View Full Version : Honda Civic / Del Sol (1992 - 2000)
- can i use accord parts to get a 4x113 bolt pattern
- Radio install trim?>>?????
- ebrake wont 'click'
- FYI - Cheap Parts
- auto to manual question
- How to measure and lower a car evenly
- which color wire..rear defroster button
- bargain or not?
- Crossed over to the Dark Side
- 2000 honda civic 4dr problem
- JDM tail lights
- E-BRAKE WONT DISINGAGE
- Can someone show me a pic of an Oil pump on a motor?
- (VA) need help w/ inspection
- Engine keeps cutting off on me need help!!!!
- header ? about d16y7
- delSOL pic request
- White Crow EG Bumper GROUP BUY!
- Backyard Special EK Bumper GROUP BUY!
- car fax request
- simplilist question ever...
- b16 grinds 2nd -> 3rd at 5000+ rpm
- so i open up the engine bay after the storm and....
- ls/vtec post already searched...
- d16z6 head into d15z1
- obd2-obd1....chipped p28
- B18c1 vs. B18c5
- How often does seafoam reccommend a cycle?
- Curious whether an exhaust header will my fit my sol
- What is the deal with PMs
- to bore an engine
- motor mount strength
- 92 si gas milage???
- List of traders/sellers on here?
- B20B swap?
- Apex n1 vs 5zigen fireball?
- Where can I find tech info on installing JDM FOgs?
- Hubcentric rings question
- Using EF shocks on your EG's when lowered.
- eg hatch front lip on 4 door.
- How important is it to use new gaskets during reassembly.
- Need a little help on this one, ecu chipping...
- 9 miles to gallon.. swapped cx.
- Jumpy Idle w/ Heater on?
- E-brake question
- Huge bent rim
- What kind of fluid do i put in my 93 d series manual trans
- civic ex stock intake questions
- Transmission Identification
- Geat FAQ write up
- Car shakes at 40mph +
- Throttle Position Sensor
- Window Problem NEED HELP!!!!!!!!
- Eg h22 axle question
- a/t swap d16z6 to d16y8 a/t
- oil changes and engine swaps
- axel help
- OBX, junk or decent?
- has anyone hoooked up edm fog lights in a del sol?
- Need your help QUICK please
- Down and out
- OEM STRUTS
- D16Y8 Headgasket.... Will it work on the D16Z6?
- How important is it to torque to specs
- bleeding sequence checked 4 sources, got 4 answers!
- h22 in EG HELP!!!!!!
- military guys
- Junk yard in socal area
- JDM Swap Info
- which wire harness to use for b16a swap into ek4?
- Spoon B16B engine questions
- help security code
- How do you join EG Squad??
- cluster problems help!!!
- PR3 Computer? Redlining at 7500?
- detachable steering wheel and SRS (searched)
- d15b swap questions?? new eg owner
- high compression b16a2 pass smog?
- Individual Throttle Body for my D16
- Steelies?
- direct fan wiring
- power windows and locks
- tips????
- Downtown Seattle/BainbridgeIsland/Poulsbo/Kitsap tuners/skilled amateurs
- monza/pacesetter and skunk2 del sol exhausts
- Optima battery
- zex/Comp cam 53900 People who have the cam !!!!
- Hondata head gasket......where to find one?
- Fmu Question?
- WTF? Blinking CEL?
- carfax help please?
- Y7-->Y8 mani swap, now surging idle?!
- Fitment of a DC2 Strut Bar onto an EG Chassis
- harness problem
- Question?? B18C1 with ctr pistons
- Tranny for sohc
- EK 99-00 SIR Headlights
- 94 civic vx
- Anyone with free carfax willing to help me out?
- Pic request: Please look
- discrepancy in mileage
- prep for painting 92 hatch
- NEW To EG's, Exhaust Bolt UP Questions for all EG hatchs with H22's
- DSM 450cc injector hookup
- transmission problem
- ball joint/control arm install help
- Vivid Blue Pearl
- JDM ITR swap in 92 si
- walbro fuel pump life, when should you change it out
- issues with snow cables on a lowered hatch
- Help...Replacing main harness in EJ1!!!
- Green/red & Green/white wires???
- Tenzo R Version 5 Steering Wheel cruise control?
- Civic/Integra radios?
- MY CAR WONT GO PAST 80 MPH ON THE FREEWAY ????
- Major problems, NEED HELP!!
- oil pressure gauge
- quick question
- b16a2 into 96 dx
- Question on 05 si seats
- Reliability issues with a Turbo?
- Engine bay...
- velocityshop.com?
- Trade or Not?? B20vtec hatch for a GSR
- Good source for EG Civic molding?
- best mounts?
- Quiet cat back exhaust
- tire + offset
- Vacuum Leak?
