View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 95 civic shock tower plug cap taken
- alternator/ other possible issues
- This my 98 Honda Civic hatchback fully done by me
- Engine Cooling System Inconsistency
- 92 Civic: Where to buy OEM GSR calipers?
- Sputtering when acceleration
- Headliner material question
- Connecting pipe oring replacement (water pump side)
- Del sol engine noob
- 93 Honda Del Sol Si (1.6 VTEC) Starter won't work
- Question about wheels and offset
- EH3 Civic Turn Signal/Headlight Problems
- Del sol dash lights not turning on
- B18c5 overheating
- 2000 Civic lx cranks but no start , no check engine on
- 95 EG cluster dimming
- Identifying Bseries cams
- Tach signal problem b18b1 ek
- starting a d15b7on stand
- Working on my EM1 - Questions as I go!
- front upper strut bar. cause rust?
- 1997 Honda Civic Hx knocking
- 92 civic ac valve discontinued
- Changing timing belt... What other maintenance should I do while I'm down there?
- Swap
- How to remove rear side glass - civic coupe
- Best reliable honda del sol build
- HARMONIC BALANCER
- D16Z6 was cutting out suddenly yesterday and now cranks but won't start.
- Leaking engine problems
- How to install EG Hatch Trunk weather strip
- Manual swap into EG using EK parts car
- 2000 honda civic ex sputtering
- HELP!!! SCHA is loose
- 1998 Civic Idle Problems
- Question on body parts
- 00 EX sputtering at start up / extended crank and losing coolant. Head Gasket?
- Fuel Line size !?!?
- Replace ECM
- Eg6 SI Build
- Help me Find this Exhaust !
- 1993 Honda Civic Del Sol main relay problem
- EBay Turbo Kit
- 92 civic hatch with b18c1 swap idled and cut out. Now it won’t start (need help)
- 1995 honda civic obd1 b20b swap electrical circuit issue
- Crankshaft pulley bolt won't come off b18b1
- Rough Start 2000 LX
- Purposefully overfilled manual transmission bad idea?
- Ej1 manual stuck in gear
- how to repair valve cover threads ?
- Odd noise, unsure what to make of it.
- B series swap parts list in a 95 del sol
- Question about Chassis
- 92 EG auto to manual
- Question my B20B people.
- B series Brackets and T bracket question
- Remove & replace fr d/s wheel bearing 96 civic ex
- Didn’t see a thread about it so...
- Doing a auto to manual swap...motor mount post question
- OBD2A fuel injector wiring
- EG OEM Floor Mats
- EG Poor Braking
- Mini me ignition timing
- Removing only shortblock, without trans?
- Does head gasket sealer wreck water pump seals?
- Y8 head swap PLS READ
- Coolant loss 95 Civic EX
- How to test a radiator fan switch?
- What Is This???
- 99 civic power door lock into and front door speakers into. Has aftermarket radio
- automatic turbo on d16y7
- Confirm if this is the thermostat bypass hose
- Anybody know what is this and for what?
- Question for B series
- Y7 to z6 intake manifold question...
- best radiator upgrade for 92 civic? mishimoto?
- Left passenger side door sticks when opened with outside handle but pops open easily
- 95 Civic Dx Overheating
- IZZE module
- Boosted Honda eg d16
- Honda eg boosted d16
- Ran Tranny Fluid in Clutch Hydraulic system. Asking for a Friend
- 2000 civic runs rough only on hot restart HELP!!!
- Ek Hatch
- 99 EX Breaking up/Spitting
- Wierd lean issue
- How to install bee-R to jdm sol SIR HELP!!!
- Intermittent Shaking
- Radio Troubleshooting Help
- 2000 Ej civic sedan front window issues
- 96 Civic ran 2 weeks ago, choking when hit gas pedal, now cranks over but wont start.
- 99 Civic Si won't start
- Front end swap
- 2000 Honda Civic EX Coupe-possible engine swap
- Cruise Control
- Fuse Identification
- Coolent back up Reservoir
- Top timing belt cover
- CV axle problems.. HELP!
- 99 ex Coupe(Scanner not Communicating)
- Mechanical problems
- 1992 civic si
- No vtec, new swap
- Cannot find where thid ground wire goes. 2000 Civic EX
- '98 Civic doesn't start
- What intake for jdm itr into eg hb si?
- What would prevent an P73-A04 IMMO Bypass Board from now powering up?
- What Engine ? HELP please
- Where can I get this tachometer
- What aftermarket B series wiring harness is a good company?
- 97 Honda Civic lx NO POWER
- 99 civic ex sunroof model ANYONE KNOW WHAT CONNECTORS THESE ARE ?
- VSS question
- What sensor is this
- Honda Civic Si ignition switch
- Civic 93 keeps overheating slowly (bleeding air fixes temporarily)
- 98 civic coupe a.c compresson turns on
- cannot find injector manifold fpr
- Civic HX engine swap
- What's that sound game?
- 2000 Si AC Reinstall
- What coilovers are these??
- B16b Exhaust manifold - What size collector?
- Teardown for parts or fix/sell 4 door LX?
- EK Stainless Steel Brake Line Help!
- Need help!? auto to manual b20 conversion
- Any advice?
