View Full Version : Honda Civic / Del Sol (1992 - 2000)
- REAL QUICK: 1999 honda civic front lip question?????
- si not getting enough gas..?
- ----- Will a J's racing CF Intake fit my Car? -----
- Civic 92-95 EG6 cup holder problem
- what is a lsd transmission
- What is a LSD transmission?
- is RHD legal in CA?
- energy ball joint boots
- CTR EK9 Mirrors on EM1
- B18B into 95 Civic DX Questions
- cel light..
- Wiring in new ecu clips
- Are 92-00 Civic Top Hats interchangeable?
- Thermostat?!
- question about Power window problems...
- Stick D16y8 Dizzy compatible with Auto??
- B18C help
- change brakes
- Oversized Injector Question
- Vtec question... 93 del sol.
- custom ac bracket?
- THIS MESSAGE IS FOR "93HATCHATTACK"
- Injector question
- rear cam plug question ??
- possible brake master cylinder problem?
- Best Cat Back.
- TK's coupe build. its gunna be a long one.
- no fire
- what are fat fives worth? (gsr integra wheels)
- b16 swap
- whats the better engine, and whats the difference. For a 95 civic dx
- 94 Cupe - B Series linkage
- need some help with exhaust mani!
- my ecu p28
- b16 intake ...engine light
- Mix fluids
- Anyone know what this part is? (Rear window glass clamp)
- Front Brake Pin on EX non-abs
- Pointer on what kind of tunage to go with
- 98 ek manual to power window conversion
- weird clickin noise when cold!?
- overheating question(s)..
- Need Correct Part Number Fast!
- 1992 Honda Civic EG Hatch...brakes SOMETIMES go all the way to the floor at a stop...need help befor
- How to tell is I have a ITR throttle body ??
- d15 block d16 head?
- rev on a b16a
- need to make right choice, any ideas?
- Another Idle Problem
- where to get cheapest bumper?
- Swap Help.
- Brake pedal fade
- AVS Auto Ventshade Window Visors Installation on a 97 Civic
- suede cleaner
- How to swap my d15z1 vtec-e head
- Grinds into third
- ASR Subframe Problems
- The speicific torque to tighten the b16 valve cover bolts
- question on JDM typr r and 5 lug conversion?
- crankshaft pulley problems
- Does anyone have pics of what the prothane/poly inserts look like?
- Alternator not charging battery after wiretuck, battery has enough CA's?
- p2p auto to manual ecu conv.
- VtecProb
- Timing Belt on EM1
- Should i use the mounts that come with the swap engine or ?
- request: EG6 vin #
- is a del sol more like an ehkor eg?
- $$$... body or motor
- ek civic steering wheel
- different spring rate combos????
- eg civic sedan: jdm sir power doors, help?
- obd2 civic injector gang plug
- Suspension help
- Screwed up EK Rear Upper Control arms mounting holes threads. HELP...
- your car on jackstand
- gernal performace ? on swap
- throttle body
- picture of sensor
- ac outlet
- ek swap
- installed springs
- type r
- where can i find these rims?
- headlight assembly
- NEED HELP ASAP
- 92-95 civic 2dr
- LS turbo questions
- someone hook me up with a h22 basemap on p28 chip.
- 99-00 front end
- Brake trouble on a 1994 Civic EX
- help, just about boosted!
- help pulling axles
- cranking noise
- need help with putting 99 si gauges in 98 civic
- HOW DO I CONVERT AUTOMATIC INTO MANUEL??
- At least I'm not spoiled!
- ecu harness
- Does eg ex coupe headliner fit in eg si hatch??????????????????????????????
- Extended shifter ghetto fab style
- state ref question
- gsr 210hp?
- 94 Civic DX A/C...
- Installing Tein Basics....good height setting?
- A/c
- z6 head porting, pluging EGR port
- Buddy Club Pro spec exhaust.
- skunk 2 stage 2 for $325 good deal?
- apexi intake
- turbo help
- '95 Civic Del Sol - how to check or change instrument panel lamps?
- ecu help
- civic vx WHAT CAN I DO ?????
- Ek door swap, DX to SI doors
- No Pressure on the Clutch Pedal
- 93 Del Sol S to Si help
- civic knocking sound
- 92 eg, b18c1, P28.......Sputtering problem when just warming up, ????????????????
- question...
- weight and platform comparison del sol and hatch(searched alot)
- msd coil pack?
- STRIPPING AN EG
- would you??????????
- front lower control arms????
- Need tranny help
- CEL for ECT
- NEED HELP rear wheel bearing for SI
- Mixing tranny fluid?
