View Full Version : Honda Civic / Del Sol (1992 - 2000)
- rear suspension ???
- Valve lash and spark plug gap?
- Engine looses power about 6500rpm?
- obd1 gsr swap into 97 ek. had a code 10, fixed it, now getting a code 6?? help me out guys
- how to tell if i need a new head or not
- F20C swapped EG?? wtf? I didnt think it was possible
- b16a2 valve lash
- Bent my front frame :|
- CHENCK ENGINE LIGHT
- H22 with d15 ECU temporary?
- brake light question
- Brembo GT Brake question
- replaced tstat, lower hose cold, wtf? b16a in 96 civic
- Idea for del sol top seal repair.
- TB Does not Line up with IM?
- Door Panels
- Vtec but no power
- EG and EK tranny question...
- [How-To] Install Heel Toe Jimmy Jammer
- 98 Civic HB CX aftermarket exhaust issue
- 93 civic dx lower control arm bushings
- carfax..
- Bottom end Turbo build d16y8
- WHAT ENGINES ARE A ALMOST DIRECT BOLT IN FOR A 1994 CIVIC CX?
- Prelude Discs on EG?
- 93 civic have a cabin filter?
- switching gears
- Anyone know the flow rate of the d15b7 injectors... was wondering if they were 240cc
- D-series EK clutch fits a EG?
- IACV Cleanout
- stolen 93 civic hatch nor/cal richmond 10/11/07
- B18C problems
- AWD CIVIC??? CALL ME CRAZY!!!
- B16 and D16 series fuel pumps
- buying brakes...
- turbo vs all motor?
- I got a V-tech head for free but I dont know what kind of head is,
- HELP ME OUT ! my car wont start!
- Does DC2R muffler fit EK Civic?
- Buying a civic
- i need help regarding my seibon CF hood.
- threw a code 41 oxygen sensor heater
- MAP Senso
- squick sound
- 1995 Civic Vs 1992 honda Accord
- Throttle Body HELP!
- iac valve
- Attention UK Honda-tech members
- del sol front end questions
- Need a COMPLETE turbo kit for my eg coupe with d16z6 engine anyone knows where i can find one???
- pulling A/C belt off
- 92 VX o2 wiring help needed for my swap
- Busted Radiator Throwing CEL Codes?
- intake manifold question
- Motor Mount
- d16z6 blown head gasket what else to do when in there
- best swap for 97' civic ex
- Keeping AC with turbo DOHC ZC EK (or D)
- question about buying an 99 ex coupe
- Climate Controls Cover?
- motor rebuild.
- weird sound
- gsr ek... axle problems.. HELPP!!!!
- Oil in Coolent, Need some advice.
- HELP! VTEC head???
- Torque specs for header?
- Noise coming from t-belt. Open cover
- will this clutch fit?
- 96-00 axle back system will it fit?
- need help been searching !
- Whip Factory in plainfeild IL?!?!?!
- Raceline Import Tuning
- need sohc help!!
- code 43 help - stock EG8 sedan
- IAT sensor melted...where can i get a new one
- Broke the DAMN bolts! HELP
- CEL CODE????
- Question about JDM power folding mirrors?
- reverse neutral switch question
- INSTALLING HEADERS...
- Quick Question? Nuespeed Race springs or Skunk 2/Omni slip on coilovers?
- Question on bushing kit
- my 00 ek9 is stock! In engine
- Turbo Question
- Key fob for 2000 EX How to????
- a exhaust question
- IM HAVING HARNESS PROBLEM'S ANYONE HELP!!!
- Door Panels?
- valve clearance info help please asap
- what steering wheel options do i have?
- motor mount problem
- Clutch Plate Reuseable? and How to Identify Clutch Plate for what Car?
- Which to get: Brembo Rotors or Generic Rotors? Q. about rear drums
- h22 into hatch?
- EG Hatchback Rear Seat Fitment.
- b18 turbo swap
- if knock sensor is broke what will the car do?
- B20 in Ek... Questions??
- b16 swap?
- 4 door EK tweeters
- y8 shortblock
- 98 EX Electrical Problem
- Pulled code 65: suggestions?
- is this right? part identification
- HeadGasket & exost manifold missing bolt question
- 300 hp with stock fuel pump, will fine??
- Six speed transmission
- Help gsr sputtering problem
- Charging system BS
- Does Da rear disk brakes Fit on an EK/EJ6?!
- Another Overheating Problem
- help, B16
- stumped
- Clean Engine?
- alcohol injection
- Fuel pump fuse/main relay problem !!!
- 96 auto civic dx stutters and check engine light any suggestions???
- help diagnose rear suspension problem
- How To Make Gauges Light Up
- alternator wiring problems PLEASE HELP
- jdm eg9 corner light question
- slow starter
- 2000 civic si engine swap question
- apexi n1 exhaust
- question about burning Gas in my car....please HELP...
