View Full Version : Honda Civic / Del Sol (1992 - 2000)
- d15b ?'s
- Help.. My beater is acting weird
- What kind of lip do you have?
- Need to know: how to mount teg center console in EG with GSR Dash?
- Swaps alrdy sooped up?
- civic price check
- Can I use an engine from a 02 civic si in my 95 civic ex?
- Tranny swap: y7 > y8 gear pops out of 2nd?
- how to install 99-00 fog lights ( not electrical part )
- 3rd gear sound
- CKP code 4!!! Help asap please!
- Aww crap... broke a valve cover nut... question
- For the EK4 and DC2 people out there who replaced there shifter
- Wheel Bearings
- CTR short block for sale!!!!!!!!!!!!!!
- What type of engine?
- need help
- whats a good tire size
- WTF, I Have to Put New Brake Fluid Every 3 days!!! HELP...
- Window Pain
- How many EG's using cable trannys on here...comments?
- very quick questions
- please help: vtec question
- Check engine light came on
- Does D16z6 Oil pan fit on D15 motors?????????????? NEED FAST CONFIRMATION
- Window weld mtr mount questions please help
- can someone please tell me all the parts i need for a swap!!!!
- Krylon stain glass pain?
- Anyone else having a problem ordering Autozone Axles?
- White Spark Plug on b16a
- How to distinguish between GSR/EX/Si Brakes?
- 95 delsol with jdm b16a gsr hydro lsd. Should i change tranny to diff spec????
- where to buy new starter/dizzy/alt for cheap?
- anti sway bars
- subframe damage
- Code 10
- tuning turbo help
- help me with hood?
- Alignement for a drop suspension
- d15 o2 sensor
- b&m vs. skunk2 short shifter
- Skunk 2 Intake manifold Gas leak... problem
- B16A2 HEAD
- Broken and Stripped Mount Holes - Can this be fixed?
- 2000 Civic Mid Pipe...
- Tein springs
- Distributor problems on my d15b any ideas
- Power loss?
- Dropzone Coilovers worth the money or not?
- Compression Test
- Need to know what I need for a gsr swap in a 90 dx hatch
- vtec wont kick in
- how do you know when a b18c is a jdm or not?
- distributer question
- What type of tranny fluid for B16A with LSD tranny?
- 94 DX--Want Cruise Control--how easy is the install??????
- where can i get fogs like this,... ??
- Rear drum adjustment
- How do i change my valve seals.
- honda parts
- my car squeaks with every little bump
- Pic Request: NR Auto Overlays
- d15b7 with a td04
- p0505 after head gasket replaced....
- coolant question
- b16a specs
- ATTN: Red EK Hatch STOLEN last night, Hoboken NJ.
- HELP HELP HELP........00 si b16a2 into 98 hatchback..
- location of ecu in civic EX 5sp '92 (after reading faq!)
- headlights dim when i hit the brake
- tranny has trouble shifting.
- which tires to get
- exhaust prob!!!!
- D16Y8 TO B16A1
- hehe
- What motor oil do YOU use?
- have this problem?
- skunk2 camber kit for EK
- Y8 camshaft in Z6 ???
- Ek sideskirts on a Ej
- jdm b16
- HELP!!!!!!
- whats better
- how to tell if ecu is manual or automatic by part number?
- installing msd?
- Is Hasport Brackets for K20EG strong enough for turbo application.
- k20eg :hasport brackets
- SHaving roof gutters
- Header Talk
- is this auto or 5spd?
- Timing Belt Cover, which one???
- recall alerts
- front bumpers
- b18 header for swap
- ??Running lean???
- corner light problem
- Brake help rear discs
- problems with engine :( please help
- can this be poped out ?
- After.....coming back from the Service store
- Beeping noise
- Prelude Seats and 96 Civic EX Coupe
- Car running through coolant, can't find leak....
- i want to paint my rims............
- Blinker Problems....and Other Q's..
- bad gas pedal vibration
- need help finding
- How much louder is a test pipe over a resonated test pipe?
- Does anyone have the JDM EK Civic headlights part number.
- Just bought a new car!!!!
- times at osceola dragway in elkart indiana slightly modded 93 cx
- getting ready to install shocks/springs...
- DIY Rear Lower Tie Bar
- tranny problems
- del sol front bumper 1996-97
- curses, rod knocking
- suspension help
- axle trouble, need help.
- New gasket
- bushing help
- (-) trunk pin or trunk trigger were?
- anyone got the Momo ACROPOLIS seat in heir EG?
- valve lash?
- removed ac now my car wont run???
- o2 faker
- Car vibrates badly... shocks, motormounts or axles?
