View Full Version : Honda Civic / Del Sol (1992 - 2000)
- whats better b16 or b18
- EG with B16a2: Need help with b20 swap
- Fuse Box 'option' power source terminals
- d16y8 piston compression
- Lowering problem?
- How to Disconnect Drum Parking Brakes?
- idle problem..
- del sol seats??
- Changed catalytic converter/exhaust manifold car won't start
- Overheating/fan/t-stat problem
- Stock Intake Compatibility 96-00 Civics
- 97 gsr has bouncing idle but no CEL codes
- Replacing wiper switch for a 1997 Honda Civic Ex
- Window problems?
- D.I.Y Door Lock Switch Relocation
- ek coupe rear seats into ej1 coupe
- rs akimoto intake on ebay?
- Jdm p30 vtec
- 1993 del sol rebuilt motor now rattling?
- Little ecu chip help
- Removing 99 Civic hub! help
- 99civic ex with ls engine and ECU: Problem with passing emissions in NJ?
- D16Y7 motor build ideas
- Should I buy an eg coupe?
- Ek Coupe got rear ended cost of damages?
- EJ B18b Swap Clutch Issues
- Help tracking down possible bumper.
- lsvtec pinging
- Car jerks at 4,000 RPM
- Eg Coupe Interior Options???
- Ported D16y8 head ?'s
- 99 Civic LX Cracked Exhaust Manifold, Question (pic)
- new to the civic world and got a few questions
- My lil grey hatch with broken valves! (pics) :)
- What's needed for a full b16 swap?
- b16a cutting out in vtec
- alignment after strut bars??
- RHD VTI DLC/OBD2 connector help!
- JDM B16a Motor Troubles... Wont run good....
- eg hatch z6 timing
- jdm p30 b16 vtec set
- Starting problem. Bad fuel pump?
- D16z6 Gas in oil wont run! Help Please!
- Question about my ODB0 Head with odb1 engine build
- Need picture of the 6th generation wiring for power windows
- Is Tiger Japan a good import site
- Shift linkage hookup... Can't get to Park
- p73 ecu immobilizer removal
- HELP!! JDM GSR SWAP
- Del sol Auxiliary bulbs
- Parking brake confusion
- Continued Del Sol Issues - shakes on freeway and needs new seats
- CA REF Question: 96 Civic with 98GSR Engine.
- Ok getting a 99-00 Civic Si...what can I expect?
- Pimp a hatchback -- reasonable suspension upgrades?
- possible bad trans or bearing
- Door lock. Grrr
- motor cuts out in low rpm acceleration and wont accelerate
- Check Engine Light GO AWAY!!
- Vtec wont work. Help?
- gauge pod???
- 99 si power door conversion
- Strange Knock only @ idle need opinions
- What would you say this car is worth?
- Civic Bogs down in lower rpms
- b18b1 compression
- Best break-in fluids??
- Ignition timing help.
- broken fuel pump? help!
- del sol with big turbo kit
- Bouncy Idle
- Key in chime problem
- I need a motor site... low on options
- Cracked head post for distributor
- Columbus, OH -- In search of help OPENING HOOD!
- quick question about o2 sensor
- 2000 SI wont start
- Will a 99-00 Ctr climate basel fit a 00 Si
- Potential Swap for my EK
- tranny - interchangeability and dissassembly questions
- AC Compressor Differences?
- B16A SWAP IN EK THE RIGHT WAY HELP!!!!
- No start; ECU clicking?
- shocking question
- ITR and Si fifth gears -- Interchangability questions
- EG passenger side airbag removal?
- OBD2a Civic, OBD2b Si engine, OBDI P72 ECU: Need help with wire harness
- my car is a mut... long block ecu and dizzy questions
- Poor fuel mileage 95 del sol s stock engine...
- To have A/C or not?
- B18C1 parts list good?
- How much will a b18 engine/tranny swap cost
- Need help finding a home for these hoses
- Inner tie rod removal HELP!
- A/C issues need help.
- power door conversion not working
- MINIME vtec problems
- 99 si floor harness wont fit my 97 hatch
- do i need a bigger fuel pump?
- 94 civic dx wont start
- d16y5 swap into 2000 lx
- billet cam seal
- Hood Won't open on 2000 Honda Civic Ex
- 99 civic with vibrating transmission in 1st gear
- I have a few questions about adding keyless and auto start into 98 civic.
- when i move the steering wheel left and right makes cracking noise
- z6 in a 96 honda civic
- car is shaking a lot when i slowly let off the clutch
- engine oil lights stays on after start?
- Y8 Intake manifold studs stripped?
- JDM EG6 cluster comment plz, pics inside (from Malaysia)
- Door lock problem with Compustar alarm system
- HOLY SHIT! Whos F20 RWD Civic is this?
- d16 overheat at 40+mph
- How much to install power steering in my 97 Civic?
- trouble keeping coolant in coolant reservoir and radiator
- Help! Neutral Safety Switch? No Crank
- distributor?
- d16z6 not starting
- whale penis intake metal peice confusion...help
- simple b16 question
- 93 civic/ls swap -- no spark or fuel after kill switch installation
- gsr ys1 lsd tranny problems and intermediate shaft leaks
- Bad alternator or battery?
