View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Mud Guards (Flaps) For My Em1
- car rough idle need help please
- Bisimoto "typo" error on website... wtf?!
- hey whats up im new
- Plug help
- Greddy FPR.
- Cat-back exhaust advice (96-00 EK Civic)
- eg/ek a/c
- My P/S Delete experience.
- Have you guys ever seen this?
- Anyone know how to wire m3 side mirrors?
- Any recommendations for a good oil pressure gauge?
- has anyone used the e3.64 spark plugs?
- intake wobbles...
- need some help here
- I have no idea whats wrong with my car. please help !!
- swollen upper radiator hoses
- 93 CX hatch Brake lines stay on.
- 95 Civic LX Pin out info and harness compatibility Question???
- 99 Civic Low Beam Headlight Recall?
- Transmission/axle knocks when turning right and going strait
- b16 keeps over heating n e help?
- Lucas Motor Oil In Honda Engines
- help on Ek
- White smoke coming from muffler
- apexi vtec controller?
- timing belt
- Axle Help
- ITR LCAs and Strut ?
- Need Help bad idle
- new parts questions
- 99 civic ex convert to obd1
- wiring up meh vtec
- removing starter assembly
- Need some help with 2,3, and 4 misfiring
- changing a head gasket
- winshield wipers
- Does 1994 Del Sol D16 need new cat?
- REAR BRAKE IS STICKING
- Sensor help!!!
- mini me sparkplug wire question
- type r cam set up.
- just a question about my caliper piston (pic inside)
- need help with exhaust!!
- Idling woes 99-00 em1
- Need help on which VALVES to buy !!!
- Stock front strut bar
- jdm type r swap problems
- cat question
- dizzy question
- ek d16 engine question
- Hatch interior install....
- Would you pay more for a CLEAN TITLE CAR? does a REBUILT or SALVAGE title bother you?
- alternator problems
- JDM EG civic interior conversion/swap question
- Exedy Clutch
- h e l p b16a2---obd1
- steering wheel size??
- Power Door Locks HELP!
- steering knuckle question
- Gauge Cluster, Turn Signals, Clock wont work.
- d16y8 knocking?
- deck lid removal?
- installing a timing belt help please
- Ebay Rear LCA
- 00 taillight housing on a 96
- would oil in the combustion chamber show on the plugs??
- 4.9 FD in D15 non vtec?Is it a good start?
- Best OEM clutch combo on LSVTEC???
- ITR rear seats in civic coupe 94
- 99-00 flaps on a 96-98
- CF hood
- 1994 Honda Del Sol DOHC motor mount question
- How Important is the SplashShield
- Please Help... B16a losing oil pressure at vtec crossover...
- 96 civic w gsr intake manifold ???
- Eacv?
- DashzRacing CAI
- Need Some Advice And Help
- Stock Car
- 97 Civic steering clicking
- help please mini me turbo
- eg6 with cusco rollcage can you still keep rear seats???
- need help with my radio harness
- tach issues
- 93 del sel with b18c ITR troubleshooting
- Advan rg II on EG civic hb
- Need a Engine diagram
- JDM Headlights..
- ITR manifold on b16 install problem
- air intake question
- Front kit decision..is body work required for Blitz body kit??
- can someone help me out?
- eg help
- Question for BAR'd guys!
- trans bolt size
- looking to buy a eg..help
- can someone help me out!?
- 99-00 tail lights
- horn/hazard lights won't work
- Start up/ bogging issues
- certa fit bumpers
- Bad start/ bogging issues
- Need A Engine Harness Diagram/94 si
- certa-fit bumpers
- How to remove hood prop?
- 92 vx hatch - trunk latch
- 1994 honda civic ex shakes at low speeds 1-3 gear 2500-3500 rpm only on acceleration
- D15z1 VX wiring and EGR problems.
- D16y7 Clutch Replacement??
- gsr clutch slipping but its brand new
- How do you take off the control unit?
- 93 delsol h22 linkage question
- Anybody have a trunk lid install for 96-00 Civic Coupe?
- timing belt issue! help
- EG Corner Light Question
- rear disc swap which cable?
- 1993 Honda Civic LX
- D16Z6 Block+ D16Y7 Head= Timing Disaster???
- window problem.
- Can anyone identify this strut?
- Does this car come stock with rear disc?
- Honda OEM piston rings. What kind are they?
- eg fog light relay type/number please
- will auto harness work in a manual car
- AEM EMS WONT START MY CAR HELP
- As much HELP AS I CAN GET
- cel light as always
- ek ecu pin diagram
- Supercharge EM1 or S2000?