- Check engine light; 97 hx
- Civic RIP
- Total JDM Motors
- New to Honda
- Idle Air Control Valve ERROR Code 14??PLEASE HELP....
- wilwood brakes
- what ur 1/4 mile time slip?
- High beam wont work...
- Climate control light not on, need to know what wire it is
- How much do you pay for alignment/SoCal shop recommendation?
- leaking gas....
- IAT Sensor (Intake Air Temperature)???
- Crx DC header on EG???
- where to get a gsr motor?
- the (+) e-brake wire?
- Wiring Problems
- HX Tranny swap?
- what type of gas do you use??
- CV joint starting to go... how much? do you think.
- Z6 head Y7 block what head bolts use?
- body kits
- cx/dx differences EK
- Changing all 4 tires?
- Question about CoilOver for 00 Civic
- Valid site?
- MILLING A D16y8 HEAD
- Ef Owner with a Question for a Friend
- what year is my motor?
- For people who installed the C's short shifter
- intake manifold questions
- Anyone up for a Korbach Frame Locks Groupbuy??
- 97 Civic timing light help ?
- heater core
- amber clock
- putin on catalytic converter for 92 civic hatch
- what kind of mounts do you use to put a 94 gsr into a 93 DX hatch
- Newbie! Hiya guys! Getting my Del Sol this week...
- Anyone using a Crowr stafe 2 Turbo cam???
- help needed with swap
- wiring issue
- What rim offset would be ideal with Spoon coilovers?
- car idling very low, missing a little, timing maybe? help please
- need help making decision...
- 99 EX side mirrors
- moving to SoCal..Help me with bar???
- Paint help
- brake light remains on....
- suspension question
- water channels on hood running black stuff on my paint...
- oem radiator support or ebay radiator support
- steering arm?
- Ebay dual gauge bezels...better or worse than Autometer?
- 2.5 in. down pipe to 2.2 in. axel back?
- throttle crazy when car not moving.
- 94 civic ex with B18C1 swap
- civic short shifter
- 99 DX OEM parts
- wetsanding paint?
- whats necesary for the y8 mani. swap on a d15b vtec
- Short Shifter
- si cluster on ek's
- Eibach Sportline Springs?
- valve ticking
- How can I make my exhaust not sound so loud?
- New kid on the D16 block
- what radiator for an h22 94 civic
- Need sum help on stock redline?
- D16Z6 timing issues? Need help.
- FBP EM1 getting her back after 3 months
- Spark plug gap?
- B16 EXHAUST PIPPING
- Y8 in a VX????
- Headlight and Idle Problems
- Loss of power at low RPM, random miss 97 civic ex
- SoCal Emissions?
- Lowering Question
- Are all 94+ integra spindals/hubs the same?
- need some help about 6th gen Civic cluster
- Teg full size radiator + A/C in a 5th gen???
- which short shifter better
- Valentine 1 Remote Display Custom Install Write-Up
- removing ecu question
- Do manual eg folding mirrors fit on an ek?
- Spoon N1 Muffler..pics
- B series TB on D16 problem
- Getting ready to buy another Honda but I have been out of the scene a little while and have a few ??
- look for old jdm post
- AC Compressor Bracket
- oem front lip hardware
- D16y8 Intake Manifold that is missing some parts, can I use parts off my z6 IM?
- higher reving cam ?
- Brake Info
- Coilover Kits
- 96 civic hatch... wats good shift point?!?!?
- Evap Purge Valve
- Best way to quickly prep stripped engine bay for paint?
- d16 w/nitrous 1/4 mile time
- Noob Question, what is EG, EK and are there any other letters i should know?
- 00 Si Dash into a 00 DX, From Tan to Black, 2 door to 4 door parts
- Which OTHER shocks fit onto a 94 Civic Ex?
- cost of d16z6
- LS swap in to a EG?
- Omnipower Drag Coilovers, who has em?
- Cheap Headers for a B16
- '00 Civic EX radio harness...
- d16z6 pcm harness
- ek rear disk ?
- starter question
- How much should I pay for a four door SIR eg cluster???
- FUEL RAIL QUESTION???
- Civic 04 Projector Headlights??
- D15b Eg quarter mile
- need help 2
- my 95 cx won at nopi
- need help
- exhaust questions
- question about b20z
- car jacking at UCR
- 1/4 mile times 93 hatch with a 95 d16z6 slightly modded
- What is port matched? in terms of TB
- 95 ex motor
- Blew rod out of engine! Have a 97Ex D16Y8 can I use a D16Y7 Block?
- How Much Is My Car Worth????
- problem with iac valve
