View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Help me choose/opinions
- civic ecu problem
- Help with dx
- camber kits
- Shifting seems sloppy/gooey
- side mirrors 96 EK
- Integra Center Console and Arm Rest into a 5th Gen Hatch?
- HX vs EX
- civic + lsvtec + n/a = 11's??
- Progress Rear Sway Bar
- b20vtec
- si muffler into ek
- GSR Shift Linkage
- hey guys can you help me out a bit deciding.
- Looking for new tranny
- D16 Valves
- Sup people new to the site
- i feel grinding
- 97 hx brake rotor size??
- Stock 02 EX wheels rubbing....
- Will an AEM CAI from a 00 Si fit a GSR?
- got a b16 swap, now wont pass emissions?
- sterio problems
- '92-'95 Transmission differences?
- MY CIVIC JUST GOT JACKED 11:30PM St Paul,MN
- Wanted: 1995 Civic A/C schematic
- HID VS. XENON Lights
- I searched, Prestone Coolent vs Honda Genuine Coolent
- UGH cant get my manifold on..
- d15 spark plug gap
- wiring several gauges/electronics...something blew
- EAGLE RODS FOR YOUR D16 OR ZC!
- ALRIGHT SO LISTEN UP....
- Bolt torque... is guessing ok?
- Endlinks might be broken
- auto to manual conversion
- CTR 5 lug questions???
- A must read
- im ready 2 start my project....set up and pic+ ?
- what should oil psi be at?
- HELP! possible CV axle dilemma!
- Share your ECU tech with me! *56 k no way hey!*
- Thermal R&D exhaust question
- No oil light? Car won't start?
- Quick Questions
- 04 civic ex
- Will a 98 civic ek b pipe it for a Eg??
- d16y7 distributor
- b16 intermediate shaft
- code 16?
- z6 head bolts
- CTR struts/springs VS Tokico Hps VS KYB AGX for a Daily Driver 1999 DX hatch??? HELP!!!
- Vision Amber Corners
- VAFC dimensions/size
- F20B, H22, or B16A2
- ecu HELP!!
- s2000 hids on a jdm eg headlights
- Work list for a 1995 Civic 109K miles and no service history
- 1st post, just wanted to say hey
- Spark plugs and wires worth while on b16a2?
- Install ABS in an eg dx hatch?
- Any other head I can use???
- 92-95 Radio Dash
- new to the site...my 97 coupe teel me what u think
- Denso o2 Sensor????
- installing koni yellows in my ek hatch, how to cut?
- gsr climate contro lights
- code 23 knock sensor after vtec??
- gsr block w/b16 head good combo?
- Clutches?
- HELP CAR IDLES WEIRD
- HELP!..fuel pump install on 02' civic coupe.
- Honda 600s
- Building a B16 EG Hatch....what radiator should I look into
- Me=Retard, tons of air in brake line.. help!
- MY HOOD WONT SHUT!!!!!
- Do D16Y7's come with an oil pan gasket?
- What Radiator?
- D Series Build?
- New suspension Question...
- CEL code 14 help
- Head light adjustment
- Does anyone know anyone producing quality C/F parts?
- will a automatic gauge cluster go into a manual
- How much do you guys think my 99 Si is worth
- ls tranny?
- Meatiest tires on stock rims
- obdII to obd1
- generic intake question
- b18c1 block what next?
- corner lights don't come on immediately
- just look and see this stupid question
- for those with EG's with swaps and no power steering need some imput
- A/T and M/T Air Intake Problem and Question.
- Where should I start?
- How much..?
- I need opinions !!
- Door lock troubles
- turbo EG with stock trim
- How hard is it to change.......
- Motor Mounts For Swap
- Does anyone make CF insert for the stock sunroof on 99-00 Si's?
- quick question about 96-00 sohc vtec head
- GSR swap into 98 Hatch with Skunk 2 IM
- Replacing Frong Brake Rotors
- Help with v-afc2 install
- APC air/fuel gauge install help
- Should a Civic go over 200 wheel power for mountain driving?
- HX wheel width?
- Is Greddy EVO exhaust legal?
- '00 SI front brakes into EG?
- rim offset
- Anyone know where to find the radio code on 99 Civic ex coupe?
- WANT TO BUY: p54 or 97-99 CRV AC compressor bracket. Dallas / DFW area
- Front Sway Bar on a 00 Civic
- Are 90-93 Teg Brakes Interchangeable with 92-95 Civic Brakes?
- Keys.
- How much do you think I could sell my car for?
- Having troubles deciding which clutch disc to use
- Which clutch set up should i use?
- ? about the back of the Guage cluster
- Couple problems in my 98 ek...HELP!!!
- Integra Dash Swap Info
- EX VTEC??
- emergency del sol engine swap
- Catback worth it? <<<NOOB
- Tail Light Problem
- In need of urgent help
- 96 civic Struts on 89 hb
- Headers for 1998 Civic DX
- Diagnostic Test for 92-95 Civic..
