View Full Version : Honda Civic / Del Sol (1992 - 2000)
- engine coolant temp sensor
- help????? JDM eg cluster?????????????anybody know about the bulbs please help??????
- RED CIVIC DOOR HANDLES!!!!!! 92-95
- compression calculator
- 2005 civic seden oil filter fit B16a?
- EJ SUSPENSION DIFFERENCES??
- Ls Vtec dowel pins???
- 93 hatch w/ ls swap
- User Friendly alarms
- How hard/much to install A/C on 2000 CX hatch?
- Removing a stain?
- Din gauge pod
- type R launching???/
- Wanted: Stock d16y7 or d16y5 exhaust manifold
- Clutch problems HELP!!!
- Polyurethane L/R Upper mounts???
- del sol door panels
- NEED HELP BAD!! clutch?
- First K20/EG to Pass CA State Ref
- d15b swap into 93 del sol. WONT START!!
- rear dic converstion
- Del sol.. smokin
- cranking forever to turn on
- resleveeing a gsr block
- Foglights Help
- Tranny question...
- 5th gear Problem!
- HELP B SERIES CRANK POSITION SENSOR WIRING PROBLEM
- power steering pump and bracket help
- Wiring Harness Help!!!!!!!!!!!!!!!!!!!!!!!!!
- 98 HX with a little bit of hesitation
- eg heaadlight questions
- B18C GSR with Type R cams
- Z6 head, Y5 dizzy
- chattering sound on 2000 ex coupe
- y8 IM makes car run rich....i think
- Custom line for 4040 prop valve to 1" GSR Master Cylinder
- SPOON CAMS NOW TICKING NOISE???
- over heating
- 95 civic hazard wire to integra hazard question? please help me...
- how to get rid of grinding
- clutch problems
- Code 24
- LX Transmisson options?
- b series clutch
- Anyone use freeze 12 in place of r-12 for a/c?
- need this piece
- throtle cable for swap
- tranny
- Help !!! del sol vtec high idle
- H22 in an EJ6
- how to slow down turn signals??
- auto to mani swap
- ECU BLINK CODE QUESTION
- HELP!!! starter problem with swap
- New CTR 300mm brakes onto EG6
- HELP!!! WEIRD POWER WINDOW PROBLEM ON MY 2000 SI !!! PLZ LOOK!!
- Cheap Effective Mods: Newbie question
- Exedy cerametallic clutch stage 2
- d16y7 burning coolant
- MORE OFF THE LINE POWER / Torque for My 2000 CIVIC SI
- where to find oem carbon fiber hoods in stock these days?
- heat coming from center console through emergency/handbrake?!?!?! wth?!?!
- Most intakes are 3 inches right?!
- Bad water pump I guess?
- Corroded/Rusted Throttle body?
- how do i remove my power mirror on my 93 del sol?
- noobie question
- MAP SENSOR BAD?
- Jdm fogs on the side bumper??
- how to bleed the brakes after full brake swap?? search button isnt showing up :(
- Genuine OEM CTR/ITR oil caps... all metal?
- alternator / starter question
- CARB items who?
- can I use this for my car please help!!!!!!!!!
- leak in engine bay
- clutch problems
- New suspension but still rides rough???
- Dash and cluster lighting problems....
- power window conversion....
- Help
- Installing Drum brakes 96-98
- Preserving headlights with clear coat?
- Which Throw out bearing??
- I need help. My brakes pedle goes to the floor after swaping back a SOHC motor
- p28 ecu problem-code 1
- what parts to sell from a lhd swap
- Best place to go to find inexpensive, quality remanufactured parts
- Firing problem
- Can anyone run a carfax for me? Anyone got unlimited?
- Rear Suspension Problems on 99 Si
- 2000 civic ECM problem
- Telling difference between SiR & SiR-S
- Advice needed for turboing my b16 SiR
- act clutches
- hmotors online
- P7H Ecu...
- evo, sti killer build?...
- rear brake piston boots
- EG interior question! help plzzz
- old home to new home will it fit? and some 4 dr questions
- rear subframe tearout question
- the PIN!!!!
- obd0 b16
- b18c turbo videos please
- Help me fix my power mirror
- help on fixing my climate control
- Will 96-00 civic air conditioner fit a 93 civic?
- Intake Manifold Help 96-98/99-00
- shift light question
- New paint job / Unbend frame (not serious) - (SOCAL)
- I've searched high and low for headlights with the lens made of plastic. Where to find?
- finally got my a/c running, but.............
- Rear integra trailing arms in a civic??
- VAFC as a tach
- 93 Civic dx hatch - MPG
- auto to manual thread *Update#1* Got pics .. tell me what i'm missing/what this is!
