View Full Version : Honda Civic / Del Sol (1992 - 2000)
- opinions on itr bar and beaks kit for EK chassis
- civic rear hub work with integra spindles?
- Rear fog.
- oil preasure gauge
- paint ?
- horn doesn't work
- 92-95 JDM EG6 gauge cluster lighting problems... wiring? What. Help me out.
- Not a main relay, what else could it be?
- So now my gauge cluster doesnt work, help por favor
- 99/00 ek conversion
- How to clean my rims????
- oil on spark plugs
- ls swap into an ek
- del sol aux light question
- Looking for MPH window switch...
- A/C Drain Tube - WHERE? PICS PLEASE (air Condition , Leaks , Water , Passenger)
- Clutch noise on 99 si help
- 96-00 civic motor mounts
- harness question
- Free Headlights!!
- calling all jdm megan header user..what/where donut gasket????
- EG Exhaust
- which motor mount inserts do I buy?
- spark plug crush washer question
- which oem full radiator fits into 99-00 civic?
- radio code?
- exhuast Hangers
- Can I BAR This?
- replacing wheel stud
- DIY: Install Front Tow Hook
- where can i get a rear SI endlink-to-LCA bolt
- 93 door panels
- EJ wont start. HELP
- B20b taking place of b16
- quick manifold question!!??
- ignitor replacement
- Civic Coupe rim offset question...
- Crankshft Woodruff keys
- Front mount intake
- crap someone help me please :{ :{!!!! QUICK!
- noob
- Converting EX HU into amber
- wtb: hx, ls, gsr blades, rotas in 909
- help z6 nos dry kit
- Question about Eg Exhaust...i want a Exhaust but not LOUD one..smooth sound..any idea ?
- gsr sputtering and dieing
- **New rotors and pads for 96 spec itr 4X114 lug conversion?????
- Need help finding non-pro skunk2 intake manifold
- question about decking
- 92 eg with full gsr set up FOR SALE...4500
- Engine replacement, where to rent hoist?
- Rear disc conversion help
- EG wont start help!
- pilot bearing and release bearing
- Way to remove outer tie rod end WITHOUT ripping boot.
- ls vtec conversion
- whats the best set of cams for the price?
- Governor Q?
- ecu..
- Itr eater- This is it. What do you think?
- Civic/Del Sol Chassis difference
- motor can't go into car
- 4 door eg body parts
- Ne1 know how to diable the SRS light. Without unpluggin/harness/bulb?
- Need a lil clarification.
- EG and DC exhaust?
- Cel 21 .... Help please
- Pilot bearing won't fit tranny input shaft
- del sol interior
- 99 SI tailights fit 96 EX??
- JDM 4-lug Type R Wheels & Suspension???
- Foglights
- I Need Help finding an OBD-II dx or ex engine in AZ!!!
- Loud obnoxious squeaking sound...
- EG Mudguards with EK Sideskirts??
- Help power windows in an EG sedan?
- The car Cranks, but doesnt want to turn over (need help quick)
- 92-95 eg hatch mudflaps
- Question about my 99Si....Why would v-tec not kick in.
- Question is a 96 civic hood latch the same as a 99 civic hood latch?
- z6 oil pan fit a y8?
- Installing Hx rims on a civic ex
- swap
- Where to find a clean honda??!!! Its so hard!
- flywheel and flywheel bolts
- gsr del sol problems....
- gsr specs
- NEED TO RAISE MY CIVIC!!! HELP!!!!!
- 95 coupe catback exhaust question...
- i went to get my car inspected and they said i need new struts
- pr4 obd0 ecu?
- Turbo Setup Questions..
- no air flow on hot?!?!?
- engine hoist
- replacing headers and cat question
- final drive D-Series for tranny?
- question four door owner pls help....
- difference between 94 del sol si and 94 coupe ex front brakes?
- JDM d15b into del sol(mounts)
- (SRS) LIGHT ON
- Iacv wire colors?
- could it Fit
- D SERIES CAM
- exhaust problems
- Cruise control in a DX hatch.
- WARNING DO NOT ATTEMPT TO HELP THIS PERSON!! SCAMM!
- Oil pressure sensor / Obd2 / Greddy Informeter question
- rear sway bar END LINK BOLT broken in LCA. WTF?
- Battery shorted ~ replace or can recharge ?
- cleaning engine bay
- d15 n d16 ?
- car wont start please help d16z6
- Cars Overheating
- 94 civic dx rotors....same size as crx si rotors?
- Which motor for my car? (92` CX)
- Noise from water pump area!!
- Need SRS Flashing Code List. -Please post. "Searched"
- INTAKE for ek vs EX
- RELIABILITY of stock internals
- Question about suspension for 96-00 civics....
