View Full Version : Honda Civic / Del Sol (1992 - 2000)
- EM1 Vacuume line HEL[P
- B18C-R swap
- paint supplies
- Cleaning the the body
- Off a cob?
- replace front struts
- it doesnot desacelerate, help pls
- brake lines help asap
- Air conditioning issues *detailed symptoms.
- cel light help
- Shipping Integra Rear Disc Swap...Cheapest Way?
- what are the stock wheel bolt sizes?
- New to the swapping thing can you help a little.
- Keep my same engine, or SUPER JDM D15B
- Forced to biuld.
- obd2-obd1 GSR swap (now Cylinder Pos. sensor error code)
- Civic Evap question
- Radiator support..
- del sol cluster into ej1?
- 94 EG Hatch with AWD?
- Burning oil/small misfire at idle
- Window completely off
- will 88-91 civic/crx steering rack fit/work on 92-95 civic??
- My door wont close..help!!
- b18b swap 99 eJ SOhc
- Car's sucking up gas like nothing
- rear brake rusted
- can i keep my sohc harness with ls swap ?
- Cast turbo manifold Q
- Jdm fog light switch help
- '92 VX Blows weak
- WHERE TO GET HOOD-VISOR
- HELP! B16A EG wont start!
- Clicking sound when turning - Not CV Shaft
- honda del sol timing probelms
- Flood Damage..
- civic wont start
- is delsol chassis weak or is it just me????
- car gets hot when im stopped. Any ideas?
- mini-me head bolts?
- Shipping my car what kind of blue tape to use?
- F22???? Should I????
- Low seat rails
- ECU HELP >=/
- b16 with b20 bottom end
- no start,replaced dizzy and main relay...now what
- destroyed the motor, possible damage to head?
- cooling fan fuse keeps blowing
- Quieting down my exhaust...
- HOW TO DO A DIAGNOSTIC CHECK MANUALLY.
- WTK: What would happen if my TPS sensor on my D15b non vtec throttle body is bad.....
- led/superwhite options
- car stalling
- axleback question
- Cel #45 Fuel system too rich or lean.
- Omni clutch master?
- Clear coat faded on my J's cf intake
- Help with my 95 civic and help make faster?
- 75mm Vitaras vs. 75.5 SRP's, want some opinions
- REAL Spoon???? PICTURES!
- Replacing Radiator Core Support on 94 Hatch
- Eg4 & swaybars
- Painting engine components, heat paint?
- Error Code 3
- auto ECU
- distributor leaking oil and coolant like crazy!
- B16A JDM B16A2 Usdm advice
- scratching sound when reving above 3000 rpm
- NEED HELP! Power window conversion locks don't work
- vtec is not opening
- where to find this b16 head part! please help
- Z6 Swapped ek throwing IAT sensor code
- Easy question about o2 sensor
- Running Wierd
- 2000 civic si cluster dome light problem plz help..
- ? about obd2 sensor
- Does anyone sell this bolt individually?
- suspension noises help
- GSR seats in an EG hatch?
- what can i do to raise the back of my civic
- *** I GOT A STORY! AND A ??****
- eg w/ gsr runs but randomly dies
- d16y7 turbo new to honda tech!
- obd2 to obd1 single or d-series step down help
- 93 Del Sol strange light problem
- new member
- Need help CAr wont start..might be electrical?
- D15B into EG Wiring help
- 15/16" brake master cylinder on Civic with rear drums?
- Milano red
- 5/16 coolant hose?? fuel line hose use for coolant hose.
- b16a head gsr block
- 97 del sol
- vtec not activating
- A/C smoking
- what throttle body
- e brake
- Fuel needle on CLuster not working, fixable?
- What could be frying my icm, ecu?
- misfire issue
- please help d15b vtec problem
- WANT TO PAINT JDM RISING SUN ON VALVE COVER
- NO vtec on my b16 agh!!
- EG Fog lights Problem
- Weird idle problem b20z
- 94 coupe axle back exhaust
- Short Ram Intake on a automatic? good or bad idea?
- New paint job: exotic or simple?
- EG GSR SWAP TURNING PROBLEM
- D16Z9 rev cuts at 6500 RPM
- Throwing code 22
- L.A/LBC Area EK Owners--Best Local Junk Yard To Find Parts?
- New Radiator Fan issue
- B18c GSR swap in 93 civic hatch.
- d15b7 white smoke after replacing head gasket
- Exhaust Help
- b16a
- steering wheel doesnt go back to center after turning by itself
- Need EM1 wiring harness diagram
- askin this for my buddy...b18 swap help..
- Cable to hydro?
- 1995 Del Sol Axle issue
- Del Sol B16A no AC compressor but has all wires and hoes
- Idle problem?!?!
- Best fog lights?
