View Full Version : Honda Civic / Del Sol (1992 - 2000)
- speedometer issue
- 98 HB/B16 swap with OBD2A to -2B JUMPER HARNESS - Any problems expected for swap?
- The Best 92-00 Civic/Del Sol?
- D15B7 IDLE ISSUE
- d16z6 Possible rod bearing.
- OBD2a motor to OBD2b harness questions
- main relay fix
- 98 Civic hatchback mpg
- 1992 Honda Civic - Thrown Rod
- S2000 vs GSR EK???? need opinions
- manual steering rack impossible to find
- Car Broken into - Stolen Alpine IVA-D105 HU in Las Vegas - Acura 1.6EL
- Why does my civic VERY hard to start cold but starts and runs fine after warm up ??
- choppy throttle, idle stalls - fuel pump?
- UGH!!!....another d15b/y8 question
- help with installing chasebays brake line relocation kit???!!!
- Mysterious wet carpet in driver side after it rains
- help friends car overheated
- Warming up engine?
- Putting A/C back into 92 civic. Is a lightweight underdrive crank pulley helpful?
- 97 civic LX dimmer shorted out my dash lights?
- vtec solenoid gasket
- A/C wiring Diagrams and Pictures?
- 97 Civic clutch issue
- 93 civic sedan brake light won't work and shift lock?
- Front oxygen sensor pulled, red and yellow discoloration on it
- in depth a/c question, alternative oem condensor fan?
- Tumbling Sound wen turning coming from back of
- Civic race car always cuts out at same time
- B16A2 Issues
- Help with 1995 Civic EX CEL 17, 20 & 41
- Tranny Mount Bolt hole Stripped. :( help please.
- Want to buy this Del sol is it worth anything?
- b16 cx rough idle
- Speedo and VTEC don't work.
- Jackson Racing Supercharger D16Y8 EJ8 2000 EX
- High Flow Cat Convertor
- 95 Civic - Need help with VSS
- 1997 CIVIC DX, low miles, clean title. VALUE?
- In need of help loosening 98 civic crank pulley bolt.
- Door wiring harness
- How long does it take to replace the engine harness of a d15b??
- Who makes Denji knock offs?
- What cams can i use?
- Ls swapped EK, Electrical issues, car wont turn over.
- coolant system question
- Del Sol Trunk Stay help?
- What type of bumper and side skirts are these?
- timing belt help plz!!!!
- new engine same problem as old one
- mini me swap help(harness issue)
- who has used this LSD insert?
- d15b/Y8 head. spark plug?
- B16A2 - Coolant - Engine drain plug?
- rod knocking?
- honda civic 99 se help!! (auto)
- Over Heating Still
- D15B Vtec-e elimination question
- Got a Question about swapping.
- tapping the oil passage in a head for b20v
- what is this in my coolant? [PICS+VID]
- 94 honda ex turn signal stop working
- Need PCM number for manual swap 96 EX
- engine code help
- honda not getting power from battery
- mini me timing mark cam help?
- help..! s2k cluster in a del sol
- Rear lip question
- Need help!! any thoughts?? Im in Limp-in mode
- head work
- Honda Del Sol S 1.5 AT engine swap b16
- 98 ex LCA bolt broke in half. HELP
- my 92 civic hatch build (chuchara sports)
- Do the OBDII scanners sold at Autozone read realtime RPMs?
- How do you disable the computer timing adjustment to check timing?
- HELP 2000 civic si B16a2 spark plug cover color
- piston wont release
- HELP... VTEC
- 98 dx wont start
- new clutch still problems
- Sway bar end link questions
- 00 Civic Si - misfire and vtec
- how to get my speedo to work on 92 hatch eg w. b16a swap
- car problems after nasty curb damage
- 97 civic - header and straight pipe questions
- "fixing" vtec wiring
- brake master empty overnight
- EG Civic air box on Del Sol
- 95 dx going from no tach to tach cluster
- Tach on a D15b swap
- is this a b16a3 engine?
- Buying new speakers. Help me out!
- Loud Squeaking When Turning 93 si
- 2000 EK d16y7 Noise. To Bearing?
- How does this strut bar fit my civic?
- EK starter cut/kill relay part number
- when clutch is engaged makes weird noise
- Toe Adjustment Bolt Spinning - PICS!!!
- power steering
- Is this car overpriced?
- if my honda was tuned with 440 injectors can i go back to stock without retuning it?
- question ?
- Is this b16a crank done for? Also, scoring on connecting rod..[pics]
- should i buy this 95 del sol with 235K miles
- code 65 fix cel fix secondary heated oxygen sensor install universal 4 wire
- EG hatch bumper repair?
- help please eg civic conversion wiring
- Car does not start
- Exhaust Combos?
- MPG Converting???
- looking for this M248 tranny solenoid seal
- 1997 CIVIC DX question! PLEASE HELP.
- Wobbly Brakes
- vtec tranny
- rear camber adjustment problem, please help
- Tranny mount question
- My Smog Adventure Continues D16y8 running rich?
- 94 ej1 - VTEC and redline questions
- 95 Integra Steering wheel fit?
- Cutting bumbstops?
- Anyone know the P/N for the 99-00 Civic Splash Guards?
- wiring diagram for cigarette lighter?
- B18c1 cutting out/Extremely rich question...
- Tranny Question which one??
- Greddy Evo 2 or Buddy Club Pro Spec Catback
- Left Headlight wire question
- Broken speedo help!?
