View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 93 Civic - Knocking Noise when braking and accelerating (solved)
- s200 or s300 for my lsv turbo? which is better?
- 2000 Civic Si no spark, coil/ICM tested good
- Newbie Emissions Question (D15B7)
- Civic burning oil/ compression
- Different iacvs??
- timing tensioner bolt
- Bad O2 Sensor?
- Bee r Rev limiter
- is this accurate? d16z6 info my fuel is cutting off earlier then expected
- p08 ecu on d16z6 vtec issues HELP!
- Power steering leak
- 4-2-1 Ebay Header question
- Bolt broke off in subframe brkt, help!
- swap help
- 1992-1995 civic window run channel seal aftermarket??
- What can I do to my 1999 Honda Civic LX Sedan?
- 2000 Civic with CEL codes - Help Requested
- Head liner questions .
- Broke thermostat housing....
- 93 EX coupe Auto Transmission?
- My Transmission is dead...or is it?? 2000Civic
- coupe exterior
- Can't find Del Sol Tail Light Turn light Part Number
- D16y7 Auto to manual Question.
- Arp Flywheel bolts vs Stock flywheel bolt
- Power Mirror Switch Triggering Power Door Locks
- changed ignitor and coil now car wont start
- License plate garnish removal for an EJ1.
- MY 93' Honda Civic project...
- 96 civic with d15b7 Idling Issue
- Engine vibes after I changed my motor mount
- 94 Civic hatch - dimensions to straighten lower rad support
- 95 Civic Hatch Coolant All over bay
- 92 Civic SiR strip bolt help
- Knock when clutch engaged.
- help!Broken piece inside intake manifold
- 93 Del Sol D15 Timing
- 1998 Civic EX Crank No Start Need Help Badly
- Bee-R Installation Help needed, OBD2A
- Crankshaft pulley bolt torque specs
- K20 Questions (:
- Oil Pan Drain Plug Bolt size, year 2000?
- 1992 civic cx, stuck rear seats.
- 92 civic cx. My rear seat will not fold.
- b18c5 obd2 harness into em1 p2t ecu.
- Bought my 15th Civic Today :P
- B16 misfiring
- cowl swap
- Can You Adjust Illumination on JDM Guage Clusters?
- What B16a/ distributor do I have?
- 00 civic problems :(
- 97 DelSol with B18c swap - starter suddenly quit
- Jdm d15b non vtec questions
- Unknown leak behind driver side wheel, what is this? Is it easy to fix??
- 98 Civic Auto trans problems
- P0705 trans sensor
- 99 honda civic oil on spark plug thread and electrodes
- Power Window Issue
- EJ1 rear seat question.
- Poor gas mileage on 92 civic cx with B16A3
- 95 Civic no fuel no spark
- Time Attack EM1 steering issue
- 4x1 header on a 1994 DX? Worth it?
- Upstream/downstream 02 sensor swap
- Please Help A/C question
- Chipped crankshaft at woodruff key indentation
- 97 Civic B18A1 Turbo Swap Wiring Harness HELP!!!
- import civic 1996
- Shift knob problems
- EG6 LIGHT PROBLEM
- 94 civic tps
- CV axle replacement on a b16 Sol
- 92 DX Hatch fuel line tuck questions
- Heater doesn't get hot any more?
- 2000 Civic Si Misfires
- 1994 Honda del Sol fail smog (CA)
- 1997 Civic full transmission oil drain/change
- b16a2 rev limit
- unable to proper set timing light
- help
- 97 civic hx temp gauge issue
- 97 Civic cx hatchback rear floor beam / panel question
- Non "fart can" style muffler recommendations
- Compression testing
- Power Window Conversion EK civic
- Horn Stopped Working
- oil in coolant reservoir
- DEFCON 1 Water pump replacement problems
- Rebuilt D16Y8 not running right
- Question about "Chipped" Computers
- ej1 rear panel
- overheating 93 civic
- 94 Honda civic VTEC help with the codes
- gear whirring noise
- AC Issue - 97 Del Sol
- heater blower stopped working 00 civic how to test
- Sort of locked out
- Where to buy good window weatherstripping?
- Why does my 1994 honda civic get hot?
- P28 Jumper harness obd2a/obd1 issue 96 civic ek
- Humming sound only when pushing throttle slightly more.
- Wiring diagrams available
- Fuse #44 fi em keeps blowing
- Speedo, Tach and Temp on Gauge Cluster went out
- Good info on a D15Z1
- 96 civic ex no power to tailight fuse with headlights on.....searched
- Cigarette lighter Issue
- 94 Dx "Mini Me" Shuts off, then won't start.
- 1st. and reverse at same time ??
- 1998 civic ej6 lowering springs?
- Smoke from exhaust during throttle
- 97 Civic B18A1 Turbo Swap Won't Turn Over
- the infamous code 43
- dashboard electrical problems /1995 civic eg8 sedan LX
- Axles
- Using an A/M intake without vacuum line cause CEL?
- 1992 civic low idle
- B16a2 Hose Question (with pictures)
- trans dx vs ex
- 1998 Honda Civic CX Hatch AC Problems
- Will Honda power steering fluid stop leaks?
- D16Y8 with D15 block??
