View Full Version : Honda Civic / Del Sol (1992 - 2000)
- start my car PLEASE
- i need transmission for my 00 civic d16y7 in it asap !!! have 500$
- S40 Tranny question
- Difference between 1992 Si and 1995 Ex Shock fork?
- A/C Changeover for 94eg?
- del sol engine swap b18
- tranny help
- Current sale price of 98' Civic HX?
- GC collar upside down
- New Honda pads, Rears drag bad
- B16B which hasport mounts???
- Just bought EH2 ?'s
- p06 to p28 help.
- Where can i find windshield weatherstrip?
- wierd vtec problem
- Location of temp sending unit on 95 Civ?
- obd1 gsr into 99 civic si
- Need Help FAST!!
- non-vtec to vtec
- need to know....
- Electrical Cylinder Switch screws?
- No power to main relay/ fuel pump
- Question About Switching Corner Lights on 2/3 Door and 4 Doors
- p06 conversion
- Automotive grade bolts from Autozone strong enough for holding motor mounts?
- Chipped P08 ECU
- 2000 civic si
- Did A/C come standard on Del Sols?
- What To Do
- Popping a fuse......
- 97 civic 4dr broken hood cable
- 02 sensor problemms
- whats my problem???
- d15/16 axles
- vtec, secondary butterly fly and sway bar ?'s
- D16y8 Head on D16z6 Block
- DIY DSM turbo kit on d16y8
- Question about Radiator Hoses for B18C with B16a2 Head
- Type R k20 ecu where can i get one?
- Back at it. New to the forum.
- intake manifold????
- IACV/Code 14 issues
- clutch pilot tool
- 99 civic si cluster help?
- d16z6 lift and duration(factory specs) does anyone know?
- another honda newbie
- differences between 95 dx and ex
- good plug wires?
- Crazy idle with video
- 99-00 Ek9 Ctr front lip vs. 99-00 Si front lip
- 13" Steelies won't fit on my 93 EX :(
- Help on A/C belt. Yes, so embarresing...
- looking for info on valve cover
- b18c swap help
- changing transmission fluid
- h22 into EG help..
- Help Please! power window door harness help asap
- EG h22 install..
- 2000 Si - B16 - Losing oil
- new guy with destroyed interior
- CTR carpet fit in a 93-95 Civic Coupe?
- 92 hatch with 1996 integra dash
- EK9/CTR headlights real or not?
- Engine dies when warm need help!!!
- Good oil pan for slammed cars?
- ECU's
- radio static
- how wide a wheel can you fit on EK?
- Master Cylinder
- How do you get rid of the valve gap ticking noise?
- Mirror Block off plates/mirror delete covers
- OMFG!! Part 2..
- 92' civic Ex prablemos
- Want to know: EK Type r OEM sticker dimensions
- Misfire Issue
- d16y8 smoking prob!
- PCV valve grommet stuck in Black box need serious help
- i want a QUITE EXHAUST!!! HELP PLZ!!!
- Brakes for K20a swap???
- difference between OBD1 and a OBD2 with d16y8
- d16y8 swap to a d16y7 non-vtec
- question regarding power window into an eg
- Motor Pull
- What is a good Header Upgrade?
- Attempted Grand Theft Auto in SoCal.
- CTR ecu
- O2 Sensor trick
- my car
- ctr and ctrx
- how do i put a/c on my eg gsr swap
- Japan-partner?
- Swaaped in B16a2 from D16y8 and Power steering doesn't fit. options?
- weird problem
- 95 civic with 248,000 miles on original clutch.... replace even though it works great?
- JDM OEM Yellow Question. Help please, searched already....
- Brake pads?
- Dashboard Vin Replacement CHP Blue Tag Process?
- squeeky steering when stopped
- lower control arm bushing
- sohc d16
- new
- looking at a dx. and wondering how hard it is to drive with no p/s
- trailing arm tool
- Is this the right throttle body & IM combination pictures inside
- Injector Install HELP ASAP
- Big problem with turbo sohc Need help asap!
- b17a1?
- Remote lock + aftermarket stereo?
- Clutch bleeding problems searched and to no avail! PLEASE HELP!
- need help changing tranny in 98 civic ex from auto to manual!!!
- b16a2 turbo
- adjusting headlights
- Civic eg fix
- 96-00 front seats fit 92-95?
- Just wondering if anybody has swapped a J-series V6 in a Civic yet?
- will this fit??
- AC Fitment Questions
- Fluid Review (please, no oil rants?)
- odd del sol tranny issue i hope this is a known problem
- Cooling system overkill??
- Tein Suspension Kit question
- Si rebuilt block, burns oil fast
- How to change the clutch
- Speed Sensor Plug (VSS plug)
- REAR DISC BRAKE CONVERSION
- 92-95 civic COUPE tail lights same as HATCHBACK tailights?
