View Full Version : Honda Civic / Del Sol (1992 - 2000)
- jdm b18c swap to a 2000 ek9 coupe
- engine running a little too hot, pics to explain the situation.. help plz
- I'm looking to get a Honda Civic EG
- exhaust valve
- GSR Seats
- Help: Ticking
- FS: stuff that's been edited by moderator
- JDM B16 swap having some problem need some help!
- coil overs?
- Whats needed for a 98 ek to an h22a?
- 2000 bump on 98 coupe??????
- speed sensor
- b16 question?
- Tips unplugging brake switch cable - Del Sol
- cluster
- b18 out of 96 teg direct swap into 96 hatch???
- Sooooooo
- Problem with speedometer and breaks
- Newbie Problem About My Car
- Question about my Foglights....they're not working, 2000 civic si
- 2-3 Shift problem, GSR Tranny
- Fuel Problem????
- TURBO????
- Original ITR suspension (coilovers) into an eg coupe
- Motor problem
- ...Kind of dissapointed
- B20
- Bad Main Relay?
- blown head gasket
- OBD1 TO OBD2. SO I CAN PASS CALI bar.. 94 SI HATCH WITH 99 GSR.
- itr seats in an eg?
- VSS Question
- help
- engine reving up
- Couple exhaust questions 00 si
- noise from gas tank
- tire size
- GSR running rich
- 99 00 foglight installation
- HELP
- i need a place that can smog my EG with a b16
- Did I realistically affect structural integrity?
- New member with '94 Civic EX...
- Coolant line trick....
- referee centers
- Wheel Hub Removal HELP please
- ek9 vs dc2 Intake Manifold
- whats a D series motor/trans worth?
- Prop. Valve
- My new distributor from Advanced auto parts did not fit my jdm b16
- buddy clubs fake p1
- my light not working???
- Questions about rear disc conversion on EK (yes I've ready FAQ)
- Need Help Fast!!!!!!!!!!
- left turn signal bulb keeps on blowing out
- Check out this rough idle!! **Vid inside** IACV cleaned / Code 14 thrown! LS swap / 96 DX!
- Rear wheel noise/ squeak
- gsr seats into 96 hatchback
- Aftermarket deck and OEM clock not turning on
- Low beam went out, but hight beam is OK
- wut should i do first if i want to upgrade my fuel system?
- EG foglight help?
- Headlight bulb replacement
- Check engine light problem?
- STOLEN 92 CIVC SI - WASHINGTON
- AC removal
- Need to know all 92 Civic Si Options
- Question - Broken ARP headstud for d16y8. Would I be able to purchase just one?
- motor mounts
- does any with a rhd EG hav a AIM
- a/c heat parts i need??
- zc motor. does is come in dohc and sohc
- climate control
- question about a zc motor
- Seats
- 4dr / 2dr bumpers
- quick question:: sohc si tranny or y8 tranny?
- Car redlines at 4200 and Rich Black Smoke
- Anyone have a pic of the 92-95 civic SIR JDM
- I tore up the JUNKYARD!!!
- REAL QUICK HELP!!!! Just did tune up....need Firing order!
- which motor is the japanese zc motor same as here in US?
- dumb ass question but i really want to know
- anyone know if 97 prelude master cylinder fits EK civics?
- Broken Steele
- can someone please please pleaseeee help me. Timing issue
- CAR WONT START...
- cel light question
- Code Questions
- power chamber intake for a 95 dx coupe
- Would a b18b1 overheat using a 92 CX radiator?
- SWAP INFO.
- What is needed (ECU wise) to put an obd2 b18b1 into a 92 cx?
- B16A2 head & Type R block?
- conversion from cx hatchback to Si-r.
- !need help! with the keyless entery on my 97 civic ex
- My shifting gears problem has returned, only happens when the car is running hot in traffic?
- gas mileage for a b16 engine
- Anybody ever done anything crazy with there armrests?
- Camber and Toe
- whats the best ecu?
- adjusting front camber
- Fuse question??
- Cupping Tires. What can be the cause?
- vtec head on D15 engine
- What brand makes a quality resonator?
- ep3 steering wheel on an ek?
- ready to swap d16 engine, can anyone help me please?
- distributor oil leak
- 92-95 EG Spoiler Reccomendation
- noob question, i'm sorry... Si gauges in a EK DX? tach wiring?
- Koni Yellows on Civic Skunk Coils - Will GC's Improve my Ride?
- ---How To: Theft Proof alarm install---
- eg6 w/itr hondata?
- My first car,my first Honda help
- Weird Bogging/Idling after i get on it
- zc intake
- Buying A Passenger Seat for a Driver Seat??
- I need an anti-sway bar
- Front passenger lower control arm pivot bolt bung nut
- Headers 4-2-1 VS 4-1
- LCA skunk2s or blox
- Can anybody help me plan my first car?
- Should i port and polish my civic? 2000 ek9
- gague pod question... where to get a a pillar for a RHD EG???