- Uh oh noise...
- what is a JDM Soshinoya badge?
- 94 Civic VX (1500)
- casting codes...
- skunk2 chip
- 94 civic vx hatch pulls left after axle replacement
- leaking tranny??
- HT Site Question
- Doors
- I have a fuel pump problem need help!!!
- help on 99 si
- Anyone know where i can download.....
- d16y8 into eg si
- injector ????
- Fitting OEM hid's into Ek Civic headlights
- '89 Civic Wont Start: Fuel Pump? Is there a fuse?!
- es motor mount inserts
- help on my coupe 93!
- i am an impatient noob...
- Thrown Rod Bearing ? How do I fix that problem ?
- taking apart headlights?
- Problem with my CKF
- rims wont go on wheelstud fully.. need extended wheelstuds.. where do i get them?
- Tranny Grinding (searched)
- 94' CIVIC NO A/C PUTTING IN A/C help!!
- honda civic filter
- tint help
- spraying carb cleaner in egr valve to clean
- Assorted EK body parts questions
- Honda Civic - Car locked, remote does not unlock it - Help
- Need help..
- Intake
- Shift linkage question
- 98 civic Tein spring question
- EG Harness Question
- Ok this shipping crap is confusing.
- Switching to right-hand drive..???
- rear disc conversion for 99ex
- POA ECU in z6?
- iacv wiring!!! need help!!!
- is this a GSR or SI sway bar? help please!
- How to clean a transmission?
- Removing/Reinstalling Air Conditioning...
- idle problem
- 99 Si, sometimes won't shift into reverse?
- detachable EK9 steering wheel
- S1/J1 Transmission weighs 110lbs?
- l how to clean muck off my headlights
- ? how to polish up our acura rims sawblades si rims? how to do you do it what is the easiest way??
- ls with b16 tranny?
- I'm sad. Water in Spark chambers and.... help! -searched-
- Extremely rough cold starting..
- wheres a good site to buy affordable engine mods? (dont say ebay)
- Manual Transmission "Flush"
- 92 si hatch for sale: pix. nashville area
- side skirt clips for the eg
- flywheel bolts
- searched and searched... knock sensor cel wont go away.
- Installed new Clutch Master Cylinder no pressure...
- will bad gas make your motor nock?
- turbo or swap?
- Change seat for more head clearance
- 95' DX, no underdash fuse panel, cant find illumination, HELP!!!
- civic del sol
- Srs light stuck on after integra dash swap. "Searched"
- exhaust manifold question
- odb2 b18b wiring in a 96 dx hatch
- looking to buy a 99-00 si cluster
- Some things that make me cry
- HELP !!!!! i have a tire problem
- SOHC4life 96 can suck my dick
- Idle problems
- Does anybody know the mm size of 99 si front rotors??
- d series swap help
- Tire Pressure
- is a po5 ecu vtec ?
- integra brakes on del sol
- Had Injectors pro. cleaned and now cel?
- atdoes honda's have a battery relay?
- bolts for flywheel and exahust manifold
- Downshifting gears? personal techniques?
- how to "clean" an engine apart
- oil sending unit
- code10.1
- Car is chuggy...
- REWARD 1994 Honda Civic STOLEN VIN# 2HGEJ1129RH001411 Troy, MI REWARD
- B16 95 Civic LX. Shift linkage a little loose. Cause shift problem??
- "The Shake"
- Couple of questions??
- Longblocks....where
- what kind of internals should i get
- Shift fork squeaks
- 4 Door EG Civic 4WD?
- this aint right
- TRANNY PROBS...
- Knock sensor
- A site like Honda Auto Motive parts that accepts paypal?
- exhaust question
- DIY: 92-95 H.O.P. Window Visor installation
- s2000 seats install problem
- Brakes Soft...
- FS/T: CIVIC EX JDM K20A Type R
- throwout bearing
- 92-95 Eg Civic Hb Integra Dash install. Went good,
- vtec pressure switch?
- long block??????
- Quick question....EG exhaust
- cheap upgrades
- progress sway bar on 99 ek
- VTEConfused?
- I need a turbo idea please
- Pulling a motor outta the junkyard?
- gsr motor
- Nitrous question for d16's
- disc brake upgrade
- Idle problems on my eg
- Doors, I need doors!!!
- Problem with my car starting... HELP!
- Installing new radio, first car.
- 98 Civic EX Cp Driver Door Electric vs Manual
- what car is llighter stock?
- Alignment on 98 lowered Civic Coupe
- Sensor Help ASAP!!!!
- Swaping my 98 Civic
- B18B1 in 96 CX Questions
- poor man type r
- b16a swap need opinions
- help with cluster
- spoon plug wires?
