View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Distributor on my civic.
- Car doesn't want to turn over
- New to this site.. new 95 Honda Civic Project!
- confusion about coolant lines to auto tranny? A2M
- axle nut broken
- header
- uk chassis codes
- CHICAGO - anyone with trail arm bushing tool for loan?
- Tranny popping out of 2nd gear
- odometer reading?
- will eg gas tank fit DA? N/M
- what ecu for my built head stock bottom end h22 civic
- Steering column alignment?
- Need help with wiring on obd2b to obd1 swap<<<<<<<< Please Help
- catalytic converter
- 1995 Civic OEM Colors
- acg fuse blowing
- sticker emblems
- JDM B16A SIR2 WITH TRANNY FOR SALE
- Tinking, crackling, chattering noise from my B16A..Help
- Expecting the unexpected..engine swap
- Need power window regulator tips
- cold air intake quieting down?
- obd2b swap in 92 CX
- piston / valve clearance y8 b7 mini-me
- is this the actual size of the sidemarker template?
- d15b8 w/b15b7 intake manifold erradic idle - vacuum leak?
- DIY header/ catback installation civic
- Looking for tranny 95 civic ex coupe
- 1 question
- Muffler on Stock Exhaust Question
- srs question!?!?
- Brake Question
- how much is this setup worth?
- Problems after ZEX 59300 cam install :(
- SHIFT LIGHT MOUNTS PIC REQUEST!
- Whats the best most simple way to keep my air conditioning and power steering after swap?
- b16a2 compression test results
- I'm looking for parts at Honda Automotive Parts Online, can you help?
- turbo kit
- Will my eg d15b7 throw a code for spun rod bearing?
- 96-00 ps removal: Easy with motor in the car?
- ITR Seat ??
- ITR sway bar on a CIVIC
- no vtec! help plz
- V-tec problem..
- Mini-me tranny Q
- Partial DIY and pictures of the D16's PCV valve
- 99 civic bumper removal
- looking for thread where they painted a GSR shift knobs numbers red...
- What are the signs of a bad fuel pump? Need help ASAP
- EK Brake Swap w/ABS Question (Yes I searched)
- oil almost quart low?
- Help, tinny, grinding, metallic like noise coming from timing belt area
- 4th or 5th gear?
- 95 civic si vacuum diagram
- whats the best way to secure your car
- search*pic* empty trunk eg5/6
- D15B7 Engine cranking but not starting
- brake swap help!!!???
- Check engine light code P0135
- Size of EJ
- removing motor without tranny, axles??
- Want to confirm:. Is there any way to jump an obd II ecu to find cel codes?
- Can someone identify this buddy club suspension.
- hondata or chip ecu?
- a/c on idles like crap. d16z6??!!
- b16b torque spec
- I need help finding my fuel pump relay
- removing center console on EG problem...
- 92 honda civic b16a hatch best sites and suppliers
- Eclipse turbo for a CIVIC99 si ??
- SOHC Vtec Head?
- Tire size 225/50/17
- 94 ls fuel pump in 92 civic dx
- which civic?
- Magnaflow Hi-flow cat sound like crap!!`
- part numbers for brake lines and e-cable lines??
- ls lca and sway bar 96
- lookin to get another car....
- help on oil spill...
- how to check CEL with obd2b car and a obd1 engine
- Anyone running a Comptech Sway/Tie Bar Combo on their EG? Exhausy Clearance Issues?
- stroked and forced b20
- best ecu for my gsr
- STRANGE exhaust sound help?!
- jdm civic siRII
- how to pass emission test in chicago w/ a swapped engine?
- chip p28 problem
- ek headlight adjustment
- SI head Unit!!!!NEED HELP
- Mounting WW rs lip
- Hardlines for brakes 96-00 civic help?!!?!
- need a pic of a 1995 civic lx dashboard
- New ignition, can i re-key the doors?
- non obd motor ?? can i make it work?
- Nut stuck on fuel rail stud
- Where to buy STR(BDL) Cam Seal
- OptionJDM replica Spoon CF front lips......
- This could have been really bad. Broken A arm
- quick question
- Urgent help needed please. No Brakes!
- **Does cusco make>??**
- cup holders?
- Suspension, Steering, Tires
- running 440s without a upgraded fuel pump?
- ZC
- radiator question
- HELP!!! Del Sol Problem
- b18c in 94 coupe
- How To Clean A Fuel Tank?
- Help! Washed engine bay, car bogs, water in spark plug?
- Need Help with some wiring issues...(So Cal)
- b/mid pipe
- door panel w/tweeter molding for eg hatch..
- squeek? grind? please help
- direct wiring map civic
- insurance question?
- oil on spark plug sleeve
- show off your rims on 96-00 civic coupes....
- Anybody recognize this white CTR replica?
