View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Suggestions on Suspension
- 99 civic si turbo what ehaust to use 2inHalf or 3in
- Replacing power steering pump?
- cam bolt broken. need help badly.
- Mugen 4-door side steps on 93-95 coupe?
- Interchangeable hoods?
- distributor help
- Need alot of help on install of A/c into an EK with a TYPE R swap
- SRS Light and a few ?'s
- another broken bolt ugh!!!!
- B16A2 Sparkplug Service (Pic inside)
- changing b-series head
- I need advice or help to make my car turn on
- Is it Ricey or No?
- C.E.L Code 4 cps please help thanks
- 97 civic 4 door power window trouble
- turbo problems.
- Spring pin in the shift rod
- Strange question about integra seats into 99-00 EK
- No Start 98 Civic LX Auto
- Exhaust muffler...preference.
- idle problem... ITR w/ 2000 si trans swap into EJ1 coupe
- What's your opinion on an ej DD..
- 97 civic ex plugs
- dash board swap?
- What do you guys think
- Need help passing inspection in Va
- Anyone using a Mugen Fan switch and an OEM thermostat?
- Bad vibration in shifter!
- My 94 vtec del sol...Going for BIG HP...!!!
- Mugen Thermostat and Fan Switch Engagement temperatures?
- Need Help Timing adjustment for 94 Del Sol
- HELP!!!!!! car in gear, clutch is out, car still rolls. wtf.
- corner light prob.
- del sol steering wheel
- Push button map lights in 96-00 Civic?
- So what are my choices for decent cup holders in 99-00 EK?
- B18 eg swap question
- Issue installing exhaust
- Help with FPS
- rear toe adjustment nut problem
- Darn car hesitates when driving...
- Junk Yard Shops In Da 818
- 99 si won't pass 6k
- eg hatch track race
- Questions about the yakima rack
- HKS Super Mega Flow Air Intake Question
- 92 eg hatch door swap?
- H22 DELSOL TRADE FOR BIKE
- weird sound when i turn my AC on?
- Small rust problem
- code 15 can some1 help
- need help with b20 swap into a 92 civic hatch
- 94 dx b16 swap
- running rich every time i step on the gas
- 94 VX Tail lights are goofy as he11
- droppin a h22 in 93 del sol
- 94 del sol need need hp help
- question about wideband o2
- How to install a deck into a 1999 Honda Civic
- My car eats wheel bearings?!
- another p1381 please help
- Possible Cracked head d16y8
- CEL Problem
- engine harness questions
- gsr swap, Mounts in 93 civic?
- Need help ASAP car wont start up not a dead battery, and a weird clicking noise!!!
- help me out please!
- EF apexi n1 exhaust on an EK hatch
- EK Power door wiring question.
- What Clutch Should I Get For My Em1
- Skunk 2 coilovers.....civic drop......
- Cap,rotor Problem
- anyone ever heard of Godspeed
- hearder question...
- eg foglights installation write up/ how to?
- 96-98 trim ?
- JDM 97 B16a SiR-II OBD 2 Into EM1 Question
- quick release question
- 92 dx torque mount issue
- So I got stuck with a D15y8..
- Post only your complete K swap price
- Transmission noise/grind
- unable to locate secondary o2 sensor 93 del sol
- Distributor help?
- distributor problem? maybe?
- what would you reccomend to do?
- Intake Manifold ticking...help
- which wideband 02 to get and how to install?
- h22 afttermarket headers
- tranny question
- Installing Skunk2 Intake Manifold on b16a2
- h22a spark plug wire issues
- Weird clicking noise
- oil squirter...am i F*@$ED?
- 2000 Civic HX - to - b16a CEL 80
- b series shift linkage question
- head bolt help please
- Update
- 98 Civic EX AT only 82K, suddenly died, no spark
- Crome ECU Tuning
- Rear Caliper Replacement
- new brake pads install help?
- Fresh head & block surfaces, new HG, leaking?
- ls b18b swap in to a 98 civic ex
- lights slightly surging at night .96 coupe ex
- Out of gas, now won't start
- Cluster Question
- jdm cluster harness and us cluster, will it work?
- gonna get get 97 ek hatch where do i start
- EK Hatch wing options
- Canadian Si-SiR Rear Brake Swap
- dropping the fuel tank in a 93 del sol.....
- 98 civic ex vtech idle weird
- Alternator maybe??
- desh board change
- my ek 99 SiR PHDM on track
- B16A2 into a 99/00 Civic?
- AC compressor Removal?????
- 99-00 EK fog lights
- whats recommended for the jackson racing supercharger?
- eg transmission
- v-tec problems?
- SOHC possible build?
