View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Ignition Timing problem
- p2p or p2n?
- 98 Civic Auto with P0700 Code
- B16 swap EG8 broke down on highway.
- Another koni gc question
- Help!..Horn blows when headlights are on!!!!
- Del Sol Stuck Oil Filter
- 95 coupe coolant question
- Major coolant leak
- new here! 93 del sol smoking like a freight train!
- '93 d15b7 hatchie
- ek exterior door handles, will sedan ones fit my coupe?
- 98 Civic Auto Shifter
- wire up abs in a non abs car
- How to tell if used bumper is OEM before I buy
- looking to cage my eg coupe
- 94cx Not turning over. need help diagnosing.
- '92 Exhaust and battery issue; expertise sought
- JDM D15B Non vtec oil light
- 92 civic alternator issues
- running eibach rear sway, run a sway bra brace?
- Honda Civic 98 EX Window keeps falling of track!
- Nasty shake at low speeds coming to a stop.
- first y8 build
- b16 ek hatch wont hold a charge
- found out car came with rear disc swap...
- 92 Civic Headlights/Dashlights/Clusterlights Keep Cutting Out
- From Houston. New to the Forum, white 94 Eg two door coupe
- whats making my front end vibrate?
- I have a 1.6 VTEC with Si knuckles Anyone else???
- B20B Block/ B16A2 HEAD...Blown head gasket!!!!!
- changing head bolts
- 94 EX coupe - Wire Nightmare - fuel pump hooked to a switch
- FAL window kit installation question
- $For Sale/Want to Buy$ - 92-00 Civic/Del Sol Parts Only (NO COMMENTS ALLOWED)
- Is my new old car dying and just bought it?
- Rough Idle and Choppy Heat
- Price Check on Repairs. First time honda owner.
- will a 94 accord cold air intake fit my 94 civic vtec
- ***98 Civic died and won't start. Please help me troubleshoot***
- 93 del sol si defroster not working?
- Lower Control Arms
- headlights dim then brighten.
- who owns the engraved civic? front page yahoo
- What is wrong with my transmission? (video)
- My del sol reverse Lights always ON... Help!!!!
- 1992 Honda civic trouble starting
- z6 build complications
- 1997 civic coupe roof moldings
- Honda civic led
- JDM 92-95 Thin Side Moldings - anyone install
- WILL D15 COMPLETE INTAKE MANIFOLD WORK ON D16Y7 HARNESS.
- EG Hatch question
- Exhaust
- Cylinder compression check D16Y7- Results inside
- Weird idle?
- very stiff ride help
- 98 Civic Ex - Highway swaying, Rear wheels have play on ground
- d16y8 head removal
- Rear window/glass
- Question about AC compressor replacement
- 96 coupe w/koni's
- civic burning coolant causes
- swap or catback
- how do i know what head i have? help
- es oh es! idle issue :/
- weird smoke from shiftboot
- 1992 service manual???
- dash lights flicker
- D15b vs d16y8
- fuse 15 ELD CEL help please
- I saved a sol: Come meet Skittles!
- Mending Sunroof 1995 DX Coupe
- Ground Control Spring rates?
- Cam length???
- Please help me diagnose the cause of my misfire D16Y7
- Dash lights not working.
- Smoking issue?
- d16y8block/d16y7 head
- 96 Civic with a jdm integra front end
- d15b dual vtec obd2 to honda civic ex 1998
- b20 not starting
- Check Engine Light code help
- Strut choice
- B16a2 OBD2b swap into 93 Dx Coupe Help!!!
- Need a professional!! D16z6 map sensor problem.
- 1996 Honda civic EX cutting off when coming to a stop/low idle.
- My Honda Civic 1999 Overheats when driving over 65MPH during the day
- help get new sol to top running condition
- Front Knuckles
- B16A swapped ek wont crank, no clicking, good battery, need adivice on where to start
- Help needed, 93 Del Sol
- ecu question
- INFO ON THIS EM1 BUILD?!?!?!
- Quick question before $$ upgrade
- 95 Honda del sol trouble with exhaust bolts
- Head build or Turbo?
- Spark Plug won't turn
- Valve cover installation 96 Civic
- questions about ac bracket mount
- 96 civic cx fuel consumption
- No vin on dash
- 98 civic swapped and has radiator fan issue
- 94 civic cx bogging down
- Knuckle/Hub Interchange
- D16y8 intake manifold swap
- what pcv valve?
- Brake problems
- Ac compressor question
- D16y8 Block with D15y7 Head
- b18 swap IAT sensor cause car to bog down when given gas?
- neutral safety switch no work!?
- 93 Civic DX Auto - No Start, No Crank
- question for the ek hatch guys/girls?
- suspension question
- 98 Civic Ex hoes issue
- 1992 Civic LX 4 door no spark
- need help finding a connector
- New to building! '99 Civic DX
- 93 civic Si rim size help
- 92 civic DX sedan head gasket
- B17A1 build help!!
- 1998 Civic EX water pump leak, engine sputtering then not starting-timing belt skip?