- "What would u do" if money were no object on a ls motor for turbo build?
- FS: 1992 Honda Civic LX
- window troubles
- Cold Air Question
- MAJOR PROBLEM with drivers side engine mount
- b18a1 swap for my civic
- EL front end on 92-95 coupe
- i dont know whats wrong
- rochester boy in need of help
- whats with the shake ? ? ?
- did 92-95 dx 4dr civics come with power steering?
- How Bad Is The Damage Of My Car? Frame?
- B18 motor making noises wtf should I do
- 99 parts on 97
- again im lame but
- Does the d16z6 head and d167/8 head have different Cam timing??
- Questions About Speakers In A EK (1996-2000) Hatch?
- Auto B18B swap (PLEASE HELP)
- 195/50/15 or 205/50/15?
- Strange noise when accelerating
- question need help on deciding si's????
- Trouble after Coilover Lowering (Ek)
- What Does this do ?
- stupid question but searched but no results with what im looking for.....do the a/c lnes off a 99 ci
- b18b in to a dx eg
- B16 Throttle Body question......
- 98 itr lsd fit in b16a2 tranny???
- D15b7 -> D16z6 Tranny Help Needed Please!!! ASAP
- what kind of cams are these?
- quick help on tool selection
- CTR crank pulley belt
- Carfax report please.
- da radiator
- ABS plastic front lips vs. Urethane front lips
- Will this work??
- NEED HELP...problem with JDM clock.
- Weird gauge cluster problem...Lighting goes out by itself
- IS IT TRUE AN EG SI HATCH IS HEAVIER THAN AN EG 4DOOR?
- saggy suspension, help please!
- squeeky uhh p/s belt from uhh timming tensioner?
- EK vs EG
- $255.00 for a tune up?
- Need to know?whats best for my car.
- Question on 38mm offset for Mugen RNR's?
- car needs tune up
- very intersting find about Del Sol cars
- civic headlight (bulb size?)
- Rear Shock/Strut for 92-95 Civic (will 96-00 work?)
- b18c1 GSR INTO 98 honda civic QUESTIONS
- JDM front end conversion???
- Oxygen injection instead of Leaf Blower injection
- Loud Metallic 'Pop' when car cools down?
- Smog question... searched
- 98 ITR extractors on Ek4??
- Valve Cover Trouble
- b series swap from stock civic dx
- I bet nobody can answer half these questions!
- Fake J's eg intake in an EK with type r motor - very, very tight fit
- Castrol oil?? new??
- "spoon" style Del Sol front lip
- WTB: Full D15 or D16 non-vtec motor.
- Modified Exhaust
- Question: need help on 97 civic engine light...
- OBD2 Drive Cycle?
- 96-00 ingalls front camber kit, A-ARM style
- NEW 92-95 Civic Mugen Lips (Real Ones)
- i cant post in alot of sections
- EK22 Wiring / Startup Problems PLEASE HELP!!!
- are all b series flywheels compatible with b motors?
- Good places to buy an intake
- Rod Specs... can someone help me?
- Gauge wiring question! (already searched!) Please help! :)
- Del Sol Rear brakes
- some good ideas to supercharge my gsr
- JDM honda logo
- flame thrower kits on 92-95 civic
- Honda-Tech, ha.
- 97 hatch q's
- Code 10/14/41
- zc rods fit in D16y8?
- anyone with a 00 WHITE civic?
- Will a ctr rear sway and itr LCAs work together?
- Installing a strut bar?
- rear disc brake help
- Help...Side skirts for a 99 civic 2dr??
- m turbo Oil pickup - screen cleaning?
- shocks and springs
- question on a grill
- info needed for reffing b16 into eg
- b18c1 and i want to supercharge it
- Someone tried to steal my hatch
- How to post a picture?
- This may sound stupid, but eh....it's kind of techy.
- cant get rid of code 22......
- civic HB for sale: good deal or no?
- anyone happen to know the list price of an s80??
- Big Problem need help on next instalation!!!!
- noise coming from rear end of car
- car wont idle when started...swapped EK
- HELP with wiring- tailights WV/MD/VA
- a/f gusge no read
- auto to manual swap? what do i need?
- Interior Work
- D15b vtec parts
- how to roll power window down?
- car wont start need help!
- waterpump question
- crank pulley chatter?
- Quick Release and Horn??
- Valve Cover Temp
- Question about transmission
- TEIN SS from 99-00 Si fit 99 LS Teg?
- Hi Flow Cat
- Did the cluster swap from DX to LX and fuel gauge is a NO\GO
- Salt oxidation on aluminum
- alignment question....
- Clunk noise on pressing brakes first time
- 99-00 Sedan and coupe Front bumper the same correct?
- NEX Coilovers. Good Price, what about Quality/Ride?
