View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Trunk Box?
- d16y8 head
- Horrible squeak wont go away!!!
- Anyone riding on Tein Coils all the way down?
- j's racing intake
- Quick I need help/advice
- exhaust/downpipe question
- !help! - 2003 civic ex - windows dont work - fuse diagram??
- 96-00 rear speakers, THE EASY WAY
- throttle cable?? and skunk 2 mani Q???
- trial user
- help
- B16ASiR2 turbo vs. B18C
- has anybody's seat ever started to break through the bottom of your car
- Lots of questions reguarding a d16a6 into a 95 hatch CX
- anybody tired 32 offset before?
- seats for my del sol
- i got water in the engine plz help
- What lip do i have
- charging porblem? 99 civic LX
- is it my head gasket???
- best roll cage for eg. anyone have pics or know of brands
- Difference in spark plugs
- Brake Kit For Si
- Which one????
- h4 6k hid kit in a projector housing from ebay?
- Question about a header on a 97' Civic DX
- Which Intake manifold? AEBS or Type R...
- HELP.. car is making a new noise
- A/C Question
- took off wheel, now heavy clunking??
- need new valvecover gasket?
- D15 for free with 155kmi. WHat would you do with it?
- B18 Tranny
- Endless SSS brake pad (w/ Integra brake conversion) on an EG review
- 90 LS REBUILD (swap for my civic)
- Water in headlight housing
- auto transmission
- VTEC SYSTEM MALFUNCTION???? HELP
- Bad idleing please help
- suspension for my 96 ek....need help
- self adjuster on the drum brake not working!!
- harness questions??
- ***LCA Question***
- fuel pressure check problem
- 99 or 00 civic si
- http://www.freeiPods.com/default.aspx?referer=7334371
- What do i need? Help!
- What Cold Air Intake for EG with a B16?
- Help with intake manifold coolant hoses.
- What to do with A/C wiring?
- HELP! Changing OBD2 Altenator PLug to OBD1 Wiring?!?!?!?!
- b18c into eg
- ECU Question. Urgent Help!!!
- what do u use for your tranny fluid?
- need a 96-98 civic trunk lid, factory dark green if possible
- 95 Prelude seats in 97 EK (searched but no good instructions)
- where are Cruise control buttons on eg civics and CTRs?
- No Sprak!! Dead Dizzy?? Rotor Screw??
- 01-03/04 hoods
- MOMO Steering Wheel Hub Removal
- h4 to 9006??
- Question about a head?
- d16z6 Cam Install question
- '96 Civic EX Coupe Auto Wiring Harness
- EK auto tranny in a EG auto (i seached and went though all 188 post)
- HELP what should my next upgrade be?
- Is there a HOW TO on EK trunk light???????????????
- Low Fuel Light....
- 2dr bumper on 4dr w/ pics.And a quick question.
- 99 SI exhaust fit 99 ex?
- installing itr piston in b16
- just blew my engine
- grrr... car wont go into gear!
- ECU tech gurus
- Where did you all mount your MSD Blaster SS coils?
- Diagram with exact wire colors needed for Conector C446
- just got a new hb have a question??
- does anyone know if this will work?
- 98 ek speedo & rpm problem
- TB swap confusion!
- Kumho Ecsta ASX tires...feedback needed
- Airbag (SRS) Computer Needed....
- IS THIS TIRE MOUNTED BACKWARDS?
- What bulbs for oem 99-00 fogs
- BIG PROBLEM!!!!!
- My idle is weird
- Switching to synthetic oil
- ZC Parts
- Turbo with NOS
- Good machine shop in chago for ball joint pressing
- Anyone here driving an EM2?
- gsr swap on ek hatch?
- I'm not convinced when it comes to Redline oil.
- another piston question
- Beaks kit with lower tie bar vs asr ek reinforcement kit
- What tire size?
- Where to buy just one Tokico front shock?
- SOHC ZC
- Brake Part #/compatability Q
- teg seats in a ek
- B20/VTEC - Turbo Lag
- Tein RS - 92 Hatch
- del sol floor brace
- where to set v-tec
- just want to point out another place thats bad at business
- Suspension setup question
- Removing clocks from 94 Del Sol
- valve clearance honda civic D14A3 1997
- CTR WITH ROUGH IDLING
- D16y7 with Z6 head?
- wont start, no power
- N1 exhaust for 95 ex?
- anyone rubbing with a 42mm offset?
- My Civic-95 got stolen yesterday
- Transmission help
- why did my new cat go bad so fast?
- d16z6 what to do
- hesitation at certain times
- will the back seats from a coupe work in a hb
- Ek with b series - Tein ss better spring rates?
