View Full Version : Honda Civic / Del Sol (1992 - 2000)
- TO ALL DYNOMAX AND GREDDY EVO MUFFLER OWNERS>>!! POLL
- TO ALL DYNOMAX AND GREADDY EVO MUFFLER OWNERS>>!! POLL
- Thank god for my 2-way alarm....fuck thieves
- Some wheel studs stick out further then others...
- B18C Running Rough???
- Which to get?
- Causes/solution for running rich?
- GE LS/VTEC Kit...Wrong headgasket?? Pics inside....
- Newbie needs help...Tach installation??
- EG Auto-X Brake Setup Suggestions
- EK Honda TSBs
- How to remove hub?
- Fiberglass headliners?
- Will this work/do anything much?
- Civic 99-00 interlock control module
- Help with wheel choice??
- Tell the Diffrence beteween a 92-95 CX hatch and a DX hatch
- go about boostin accel.
- no fuel?
- misfire dealer cannot fix it
- Exhaust suggestion for a 96 EK plz plz plz help....
- What kind of clutch???
- Weird noise...
- Ek sideskirts on Eg question.
- Wheel Weights
- Mini Me HELP : crank pulley BOLT!
- Getting a new ignition from honda, how does it work?
- thinking about selling my civic....
- HELP NEEDED:94-95 GSR BLOCK IS IT TRACKABLE
- EX clock, Need HELP!!!!!!
- J's Racing Discounted Parts!!!!!
- GSR Head on a D17A2?
- Code 41.........What do I need to change.
- newbie style fitment question. 99dx
- Exhaust Question???
- Someone stole my distributor and wires... doh
- engine question
- non-honda swap?
- jdm climate control in a eg?
- HID pictures request
- which header is better do You think ?
- specv?
- weird overheating problem
- Parts for at/mt tranny swap (already searched)
- rear sway bar problem
- been a while
- what engine to swap???
- timing is really off
- Where to rent Ball joint pressers?
- ECU pins
- Need to Know if I can use a VX tranny to a B16A2 motor 92civic hatch
- jdm EG6 Front brake setup
- what jack for a lowered car
- Help, im getting zapped everytime I exit my EK
- P08 vs P28 on a d15bvtec?
- help with shocks on 2000 civic hatchback
- Greddy Evo II review 92-95 civic
- I have a question about Camshafts.......
- Stock CX flywheel = lightweight
- clutch poll
- Calipers Upgrade
- how do you remove a 98 civic door panel
- My gas pedal keeps on sticking
- Dash Swap - Glove Box Won't Fit
- new guy problem ::: code 45
- Mini Me ECU Question Y7 head onto D15b7 block
- New clutch for used transmission?
- can someone answer me these questions?
- Help removing resonator
- whats the best 02 SENSOR for my setup
- Oil in Intake Manifold (b18c1)
- Ball joint removal...search is down
- Spoon caliper compatibility?
- knock sensor question
- Pulled up the carpet.............
- Stock Radio
- need a hatch within a days drive
- power window help
- Best header for B16
- front wheel hub removal
- gsr swirlies
- a good eg radiator for a turbo car
- Spark plug/distributor question
- How to read a volt ohm meter?
- Front suspension - question about parts!
- Removing 96-98 EK Center Panel (Climate Control)
- O2 Sensor cable won't reach on my new header
- Civic Performance Chips
- Does any one know this?>
- car won't start...lovely
- Fuel Filter Replacement Question?
- VTEC wiring question???
- My New Civic EX
- Hasport Mounts
- Testing Voltage on O2, is this safe and will it work?
- 00 Si using oil & smokes on takeoff
- Help!
- h22 civic custom axels?
- i need a honda crx si
- EG Aftermarket tach install ? Where is the illumination wire? *with pics*
- EG cluster question
- 96+ Power window and door harness
- civic 90hp questions
- valves
- How do you intall..
- rhd del sol conversion clip
- where could i find a wings west spoiler for the 95 civic?
- How's your Gas Mileage?
- hid problem
- V-tec Diagram???
- EG or EH
- PLEASE HELP Problem with tps sensor on 92 eg with LS B18B1
- 4 wheel disc brake swap questions
- valvetrain issues
- No heat!!!
- keystone vs OEM for 99-00 front conversion
- Fuel Filter Symptoms.... 1993 Honda Civic DX d15b, what did you have before changing your FF?
- WILL IT FIT OR NOT..................PLEASE HELP!!!!!!!
- TO ALL DYNOMAX OWNERS!!
- which coilover is best for H22A eg sedan?
- Greddy Sp2 W/ Turbo Setup?
- Engine harness?
- OEM Honda clutch fluid vs. regular brake fluid
- INTEGRA FRONT ON 95 FOUR DOOR CIVIC
- wheel questions...
- Si questions galore!!!!
- where do the airvents lead to?
