View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Trying to pass smog, HELP
- Bent Chassis Repair?
- 94 civic ex
- b16 engine shake. head prob?
- hesitation under 2000 rpm jerky throttle?
- 95 GSR engine into 97 civic EVAP purge solenoid question
- Honda Civic LX Axle Problem
- Sealing up a hole in the firewall?
- CAM IDENTIFICATION HELP NEEDED!!!
- front frame core support, pull or replace?
- Compression test results
- **98 y7 swap to y8 HELP LOOKED ALL OVER
- My del sol wont start helpppppp!
- Tonight's Findings/Exhaust Cam End Seal Replacement/Ractive Header Fitment Issue...
- Anybody ever replaced the CYP sensor IN the distributor?
- eprom burning problems
- Results from attempted install of Integra GSR brakes on 92-93 Si knuckles.
- idle problems
- Anyone know what these seats are out of????
- 99 Civic EX...Converting it from an auto to 5-speed???
- b16b vs b16a Intake Manifold diff
- What is this?? haha
- noob question about oem front bumper
- AfterMarket mirror Fitment Quick Question
- new chip/idleing at 2000 rpms help?
- 94 civic help
- master cylinder or brake booster im not sure
- where is the best place to buy a complete swap?
- Simple Question: Will EG Harness Bar fit EK
- speed sensor problems
- Help!!! Car died while driving!!! =(
- b18b1 ls non-vtec how do i make it vtec?
- should i keep my b18b1 or go b16a2
- power steering help :)
- OEM Style LED tail lights for 2000 coupe
- shifting issues.
- coolant temperature sensor question
- Torque mount question B series swap
- What's the best swap for an EG??
- Head Gasket Replacement - Car getting hot
- core support cost
- Possibly trading my mini me eg for this eg sedan
- SSR type F Q
- d16y8 question
- GSR LSD trans?
- B18b turbo build gasket
- Is this a good price for a Exedy/Daikin clutch?
- 98 civic EX stereo diagram
- HELP ME FIND SEAT HARNESSES!
- 96-2000 civic A/C Diagram
- 98 Civic EX Road trip ok with camber?
- si seats
- Need info!!! 99 civic si blue all STOCK!!!
- Password JDM Shift Knobs
- d15z1 with z6 intake mani,distributor,and ecu??
- Acura 1.6 EL Tech Thread
- D15z1 throttle body size and help.
- front end????
- Intake Manifold vs Throttle Body
- Bogging/Hesitation Below 4K????
- Is MACCO a good painter?
- burned ecu?
- three distibutors
- Engine gunk and flush plzzz help....
- 95 Ej1 with alittle sweet smell from the tailpipe
- another sluggish b16a
- Are AC compressors for all EG's compatible?
- Valve Lash/Adjustment when & how
- how to tell if inner tie rod is bad
- has anyone seen my baby? 92eg turbo hatch pic inside
- AEM wideband?????
- Is JDMshit.com a sponsor here??
- My 2000 SI Build
- lowering and wheel question
- Yonaka Motor Mounts
- sticky throttle pedal
- can my ride in my del sol?
- gsr block with type-r head?
- wtb b16 parts
- Looking for good garage in San Diego to start my build
- H2B...
- Stand too close and the hoes might BARK!
- How to check CEL's on civic with jumper harness.
- 2004 civic front seats fit an 95 eg
- stolen
- 93 Honda Civic DX/ b18c1 SWAP
- Newly installed wheel bearings keep going bad
- who's running an intercooler and fogs on their EG?
- engine identification
- Trouble Starting Civic. CYP Code...
- B18A1 INTO EG6
- Is there anyway to read RPMs on an EG with a DMM?
- ABS sticker location on 94 Si hood
- need Help chipping my P28 ecu
- water pipe / connecting pipe o-ring replacement
- ESTA TRACK IN CICERO , NY
- d15b or b16a?
- Which LIP to buy?????
- revs out of control
- 92 EG dx hatch with H22 questions??
- My 92 civic hatch throwing a cel!
- HELP! how much to get my car registered in california
- B20 swap help!!!!
- WTB ECU
- what does it take to have a/c??
- Honda OEM Bolts
- 2000 si charcol canister?
- d16z6 turbo problem
- Need help with a ls vtec swap
- 2 o2 sensors
- side molding removal
- b18c gsr with b16b(pct) type-R pistons
- Metal steering column covers !!
- 99 civic ex
- 96 swap
- turbo b16a2 help
- AEM Intake Filter (Cleaning)
- B18C vs B20Z2?
- Intermittent no start solved
- b16a idle prob...
- New brake pads if using new rotors
- what performance parts should i get for my ls motor?
- ECU swap issue
- 92-95 Eg Bubble..
