View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Y8 ----> Z6
- What parts for HX?
- 95 Civic vs. 95 Del Sol HELP!!!
- battery light keepings lighting up while driving!
- question
- how do i know its the valves?
- vacuum lines on b18c in eg
- d16y8 i.m. with d15b7 fuel rail
- How to fix floating cloth on door panel?
- Into a Sol... h22 or c5?
- Gauges in glove box with afc
- Anyone here own a 7th gen HX coupe?
- what to do?
- Fuel pump Question
- 99-00 headlights on pre 99
- motor swap question
- couple ek swap questions powersteering and reverse lights
- T1R test pipe size?
- Quick diagnostics please
- concerned about my safety lol
- ebrake pics
- Tanabe or Tein??
- New Member
- gsr vs si calipers
- Civic Auto Tranny Swaps
- Clutch problems
- '98 hatchback Rear Tower Strut bar installation = HOW?
- Car starts bogging at 3800-4000rpm need help
- Help Please (Frozen Bolt on Mount)
- removing shift linkage
- independent IAC wireing.
- rear disc conversion
- Freakin' Wipers...
- aem v2
- question Honda Civic 1998 Hx.
- Borla or Magnaflow...which one?
- Can I bleed brakes in a two day episode(rears tonight, front tomorrow??
- VAFC on a D16Y5 HX???
- 96-98 2 door OEM power window conversion/install
- H22 in EG/EK Anyone have hotshot header???????
- Anybody have pictures of a 99-00 CTR Interior?
- Civic Type-r question
- B18a , B18b? swapped in 95 Hatch back.......motor Mounts Requierd or Not???
- Off Topic.....spoonfedhatch is sold :(
- Should the wheels turn while in Park????
- engine overheated...
- help fine
- formula D drift contest infineon raceway
- im new
- 2000 Honda Civic drive belt replacement
- quick question
- im new
- Oops... That wasn't good for the engine
- got my hatch
- Will a d16z6 dizzy work on a y7 into a 94? Help asap.
- looking for P28 diagram trying to find out which wires I need to solder on for vtec!
- Easiest CA legal swap in 93 DX
- Purge Fuel Pump?
- whats the best tranny for fuel economy?
- Will i be able to pass for bar sticker?
- HONDA CRAAH FRONT END NEED HELP
- need help to wire vafc
- tire size
- Part# or place to buy peice to relocate radio behind cupholders in 96-00 civics?
- 92-95 vs. 96-00 FPR's
- WHERE TO GET APEXI N-1 for a 92 eg hybrid hatchback?
- 2dr vs. 4dr mirrors
- Brake Parts Compatibility
- Highest Horsepower Civic?
- jdm b16a sirII t/b vs. usdm b16a2 t/b
- 97 civic EX
- replacing del sol seats with integra seats...
- Will a 89-91 crx/civic hub fit my EG?
- tradding my b16a2 good idea?
- just got ahold of a wrecked k20a2. anything to worry about? where do i get swap parts? (pics)
- What should be my next step?
- Windshield Wipers... Strange...
- air conditioning removal from eg
- Brake lights don't work on 92 CX...help
- wtf
- JDM OBD 1 B16 into a 99 coupe Question
- D15Z1 MPG story
- B18 gsr build up ?
- CAR WONT FU*KIN start.
- Engine won't crank Help!
- 5 lug work with d series
- Alignment Gurus Needed. (Print Out Inside)
- NEED CAR FAXXXXXXXX ASAPPP ....plzzzzzzzzz anyone
- vafc2 tuning! any pointers!?
- Are yellow headlights illegal (Ion Crystal Color)
- jdm ctr non srs wheel... few questions to the owners out there
- LSD help!!!!!!
- Possible Suspension Problem? 92 EG Sedan
- Diffrence between stock Civic and stock GSR shift linkages?
- Stock B18c1 is running 4x richer than normal. HELP!!
- What to expect with an AEM V2?
- bad gas mileage?
- Possible electrical problem, PLEASE help???
- I need some help..
- Got my drivers side door kicked in by some punk kids the other night.(vegas area)
- Ideling problems
- Coupe rear seat ---> EG hatch... how close to fit? (searched)
- Swap problems!!!
- LS brake Conversion on an EK
- oil in a bad place?
- turboed civic not performing (why?)
- ¿?QUSTION?¿
- dont let the civic get beat by a spec v!
- AXLE PROBLEMS in my H22 EJ6!!!
- Intercooler Size
- Replacing stereo and plastic piece around it
- fuel rail swappable?
- How to lubricate my accelerator cable or replace it by myself? Tks
- H22 del sol axle question?
- Are 2,4 door and del sol steering columns the same?
- where can i get some 205/50/15 tires
- HELP! Had problems starting after being shut down.
- 00 Civic radiator?
- Cleaned out intake manifold. Now the idle revs high. NEED HELP.
- wrecked the 95 civic vx
- High compression thoughts and lazy to find the other topics
- close ratio transmission
- Greddy header question....