- What injectors are these?
- 98 civic random misfire around 3k rpm
- Can I use this with this.
- Code 9 on d16z6 EK!
- O2 Sensor Clarification
- 94 Honda Civic EX engine and brake problems.
- 92 honda civic cx hatch back wont start
- 1998 honda civic ex transmission selector issue
- del sol ECM
- Ecu
- Guidance with my build
- Anyone else have this on their eg ?
- ECU Power on 2000 Civic EX standard
- 1992 si sometimes doesn't want to start
- Peakboost peak boost 2018 stay away
- Going insane over this b16a swap
- NEED HELP WITH MY 1998 HONDA CIVIC EX
- D series ps pump on b16b
- Which exhaust manifold for B20 in 95 Del Sol?
- 99 ex - Driver Side Wheel Won't Spin
- Electronic problems
- Broken valve cover bolt = no vtec?
- ENGINE SWAP
- Need help with d15b y8 head setup
- Wires came out of connector the car wont start
- Del Sol Stereo Harness
- Del Sol shift linkage B20B4 block with A1 transmission
- 98 ex civic motor/trans mount problems!! help plz.
- Dash & running lights won't turn off.
- Wont start
- 98 Civic Hatch B20b/S80 swap shifter loose
- 2000 Civic Si (EM1) Loss of Compression
- Wiper arms
- weird Automatic Transmission question
- Installed Hybrid K swap AC kit but AC doesn't work
- 97 LX Driver door power lock stopped working the rest still work
- Engine wont turn by hand with transmission bolted all the way in
- Suspension "grunt" / "knock"
- b16a1 no start
- 94 del sol s automatic shifting issue
- D16y8 into 94 civic vx
- 97 Civic's AC not working. Very hot down here
- 93 Accord. Shaking when braking at above 70 kph
- D16y8 Goes into limp mode randomly No CEL
- 95 Civic radiator upgrade or repair?
- 1997 Honda Civic no blower on any speed setting
- Codes 20 and 41 in 99 Civic
- Transmission replacement
- Transmission needs some pumps in the clutch to switch gears smoothly
- hard starting SI
- honda civic lx 2000
- 97 Civic LX transmission filter? Preventative maintenance help
- What A/C Pressure?
- Honda
- Rear brake line help!!!
- Are the SI rear trailing arms compatible with the del sol S.
- Shock tower problems.
- 2000 Civic Si Bolts for bumper! Requesting Help
- Car bucking and dying
- Thread size of oil filter stud - BLOCK SIDE???
- swap 01-03 cluster on my ek , help ?
- Repair or Replace? Front Bumper Skin
- EK OEM tow hook replacement
- D15b2 eg4 93 mpfi swap
- Del Sol Weatherstripping
- Low IDLE with headlights or brakes pressed in... Clean IACV already
- Another tps thread *SOLVED*
- High Pressure Power Steering Line O-ring
- D13B2 to D16Z6 swap issues/questions
- Loud knocking noise from swapped engine on crank.
- Brand new rack and pinion
- b18c swap into a 1996 civic ek
- Need help don’t know where to start
- Used trans prep ?
- Broken axle?
- what is this drain plug for
- Catalytic converter
- Fog Light Wiring Harness
- obd2a/b iacv idle issue
- Wireworx harness help 99-00 civic
- Clutch Bleeder Valve stripped, Where to buy a new one??
- Reverse lights stay on
- 1999 Civic LX Start and idle problems
- Fuel injector problem
- Head Rattling
- LHD EG optional console for $20!
- I just wanna know about my Dipstick D15B7 to d15b vtec
- 97 ex coup engine swap questions.
- d16z6 head on a d16y7block what would be the compression
- Putting d16y8 in my hx
- civic dying
- Swap issues. Obd2a engine obd2b car
- Electrical Grimlins.
- will an acura integra 97-01 rear complete suspension work on a 1993 honda civic dx r
- A/C compressor blowing hot air
- D16Y7 Valve Train Question
- can you show me a diagram of how coolant flows through my 1997 honda civic hx
- HELP 93 Del Sol Si brake rotors .... Uuugh
- 99 Civic LX Stalling When Gas Pedal Is Pushed
- Honda civic d15b vtech has a couple of problems
- REV COUNTER
- Honda Civic EK OBD2
- 2000 Civic b swap secondary o2 question?
- D15z1 z6 head ecurrently question?
- Liquid leak on Honda Civic 1997 LX
- Reliable Turbo Kit for Stock D Series civic?
- 1999 Civic SI keeps killing brand new batteries
- 97 civic ek hatch not starting issue..
- d16z6 in 95 civic vx
- Strange sound - kinda knock, kinda not
- Mini me
- What’s the worst rust you’ve repaired?
- 2000 Civic DX smaller diameter steering wheel
- Del Sol crank but no start: tried almost everything
- 1995 Civic DX - No Power at Fuel Pump (I have done some troubleshooting)
- Woodlock’s 2000 civic build
- Coilover issues
- swapped civic hard start after fuel fill up
- honda civic 1992 clicks but start
- Loud pop, shift position on brake release
- New Member 94 civic 1.5 l mil dtc 8 HELP