- gsr head or si head which would be better
- Converting from R12 to R134A
- Clicking noise when rolling in gear foot off gas
- Bwhit's H22 EG Hatch Build
- 96 Civic HB Power Door Conversion
- Cam Shaft Position Sensor CEL .. How Do I fix it ?
- HELPPPP car keeps rev.
- B20 dizzy on gsr?
- Need help ASAP
- Tire thread dead
- How to fix broken glovebox hinges
- 94 eg suspension on 17inch wheels
- time is of the essence, need immediate answer
- dc2 rear disc conversion on ej8 question?
- EG sunroof visor hardware??
- Fitting of an ITR header on Apexi WS2
- Fuel tank drain bolt
- Whats causing this wierd idle?!? **VIDEO**
- Great crank... no start! my only dd plz help!
- WIRE TUCK!!OEM CATCH CAN BOX A PROBLEM!!!!!!!!!
- D15B7 in 4dr Civic DX
- b16 intake manifold vs type r manifold
- car shut off and wont start...
- D15B7 Idle Surge/Power loss. Lots of detail. PLEASE!
- pro comp rev limiter help!!!!!!!
- difference between s2k oil filters and regular oem
- Speed sensor
- my ebay kitted 2000 4dr with ls swap.
- Rebuilding GSR transmission!
- eBay suspension parts
- Ek
- converting to rear disk brakes
- obd1 obd2 harness
- About coupe and sedan aftermarket exhaust systems...
- Stanley sidemarkers
- h22 into civic coupe
- Honda Del Sol Trunk Pop Problem Fixed!!!!!
- Power Steering Pump
- 1998 Civic hatch build thread
- h22a shifter cable pics.
- Speaker placement!? Help a honda out?
- Cel code P0141 how to fix it? help
- I need opinions on getting more power
- Bucking at mid-RPMs
- help on deciding what cams should i go with?
- Cel code woes
- 99-00 civic si or 94-01 integra gsr service manual.
- Need a Little Know How (B16a)
- I need to know how to wireCTR Power folding Mirror
- WTF is this??
- Rubbing?
- Is my motor obd1 or obd2
- seats
- OBD1 or OBD2: how do you know?
- B18B turbo Build
- Auto Tranny
- BOV Question
- Ek Doorhandles on Eg?
- 92-95 Coupe Rear window visor?!
- HF Turbo Manifold Question
- 99-00 inj. connector disassembly
- 2000 SI b16 motor into a 98 civic with a d16y8
- h22a axle help
- ac compressor interchangeable?
- Question about 1993 Civic DRINKING oil
- B16 biuld ANY IDEAS?
- Neep Help Trying to redo honda del sol
- b20vtec died wont start
- D17 Speed Sensor on d16
- b swap axles????
- Why is it so bad?
- HOnda Accord SE 2k2, O2 Sensor Check engine light
- Help, switching del sol door exterior handle locks.
- 92 Civic...overheating (epic tale)
- Mystery Plugs
- Front Seats
- chip my p28 or buy p30?
- transmission question for a friend
- Removed Cruise Control, Now Having Idle Problem
- Recommended SoCal shops for EK rear brake conversion and BBK install?
- spindle???
- gsr ek swapped throwing code.
- 195/55/15 on 15x7?
- Vancouver Island Poker Run for Charity
- Transmission issues (isb, and maybe more) advice.
- wtb-99-00 civic si
- P0740 Torque Converter Clutch Circuit Malfunction
- Godspeed cross bars with interior?
- PLZ help me with my 93 del sol
- eg with b18a not getting power
- who can chip my p28 for a b16 near detroit, MI
- simple question- battery relocation
- Remote start FUGGIN UP
- Rear Disc Conver PORP VALVE QUESST.
- rough idle tried everything i can think of
- 94' Civic EX Coupe..Multi-Problems
- B16A2...VTEC NOT ENGAGING
- Ksport Kontrols on an EH3
- weird rattle on the driver's side
- Painted My Valve Cover...
- civic with integra exhaust
- d16z6 tranny grinding into 3rd/4th! :(
- Uneven Ride Height
- ls motor bogging when accelerating
- power port dead?
- Unhappy with Muteki Lug Nuts
- Water pump leak "Q's" on my d16z6!
- Fitment problems....
- My cars value
- Need HELP!!
- Knock Sensor and P28 computer
- Low OEM rails?
- Problems after replacing I M, help!!
- Mysterious Starting Issue?
- Timing is off, dizzy is turned all the way...HELP
- d16z6 dizzy problem?
- Car only starts unless shifted into 1st or 2nd?
- can I use my 94si ecu in a b16 swap
- Idle Issues!!!!!!!!HELP
- vague ass del sol steering column wiring question.....
- ek hatch rear fog light fitment
- GSRd Del Sol!!!!!
- Whats this wing called?
- ac tech questions
- my 97 civic hatch heats up
- Squeaking when braking moderately...