- 93 eg hatch d15b7 down on power
- HELP B18B swaped 95 civic shut down
- need to drop subframe ?!
- Any trick to take out front shocks without taking out shock fork bolt?
- Auto Transmission Gone?
- 2006 + si seats in 96-00 civic. What's needed?
- blox 68mm t/b vs omni 68mm t/b
- how to bridge the heat sensor??
- Carbon8 mag babe of the month. help vote!
- 95 Civic Condenser Fan
- what springs and retainers?
- how do u convert to power windows?
- ITR intake mani questions on a b16
- FNG here!! d15b7 a6 head build
- b16 heat question????
- I want to increase the horsepower on my D16Z6 stock engine
- B20B help needed.
- will TYPE R LSD fit a GSR transmission
- A/C works sometimes
- 95 Ej1 B18B1 Swap bogging/stutter problem..please help.
- Installing One Piece EG2 headlights
- Article: DA Seats in EG (seatpan swap with pics)
- tein basics help
- Need help with shock struts.
- EG side molding/side skirts question
- Regulator? Or the Motor
- AC doesnt blow hard enough
- Looking for help/tools with swap SATURDAY 10 AM on Ohio State Campus
- WTB 92 EG Window Sash
- NEW A/C no cold air
- back up lights
- h22 eg help
- Parking Brake Problem
- everything the same? swaping lx to ex tranny?
- Airbag system help!!!
- Bolts are expensive....
- odometer/trip seem to work but my speedo is off
- Fuel pump relay removal
- Which seats would you preffer?
- Wheres My MAP sensor at? supposedly its there
- Official B series build dyno numbers thread!!!
- Will Swap Pass Smog?
- Need an answer quickly
- in doubt about my del sol si being a vtech
- H22 in Del Sol - Your pics request here!!
- need paint ideas
- Passenger seat removal question
- Gsr swap mounts makin me angry!!!!!!!
- Gas pedal soft
- HELP 96 ek thinks its in drive when its in park
- 94 hatch thumping noise when turning right
- what is the difference between these two?
- well that was fun while it lasted....swap??
- clutch soanr work
- good deal?
- rear camber arm chassis nightmare
- DIY brake pads and rotor?
- My 98 hatch. EJ9 (lots of pictures)
- 96-00 Civic Hatch Jun Wing
- ground control coilover kit any good?
- WOnt Start Help!!!
- 2000 couple trunk dimensions
- ECU Pinouts NEEDED Del Sol odb1
- How to loop heater hose?
- Help with figuring out wheels...
- EK alarm problems
- ek rear fog light wiring help!!!?
- How much would you pay?
- Timing belt
- honda del sol timing belt issues
- is there 4x114.3 ITR wheels....?
- d16y8 engine in 92 hatchback
- reverse lights?? not working at all
- 2000 civic ex motor wire harness into 96 dx hatch, CAN IT BE DONE?
- Brake prop valve
- -Need Help! i need to find guide for replacing b18b head?!?!
- knock sensor question
- 98 b18c in 99em1
- differential fluid
- 99-00 coupe black leather seats?
- Side marker wiring Question..??
- Gear Oil Leaking Everywhere
- Need help with finding a link to head replacement of b18b
- D16y7 build. 75.50 pistons wat headgasket?
- distributor leaking oil is it just a o ring or what
- RPMS bang out early
- Ls turbo eg ques
- my sister backed into my car, parked uphill in 1st gear, trans okay?
- my 92 civic hatch sits uneven?
- Obd1 code 20 help plz not a noob here
- How hard is it to hook up a jdm climate control?
- Intake Mani Swap?
- Questions about my radiator support on my EG
- Remove engine in order to remove steering rack?
- k swap into RHD
- Kony Yellows! Who's using them & how do you like them?
- water temp gauge rise when headlights on...
- 99 civic si header and ITR header question
- rota RB offset question
- knock sensor help?
- Ever heard of a 1995 Honda Civic HX hatch?
- lsvtec oil leak between head/block under dist.?????
- 96-98 power window conversion... which floor harness??????
- Weird A/C Condenser fan problem
- 00si w/b18c reving problem
- Members In Delaware?
- Civic EG Head Gasket/Head Bolt
- Am I Missing Something?!?!
- 99 civic-intrument fuse(7.5A) keeps blowing up
- What spark plugs for D16Y8?
- help me on my swap please...
- How do I diagnose my steering problem?
- blown hole through block, head still good?
- Power Door Conversion
- Need motor mounts, but which?
- Interior Color Change
- Steering Wheel Vibrating Randomly - Problem Inside
- Advice on GSR b18c motor
- Arms and rods?
- B18B in EJ1 running/starting issues
- momo stering wheel horn install ?
- motor mounts?? what to go with
- Car Shakes at high miles
- thinking of getting my 93 dx b16a tuned
- Tach Jumps around during acceleration