- CODE 10 and CODE 14..HELP..WHAT ARE THEY I CANT FIND THEM ON THE INTERNET
- Carbon Kevlar Lip EK Civic 99-00
- compression
- honda fit lip and sideskirt on to a civic?
- Gsr ignition timing....cant find mark on cover?
- will honda insight seats fit a civic????
- HElp no one has the answer and cant find it anywhere
- engine idols fine then drops
- Random misfire
- Which offset for Rota Slipstreams, +40 or +45?
- Loose Alternator Bolt?
- O2 sensor CEL
- im tryin to put a transmission in my civic ex
- Control Arms
- Break-in time for new motor
- Civic HX ECU/ECM issue - A32 vs A33
- Pinouts for O2 sensors on OBD2B
- D16Y8 Manifold on a D16Z6
- header to catback question
- Headlights help.
- 96 civic ex air bags deployed..how do i reset
- How to adjust timing belt on 1998 EX
- 95 Civic EX Car dies while driving....
- knocking noise when engine is cold
- Vehicle Speed Sensor, VSS problem
- Whats the color and Code of this civic?
- Problems after motor swap by shop
- FOG LIGHTS!!! there killling me!!!
- need some help
- Spark problem with VX motor
- B16 head/ GSR block?'s
- used DOT 5 in my car...
- LOUD VALVE TICK AFTER INSTALLING MOTOR?HELP
- 92 4dr suspension advice
- 94 civic with 97 gsr swap i need sumhelp doods!
- How Much Do i Need To Torque This Down?
- STOLEN:MD 00 4door champagne 9/30
- Texas vehicle inspection checklist concern
- windshield replacement
- Clutch Switch
- timing belt problems
- Maintenance tips/General Tune up tips
- Canard Question
- Looking for the 0-15mph time for a 95 civic ex coupe.
- Y8 Intake Manifold Question. Will it work?
- what does offset mean ??
- whats the difference between s80 tranny or y80 tranny for a gsr
- cruise control, horn, srs light all messed up
- how to wire a neutral safety switch on a 95 civic
- need help on shift light
- hey what should i do to my car??
- No fuel going through
- gsr swap. slicks or drag radials? whats the advantages??
- just did a swap.. help appreciated
- sohc d16zc
- Can HYDRO B16 transmission Internals be used in a CABLE B16 tranmssion??
- which cams dyno highest horsepower gains
- d16z6 rod bearings help
- Back into the Honda Scene
- vss problem. code 17.
- main relay not screwed; is it ok?
- rattling sound underneath car
- Actual opinions needed, Is this a fair price...?
- D15B swap.
- brakes (96 civic)
- mini me.
- S2k Cluster swap
- Seafoam
- makes or has carbon fiber
- Hasport motor mounts?
- bad idle/timing belt
- trial user
- Intercooler ?'s
- help with bleeding clutch
- BOV help
- 97-2001 Honda Prelude Seats In 92-95 Civic Hatch
- I need YOUR opinion ON oil STABILIZER .....
- Map CEL only when cold. HELP Please!we
- runnin a z6 with itb's...head gasket?
- need input
- transmission stuck in 4th, need advice asap
- pr3-3 valve removal/ installation
- Pimp My Ride :D
- 98 will not start
- power window!!! experts
- 97 civic ex coupe o2 sensor issue need some help
- smog
- 00 si engine code pop
- Stock A/C with 97-01 CR-V A/C mount bracket
- Question about p28 ecu swap for an 1999 si
- SRS Codes
- buying engine from passwordjdm?
- Cleaning Your IACV, Add this to the FAQ
- 94 civic and 94 del sol passenger aigbags
- 99-00 HEATER VENT TO CTR VENT
- one trailing arm bushing bolt broke is one enough??
- Just curious to ask you guys...
- Thermoswitch / Radiator Fan
- TDC???????
- 01 Prelude Seats in Del Sol
- no vtec harness... what to do?
- Stupid question....... Clutch feel.......
- d15b oil pressure switch?
- Stupid Trim Question EG Hatch
- pic request
- 98 single cam non v , power steering problem help needed please
- need some help please
- What specs should the headlights be adjusted to?
- Anyone know how to adjust the sunroof on a '97 EX?
- gsr in 96 hatch no vtec
- Tanabe Sustec Pro S-OC coilovers for $250?
- My horn quit working... need help
- electrical problems
- Civic Ej8 door moldings
- temperature gauge flickering problem
- wheel fitment question. very frustrated
- WHAT IS MY ECU TYPE?
- performance upgrade for 96 del sol
- bbk 62mm tb problems
- S2k Seats
- What swaybar brackets to use on 2000 civic dx hacthback????
- 98 civic hatch cx
- clutch master cylinder failure