- Swaping mounts
- Fuse #15 blows AS SOON as key is turned to on(2)
- Boosted EG Hatch intro and pics
- MAP sensor Issues
- Custom Paint job
- d16 tune questions
- miss fire
- HELP::CAR WOULDNT START THIS MORNING B20B EK
- 1997 Civic DX HB 81,000 miles Problem
- Del sol rear disk conversion. Squishy pedal. Help!
- Mud flaps with a rear lip?
- Swap d16y8 engine to ZC/D16A SOHC VTEC Engine (OBD2)
- 98 ex rear brake knocking
- A/c delete question
- B16, B18, or B20
- 93 del sol trunk liner?
- Where to go to get racing header installed?
- oil inside overflow tank and on overflow hose (93 del sol)
- d16y7 intake manifold to D16y8 intake manifold. helpp
- 91 CRX HF d16z6
- HELP : CKF p1337 bypass obd2a
- Problem With Car Not Starting B16a In EG Hatch
- What power steering fluid to use
- Clutch bleeding
- 92-95 civic front end conversion on a del Sol
- 98 EX Power foldding mirror help
- 2000 Civic: Need to replace cat/ O2 sensors/ IAC valve?
- OBD1 Injector ID help. w/pic
- skunk 2 alpha throttle body 70mm and 70mm intake manifold b16 issue
- Valve springs
- 99-00 si cluster help.
- 99 Civic Si Ignition Problems
- fuel injector problem
- installing a/c in cx
- ICM also called ignitor
- wire size for grounds
- 6.5 alpine speakers dont fit 97 civic ek
- 98 civic ex stalling?? Help please
- Mini Me Swap HELP
- rack n pinion question?
- what transmission?
- 95 civic dx d15b7 upgrades
- stock swap info-help
- Temp Gauge & Assessory
- Plexiglass targa top Replacement plexiglass?
- ek skirts on eg, mudflap fitment?
- need some help identifying the model im buying
- 94 civic bseries axle help
- 99 civic si w/ obd1 jdm b16a swap problems
- leak from feed line connecting to injectors
- misfire... / power cut
- Help Please! Fuel Not Priming
- Main ECU wire harness.
- EM1 - info or links to diagrams on how to properly install a rear bumper skin
- d15z8 vacuum pipe's
- Need help 93 hatch z6 idling problem
- 99 Civic 3 wire to 2 wire idle control valve help
- Vitara Pistons
- z6 swap into 97 ek hatch fuel injectors not working
- Gas tank installation fail?
- Throw Out Bearing
- wire fog lights/driving lights to headlights?
- online used honda/acura store for yall
- 1995 civic DX motor swap
- how do you install a aftermarket steering wheel
- BUYING A DEL SOL
- No Power to Distributor!
- How do i set EK manual trunk to automatically lock
- starting problem
- 98 mini me swap, doesn't run right!
- Sherman Wheel Arch Repair Panel
- Block and head not right
- Catalytic Converter on 99 Civi LE, How to replace
- FYI d15b2/y8 mini me
- O2 sensor need help ASAP please!
- Aux lights
- p2e-p28 ecu high idle hellppp!!
- Thermostat real temperature for EX
- Preventative maintenance before 500 mile trip
- 1994 eg hatch no crank,no start
- Moisture Shield Material suggestions needed.
- cleaning headlights
- DX to EX Trans Swap Help?
- Manual Civic 98 EX Idles High when moving and back to normal when stoped
- mini me swap question's. D15B/D16y8 head ek sedan
- Brake Line p/n's with ABS delete?
- 00 civic si overheating
- Can anybody tell me what this plug is
- High Beams Won't turn off!?!?!
- Grinding/ chirping sound.. Help!!
- Clutch replacement/Engine won't start
- Tambourine under my hood?
- Eg hatch p28 ecu help
- strange ring with ebay headers/downpipe/resonator
- cv shaft help
- 96 ls into 94 Cx hatch ??? No spark ???
- D16Z6 Dizzy issues/ NEED HELP
- 1995 Honda Del Sol Engine/Model Question
- What is this little can/filter in my 98 civic lx?
- Idle probelm after TB cleaning
- B15B7 high idle
- EK not cranking -- Ignition switch test (23-89 in EK service manual)
- 95 civic ignition cylinder problem!!
- D16Y7 to a D15B non-VTEC?
- OBD1 Check engine code opinion?
- Water in oil?
- Synchromesh Manual Transmission Fluid!
- Does VSS supply distance data?
- No power!
- 1995 Honda Civic Engine Swap Advice
- Best ecu for my jdm gsr swapped 99 si.
- gauge cluster help please
- Help with Knock CEL
- NEED HELP PLEASE.......
- B18C1 timing marks question.
- 98 civic CEL on...
- Unknown oil leak help
- No0b
- Will accord sedan rear seats fit into my 00' ek sedan?
- Exhaust Help!
- Headgasket, or not?
- EG6 hatch GSR issue help
- D16z6 help - no start issue
- JDM D15B Vtec
- 98 Civic Swap Questions
- sleepyaccord96's 94 DX hatch build/paint
- Forgot to Re Install Bump Stop?
