View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Radiator question
- lost power during Spark test??? WTF
- Horn went off by itself when the car was parked
- window tint?
- Thermostat issue
- b20b does not pass 1000 rpm
- 95 Honda Civic Fuel Filter HELP!!
- braking problem.. plz help
- No steering returnability/ play in wheel
- Redoing my suspension for most comfortable ride
- Car "wanders" while driving
- How much will come out if i pull off my lower radiator hose?
- What Should I Do To My Car Next?
- '94 Civic DX Coupe - what is this cable? SEE PIC
- my b16a is a thermostat junkie!!!!!!!
- what to do with my civic
- Need help with my 95 civic si/95 gsr swap..
- 95 delsol motor mounts B16
- Cam cap order for b16a2?
- gsr leather seats back to life ...???
- 99 EM1 fog lights wont fit flush with bumper...
- DC carpet in 2Dr EJ?
- Locked only set of keys in car....
- Help!! 93 white civic hatch STOLEN!!!
- 94 del slo VTEC flywheel removed
- f^cked up an axle - does it need replacement?
- del sol help
- motor break in periods?
- Who knows about Invidia Spoiler for EG hatch?
- S2k cluster Into Ej1, AP1 Or AP2?? Which Is Better?
- Bad wheel bearing?
- fuel pump problem, its my daily
- Can you put RSX Gauge Cluster into 92-95 civic with modifications, searched
- My VSM EJ7
- relay help
- help with intake manifold
- Does Anyone Have A Link To A B Series Swap Into A 95 Civic DX Thread
- GunMoto's 92-95 Civic EG 4dr (sedan) Side Marker Template & DIY
- About how much should a full gsr swap run me?
- Pool of water in EK hatch trunk.
- delsol bra?
- Blew my block, poor and in school, advice?
- Radiator with thermostat built in, info needed
- Help - MAP Sensor Check engine light - weird sensor and weird pull thing
- Help with wiring issue please.
- d16y7 with a y8 im and ls tb HELP!!!!!
- 97' Civic RPM's drop engine stutters
- Types of gauges that will work in 92-95 civics
- D16A6 dizzy on a D15B2?
- NEED HELP ASAP. CAR WON'T START
- i got a new eg8 clean title for $1000.
- civic randomly boggs at idle.
- After replacing timing belt car wont start
- d16z6 with mild mods or b18b1
- ecu tuning question
- ok delsol ppl i need some info
- 2.5 piping and stock exaust???
- need help,from which Honda are this generator and ignition distributor
- d16z6 intake manifold vs d16y8 intake manifold
- 95 civic idling up and down...
- Valve cover bolt part number?
- CA ref need help
- new clutch burning?
- Converting from d16y7 to d16z6!! HELP!! NEED ANSWERS TO QUESTIONS!!! pLEASE!!!
- Relocate cat on 00 EK, what exhaust?
- tire tucket back after accident
- confused setup
- Idle issue...
- 94 CIVIC-LX Erratic idle on Park
- HID one side keeps going out.
- eg crow del sol
- s2k del sol
- s2k del sol
- s2k in del sel
- temp needle issue
- d16y8 supercharger question.
- some lil @#^%@$&^@#&^$&%$@#&^ hit me tonight...
- Japan Version 95 Lx Civic
- del sol vtec axles removal problem - help!
- My 98' Honda Civic LX, First Pics.
- Bent Steering Column
- Post your car and rate the one above you.
- b18a1 swap........
- EG AUDIO CONSOLE .. QUESTION
- 92-95 Mirror Block Off Plates
- brakes question
- b16a2 swap question
- 95 sohc civic overheating but no heat
- Help! My Innovetive Mounts are off by a half inch.
- help ..lost bolts for valve cover
- Should I rebuild my dx transmission or replace it with a ex tranny?
- 92 gsr si hatch
- Best Year EK?
- b18b1 swap eg clutch problem
- Help on Code 91 FTP 99 Civic with 00 D16Y8
- Need wiring pin out for TPS and map sensor
- QUICK!!! Wire color for Knock and RPM in OBD2A EK SOHC Vtec harness
- Help me identify this piece please!!
- Need Pics - 5g Hatch w/00 Front
- compression test
- Coolant Temp Sensor broken
- Skunk2 or Teins springs for 93 del sol?
- jdm del sol sir s##t brakes
- eg passanger head light not gettn power
- Engine help please 93 civic dx
- motor mount bolt sizes ?
- Eg6 cluster symbols help
- Broke something in head
- civic gas tank
- Hood Realease Cable
- Strange no start - pretty detailed
- WTF car just died on me and wont start, not getting fuel.
- CEL Question
- power or manual steering?
- obd2a engine harness off a Del Sol.
- need 95 coupe driver side window motor
- springs
- Dying D-series help!!!
- DOT 3 or DOT 4 for clutch fliuid
- please help mini me swap
- h22 with 94 accord ls transmission
- Climate controls backwards?
