View Full Version : Honda Civic / Del Sol (1992 - 2000)
- bad starter?
- fuel pressure settings?
- Calling Honda Gurus, please help.
- acura equivalent to majestic honda??
- what would I need to hit 14's...
- ecu question for b20b??
- question about ecu?
- where to buy d16y8 gasket?
- is the auto d16z6 head the same as manual d16z6 ?
- Rear Lower Tie Bar for 99-00 Sedan
- Oh look, yet another idle problem. Take a look, I'm not an idiot, honest.
- New Hatch Minor Questions....
- single cam qestion
- ASR brace with ST sway bar?
- Parts needed for AC (AirCon)
- headers
- how much should i ask for ...........
- open header problems
- WIRING UNDER DASH FOR EG HATCH QUESTION
- JDM V-Tech E?
- b16a .. from stock injectors to DSM? help?
- switching AUTOMATIC EK in MANUAL??
- Brakes Question
- BOOST BOOST BOOST
- Pic Request: Stock D16Z6 Cam Distrubitor End
- GSR Valvetrain in a b16a?
- Hole in my oil pan
- Civic rear disc conversion
- D16y8 redline?
- b16a1 vs. b18c
- best tie rod ends and inners
- SiR-II Gauge Cluster
- Simple intake fitment question
- Dizzy guts, interchangable?
- del sol exhaust question ( same as 92-95 hatch?)
- B16 cam ????
- well this performance upgrade help me?
- wicked cool jdm sideways exhaust, where can i get it yo
- Anyone have some 92-95 OEM Fenders and Stock HOOD for sale?
- coupe Front main core support on sedan
- passwordjdm question
- 99-00 power conversion
- best performance parts
- Does a d16 intake work on a b16 ??
- exhaust leak?
- Perfermance SHops.
- LEAK!! Waterpump Center Area - Where could it be coming from???
- Another Question
- headers on d series
- ? on 2dr and 3dr mirrors.. 93 civic
- Civic 95 engine work
- HMotorsOnline
- Adding power steering to 99 civic
- 4 wire o2 ecu pinouts
- one day project 93 coupe
- FS nts: 93 jdm Del Sol turbo. fully built. only 5000 miles
- lsvtec ?s inut needed
- speed gov engaged?
- Put motor back together, have leftover parts. Identify these please...
- Megan Vs OBX Exhaust?
- 1997 Honda Civic problems...please help
- Windshield Wiper Problem???
- Just got a hatch.
- adjustable coilovers or lowering springs?
- TypeR Converted To Obd1 Starting Problem
- Need help wiring car in PA
- Thread size on shifter bushing
- safc2 questins
- 200 civic automatic why is my cat keep burnin up??????
- SAFC2 HELP PLEASE!!!
- 95 delsol ignition timing question
- need new axles.. which ones though?
- 170bhp civic 1.8vti------integra type r 190bhp whats the difference. can anyone help?
- ?'s for a lsvtec swap n a EK
- how can i know what this half shaft belongs to?
- HELP: size LED bulbs for 97 civic gauge cluster
- rear seat delete
- need help chooseing what jumper harness to go with for b16b ctr motor swap in to a 93 civic
- megan racing header
- Ek w/GSR Exhaust???
- A/C gets cold then no cold not it is all hot!!!
- b18c1 front clip needs??
- civic swap..... need some info ........
- Car only runs smooth when cold
- Gears winding out...
- *jdmmotoring.com*
- !!!!!!!!!I NEED HELP FINDING EM1/EK FOG LIGHT BENZELS(COVERS)!!!!!!!!
- 99 civic si
- standed 99 civic vti-s lost all peformance wont go past 110mph
- "CIVIC" emblem locate at the tailgate?
- oil pump Q's
- Difference in b pipe length in 96 civic dx and 96 civic ex.
- what is the correct timing for stock JDM b16 motor **ASAP**
- anyone with a 98 that once was stock automatic and is now swapped 5 speed vtec please look here
- Is There a way to do the 5 lug conversion on civic without the type r suspension?
- anyone with a 8 that once was stock automatic and is now swapped 5 speed please look here
- horn doesnt work **help**
- radiator hose
- cleaning jdm window rain visors?
- Primary O2 sensor. How do the wires in the plug go?
- H23 into eg hatch??? help please
- What wheels for my EG Hatch?
- D16z6 dizzy
- REAR SEAT CONVERSION
- couple of ?s
- D16y8 cam gear help
- Motor Swap - Wideband O2 in HX - Problem?
- yeaaa...another bolt issue
- need gauge cluster for my 92 eg6
- will 99 civic headlights fit 97 civic?
- Built mini-me compression
- ek hatch for sale
- CTR Headlight help
- Injectors help?!
- crank angle sensor and limp mode
- What size are 2000 EX injectors?
- EG coupe doors on an EG hatch
- Where to get EG duck bill......every where sold out =(
- rear disc problem...please help.