- B-series halfshaft question
- EK Spoon Wing
- Replacing TPS b16
- Sunroof wont open, close or tilt & pm dont work
- got a couple a/c questions
- mini me swap problems
- 97 Civic EX - need rear panel part number and help redoing interior
- BBN Performance Reviews???
- 98 civic HB ek need engine swap help, PLEASE!!
- 94 civic dx sputter,car turns off ..please help!!=[
- Coolant Leaking Issue. 99 Civic EX
- em1 b16 sputters above 3K rpm
- EG hatch is sooo SQUEAKY!!
- DIY: B18b1 swap into 00 Civc EX with A/C and power steering (PICS)
- Does a D16Y8 exhaust manifold fit a D16Z6
- What are the measurements for jdm side markers lights on EK?
- d15 head rebuild
- timing question
- H-beam Eagle Rods on D-series Block Q's??
- D16Y7 - What wire is this?
- B16a turbo del sol won't start. HELP PLEASE!
- D15B7 - Head Gasket Questions
- what is the best lca for a 97 coupe
- Cheap vtec-e gas build
- Ap2 Cluster wiring help!!!!
- 97 Civic EX won't start
- Civic Idling Issue
- Wire routing help
- 1995 ex D16Z6 clicking valves?
- 97 civic. Cranks but won't start.
- Radiator Cap / Radiator Leak?
- What front bumper is this (EG hatch)
- No compresion on 3 cylinders!
- Lower Control Arm Bushing question
- B18C1 overheating issue
- car wont start :(
- Idling low, new help?
- Just a b15b motor questions in a 2000Ek
- TPS bypass valve sucking in air
- Best tranny for my d15z6 turbo
- 98 Civic EX sedan - Need help on engine rattle noise (driver side lower belt area)
- Calling all Cusco Roll Cage owners......
- Rear drum can still rotate while e-brake is on?
- price for used 96-98 sir headlights??
- evap canister and purge solenoid d16y8
- 93 Honda Civic help
- Ahhh major frustration..finished b18 swap no problem number 600...plz help
- Guage question i.e. tach, speed, fuel etc...
- intake gasket help...for d15z1
- Engine Swap
- 98 Civic LX -- need body roll help
- passenger door wont lock
- 96-98 CTR Headlight from these sites?
- 99 civic LX auto D4 light blinking!
- GSR Swap Intake Mani Sensors Help
- 99 EM1 - location of ECT fan switch?
- 95 civic Stuttering Randomly...?
- 93 del sol got new brakes and bled fluid but still spongy.
- Front Wheel Bearing/Balljoint Replacement How-To
- 92 civic si - lsv swap- cranks but doesnt start.
- Fried alarm, fried wires now car wont run!
- HELP! 2000 civic si CEL p1456 won't go away
- 96 civic B20B with 96 ls tranny
- 94 del sol hydralic clutch line? help
- how do i: wire up aem uego as primary o2
- "Wish I knew this before I started installing those coilovers" Thread
- What is a 96 Civic EX with 180K miles worth?
- Misfire problem. (verry low rpm)
- 97 CIVIC AC ISSUE!
- No power and car sounds like a Subaru
- Part Number for 99-00 Si Spoiler
- Need Help. Climate control and Cluster Not lighting up on 94 civic
- clutch problems
- b20vtec throttle delay and bog under load
- D15B7 OBD1 IDLE ISSUE D:
- Misfiring under load
- p2m ecu is this for
- Car cant redlines at 5 1/2!! ECU??
- Mugen Head Gasket
- mini me timing belt? d series 98
- 70mm Throttle Body on B16a??
- B16A2 - Coolant fluid - Do they mix?
- Fluctuating Idle Problem - 2000 Civic
- putting k20a2 in 93 eg hatch
- 92 Honda civic dx fender front rear bumper question
- need eg hatch interior badly
- i need help with (shim sizes/specs) d16 transmision and valve angles...
- Vtec head help asap
- Wiring IAB question
- Rear Brake Conversion 91 CRX-99 Civic Hatch
- speed sensor problem
- Show me a pic of a civic Hatchback with RSX rims
- Idle Problem on B18a1 Del sol "pic & vid"
- Lowering Question?
- Recaro's in Tan Interior?
- 1993 Honda del Sol S engine cutting out
- b16a has bad idle, wont stay running
- valve spring compressor
- craigslist win!!! Is this all i need for a mini me mod?
- B20b into a 94 civic ex
- 95 Civic EX will not start. Have spark and fuel. Tested lots.
- DC2 exhaust parts on del sol sir
- need help on vss
- will EMracing EF triangulated bar fit EK??
- Car stalls and sputters while driving Ej6/B18B
- help
- When i brake hard, my car shuts off? Why?
- Pic request: 98 ek with spun supermesh
- /// 99 civic Si A/c problems!!!!
- AC condenser bracket
- How much for a used catalytic converter?
- 94 civic ex. b18a1. pr4 ecu. I have a throttle body question.
- 1999 Honda Civic EX - Dome/Gauge Lights
- Headlight is functioning oddly
- Intake System Help
- fuel knock or valves
- B18 water leak
- vtec pressure code
- 00 Civic Si - alternator not charging battery
- '93 Civic D16Z6 bogging down and dying
- Ej1 b series swappp
- Is the 96-00 Civic air intake the same as the Si?
- only 2 cylinders firing! HELP!
