- which rear main seal to use on d15B?
- TSX Throttlebody on D16z6
- JDM Time!
- idle problems with a d15b7
- Car turns over and will not start
- bushing digram 96-98 civic (front)
- JDM ITR FRONT END CIVIC
- 92-95 civic coupe/hatch???
- Problem: Car Don't Start
- HELP!! P1491 Exhaust Gas Recirculation (EGR) Valve Insufficient Lift
- H-SERIES INTO A 96 BUBBLE
- Anyone got a pic of the odomoeter unit?
- Color code !!
- z6 head / a6 block. will a y8 head gasket be too thin?
- D15B into '96 Civic EX, backfired, now no spark.
- swap problems
- EG corner lense parking & signal light don't work!!!
- LITTLE HELP
- How big can I go on my civic?
- Will this halfshaft fit?
- F/S NUFORMZ Rear Spindle mount suspension
- Quick...will a 91 Si axle (D16A6) fit a 97 EX (D16Y8)?
- Wheel and Tire [sic] and Suspension Forum
- ek shocks on eg
- 3rd gear grinding
- Engine concerns
- WTB: Front bumper that would fit 96' ex
- not to sure about this swap? ANY SUGGESTIONS
- would this fit my car?
- del Sol Mounts
- Need help! GSR Brake conversion on a Civic 95 VX
- tranny/clutch problems?? or something else?
- High flow cat
- What intake manifold is this on my b20?
- Rear seats in EG hatch
- si spoiler
- Re-adjusting the timing belt???
- yesterday i bought a car...
- mad props to...
- Recommendations for an aftermarket Ignition
- cleaning out intake ports on head
- Extra plug after swap??!?
- Civic radiator?
- zex plugs"?
- No spark From my MSD
- b16 install in four door civic
- new user
- vtec head swap
- Mini-Me Swap.... Idle Problems
- backyard front bumper?
- Safe to run synthetic oil on "new" motor?
- How do you remove a Radiator Support?!? Is it Welded In??
- Ls Dizzy Gsr Dizzy the same?
- exhaust system for a civic
- Del Sol price, worth it or not ?
- I got in a WRECK!!
- which exhaust for my eg?
- B16A swaped Hatch Need to pass California smog A.S.A.P.. HELP!!!
- del sol dash swap
- Tech review: PSPEC tuning short shifter
- Lights need to heat up
- HELP! Every gear is neutral? 95 Civic - D-Series
- is my vtec engaging a little late?
- pic request: 99 civic si slammed on stock si wheels
- R.I.P. My little EG :(
- Need brake help.. Cant figure out problem
- HID problem.
- i gotta Q!
- car has 130k. Replacing trailing arm bushing mandatory?
- engine miss???
- Iowa Area Tracks
- where can i get a good deal for PROTHANE or energy sus bushing kits?
- Which pistons would be the best for a 11.2:1 c/r on my y8?
- JDM d15b-- whats next?
- Opinions on L.E.D. Underbody kits
- Worth It or Not
- Change Oil pump ?
- Auto Tranny.
- HELP
- MY AXLE IS STUCK
- Need to find main relay
- runing lean?
- Used Valve Springs?
- 94 Civic EX w/Auto Trans. Question
- rear disc conversion
- exhaust system for a civic ex
- ek fog lights?
- ABS isn't working.
- Hi and Lo beam on at the same time
- honda engine cleaner
- VTEC installation on Del Sol S?
- Quick Question: About D-series Distributors
- how can i check the year of a ls motor?
- WHAT DO YOU GUYS THINK OF THIS DEL SOL
- Dizzy question
- JDM gauge cluster problem. HELP!!!
- Non-turbo or turbo Echaust help
- what would i need to convert my car to right hand drive?
- Ratteling after installing B&M Short Shifter
- Coolant temp sensor question
- My 93 electron blue coupe was stolen last night. B16, BLk/Blu Advan SA3s
- Newbie ECU Question
- Helpm before write up
- H22 Accord Euro R Crazy A$$ question
- question on strut/sway bars
- removing black window Sol?
- power mirrors/locks on non-power Sol
- Timing???
- After timing belt car seems sluggish?
- grease... what kind do i need?
- quick question about 5-lug conv..
- emissions problems....
- Color of 02 Sensor for P2E (I Searched!!!) Need Help ASAP
- B16A2 or B16A3
- Sound of 5zigen exhaust????
- anybody have a dyno of a b16a2 when vtec isnt engaged at all?
- looking for parts civic ex 97
- tapping sound in B16 head, should it be louder than a D16
- rear diffuser who makes it
- Very uneven tire wear on rear tires after lowering
- car vibrates bad, need help?
- What Seats Will Fit?
- 93 Coupe with rear rust Q:
- IACV or FITV? cant tell which one...