- Ek SqUaD
- lsb1 head obd2??
- S200 push start in a del sol???
- Tachometer Issue
- rolling speedo??????
- finally my hatcher!
- fresh b20 swap starter hitting the flywheel
- Painting car interior??
- CTR/ITR Replica Wheels
- HELP with CA Smog...Failed 3 straight times
- Distance between brake pad and rotor
- 95 Civic block heater?
- d16y8 head on a d16z6 block?
- jdm h22a idle problem
- 93 civic ex automatic engine harness
- Little help guys?
- Replacing rear wheel studs HELPPPPPPP
- Transmission Swap
- wiring problem on B18c1 in 94 civic EX.. help
- Coolant blowing out of air intake nozzle
- b20 problems after warms up.
- How to get more power from my D16?
- Help with brake tuck!!
- 99 si seats ???
- "custom" shift nobs (shifter/knobs youv made)
- Alternator voltage regulator compatibility/ interchangeable ?
- d15b non vtec to a d16z6 swap
- new to HT! have a question
- Heater will not blow anything but luke warm air
- B20 EG Hatch ignition problem
- 1996 Civic coupe RWD S2000 Drivetrain
- gsr into ek need help
- NEED NEW ENGINE, Which Engine Should I Use?
- em1 oil change no oil in oil filter wtf
- Estimated Boosted D15B VTEC power?
- Just a quick rant..anyone else agree?
- replacing glass
- having problems with clutch.
- Springfield MA ONLY
- EK lower in the fron than back?
- Threads Shot on GSR tranny, pay $320 to get fixed?
- Looking for previous owner of swap I just bought
- ignition coil bad??
- Help a guy keep power steering
- J swap 94 civic coupe
- factory integra rear stabilizer bar
- Corner Light only comes on with signal, not when I turn on the headlights
- B18c1 dying when given gas
- tire sizes 185/65/14-185/70/14
- target afr's
- pedal assembly question
- feels like im going to run off the road!!
- d16z6 flywheel help
- MC went out
- REACTIVE RACING HEADERS???
- d16y8 swap wont run right
- Reasonble price for my gsr motor???????
- What do they call this kind of front lip?
- flex pipe?
- rear lca bolt size??
- DA suspension on EK?
- So many tire options...
- HELP, Water leak 1993 DelSol
- Would a crooked rim in the back cause my car to jerk left and right
- Calling all civic owners that drive in snow/ice
- Quick Question
- d16z6 running rich
- del sol disfusser
- s2k hard top on del sol
- RPM's Rise and Fall when cold
- del sol or hatch or da
- 97 CIVIC SWAP RUNNING BAD
- Eg civic Hatch Chassis *Eg6 vs all other eg hatchs*
- Integra PWR Folding Mirrors F/S
- idle issues with ek gsr swapped
- Buy new or make a clone???
- Civic won't heat up!!!
- 97 hatch back windows how to take them out?
- 1993 Civic Won't start Help please
- Will DB8 rear seats fit in EG8?
- anyone have dash lights wiring diagram?
- sohc vtec header and intake manifold will it fit non vtec motor
- will an a6 clutch/PP fit on z6 flywheel?
- eg del sol
- 16x8 - 4x100 - Enkei RPF1 on my Honda Civic!
- WTF did i do to my civic?!
- why is my passenger side wheel more towards rear of the fender???
- Is it worth Sound deadening en EG hatch
- So i Decided To work on the EJ1 and this is what i did + Pics!
- ebay mudguards
- Password:JDM Kevlar Intake (aka "Whale's Penis")
- b18b1 and a1
- NRG/Nardi Quick Release Kit
- 4th wheel bearing in 4 months
- this sucks but lesson to learn
- GSR build questions
- D series alternator on b18
- headgasket,belt and belt tensioner and timing belt
- High speed discomfort
- obd2a and obd2b quick question?
- Installing gauges-oil pressure and water temp
- clutch slipping
- Honda civic si B16a2 head rebuild
- looking for a user/car...
- Stock injector resistance?
- mini me idle issues, can someone help me?
- Help
- Check Engine light question?
- obd2 to obd1 swap info. "answers here"
- what size rims?
- EK motor mounts question
- SOHC thread stripped help (Pic inside)
- gm8 turbo - oil restrictor or no?
- How much is this worth...pics
- strange buzzing sound on startup
- jdm b16 in eh2. What o2 sensor?
- HELP PLEASE! timing belt/ timing issue. I need some advice
- tuning question?
- Coolant leak problem.
- Hooking up scanner port
- A/C question
- 98' EK Hatch Cover Template?
- operating temp.
- high mileage si
- b16b ctr FALLING ON FACE IN VTEC!! PLEASE HELP
- I'm looking for a quiet/stock sounding muffler.
- ctr ek9 wing base
- how big & where do DOHC VTEC decals go on EM1s?