- valve adjustment questions
- ground wire resistance values
- 92-95 civic power door conversion
- D16Z6 V-TEC Solenoid Oil Leak. Help
- Looking to add a second resonator
- Obd 1 cel question
- new car: eg hatch or ek coupe?
- stock civic muffler piping question
- Has anyone ever installed window switches on manual panels?
- 2000 EX Coupe with VR6 Swap.... Please be nice with comments
- ls vtec question
- S2000 Cruise Controls in EK. Where's the post???
- HELP: Civic Wont start!
- I think my car doesn't like me...
- HX Rims Does not fit on my EX....
- Major idle problem
- D15Z1 head what dizzy can i use?
- obd1 to obd2 jumper harness
- Civic engine/tranny into a del sol shell?
- D16 MOTOR BUILD.. HELP!!
- What is the difference between CX and DX Hatchbacks?
- 95 civic HB problem
- Popping noise after i park??
- power window switch question
- 1995 Ex need transmission help, clicking? noise...
- B18C Hose diagram
- Cranks but won't turnover, have spark/fuel
- my tires r showing wires!
- High Rev then CEL
- Crazy CEL !
- poisonous smell in the car
- Overheating Problems
- b16a3 grinds form 2-3 at high rpm
- GSR with b16 head idle issue
- DELETE THIS IM RETARDED
- Back of JDM cluster pic please!?!
- Del sol rear disc on an EJ? what parts?
- need front bumper and left inside pillar
- Bad alternator?
- RonJ@HT HELP!!! Swapped distributors, now it won't start. GOT SPARK
- signs of a clutch going bad....
- Need help with power mirror wiring...
- D16Z6 Cam Gear Timing
- Suspension help on my Ek Hatch
- Extra valves on Skunk2 Intake Manifold
- What Is The Trick To Remove Ecu Pins?!
- Civic seat
- No power at starter signal fuse
- difference between vtec switchover & vtec engagement
- z6 distributor problems
- ignition switch too big for column
- can a bad ground cause low idle issues?
- Rear power window won't go up
- A/C Problem - D to B Motor or RHD to LHD ?
- vtec oil pressure wireing to ecu question
- EG coupe rear lip options ?
- Need swap help 93 CX with B18C1
- Changing Trassmission
- Cruise Control Issues
- tachometer,odometer,gas and temp gauge dont work
- EG-EK question
- 94 Tie-Rod end issue!! (need advise)
- Del Sol intake
- how to fix radiator fan 95 civic
- Tach going wild after 4k rpms
- Question about seats please Help
- Need info!! engine torque damper
- Lots of engine vibration but previous owner replaced motor mounts?
- NEED new suspension
- Twin Loop replica instal questions
- AC blown? or not?
- Timing belt broke at startup!
- CRV interior in a EJ8?
- having problem with 1996 hatch IDLE
- Newbie HERE!
- How to Swap Interior Harness?
- Need help with manual window
- GSR swap in 94 civic coupe
- Has anyone bought anything from...
- jdm b18c in 93 cx? Searched??
- Loose side skirts
- Eg hatch/gsr...something wrong...lags or does not run right
- how to identify a y8 head?
- Mini-me dizzy help
- Del sol b16a
- Heater not blowing? climate control?
- RPM question
- gsr only runs with map unplugged
- My speedometer is acting weird!
- my new z06 vette kill story. video
- CEL 65 secondary O2
- B18B1 Integra Engine
- Looking to get aftermarket mounts... Need a few Q's answered first.
- Wierd jerk
- VSS Problem in my 92... RONJ WHERE ARE YOU???
- removed or dismantled a 5th gen sunroof?
- 95 civic Non abs Front wheel hub assembly EMERGENCY
- 96-99 coupe doors on hatches?
- taurus cupholder/coin console
- Just swapped my motor, feels like no clutch
- Quick question about clutch engagement
- JDM EG VTi cluster help!
- window interchangability
- EK fog light: connector taped to rear of fuse box?
- New on HondaTech, Hi everyboby !! (New pics)
- hasport motor mount question
- Weird clutch problem, info would be great.
- where to get jdm fenders for 96-98 coupe
- my honda civic won,t start
- 1994 delsol strange swap help
- installed new ctr headlights & ctr front lip
- sealing the oil pump. what to use
- 16" Honda Fit HFP Wheels ON a Del Sol
- Quick Question: Front Discs
- D series tranny problem
- Hood Vents?