- 99 civic steering wheel question
- Interior Color Options?
- B16a2 (SiRII) bolt ons
- Vtec problem?
- D16 Radiator on a GSR
- Type R cams????... searched ..
- H22 Swap Starter problem
- Throttle Cable/Vibration
- Civic w/GSR exhaust question
- high mileage engine
- A little sparkplug change problem
- B16a2 (SiR2)
- 98 civic ex..NEED HELP
- Damaged h balancer
- 92 DX coupe speddo is bouncing like crazy
- mini me problems
- Code 67 Catalytic Converter
- Changin suspension..neeed thoughts of tein vs skunk 2
- Can rear Si Seats fit 97 Hatch?
- Engine Problem...Car stumbles/bogs out
- H23A DOHC VTEC into EG?
- When replacing manual steering rack.
- skunk2 springs on a 96 ek
- Questions on quick release
- B16A2 head torque.
- Quick question
- OBD2B Y7 TO OBD2A GSR WIRING ISSUES!!!
- battery light on all the time?
- H2B costs (searched)
- mirror compatibility 00 sedan
- center consol question 95 hatch
- AEBS TB's Q
- does anybody have a pic of a white EG on 96spec r wheels
- need Some help..very important
- thinking about getting an ebay 65mm TB ? any concerns
- d16z6 stuttering acceleration
- car idles funny
- Shocks and springs?
- D15b7 performance?
- H22A intake manifold problem....
- 92 civic hatch. map sensor witch hose goes to mani and witch goes to the black thinggy.??
- Y8 Vtec Pressure sensor questions...
- Real quick question.
- Civic Exhaust. Opinions greatly appreciated...
- weird tranny grind, only grinds when engine warm? help
- Please Help me out guys
- bys bumper or replica
- wierd coolant explosion
- running off only 3cyc ?
- D16a boost
- Sub frame damage
- what seats are these?
- Hard Lines
- pulling left. Anyone?
- 93 civic LSI with D16Y7 turbo engine
- Nooby here
- Just passed my emissions..so close to failing.
- which sounds/is overall better
- Back-Up fuse
- HERES MY BUBBLE! EK 94 H22
- 1993 Honda Del Sol
- gsr leather into eg
- es tuning muffler and d15 wiring
- best ecu for b16a2
- HELP!!!!
- Diagnosis and tool/parts budgeting.
- vavles
- Knocking coming from the valves.
- loud clunk noise!?
- Quick question about intake mani's
- Shift Lock Problem
- headers
- d15b7 help!!!!!
- skunk 2 rear camber kit
- AC Delete
- vtec pressure switch bypass obd2a??
- trans question
- R & D motors?
- Air Diversion Panels
- Vtec engages at 5500 in EM1
- spark plug wires
- coilover question
- question about an adjustment of my civic .it mess up my tire's HELP
- DSM Injectors on OBD1 (Already Searched)
- valve clearance on minime swap with stage 2 cam?
- throttle sticking issues.. please help
- civic 00 intake install help..
- ball bearings?
- Prelude 2.2 Vti Discs & Calipers on a EG HELP!
- Transmission Mount Question.
- eManage or something else... NEED ADVICE..
- Whar ecu to use?? OBD-I B18b1
- NEED HELP ASAP CAR WONT START?!?!?!?
- 1993 Honda Del So. 1.6l
- EG Hatch - Blox rear sway bar & Exhaust clearance questions.
- clicking noise??
- Can I put a vtec camshaft on a non vtec head?
- type r lsd
- Purge control solenoid valve on ZC
- ITR, BLOX, n SKUNK2 MANIFOLD Q
- JR S/C will it fit a swapped eg?
- It's Hammer time!!!! ....................i mean, clean up time.
- clutch problems d16y7
- MAP sensor Code on a Turbo 1997 Civic
- PASS: JDM 4 point rear strut tower bar.
- I have a question about doing an b18b1 LS swap vs a b16a2 swap into a 93 hatch
- How do I stop my rotors from increasing the runout of my rotors?!?
- can a d series alternator fit a b16?
- Is this the same?
- I bought a del Sol... 96 or 97?
- 1992 civic dx thermostat location?
- skunk2 IM
- SHIFT KNOB
- H22A4 Hatch ECU
- Pennsylvania Help with emissions
- which HYPERREV for EK???.....
- what car did the d15b come out of
- 1996 EX using DX block.... please help proof read my list
- Window problem, FIXED, but now problem again.
- Radiator and hose question
- a/c condensor fan fuse keeps blowing
- Oil pressure light on EM1
- throttle body size
- EG6 hood and bumpers work on EG8?