- EG: Tail Light Question?
- Cost of whole A/C System
- dei keyless entry/alarm
- Will an EK a/c compressor fit on an EG???
- question about b20 vtecs in hatchs
- Weird Rattling From Motor B18C GSR
- Your opionion matters! Alarms is the talk....need ur inputs!
- the greddy sohc saga continues
- 5th gear options
- question about 98 civic stock head unit and keyless entry...
- Anyone know a about redline for a sohc
- JDM Engines East Coast
- 95 ex cluster
- Anyone have exploded view or tuitorial for rebuilding B series 5 speed??
- How To - Install variable shift light '00 Civic
- tranny fluid...
- 99 cx Hatch power steering install help
- Quick-e-Q-2
- VIN
- Quick-e-Q-1
- Just posting pics of my del slow let me know what you think
- will ITR axle back fit EK hatch?
- crv guages in a ek ??
- I just did a Magnaflow 2 inlet" and 2.25 inlet"
- CTR piston with b16a rods?
- D-16Y8 with p28 chipped
- do they even make black interior for a eg sedan?
- honda 02 sensor: $241.00!!!
- Honda Sercurity
- Would a 92-95 Civic radiator core support fit my Del Sol?
- IS this normal engine.
- Is it worth it???
- Full coverage insurance on an EG?
- Spoon Mirrors on an EG wiring question...
- neuspeed race springs......best strut for cheapest price?
- Fender liner replacement
- Is dis a good swap f20b in a E.G.
- Decisions......................
- does a y8 dizzy fit on a z6 head?
- Tennessee Clutches. anyone use them?
- Innovative mounts
- auto tranny compatability
- noise comming from alternator/water pump area???
- b18c in my eg vtec only working when cel is on (code 23)
- overheating problem/ A/C don't work
- secondary o2 sensor
- how do you take out cd player in EG Hatch??
- code 17 speed sensor
- integra brakes on my ek
- d16 with a b16 head?
- d16a swap
- DOHC 1/4 times
- EGT problem need an help...!!!
- Swap jdm d15b into 93 cx hatchback
- no reverse lights
- possibly installed chip wrong?
- skunk2 camgear trouble
- Should I be able to turn the alternator pulley with it off the engine?
- b16 v. b18
- how do you install oil catch can???
- Changed Radiator to Dual core but car's still overheating!?!?!
- Safe to boost?
- HKS ground kit
- D15 homemade Turbo
- San DIego: STolen civic..
- Green light in fog light switch
- Idle control Sensor
- volk TE37s for sale(15 in 4_100)
- Toda spec A with ITR valve springs rev limit
- gsr sway bar into EG, SEARCHED
- RWD EG6 drift machine?!
- Prop valve help asap please!
- RPM too high while balancing in 1st gear?
- 92 civic ex stalls, won't start for 2 min sometimes???any ideas??
- sunroof questions?!?
- Rad Problem
- del sol - steering
- I want to apologise (sp?) for my previous post
- looking for..
- gauges
- ?? problems with new suspension
- anyone know who would do an auto to manual conversion in NE PA on an eg?
- need some info
- Stupid Actions 101 (don't read if ur on a strict time schedule)
- burning oil
- Full Race Pro Am Traction Bar Question....
- help: what engine for del sol
- ek suspenion on eg
- 95 Cx hatch Turbo questions
- decal removal
- How do I fix it?
- Gauge Cluster lights not working
- my car wont start, non-engine problem my key is stuck
- Any write ups on installin turbo kits??
- Squeaking noise when releasing clutch.
- Trade/Compatability Question
- where can i buy a johnny racecar intercooler ?? jrc intercooler or a cheap good one fmic asap?
- Headlights, are they interchangeable ??
- Q about header heat tape...
- Plain and simple EJ1 Coupe
- Thanks honda-tech for the last 5 years
- rear seats EG9 into EJ1(coupe) - does anyone do this ????
- need tips on how to remove primer off wheels
- Looking 4pt harness
- Eg projectors
- 93 Civic
- eg gauge cluster looking
- PIC REQUEST: Eg rear interior and yes I searched
- Engine Swap Help
- How do I remove valvestem seals from B16A2 - SEARCHED
- final answer re: gs-r swap
- any airbags for sale?
- Energy Suspension engine mounts
- itr manifold on b16
- What else to do...?
- 96 ek hatch dx weight
- EK 96- Honda hatchback b16a Gen 2 Questions.
- JDM b16a
- overheating 92' civic 4dr
- Mysterious coolant leak...Im so confused!
- 06 si seats into an ek?
- The Final word on 6th Gen Keyless remote
- A/C only blows hot????
- HELP: Taillights stay on
- seatbelt ?
- ES o-rings
- deck wont turn on??
- what are they and where do they go..(sensors, plugs)
- D16z6 Tranny