- crappy interior lighting
- Rear big brake question!
- Where to start with a shell?
- First time at the races....
- honda fluids or other brands?
- 1st gen b16 in a eg, what do I need to retain power steering?
- radiator support help?
- VTEC Controller question...
- Why don't I hear anything about Mods for 7gens?
- SRS code 92, does anyone know what it means?
- *************99 HONDA CIVIC SI PARTS FOR SALE**************
- Contest- Help Me Out
- Contest- Help me out
- Coolant leak near rad drain plug. But where is it?
- 2000 Integra type R for sale ...........................................
- 91 HB w/ Z6 swap - no check engine light?
- Shell price
- Ride is really bouncy
- Which springs to buy?
- Speed Restriction...
- LS into EK swap problem. Someone chime in.
- Question About Seafoam and My Civic
- Whats a civic vx ??
- has anyone ran wheel adapters?
- taillight conversion kit
- car doesnt start
- went to the track today..times inside!
- I have some interior questions?
- How do i remove rear speakers in 4dr '03 civic lx ?
- Emergency HELP!!!!
- Would a 97' front bumper fit a 93' Del Sol?
- EK radiator questions
- need help 98 jdm itr axles
- zex cam finally installed
- Transmission Disassembly Question
- Where to get Racing Hart CP10s??
- Having a problem with my V-afc II
- Hood release cable relocation how-to ??
- Setting the timing on a D16Z6 but with a catch; NO BELT COVER and a cam gear from another motor
- PLEASE HELP!!! EG6 CX/Si wiring harness problem. Wires don't match!?
- Yellow'd Headlights... AGAIN!!!!!!!!!
- initial engine startup after rebuild...
- Help, no Vtec
- 12hp for $20 and a little hard work.
- K20A ground clearance. (Search didn't do it)
- need advice on snapped bolt
- Bell housing question
- Code 6 Code 8 and rev limit at 3200 rpms
- Teg Master Cylinder into an EG - line fittings - Need help fast
- civic, s2000, and Skyline
- need some help: stripped bolt
- I want something new. Help me out on prices
- playing with a Skyline
- 98-02 accord lights on delsol: need help
- has anyone shipped a car before?
- comptech icebox
- Rear disk conversion question
- squeak when i disengage clutch.. clutch going?
- JDM amber corner lens
- intercooler possibilties
- VTEC works then it goes out!
- I broke my mounts last night.
- 92 civic HB w/ B18C, will the header from the b series...
- Shift Lights?
- will crower stage2 cams work with turbo?
- simple but stupid question.....z6, y8 tranny?
- How to identify Bseries oil pans??
- d15b VTEC swap ~ HELP!!!
- 2001 Civic LX (How to do a tune-up)
- where is that damn service connector?!?!?!?!
- jmans car...the civic
- will 90crx locks for door and trunk work on delsol?
- Burnt out Ecu?
- AIS?
- 1992 honda civic hb stock exhaust
- D15b swap
- All those people with reare drum........how do i adjust them
- civic SI seats
- Gauge Cluster
- CRVTEC HELP!
- Teh Engine Sucks!!
- Advice on my 2001 ek coupe 1.6 vti
- tyre size help !!!!!
- bumper doesn't fit right
- Gsr cluster in Eg write up???
- What connector does this go to? EM1
- Off topic: I can't post in the classefied section?
- theft recovery, rebuild or not??
- MAster cylender is bad
- A HEADER QUESTION
- Ferio seats
- 94 oil pan,will it fit a 97 motor,sohc dx?
- synthetic oil - STILL CONFUSED!
- thinking of buying this hatch?
- can you replace the sunroof seal on a 6th gen civic?
- b18c vs b20b short blocks In a 00 si
- Del Sol interchangable parts?
- 1999 civic. Installed throttle body spacer! turn key = 7k rpms or higher!!!
- Nippon Pistons?
- HELP!!!Installing SIR/JDM headlights...
- 93 civic GSR, vtec question
- 95 Civic With A SVT COBRA ENGINE :)
- good paint store in NJ
- Clutch is too light! And no its not a bleeding problem...
- Teg seats
- install: (92 civic si/jdm h22) apexi vafc I; do i have vtm wire?
- Limp Mode??????????
- thinking of buying a friends wrecked civic with 26k
- upper control arm bent on a CX.. options?
- specs on sir-g brakes and eg6 brakes
- hydro-lock question
- (REAL) Carbon Fiber Top
- spoon duckbll wing
- 5 lug onversion on eg problem
- 99-00 si rear sway bar endlinks what is the dia. of the threaded portion????
- timing problems and locked crank shaft
- my alarm control unit burned
- aprox weight of head and block
- another stupid swap question
- oem muffler without resonator.
- '02 Civic Tail light removal
- Jackson Racing Supercharger question.
- IRATIC IDLE
- Throtle body question
- Need help with TPS FAST!!
- Overheating Problems...
- B16a motor swap problem into CX !!!!