- i cant find a j's racing intake
- Perform BREAK-IN
- Outlet size of a stock b16 header?
- just did a compression test r these good numbers?
- z6 automatic to manual conversion
- Got a clock... is it plug and play? searched...
- align cam with crank
- Will EK rear seats fit my EG ?
- CEL question
- vtec....
- Civic VX has a 5 wire O2 sensor correct? L1H1 of course.. But why does my complete stock VX have a
- just wanted to introduce myself
- trust me i tried searching
- can d16a pass smog in cali by changing manifold?
- car wont start help asap!!
- 96-00 trans on 92-95 (auto)
- Another oil pump question...
- eg 95 - rhd conversion or k-series swap???
- windshield wipers
- head
- shift linkage?
- Couple Questions about Exhaust
- Anybody know the stock ride height of a 97 Civic?
- Coilovers Install Help
- ive got an idea!!!
- HELP with d16 and NOS
- rpm gauge retarded
- Anyone with a swap or a SOHC Turbo in Ottawa?
- Turbo seals
- D15B2 Transmission Linkage With a D16Z6 in a 95 Civic
- stock sol vs. stock si
- frusterating idle issues.....GRRRRRRR
- 99-00 civic si intake on EG JDM B16A. Will it fit?
- EK Hatch Exhaust options with swap
- How do you remove the rust?
- This is for all you new people...
- Building my ultimate EK
- custom exhaust
- Dumb Question about GSR brakes on 93 H/B
- GOOD INVESTMENT????????????????check it!
- cooling sytem question?
- D15 wiring harness on b16 engine: does it put out same horespower.
- Crashed my car, need help finding part ASAP!!!
- Automatic to Manuel
- car takes forever to start
- b18c1 in civic 2 door???
- is there supposed to be a washer on the oil pan bolt?
- exhaust problem
- What is the lighest model 95 hatch? cx, si...?
- quick knock sensor question.
- replaced mounts but shifter still moves when i hit gas or decellerate.
- Help with stalling/ stumbling and very poor gas milage
- foglights DRL
- rear wiper blade size?
- jumper harnes?
- Need part number for oem 99-00 si lip
- How to Fix Mangled Rear Quarters?
- Need Help With 1996 Civic Hatch
- Need to know the original ECU
- heat smells bad on 99 honda civic dx
- How can i find out if its a SI??
- EK SiR Sedan With B16A with A/C????
- Where is a good place to find thicker head gaskets for B18B?
- heater not working well. HELP
- Lookin 4 SOHC Jackson supercharger pics
- loud ass N1....shhhh quiet please
- Greddy Headers
- Removing an EG bumper: Tricks for the removing the side screws?
- ecu question...p28
- question about b16 motor and sohc
- Rims + Lowering = ?
- Necessary for flywheel to be resurfaced?
- Parts for 1992-95 civic for sale
- 02 sensor
- Out of the loop!!....Help me rework this civic Si!!!
- Is it possible to Re-Thread axle studs?
- I think I found my muffler! Anyone ever heard one of these or have one?
- Man "Powered by Honda!!!"
- Replacing A/C & Alternator Belt
- 99-00 EM1 Exhaust Question
- tail light differences
- Primary oxygen sensor heater?
- Question car boggs/backfires...
- b20 swap in my civic
- Heater Core
- Bench Racers!! Build the car I want w/$2500.00.. can it be done?
- help with swapping motor please
- Clutch & Flywheel set-up for my hatch?????
- 92dx alternator swappable with 94LS?? or 91dx alternator??
- extremely high temperature than extermely low temperature = cracked block
- anyone running these h22 mounts?
- Switching from ABS to non ABS
- EG9 Rear Seat Assembly into 94 civic hatchback???
- weird sound problem..
- Ek Radiator 99 Si or 94 DelSol?
- ABS light
- Axle problem or what????
- ebay radiator
- ef si seats are so nice!
- s2k pedals in eg
- summer VS. winter gas mileage
- shift linkage
- how fast can a b16 tranny go
- SRS Light (EG)
- ECU problem.. vtec
- HELP! tranny problem!!
- Baffled oil pan?
- WTF is the problem
- Steering clunk
- 92 VX hatch gauge cluster light problems
- Please diagnose my tranny problem!
- Run a compression test?
- is the b16a a direct swap for a 96 EX?
- Exhaust Question? Cat doenst seem to match up to well
- Quick short shifter Q
- d15b8/d16y8 head
- Starting issue - clutch related
- DC Headers For Sale!
- looking 4 A "D16Z6" short block
- RSX REAR seats in ek
- damn it happened AGAIN...got into another car accident...=(
- Exhaust cutout question??
- Quick question, PLEASE HELP!!!!
- CEL help...
- What kind of radiator would be a good choice for a b18 swap in a 93 hatch?
- ITR exhaust vs HKS exhaust ?!?