- Ebay Chargespeed Lip for 99-00 Civics Quality
- d16z6 cylinder 1 and 2 getting no fuel/not firing
- B18C SWAPPED INTO EG WireHarness help
- Car will only start when it wants to... (Resolved)
- 99-00 civic radiator support question
- LCA bushing loose in bore stock 96 CX
- Leaking gas
- 93 honda civic hatchback si overheating
- BWR oil catch can
- My first build- 1992 Del Sol Vxi
- B18c1 ckp in ek
- Performance part shop in California ?? Also L.A?
- need wire diagram of connector in drivers door (97 civic)
- Z6 Cam in a D16Y7. Will it work?
- Rear spoiler teardown - EG hatchback
- help! vx chassis harness with DX engine
- 99 civic ex suspension question
- EG Hatch Swapping Power Steering to Manual Steering?
- tips on removing rear UCA to trailer arm bolt?
- '99 Civic LX: A/C Recirculation Valve?
- OEM manufacturer for 1998 Civic LX water pump, timing belt etc.?
- Question about shift linkage in swap
- 1998 Honda Civic LX - Defect warm start
- Del sol 1992 automatic roof top problem
- 1998 Honda Civic Dome Light Size?
- lube rubber susp bushings? stock 96 cx
- need help just an d series ecu question
- Will a D15B be a direct bolt in replacement for a D16Y7?
- Clutch replacement tricks
- How to adjust rear camber
- 98 4dr EX wiper blade problem
- b16a high idle proplem
- help with my 97 hatch gsr
- d16y7 honda civic 1995 motor tick
- d16y7 head on a d15z1 block in an ek
- Del Sol Dome Light...
- D Series Headers
- In line walbro giving me problems
- HELP!!!!!
- Throttle and RPM problem.
- innovative mounts which rubber??
- No start help
- Finding trouble while replacing bushings,balljoints, etc
- Power Booster Question
- 1998 EX Automatic Gas Mileage Problems
- B16a wiring problem temp gauge not working help!
- Best place for wideband o2 connector?
- Head bolts keep turning.
- B18, B16 eg hatch exhaust help
- My nieces 1997 dx will not start!!
- Another EBP EM1 restoration thread.
- Exhaust system mounting problems. Help?
- D4 on Dashboard Goes On/Off Frequently
- Coolant temp fluctuating
- Del sol window/lock problem problem
- Easiest/Best/Most Reliable Swap
- 99 EJ6 rear parking lights not working help!
- how does the lateral link work?
- My 93 Del Sol SI (Auto)
- fuel gauge wiring with pics?
- hood not latching.....93 sedan
- What size and thread bolts are these
- Brake proportioning valve
- D16Y7 --> D17 swap?
- Tire sizes and hub bore question
- AC problem
- EG Hatchback OEM Rear Speaker Option Install
- Recommendations for roll cage
- Help! Trans replaced wont start!
- D16/z6 minime swap from d16y5
- 98 Civic Shut Off Suddenly
- r all d15 head, intake & exhaust gaskets same?
- Right Front Rattle 98 LX
- p1509 error code
- Need help O2 sensors
- AUTO TO MANUAL CONVERSION ('99 CIVIC EX COUPE)
- 92 Civic LX: stereo cuts in and out, and more
- Maintenance Required light questions
- D16Y7 Idle problems still long after Z6 Intake Manifold Swap.
- Just replaced head gasket & water pump but still overheating
- Oil does not return to block from valve cover!
- 98 civic problem?
- VTEC-e Engines
- SRS Module Replacement - Car will not Start
- P3X ECU - Can I swap original ECU immobilizer board into replacement ECU?
- 1997 Civic dx trailing arm bushing
- loose control arm found
- What should I pull before crushing a '94 Del Sol?
- Starter problem
- 2000 honda civic seat rails
- Oil filter will NOT budge! Ideas?
- Removing my transtop
- 97 Civic will not crank or startup properly
- rear lca and are problems!
- RPM drop when multiple accessories are on and check engine light flickers
- 96 Civic EX - Need help finding replacement VTEC Solenoid bolts
- Clutch resorvoir keeps being low
- 93 Del Sol/d16y8 swap - running lean with the d15b7 ecu
- getting it ready for swap
- P28 ECU or P08??
- Car wont start when engine is hot
- help! won't rev past 2k d16z6 95 ex
- New ac compressor didn't fit on old lines?
- shocks
- exhaust
- How to straighten/allign frame for rad support install?
- Stumped! Car runs rough no cel Jdm Gsr
- Pseudo knock sound, and oil on the spark plug boot
- Rebuild kit question
- Shifter problems
- wondering about exhaust manifold
- Roof rack fitment Yakima, Thule
- 1997 Nz New ek wiring help
- Ej6 wnt start wiring problems! Help!!!
- Open Header on Y7 NA
- oil on spark plugs
- 1995 civic del sol model s rebuild
- Radiator hose/thermostat question / track car
- 97 CX hatch no rear running lights?
- No crank Please help need advice from someone with experience
- Brakes Issue '98 Civic LX
- Civic ABS light
- Overheats on highway w/ AC on
- B16c1 oil light but no sign of low oil presure
- 92-95 Honda civic optional rear trunk cargo tray?
- Civic Starting Issues
- e.g. coupe wiring help!!!