- What coilovers should I get?
- b18b swap tranny mount
- How to get rid of code 15?
- Surging Idle WTF Gives.
- EH2 Hatch Leaking
- Has anyone tried BG sychroshift II?
- scratchy noise from A/C in del slow...
- civic ex parts
- test pipe gaskets.
- Can I swap entire engine & tranny 5-speed to an automatic wih engine??
- emission station here in NJ
- Can you buy the cushion for del sol seats?
- Charging system, battery charging/drain problem.
- help with newly boosted eg
- FJO WB + more - look inside
- Swapping trannys....
- Changing ECUs....
- weird whine when clutch is not pressed
- 19 Automatic transmission lockup control valve
- A/C Compressor the same on 90 and 95 b16a?
- LX vs CX: which to buy?
- CTR Rear Lip (Mounting Hardware)
- Cam Cover
- Test pipes
- ignalls front camberkit - - questions
- Rattling Belt?
- Valve Adjustment??
- wanted: 89 civic dx sedan passenger side axle
- jdm dc2 side marker template
- Could it just be the ecu? All sensors/wiring is good. Still codes.
- O2 sensor wiring help
- HeadLight Harness Questions.....
- What Shocks/Struts Is Everybody Running With Their S-Tech Springs?
- ECU question.
- No VTEC...help!!!
- car making wierd noises when is warmed up? help
- So the shop says I need $645... please advice!
- Start-up Problems
- intake filter shape?
- should this give me 20 whp?
- Transmission Fitting
- b20vtec swap with codes: what it means??? ASAP
- how much whp does a stock d16z have?
- help me!!
- Where can I get these head lights?
- EG momo steering wheel hub info need'd
- Problem after changing input shaft bearing
- Sway bar plus Jimfab crossmember.
- The debate continues..D16A..I have pics!!
- need advice (asap)
- Steering issue.
- Water on the BRAIN.
- Codes 3,21,22,23 are coming up. Check Engine HELP !!!!!!!!!!!
- b20vtec question
- Will this fit in my car
- usdm vs canadian gauge cluster
- really hyper blinker...
- honda herpes
- how hard is this to fix?
- Noise coming from the rear part of my car
- Fuse Diagrams for 93 civic HB
- Recommended brand for cap/rotor/plugs/plug wires?
- Paint Color Website
- Help Needed
- refilling freon
- Stuck spark plug finally came out thanks to PB penetrating solvent.
- a few confused questions before i start my gsr swap???
- 92 civic not firing
- eg power window conversion
- Turbo on a stock civic
- installing speakers on a 2004 civic
- HVAC Control help?
- af guage
- coilover install problem
- ball joint press
- GPS tracking I plan on getting
- Seats
- White EG hatch on Rota's in Lake Oswego, OR with HT sticker.....
- Do Short Shifters need a "break-in" period?
- Harmonic balancer?
- New header, now check engine light is on...
- Brake Component Install: Possible in steps?
- air conditioner problem with 1999 civic sedan lx
- HID General Install Question (WIring Related)
- ITR rear sway bar on an EG
- 97 coupe with 2000 si swap problems??
- EM2 Throttle body replacement
- Loud clicking/banging from tranny...
- how much is my hatch worth???????
- sparco torino's, how low do they sit?
- more o2 sensor qeustions.
- Turbo Bolt On
- [HELP] my delsol SIR wont start.
- my headlights
- Need help from ppl for a swap in NJ NYC area
- Car Judder
- Rough idle...
- What exhaust for my CX Hatch?
- What size tires on my CX?
- civic models and engines
- 96+ experts! teach me what fits
- Igntion Problem? Engine Problem? what the hell
- short Shifter Problem
- Defective ACT Pressure Plate?? Did I get a Lemon?
- Missing PLATE
- new battery = erratic idle
- Honda access EK column light
- Install Price opinion
- Power Antenna
- >>>>>> MUFFLER CLAMP/HANGER <<<<<< HELP!
- Optimizing timing B16a2
- What is this part called and what does it do?
- electrical problems?
- problem with fluidyne cap?
- Overheating!!
- project boosted purple coupe
- what causes hot spots on the flywheel?
- 96 Civic D16Y7 A/T engine swap
- Did I buy the correct brake fluid?
- Testing a TPS.. stupid question alert
- Question about 92-95 headlights
- S2k Antenna
- just got my new jdm sirII motor
- If my pistons were in backwards?????
- cylinder wall scratch!??!!
- 94 civic EX tranny swap (98 tranny) now linkage feels off? 5th gear almost impossible
- WTF?? idle problem....
- OEM Fuel Filter
- swapping throttle bodys??
