View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Dohc zc timing issue
- Carpet help?
- Misfire on cylinder #4
- will 15x7.5 wheel fit on eg hatch
- Horn for a 1992 honda civic si hatcback
- Lambda sensor plug em1
- Rear Drums to Disk Conversion- Scarebird Brackets
- [EK] Rear Frame Vent Hole Purpose
- 92 Civic killing ecu?
- Replaced the Temp Sensor Same Problem
- Best exhaust and header collector diameter for stock D16Y8
- Honda Civic 2000 DX cranks but won't start.
- 3k Idle D16Y8 Leak In Throttle body
- Del sol -> eg disc brake conversion
- 205/50r15 vs 245/40r17
- Valve Stem Seals Replacement for 1992 Honda Civic VX
- d15b7 oilpan gasket replacement
- Mini me swap help
- Idle surge... car has sat for 5 years 93 civic 1.5L
- 98 D16 5 speed Trans help
- Help connecting loose wire
- High Idle
- K Swap
- Code 90?
- ECT Location on del sol S
- MPG with D16y8 vs B18c1 (or c5)
- New head?
- Back up light fusekeeps blowing
- Brake pedal goes to the floor, new master cylinder didn't help
- car keeps running with key to Off position
- NEED HELP!!!! Swapped a Y7 MT into 99 EX that had a Y8 AT does not start
- fuel pump not priming with ecu
- H22 ecu
- D16y8 distributor
- Interior AC Problem
- High Idle on my 99 civic
- $650 HONDA CIVIC EK hatch project
- 1997 EK Honda Civic fuel pump relay killswitch HELP
- Need help!
- D16YD vs B18C1 weight
- Fuel Pump Harness Gizmo
- D16Y8 + aftermarket header, exhaust, air intake
- Need help with my 98 hatchback
- need help ASAP, sounding metal pieces yeet in transmission!!
- Redoing A/C vent seal, is this ok?
- Del Sol Quarter Panel - Unibody
- D16Y8 or D17A2 SWAP
- New civic owner
- wideband datalogging and tuning with chipped ECU
- New taillights signals/hazards only work when pressing on breaks
- stall on accel from stop after mini me
- 98 Civic HX
- Cannot find other part
- Someone please help, I’m new. 1995 civic sedan
- The snap rings from hell?? - Lost Motion Assembly
- Car tries to stall while driving
- Anyone find discontinued part?
- Factory Antenna Replacement
- Minimum thickness for worn front rotors?
- d16y8 proper operating temp
- 95 del sol Si vtech 1.6 fuel pump not engergizing
- 1995 1.5 del sol bogs badly under load, revs fine
- Need help with bolts
- 1997 Civic producing smoke after service
- One Step Forward Two Steps Back
- What ECU do I need??
- lookin for a mugen replica bumper
- Motor Swap Advice.
- Ek coupe to eg subframe
- DIY simple service tip q's 1998/Civic-DX-coupe / AT / D16Y7 / EJ6?
- B18 chipped cylinder on the outside
- 94 Sedan wheels fitment
- Starting and running problems
- Headliner
- TPS with another connector piggy back on it.
- no power to injectors
- JDM Sol headlight
- 94 Del sol stalled at idle, won't restart
- California State ref requirements for B18 JDM in 97 Civic
- Adding Cruise Control
- Clunking Noise in first?
- Wanting to turbo my ek nz new civic
- Front wheel hub replacement, aftermarket or OEM?
- B16 stays in Cold Start mode even after warmed up
- Aluminum Radiator Recommendations
- Changing steering wheel
- What Head and Intake is this??
- What automatic transmission engine will make my 2000 civic LX sedan to go faster?
- Turn signals/HighBeams turn wipers on
- car is having starting problems/ runs good after its started tho
- cluster not acting rite/ swapped
- Losing p/s fluid, after OEM p/s rack & outer tire rods installed.
- 2000 Honda Civic dx coupe, vent line replacement NEED HELP!!!!!
- Just recently bought a 98 civic hx
- Beginner working on his engine (Spark plugs, Valve Cover Gasket).)
- Fuel pump fuse pops with key turned over, new ecu and main relay
- Trouble finding 185/65/R14 tires.
- SI sedan
- Need help Bad leak down results after head gasket and timing belt
- Fuel filter leak 95 civic
- What do you guys think would look better?
- Stupid passenger window problem, can’t use it :(
- Thin side molding?
- D15B7 iacv hose help
- fuel pump question
- What is Everything that is needed to pass state ref in B20 EK.
- Put some fuel injector cleaner in now cars not starting very easy
- Just did a head gasket replacement now car won’t start
- YCP High compression piston and SpeedFactory no notch rods.
- OEM or aftermarke restoration parts such as seals and weather strips.?
- Need help throttle body gasket?
- Honda civic 1996 vti
- Integra disc brake conversion.
- Pulse/surge with blower on?
- B18c 92-95 Honda Civic Coupe.. Looking to install EM1 OEM Exhaust.. Anyone done it?
- 1993 Civic DX B16 - idle surging after VTEC kicks in
- recommendation for brighter new headlight bulbs
- Over heating b20 gsr head. Only when high load.
- Squealing and grinding noise from engine like metal
- D16y7 non vtec Turbo help!
- Replaced ECU, now have MAP sensor fault
- '98 Civic DX Issue in need of Opinions.
- D16A Block and D16Z6 Head mini me what can i do
- PCV disaster
- Cruise control not working Honda - how to test switch and plug
- Code 16 civic 95
- 1992 Civic VX Wiper Switch Replacement
- D16y7 to b18c swap help!!