- How To: 92-96 Prelude Seats Into EG Hatch
- 00 SI springs 4 sale
- Wierd Electrical problem?
- SIR EG9 Amber Climate Control
- does anyone make an aftermarket starter?
- bent rotas need help
- Getting head milled and replacing headgasket, what else should I do?
- Heater Problem & it's darn COLD!
- hi... my car died
- Gas guage doesnt work.....help
- How to: window regulator install....Please help!!!
- B18C Cam on B16A Engine
- hondas
- 72,000 miles and threw a cel, car still runs fine?
- where to get eg6 fenders
- integra trailing arms for my 94 coupe... some help please.
- Advice on problem
- hand break on hill = weird noise?
- Bad axle question....(searched)
- Replacing Front Wheel Bearings on a 96-00 Civic
- What is the lowest you can go when getting springs/coilovers?
- NO VTEC
- *** Question: Master cylinder size is 1" for a 92-93 Integra WITH abs?? ***
- Help!
- need advice/info on insurance totaling out car
- Vtec and Vtec-e
- Anyone MISSING a beefed up civic with gsr in Michigan/Indiana area??
- automatic dx cluster
- 96-98 to 99-00 Civic front end conversion.
- Cruise control slow response
- need opinions on this radiator..please
- Runs fine then wont start
- Need Help ASAP: How to take off recliner handle GSR Cloth Seats
- ACURA EL PARTS: Seached.......(repost)
- Chipped p28 or p72 for GSR
- Hood......99-00 CF
- HELP!!! Question for my 92 Civic Si hatch
- tranny D16Z1(2) -> B16A1(2) possible?
- JDM D16Z6 engine with 140h.p.??
- Apexi-USA: need to repair my boost gauge
- Does anti-seize actually work?
- more b16a2 talk..
- lowering spring clamps?
- type r intake manifold into b16a3??????
- Seattle, Wa Honda meet
- Help on changing shocks
- new user - midnightgarage.ca represent.
- B16B DYNO RESULTS IN A 94 HATCH.
- JDM Sites?
- td04h turbo from a civic greddy turbo kit for sale
- b16 with cx radiator? is that fine?
- Will integra exhaust fit on EJ Coupe?
- B&M O-ring
- Where can i get an Intake for my D15 in my 92 CX HATCH?
- gas door
- How do i convert Auto to Manual???
- car bounces when start help!
- what would you recomend for a stripped head bolt?
- clearance issues with TWM itbs in an EK
- B18B1 in a 92-95 civic hatch back. PLEASE HELP!
- Brake Problems
- throttle body
- JDM D15 V-tec engine code?
- b16 guys post your gas mileage
- Replacing pistion rings on 99 SI
- cruise control
- jdm-usdm
- Axel bolt stripped....need help
- Gauge Cluster Question, Help
- dx 1/4 mile times
- wheel won't spin freely-e brake feels like it has no pressure
- LIP!!!!!!!!!!!
- *OFFICIAL* What does your Del Sol run?
- Anyone buy a rear disc sonversion from hmo
- Whats the STIG ? help please. lsvtec bogs until 3000 rpms...
- Easiest way to get rid of stained water spots?
- JDM EK9 retractable mirrors and compatibility issues
- jdm d16 have anyone had any experience?
- what headers do u perfer for sohc v
- curbed rims...
- 00 civic SIR turbo or super charger?¿
- ECU for a 96 civic lx
- b16a1 into eg civic
- Short ram
- 99-00 Civic Si Cluster Wiring for 93 Civic CX Hatchback??
- can i P2E be wired for vtec
- shocks on my "on" my hatch
- Wicked Tuning
- how do you take off the axel?
- Si tranny verification
- b20b and b20z
- POSTING
- enjo upper mount
- Civic W/H22 Videos
- Civic front end damage
- hondata
- HELP with wire diagram for a 00 LS cluster
- Request! D15b manifold shots- (or z6)
- obd1 restior box how to wire
- Is there supposed to be a bolt here? (pics)
- Question about cooling fan...
- ok, so the cat converter is attached to the header..
- Picked up a po6 for a b18b today and have a question...
- b16a2 won't start, STUMPED! began with spark plug popping off [experts test ur skills]
- mounting plates question
- what size socket to use to remove spark plugs?
- measuring height of car?
- Numbers
- please help my dx
- EK Transmissions Questions
- h22-eg coupe
- gummed up head ? (black crusty shit)
- EG with gsr swap smog?
- Rod bearings for LS/Vtec which company any links for real strong ones..
- Fuel pump questions
- replacing z6 valves
- d16z6 question i searched but couldn't find
- 00 Civic Si Seats in an 93 Hatch EG help
- i guess my fuel lines are frozen?? wont start
- 92-95 civic Autometer gauge cluster...?? F/S???