- HELP PLEASE!!!! REV LIMITER ACTIVATING AT 7000RPMS
- GOD DAMN IT!!! MY CLUCH IN ON THE FLOOR AGAIN!!!
- brake problem woes
- Cold air vs. Short ram vs. 50$ K&N dropin
- 96-00 stock exhaust diameter??
- sidemarkers installation
- SiR lights into my EG
- intake manifold question
- 1997 Civic ek lights surging
- SOHC OR DOHC??
- Do I Have A Jdm Trans?
- chipped ecu
- pulled a cel code 41 help!
- Is a K20 swap worth it?
- d16 injectors question
- need help finishing swap
- will a b18c5 fit a 1996 civic ex?
- k24 into eg help needed
- quick question, did all del sols come with cruise control?
- del sol exaust on my eg hatch
- Car stalls once accel pedal is released
- question bout exhaust.
- Looking to clean up my motor
- Looking for compatable obd2 ecu to replace my p30
- bit of a stupid question
- Surprise Bore Opportnity, maybe 2L need help
- difference between ecu?
- v-tec problems?
- Finally finished my 99 00 front end!
- civic swap help
- Can i use my SOHC distributor coil in my DOHC?
- Need advice on trade
- throwing codes ecu
- Anyone ever installed an unbalanced flywheel?
- Messing around with my exhaust "input"?
- Do you use hondabonda on HG replacements?
- Would foglight wiring be the same for a 96 converted to 99-00 front?
- rear tires wear inside + front rte viberation @ 70
- need help on d series cam gear
- jdm d15b help looking for parts
- Need help removing rubber hood seal clips!
- Need help getting rid of SRS Light with 2.2 OHM Resistor
- installing my jdm coilovers?
- mini me help
- Need to borrow 92 to 95 coupe in O.C cali
- 93 civic D16?? help
- Removing oil from around sleeves..
- D16Z6 Engine
- will 92-95 uca's fit 96-00?
- 08' si seats in a EJ8 Coupe
- Fuel Guage/Sender unit problem?? STUCK ON FULL
- Why does my motor bog when it hits a constant speed?
- Just an Intro: Hello w/ Pics!
- SIR cluster...ANY ideas?
- Honda civic '94 Civic hatchback HOOD question??
- Help: vacuum/sporadic idle
- 93 Del Sol timing problem
- 1997 honda civic dx..HElP..i wanna know some simple mods?
- how to replace tb cable?
- eff, car didnt pass smog, timing was off, any clues?
- How do these fit and look?
- NYS imported rhd from canada????
- 1997 honda civic dx.. NuBB (want to know some simple and cheap mods)
- HELP! My b16a2 is acting up!
- whinning/grinding noise from tranny
- Rear upper control arms 99 Civic DX
- Coilover/Shock Compatibility
- front brakes binding/seizing, right front is worst
- retrofit a 99-00 swap
- motor mount issues
- car wont start need help
- idleling problem
- higer comp. pistons for d16z6.
- Would you trade your car for the newer version?
- need help installing turbo on my sohc
- 2000 si need bushing
- EG Hatch Sputtering/Choking
- 1999 civic dx
- Whats wrong with my windsheild wiper?
- Possible NAM title.. need help
- Needed: everyones honest opinion
- Noisy Transmission problems???
- Transmission Help!!!
- Climate Control Question
- 99-00 Civic Si oxygen sensor wire Question
- Part number check
- someone help plz :(
- 99 distributor small plug 96 big plug conversion??
- QUESTION OF THE CENTURY
- throttle cable problem! help
- 96-2000 hatch wing
- Del Sol Optional rims, 7 spoke with rounds holes
- How to install The 2000 Civic Si Foglights
- Breaking in a new short block
- Wierd Wiring Problem
- transmission question
- Anyone breaking an EG9?
- A/C HELP WILL IT WORK????????
- What would you do if a freshly charged AC is not cold
- weathertech or egr slimline window visors, (in-channel)
- throwing a code 43
- A/C problem!!! HELP!!
- idle problem when letting off gas, car dies
- little help
- 96ek dash conversion.
- i dont even know anymore HELP?
- VTEC without speed sensor help!
- what bracket this is? rear sway bar issue
- 93 del Sol -- Not Starting...Fuel Question
- Mini me swap help!
- LS block
- Need help IAC valve
- 95 civic steering wheel issues
- 95 Civic CX d16z6 emissions help.
- Cooling Fan Help
- will del sol muffler fit a 92-95 hatchback
- WTF is this??? PICTURE diagram.. monster energy drink bottle??????
- intake
- What size injectors does D15B have?
- My car is falling apart!
- EM1 rear mount bracket part #?
- Blown bearing, 5lug conversion
- sohc build
- 99 hatchback mudflap set part number?
- 96 civic injectors into a 93 civic