- throttle cable bracket question
- Cat back
- JG edelbrock or SKUNK2 ?
- HELP!!! IDLE PROBLEM!!!! =(
- 99-00 rear bumper conversion for hatch
- stupid short ram intake question
- Harness mounting
- roll cage or
- 99 civic keeps throwing 01 code even after Oxygen sensor Replacement, anyone?
- HELP PLEASE!!!!!!!!!dizzy question
- d16 crank bolts
- Non abs EK cars?
- 93 civic electrical interruption...help
- Forum Input: Mods Please Input as well.
- exhaust diagram for 97 dx hatch
- No heat!!!!
- fitment issue?
- looking for an eg w/h22 swap and GE intake manifold
- 98 Civic Electrical Psychobetabuckdown
- Where can you buy a replacement Radio Panel
- 16 x 7.5 will they rub on an eg with a 2.25 - 2.5 drop?
- Vaccuum Hose routing for a 95 Civic Hatch turbo D16
- HID onto EK
- GSR OBD1 into 97 Del Sol OBD2a
- brake pads break in how to, resurfacing rotors?
- Map Sensor Problem HELP!
- Swain Technology Headers Coating
- Apex N1 Exhaust?
- Crap need brake help.
- Recently Cleaned IACV now have problems?
- my first mini me buildup
- putting ac in a 92 dx?
- d-serie tranny bolts ? on b-serie tranny
- new delsol owner here...
- weird tapping
- 99 civic exhaust question
- where to buy an a/c compressor 95 civic
- more jdm eg6 questions
- injectors damaged
- Clearing a code, why do u have to pull the Radio fuse too?
- CEL came on, then engine wouldn't rev past 5500
- Radiator GURUS: 2 Nipples at bottom, what for?
- Motor mount insert
- What is the best way to fix this snapped ground wire.
- 92 Hatch stolen MA/RI!!!!!
- clutch compatibility question
- what should i offer?
- brake fluid
- where to get helms manual
- Fuse keeps blowing RR defrost
- tail light removal
- where should i get my cf front lip from?
- question to those running with aftermarket buckets for delsol.
- BOMZ cold air intake
- Speeding up a Civic / Help out a Car Noob
- coming back to honda
- Fittings Leaking
- Keep getting code 1 afre o2 replacement and ecu reset
- VAFC help!!!
- Question about 1997 Civic LX
- Power CTR Non-POWER Fold mirrors....help installing.
- NOVA ppl
- finally got my bar sticker!
- ricey mcriceron
- 11" brake upgrade. Do I need the 23T bracket or the 25T bracket?
- 2006 CIVIC SI
- HIDs on CTR headlights?
- (New Head) Any Last Minute Advice
- 95 Civic Ex 4dr - squeeling like a stuck pig, consuming oil, etc
- another seafoam question
- How much is the 99' Front Conversion for a 96' Ek hatchback?
- h22 civic accord tranny?? was this??
- CEL light was on, changed it and how i have code 1 and 41, whats worng?
- haha probably a easy question
- ls swap question
- Seat bracket fab
- will this exhaust system fit?
- auto trans in 99 ex
- Ok guys, be honest please
- Cluster Swap question - search was down
- 96-98 civic clock
- GREAT DEAL IF YOU NEED A SWAP.
- Will running a donut on my front tire wreck anything
- CA: Officially been Bar'ed by State Ref:.
- 93 VX with GSR Tokico Blues ? ? ? ? Will They Work ? ? ?
- Locked Thread?
- Motor is now fixed! But now another problem =(
- How far on a broken ball joint boot?
- AEM Uego install
- re-occurring code light?
- integra console in eg civic fitting issues!
- Replacing intake manifold today NEED HELP Search down:(
- Is my hatch gifted or is it the same for everyone?
- Need advice on 99-00 Fog Light install.
- Problems with my motor B-series
- B18b in EK
- civic stutters when in mid rpm range
- Can This B16B CAM still working if installed?
- 2nd fan?
- heat wrap?
- 4-door bumpers...
- removal of rsx seat pans
- Chicago area, Black EK hatch w/orange rims!?
- H22A OR LS? NEED ADVICE
- Hawk HPS vs Carbotech Bobcat pads?
- Civic Front Bumper..
- Need help, car no start!
- Theft deterrent?
- ok heres a really dumb question
- When will stock injectors max out?
- anyone know all the tranny codes for d-series and b-series engines?
- Skunk2 Knob::Bronze?!?!
- Does a p28 need to be chipped for a DOHC?
- Pulled over, is this legal?
- More power (NA): cam or ecu tuning
- Heater core.. yes i know search hear me out
- help with code p1457
- prepping oem bumper
- yes..yes another b16a1-eg swap??
- Is this the sound of my starter dying?
- b16a1 block 50,000 miles
- Vibrating Noise - Help!!!
- Mini Me questions
