
- 99' civic cx oil pump.
- 99 SI throwing CEL P0139, Insight needed.
- H22a Cat question
- D16y5 issues trip'd codes! Smoke! rough idle!
- start up problem on d15b
- brake swap
- 99 civic 2 wire iacv plug to 3 wire plug conversion help
- b16 cam studs?? help
- Eg power window conversion ????
- b16 blowing oil
- need some help with gsr swap
- F20c in ej1 need help!!!
- ef2 sedan bumper vrs usdm sedan bumper
- 93 Si Hatch Back up fuse weirdness
- Do i need a relay for my kill switch?
- 99 Civic - Should I swap my rear trailer bushings?
- 93 si hatch sunroof problems
- EG Hatch Wont Start **
- Momo Hub Help
- Do I have this concept right???(Push button start)
- at a loss...radio and cig lighter electrical problems
- P2P-??? ecu whats after dash?
- 2000 civic no start
- NAME this part plz
- Detailed Power Steering Loop Discussion (Longevity)?
- HELP, crank no start!!!!
- put new clutch in 97 civic and now it shakes in 2nd
- Cold air intake advice
- fuse block question
- NEVER buy a Civic Vx catalytic converter from Bosal!
- Engine harness Grommet
- '94 Del Sol is squatting in the back.
- 93-95 Civic EX coupe :Pic or diagram request
- 1996 Honda Civic Ex Sedan LCA Question
- Start of a MiniMe build. Experts needed
- 98 Civic stiff brakes?
- Installing Cruise Control
- Help STEERING PROBLEM
- need help with B20 Vtec
- Manual P2P on Converted EK
- 99 Civic DX 4dr - Radio install: Wiring Harness Question
- b16 blown head??
- 94 civic ex temp guage giving false reading?
- A/C Compressor Swap Question
- Help: *98 Civic B18C...what is it...wrong ecu?*
- aftermarket mirror options for 96-00 ek's
- VTEC engagment & Bogging each time @ lower RPM
- 95 civic hatchback DOME LIGHT
- SMOG questions for Cali ppl
- One of my IACV hoses is cut