- What gauge clusters r a compatible with a 95 Civic EX automatic
- Brakes
- 95 civic ex 1.6 fuel filter location
- Need help with trans info!!
- Question about launching the Car
- Upgrading alternator
- Delsol starting problem
- 1993 Del Sol hoses help
- Did my timing belt slip?
- 99 honda civic obd2b with a 97 d1.6y8 obd2a engine
- 2000 Civic EX White Smoke From Exhaust wont go away for at least 20 mins of driving.
- SURGING IDLE /HUNTING IDLE
- 98 civic Y8 new alternator now just cranks
- 1992 civic hatchback
- Stumped on D16 Stumbling/Misfire Issue
- TPS ISSUE PLEASE HELPPP
- Tps affect gear shift automatic trans
- 95 civic ex car is sputtering
- Am I Missing Grounds?
- OEM or OEM Quality Body Piece Sources (EK9)
- 2 step help
- Motor Swap Help Again…
- B20b4 swap (del sol)no start or crank
- Does a 1992 D15b2 civic eg4 require a cat?
- Negative/positive wire in car.
- Memory Problem Clock and radio
- Tps wiring issue . Civic EK96 sedan b16a
- K24 engine/transmission mounts for EJ1 civic
- Need new hood latch. Where to buy?
- 96 Civic Fuel Pump Doesn’t Always Prime
- SRS light removal??
- Power Steering squealing and grinding
- Thread pitch for 95 civic ex
- 1998 Cluster Swap
- 98 civic d16y8 swapped intake problems
- Intermittent No Start Issue
- Help!!! No clutch pressure
- Overheating?????
- 1997 Honda Civic hx 5 speed smog issue, high fuel trims
- 96 Sedan Not Starting. Non noob question
- Can't figure out stumble after swap
- 95 Honda civic gauge cluster/ fuel gauge
- D15b8 in 98 civic help
- Clanking inside Del Sol steering wheel
- Help! I own an automatic Shidbox
- Oem valve stem seals ..
- D16 HIGH COMPRESSION
- 1997 Honda Civic hx engine swap to a 00 ex y8
- D16y8 aftermarket cam position and crank trigger setup/distributor delete
- Weird interplay between pulsing voltage and squealing surpentine
- D15B VTEC Whiney Aux Belt
- 96 civic ex - D15b, p28 Ecu - Idles and runs bad.
- Acura El spindles and rear trailing arm
- Tight manual steering ?
- 97 Honda civic d16y8 frozen???
- Honda EG hatchback swap
- 600+ Hp 81.5 lsvtec turbo build
- 1992 Civic VX Suspension Rebuild Questions
- make a dash harness for racing ( HELP )
- I have a couple ?s about my motor in my Civic LX it's a d16y8 supposeto bevtec
- 95 del sol engine issues help!
- Drilled hole in fuel vapor hard pipe...how to fix?
- questions about 2 stepping
- Oil leak, not sure if oil pan or rear main
- 95 civic gauge cluster wiring diagrams?
- Bogging/regulator/rev limit at 4000rpm
- Electrical loss
- 1996 Honda Civic EX Coupe & Manual Windows
- Evil Autostyle Vader Cluster
- Skunk2 manifold coolant pipe loose
- Center caps for 90s 8-spoke wheel ?
- 96 Civic EX stopped cranking, won't start.
- 1997 Del Sol - red light between climate and audio?
- 1995 Del Sol will barly run
- 99 EX, Struggle on cleaning the ac duct
- Blown Battery Fuse!! HELPPPP
- 1998 honda civic
- 1998 honda civic
- simple question
- 1990 honda civic
- d16y7 with d16z6 mini me swap, how to hook up heater core hoses
- Fuse 31 PGM-FI,ECM/PCM & Integrated control unit .
- chipped p28 ecu problems (HELP)
- B16A Turbo Build
- NO INJECTOR PULSE RANDOMLY
- EG Hatch spoilers what is the differance
- CAT BACK EXHAUST
- very bad sputtering at WOT
- Ek climate control into eg
- Diagnosing Overheating
- B16a Recently did a dyno run after a few mods
- Ecu help
- 96 power mirrors/lock switch problem
- idle issue after manifold and throttle body install..
- 92-95 Eg hatchback tailgate lock cylinder removal
- 1995 civic idling low and sluggish acceleration
- My civic is acting like a bmw
- EG5 pulling to the right when braking, driving me mad
- Trouble-shooting del sol windows not working
- 99 Civic Aftermarket Radio Issue
- Crank wont start no spark
- AC on an F20b swap EK chassis?
- 96 Sedan Camber Question
- All Three Windows Stopped Working
- 94 Del Sol SRS Module Removal
- Need some opinions on suspension on EG Hatch
- Looking for suggestions on forged internals d16z6
- What is the SE trim???
- ONLY WHEN COLD CODE 8 - OBD1 CIVIC B16A2 B-Series
- Problem:Foreign Frankenstein, D15B block, P2J Head, P6F ECU
- Looking to get my first car!
- Rounded iacv bolt 😒
- Everything Needed to Turbo your D16 and Keep AC/ PS On a Budget! (Parts/ Prices)
- Boosted D16y8 Cranks but no start after overheating
- Looking for some knowledge on a couple of questions
- 93 civic hatchback headliner replacement
- Shifting question - Hard to find gears?
- Honda civic dx code 30
- Ecu igntion power supply wire (yllw/black) touched ground.
- PLEASE HELP!! Car cranking issue 95 civic Z6
- Only 1 terminal on fan relay has power. Fan does not come on when jumped
- 95 civic - new starter engages but engine does not start