- vafc question
- Now i really need help.
- chipped p28 ecu question.
- Where to get some new Honda center caps for my GSR blades?
- New to forum! Some swap questions
- Bride Rails
- 20" slicks on vx rims??
- 4g too much for a 95 EX?
- Remove Purple from EX Cluster. Help?
- LossOf Traction
- one wire vtec d15b/p08
- rust + bodywork q's
- b16a high idle
- Need help purchasing civic
- question about P54 A/C Bracket
- del sol hood questionm pls..
- need help...cant take out stripped bolt
- How to change rear wiper blade on a 95 Civic HB SI?
- ----question about si rims-----pic request
- Huge problem with no answers still!!!
- auto to manual Cost?
- PWR Radiator
- DC2 cusco cage in a EG6?
- b16a2 swap in EG work in an EK???
- inline four for engine rebuild?
- eg wiring question
- itr front sway bar install??
- exhaust sounds
- what is this sensor?
- Maunal Tranny Mounts
- Auto to Manual Conversion
- a couple or a 4 door civic????
- Transmission syncros???
- POWER STEERING??
- VTEC CONTROLLER QUESTION?
- 92 - 95 civic rear hatch wiper removal question
- What Color Should I Paint My Gutted Interior(92 Civic H/B)?
- help with swap!!!
- Help with a Complete GSR brake conversion on A 97 Civic.
- 92eg sedan Radiator support question???????????
- Tech Ques: How do you replace valve cover seals?
- question about jdm items coming from other place than japan
- where can i buy this exhaust
- Civic..... promblems........ need I say else
- my steering wheel is not straight
- rear disc dragging
- HELP PLEASE SRS
- Injectors?
- Help a trial user, please-post in correct forum
- Does anyone make a steering wheel hub that lets me keep my horn???
- wondering about this...
- ECU help?!
- converting kilo to mph
- d16 block
- how much does a DOHC VTEC motor weigh? ballpark
- brake bleed order??? didnt know there was???
- NEED DIZZY WIRING HELP PLEASE D16Z6!! help....
- PLEASE HELP
- my car got broken into last nite!!!
- Best EG suspension kits for AutoCrossing
- D16Y7 to B16A or ZC? ALL INPUT WELCOME!! PLZ HURRY WILL DECIDE SOON!
- P72 or P30 In my B16
- Snapped cam gear bolt in the cam. Now what. :(
- Honda Car Care Days, April 1 - April 30, 2006.
- Steering rack junk?
- P28 Auto to Manual how to?
- searched... A/C help please..
- ELD????
- Alignment
- catalytic converter placement
- ticket for tinted windows
- sticky throttle body
- Civic SI Problems Pt. II
- check engine... two long and two quick flashes
- jdm lsd s20
- H22 motor swap into a 97 civic (Emissions Problems)
- Del Sol Wiring Diagram need help please.
- d15b7 with d16a6 block?
- Starting problems on a stock 92 lx
- Good place to search or find...
- No power!!??
- which master cyl's will bolt up to a 96 ls teg booster?
- sidemarkers screwed something up.
- replacement muffler
- anyone have a helms for an ek?
- rust repair quarters
- shifter question
- 00Si vs 97 GSR fuel pump..
- Problem with swap
- NEED HELP ASAP - need pinout for 96-00 civic cluster
- SOHC aftermarket Cam Q's.
- Tire Size for HX Rims
- strange chattering from clutch.....when clutch pedal released?
- replaced headgasket and theres still white smoke?!?!?!?
- I think my car is possessed.
- ek ac same as eg ac?
- Ek Coupe w/ ITR 5 lug... what sway bar can i use?
- what looks better.
- Tuning Ideas for Mini Me
- new flywheel + old clultch?
- would a d16y8 fit in a 1992 civic hatchback
- Do I need to replace my fuel pump when swapped ?
- swapping transmissions
- LSD transmission
- del sol exhaust
- drum 2 disc
- car smoking bad
- 96-98 Civic Engine Harness for swap?
- Replace axle or o2 sensor first?
- i want to put ac in my 93 civic with h22 swap
- 92 Civic caliper piston size????
- Crank pulley compatibility?
- Ek for sale
- Best Crank Pulley for B18B?
- Replacing Clutch Master Cylinder & Possibly Slave.....Questions First
- Civic and integra hubs interchangeable?
- Looking for Honda-Tech for some quality help!!!!
- dash wiring ??
- Civic 93 and New Rims Problem ...
- 92-95 Rear wheel arches the same?
- Wierd Things Happening to My Car!
- ZC wiring HELP
- Will A GSR Intercooler With Intercooler Piping Fit?
- Tornado???
- Should I get a header?
- Could someone please tell me how long one has to be a trial member for!?
- b16 engine with b16 tranny or gsr tranny?
- My Interior Dome Light is retarded.
- shocks...
- engine swap question... B16A in EG Hatch... and some exhaust questions
- B16 air intake fit GSR?