- Are both transmission oil seals the same size/part #?!?
- is this a real si? pic inside
- GSR into EJ1 Questions
- how to wire a knock sensor to a d series harness..
- New Front end Conversion
- Rough idle possible fix for everyone w/ the prob.
- i need major help.
- ***Help*** mini-me swap
- ek window problem, fuses?
- Y8/Y7 Oil Pump Shimming Numbers
- P28 ECU is better for B16 engien instaed of E30 ECU?
- bleeding the brake
- how do u guys feel about motegi's....
- D-series tranny grind on 2nd gear. Should i change tranny fluid?
- Speed Droping During Acceleration
- 1996 honda civic d16y7 5spd tranny question....
- what does a long block consist of?
- Carpet color for 95 cx hatch?
- ls motor swap help!!
- 99 ls power door lock to a civic
- Looking for EXTENDED Tuner lugs in red!!! Cant find any that fit my rim help!
- LS+B16 wiring harness
- Rough Idle
- Koni's ? How good are they ?
- Filter replacement for J's intake
- Car Weights
- ID this Throttle Body for me, please!
- Grinding Calipers - What to use /w air tools?
- Order RS*R Exmag!!
- official jdm sites
- DC2 Front Wheel on Jack Stands, Engine ON, Neutral and wheel spin on their own?
- Please help on tire selection for Buddy Club P1s
- B18B Auto Trans Good Idea?
- Adding tach
- Reverse lights
- Need help with my build,cost and tuning.
- CONFUSED: Integra Brake F/R on EK Hatch, Si Prop Valve and Master Cylinder?
- clutch starter switch??
- Dumb Question...
- Instrument panel lights not coming on 99 civic
- building poormans type r: should i change the fuel pump..?
- Sunroof
- Instrument Panel (Trunk Light) Problem
- SRS light blinked 1 and 1/2 times not 2??
- ABS on EK Hatch Possible?
- EG EK tranny compability
- Weird squeeking from brake / wheel area
- Tranny noise, need help
- Ceramic Clutch Break In ???
- 2000 Civic, No Radio Power, Stalls at idle
- Idle Problem Please Help
- CTR mirros appearance???
- CEL, need help.
- SRS light
- How do tell if its a real JDM motor ??
- sounds good enough to me
- RC 310c Injectors?
- 92 civic dx need help HEEELLLLP
- mini me swap questions please help
- Help for B16A2
- head light problems.....>_<
- 96 ek front on a eg question
- Rebuilding my stock motor
- Clunking noise if on low speed bumps.
- How do i make vtec?
- HELP!! Question about rear tranny bracket L
- SOMETIMES the car stalls and SOMETIMES won't start...HELP PLEASE!
- 2000 civic si wiring problems
- 2nd gear pops out???
- just sumthin funny that happend today!
- Won't start up.
- Gsr ecu only revs to 3k.. is it limp mode?
- dc integra cluster in a eg
- looking for tuner
- Rear brake line question
- where to buy a high flow cat
- Weird noise, only when cold water pump? oil pump?
- civic coupe stock exhaust
- newcomer
- h22 grinding noise?
- can anyone give me a suggestion
- toda cams???
- Air/fuel gauge Help!!
- exhaust/header questions
- My Build Thread...
- stickey gauge
- P30 Intake Mani
- b16 head on gsr block
- Ground Controls Question
- engine swap
- how much can it handle?
- ITR front sway on a 97 EX civic (EK)?
- part #'s on 95 hatch option speaker panel and bracket??
- i have a question about a wire ing harness???????
- head gasket help
- rear sway bar....
- can any1 tell me
- changing light bulbs
- Recommendation for a Honda mechanic / OR Eugene/Springfield ?
- Transmission help, 2 gear grindage.
- Overheating, sputtering, bad idle - need some advice
- loud rattle from my exhaust
- What is the size of the usual tuner lugs? Like the M12 x P1.5 or whatever...
- EM1 Rear Caliper/Piston Issue - Help
- fump pump/no spark?
- Code 7 TPS - Checked Voltage - What else could it be?
- rhd walk through????
- need a vin check on a block please
- H22 swap axels!!!
- Oxygen Sensor
- Quick B16 Head Question.
- quick insurance question....
- Having car trouble
- new to H-T
- How to tkae the fonr emblem off of 00 Si?
- Greddy kit with E-manage
- swap sites
- car WILL start with usdm ecu but WONT start with usdm ecu -b18c in civic-
- is it possible to run a b16a2 engine harness on 99 civic cx?
- help on ideas and pricing
- EG sedan trim levels question
- i need quick help