- Engine block help
- 2000 civic ELD is bad. Honda says no ELD?
- GSR Swap won't Start: No power to dizzy or starter.
- 95 civic valve adjustment clearance
- self tuning vs. professional tuning
- 99 si power door conversion in 97 dx hatchback
- What'd I do wrong?
- Wiring k24a2 in 93 civic hatch
- leather del sol seats??? never seen???
- CEL code p0451 and p0453
- Brake HELP PLZ!!!!!!!!!!
- Car bogging, rough idle
- Weird rattling noise
- Used Head Gasket
- d16y8 auto vs. manual differences
- 2000 dx misfire
- OBD1 auto ECU to manual conversion help
- 93 EJ1 wont start (sat for 2 months)
- Limp mode....stuttering
- Branded vs. Generic brake pads
- NEED UNIVERSAL O2 WIRING! 7WIRE TO 4WIRE!
- MYSTERIOUS o2 PROBLEM... PLS HELP!
- j series swap???
- new and need some help
- Air compressor locked and broke belt
- Car died 2 sec. after it turned on.
- Nissan civic hybrid info
- Civic Transmission Housing Crack at Drain Plug Opening
- D16y7 Swap for B16a
- 95 civvie idle surging and drinks gas like clinton is in office
- d15b vtec swap HElP!
- Turns over, wont start.
- ek factory nav system
- AC question for non-ac factory Civics
- h2b build help??
- B16 Tranny Noises Help
- EMERGENCY!! Car Wobbles like crazy
- B16a3 Del Sol timing Belt due
- Radiator Hose
- Rear Disc Brake Conversion on EJ6
- 92 Civic Si SRS problem
- 94 Honda Civic vx delayed starts
- EK Civic all turn signals dont work nor does the passenger window.
- 96 civic hatchback no spark
- PITA electrical prob, dealing with power windows and pissers
- EK Kswap with Rotrex
- D15b engine trouble
- 1993 Honda Civic won't crank
- d15b7 no start
- when relocating the radio down by the cup holders
- Car Bucks while cruising...
- bypass clutch switch
- Anyone Know how to wire up HKS turbo timer
- B18c head on B16a: good mod?
- Iacv/bogging/tb issue. HELP
- OBD2A TO OBD1, MAIN RELAY CONSTANT TICKING
- EG t bracket , half shaft HELp
- SOMEONE HELP ME IDENTIFY THIS HOOD??
- Caliper pin orientation
- fuel gauge issue
- Is the input shaft from b16 and b18 trannys interchangeable?
- EG hatch brake lightts not working!! please help!
- will gsr leather seats fit??
- CEL P0420 & P1361 PLEASE HELP!!
- Ls w/ b16 pistons..... No power after 6k
- D16y8 knock sensor question
- Way to test injectors?!
- Torn between d16 rebuild with turbo OR b18 non turbo
- car bogs, low power, bad gas mileage
- 92 Honda Civic EG9 radiator fan not working but no overheating
- jdm eg6 rear seat bracket
- Civic CEL 45 Fuel system too rich or lean
- throttle cable question
- Type R Mirrors the same for Civic and Integra?
- How much would you pay for this Si?
- 97 CX hatch SRS light is on after swap 97 EX coupe cluster?
- A lot of freeplay while in neutral
- ZC tranny questions
- will this fit on 1997 del sol?
- 1995 si question.
- Y8 Swap into obd1 car?
- vtec-e harness question/sensor question
- SRS light on even with jumpering the plug
- First Honda project...DD EJ8
- lower motor mount bolt just spins ><
- 1993 del sol Lower motor mount size mystery...
- Temp Issues Again
- Need bolts for Bseries compressor
- Timing Belt ?
- RBC manifold on K20 in ej6...help!!
- Problem with rev limit and VTEC crossover: ECU, tach, or distributor?
- Expansion valve
- ECU HELP
- Del Sol compression
- will a 92-95 auto trans work in a 98 auto civic?
- Flat Tires...
- timing belt question
- [B]A/c bracket for swap b18c1[/B]
- brake cables do I require for a civic 96
- Will integra front seats fit in 98 civic hatch?
- Code 16, Makes no sense! Help please!
- 1996 civic coupe gauge cluster.
- differance in ek lower control arms ?
- B18c5 ITR Block
- b18c5/b16a head swap car wont start (CEL #10)
- a quick p0420 inquiry
- Adjustibles!
- Help with under-dash fuse box options (96-00 civics)
- Need Help With CEL/TDC code 43 95 ej1 D16Z6
- Any websites where I can buy an already painted bumper?
- z6 into ek
- IS THIS THE IACV??
- 99 ek/h22 swap help
- making traction bars fit 99-00 SIR
- Looking for swap help/advice
- d16z6 and d16y8 main girdles interchangeable?
- d16Y8 crankshaft pulley bolt torque spec?
- What is a good torque converter for a 99 dx
- fuel pump not doing anything
- Manual Tranny hemorrhaging Dot-3 Fluid...
- civic seems like its dying
- spoon caliper problem....need help
- Cruise Control in 97 del sol
- VAFC Air flow Converter hook up?
- NEED HELP!!! OBD2 to a OBD 1 turbo problems
- Crank Pulley Worry.