- Moving Throttle & Brake Pedal Closer
- D15 Bogging/Hesitating
- VAFC2 help
- Charcoal Canister
- brake shims missing..wtf
- dc2 rails into an eg
- cam question for d16y5
- diffrence between hx and ex
- Code P1457, Idle all over the place
- Diff. Clusters (other than s2k) into an EG, EK, EH etc.. BIG THREAD
- Car overheated........what now?
- speedometer
- d16y8
- Searched: VTEC Solenoid, how much oil will leak out when removed?
- where can i get some new 99-00 civic si seat rails?
- Question about d15b7
- wtb 94-00 misc b series parts!!!!!
- overheating problems
- My d15b8 will only fire on cylinders #3 and #4
- Cost of a 1994 Civic Ex
- Alternator question
- cat converter on boosted car.
- y7/y8 mini me obd1 distributor questions?
- what fuse do i need to change
- A/C Question
- NEED HELP?
- FUEL PROBLEMS
- My timing belt snapped while I was driving. Is my car shot?
- vacuum line on charcoal canister
- A NEW CATALYTIC CONVERTOR WHAT??
- Removing resonator from Apexi WS catback opinions?
- help car wont start
- Ek9 And EK4 headers questions
- auto b18b in man. civic help please
- B18c axles?
- Fuel cell questions
- Difference in EK 96-98 from a 99-00? (Hatch)
- LS SWAP into an EG?!?!
- car died.. replaced distributor, car works.. 2 miles later car dead again?!?
- ls webs fit stock civic tire?
- stock FSB
- why wont this fit on my s4c trans?
- Name that sound...wierd noise that stops when braking?
- some sort of knocking
- Quick Yes or No: EG shiftlinkage same as EK shiftlinkage?
- Rear Disc Brake Question.
- WTB Tein Flex for 92-95 Civic EG / 94-01 Integra
- Anyone have a picture of a C-Pillar bar mounted in a 96-00 COUPE??
- Carbotech Bobcats in Front, what pads to use in rear?!?
- new here
- engine
- anyone heard of this??
- Headlight questions for an EG
- WHY?????????????????????
- I need turbo parts
- D16 FOR SALE!
- 00 b16 a/c compressor good?
- help with sealing throttle body
- Skirts from Coupe to Hatch
- Where to find a good engine?
- anyone know where to get ukdm or usdm clusters cheap? looking for mph and tach
- Engine Swap
- Cobalt GT Sports for winter?
- auto to stick
- b series motor mounts
- Temp Rising
- prelude seats in a hatch
- will a prelude radiator fit in my 93 hatch
- idle acting up...
- TPS calibration
- rear disk swap need little help
- Need new Si Gauges
- nessesary to change oil after seafoaming engine?
- ls a/c compressor
- does anyone know the length of stock cat?
- help w/z6 haed on y5 block
- Rear swaybar install - subframe
- could i use my d15 gearbox (s20) on b16a engine?
- VAFC II Settings Del Sol B16A2
- need help fast! rear brakes!!
- vss problems not answered in search
- k20 97 civic
- Shifter question
- in need of an oem acura cat
- help: obd2-obd1 dizzy & alt wiring!
- Weird smell upon turning on a/c
- WHEEL PIX REQUEST!!!
- Automatic shift cable HARD TO REMOVE!!!!!
- Fuse help
- grugeling noise from engine ... ?
- pics please & what was needed to be moddified *** ITR exhaust on a EK hatchback ***
- 92-95 civic hatch owners i need some help.......
- blower motor relay location..
- car squeeking.. rattle
- FTW
- quick question on mounts!
- vtec opens at 6000 RPM, is that normal?
- si ecu on a ex
- I'm gonna go test drive this bad boy tell me what you think...
- b16 Swap. missing some items?
- Starter relay clicking after car is started
- RSR ex mag axle back bolt directly up?
- Watch out in Jersey F-in Thieves
- 2000 civic si cd player help
- need help and search didnt help
- Cx Question.
- Anyone know if any sensors are affected by MAGNETS?
- electric cord from the block?
- need help installing a spoiler
- what could have cause my ecu to burn up like this?
- Oxygen sensor question
- Can someone verify this information
- Question For a Friends Del Sol..
- jdmcarboy ek sir bumpers
- axle question
- crank TDC
- Civic H.O.P Audio/Empty Slot Center Console
- quarter mile
- H22A into a 1994 Civic EX Searched.
- high flow mufflers
- exhaust question
- S2000 Gauge cluster in a 98 civic
- wats the differense
- Anyone know a good place for oem bumpers?
- Has anyone had any problems with their low beams?
- Engine swap for 93 civic dx
- Neutral to D4 - Trans/Gas problem
- weird timing problems with a ls timing
- S/C in EJ1 zc-1.6 vtec need coolant hose diagram
- d17a1 head gasket
- will a 92-95 si gauge cluster fit in my 94 dx???