- Question..Integra LS Tranny WIth LSD or GSR with LSD i wanna RUN V-tech ..HELP
- need head gasket whats the best?
- WHAT IS NEEDED AND HOW MUCH WOULD IT COST TO SWAP A D15ZC SOHC NON VTEC INTO A 94' CIVIC CX?
- SWAP QUESTION ?
- Ignition Problem?? EK H22
- Coil over question
- ride quality
- oil pan help
- Replacing rear motor mount tomorow. Any Quick tips before I start?
- Alignment
- engine swap in progress. Please help me!!! I would really appreciate it :D
- need help
- need help idle problem?
- one dim headlight
- Stock oem exhaust DC/EG compatibility???
- mini me turbo??
- help please i think my engine is shot
- glovebox lock?
- help with b16 swap
- 95 civic A/C still not blowing cold
- Pic Req: Phantom Grey EG with Black interior
- Brake Questions
- 95 HONDA CIVIC SI
- 95 civic A/C problem, still not blowing cold (enough)
- Fuel Rail and Injectors
- wiring harness
- WHAT IS NEEDED TO SWAP A B16A VTEC INTO A 94' CIVIC CX NON VTEC?
- hatch window
- Fuel pump
- Vtec Soleniod Miswiring?
- Help
- d16y7 swap, runs now, still shaky.
- Tricky problem
- 2nd gear problem
- d16y7 IACV location.
- Help me stop the crank pulley from spinning
- GSR motor Cyl 1 misfire. PLEASE HELP!!!!
- OBD2a OBD2b whats the difference?
- Honda Civic VX ECU ECM compatibility
- B16a OBD0 - VERY low idle, Idle bouncing *help*
- Ecu question.
- help! help! brake lights
- need to paint my rota slips
- New owner of a EK Hatch with B18 swap. I have some questions.
- My timing belt broke, I need some advice
- d15b dual vtec in 97ek ecu ?????
- OBD1?
- d16y8 Build
- knock sensor install
- What is better turbo or exhaust
- Vtec Head Swap???
- d16y7 engine in my "96 civic dx
- passenger window switch part number
- eg/dc2 suspension the same for EK's?
- 1.6 EL seats into 94 Eg hatch
- Anyone know if a 92-95 front caliper bracket the same as a 96-00?
- Fair price to change ignition?
- Price check - '94 Civic VX.
- tried adjusting idle screw, no change, b16 in 96 civic
- CEL P1456--->>>car shaking at idle 99 CiViC Lx
- Need help with 93 civic Si
- EG hatch Exhaust fumes in car, please help!
- throttle body
- mini-me or d16y8??
- Alternator Belt? Speed Sensor?
- Cooling Issue!!!!!!! heLp!!!
- help id this tranny
- 36mm axels ..?
- car salvage title!
- 98 HONDA CIVIC FEIRO
- HID Bulbs Replacement?
- I want to conver my automatic 99 civic ex to manual sawp..but i have questions that are not getting
- power steering pump question
- does the usdm eg6 hatch / coupe comes with power window?
- Please help w/ Del Sol Swap???
- hard shifting
- Knockoff Catback?
- NO POWER!!!
- need HELP!!!
- theft prevention specific
- ls vtec
- Rear LCA's
- EK bulb type
- info on jackson racing supercharger for D16Y7
- Fuel Pump Problem
- ball joints/bearings
- Power option swap
- WHY ISNT MY SPEEDOMETER WORKING??!?!?!?!?!?
- engine hoist problems
- auto-manual conversion info... To clarify Noob QUestions
- Civic SiR & Type R (96-00)
- car bogging at 1500??? help please!
- 97 Civic Coupe ITR swap, Header and CAT issues
- b16 swap question
- clutch ???????
- heater picking up exhaust gas?
- D16 Torque Specs
- what is my car worth?
- EK Civic Type R Wing
- PCV Valve 98 CIVIC EX
- popping noise and lag
- what kind of transmission fluid to put in to a b16a transmission?
- 99 EK hatch stock spring rate?
- how to remove head cover on d16??
- 95 civic bar.....
- coilovers for a 95 dx coupe
- Suspension
- crx si seats into ek?
- d16z6 crower stage 1 cam good......
- vtec problem?
- melted secondary o2 sensor wires?
- best site for jdm wheels
- Cranks
- problems with b20 in 96 civic
- damn... 900k miles on original motor
- Exhaust too loud, what can i do? silencer? change exhaust?
- 5 lug conversion.ek
- reverse light help on a swap (( SEARCHED BUT I GET THE SAME ANSWER))
- Rear disc conversion help.
- Has anyone made a kit to put a cable tranny in a hydro car?
- Schucks or Autozone Timing belt for a b18c1?
- Need A PRo for some advice on my MOtor
- Weird Idle Loop (I already searched)
- TRANSMISSION ISN'T GOING INTO 1st OR 2nd WITHOUT A FIGHT! WTF?
- Shift Lock Release (auto)
