View Full Version : Honda Civic / Del Sol (1992 - 2000)
- It squeeks when I turn the wheel..
- cruise control black box
- weird noise....
- what programming and by who? po6 d15b dual vtec
- ef plug wires on eg??
- clicking relay and now car wont start??? please help
- After engine rebuild, do i need to give it a proper run in?
- skunk2 coilover
- car runs and has white smoke and then shuts off please help!!!!!!
- ek fuel line vs. eg fuel line
- Semi-tech question.
- throwing a VSS code
- d16y8 motor problems??
- side markers ?
- 96 -98 but 99 front bumper??? pix inside
- Check Engine Light Blinking
- TITLEWORK NEED HELP
- wrong wiring harness
- Newbie needs help..
- How to verify if authentic EK9 (96 spec) headlights and grill
- Car will not go into gear help!
- How does this CEL Adaptor work?
- 95 civic rear disc?
- integra shift linkage in a del sol
- d16y7 cam specs?
- Need to know???
- 00' fog lights on a 97 bumper... (civic)
- im wondering have anyone tried this?
- have any one tried the edelbrock turbo kit?
- have anyone try putting a aftermarhet intake manifold on a d16y8?
- Rsx/s2000 seats del sol?
- Upgrading OBD0 Throttle Body
- USDM 97' GSR into 96' Civic DX 4 door
- yea nother wrie tuck. i know i know
- dash swap q's
- Dash lights Wont turn OFF even though the key is out.
- regulate gasoline and air
- check engine light help.
- ***CEL P0420 HELP***
- civic 1.5 crankshaft question
- HELP...I saw someone who had ITR seats in his FERIO...HELP ME FIND PLEASE
- all motor or boost?
- About to start my H2B buildup on my eh2
- With an LS in my EG should I buy a cold air for an integra or one for the civic engine bay
- What exactly do I need to swap an h22 in an ek?
- Civic Lug Nuts
- b series tranny
- Dome light dimly flashing ~ 75 Hz, Keyless entry FUBAR'd, 1997 HX
- trying to fix idle problem
- Stripping valve cover paint
- Newbie With Some Questions
- eg integra dash conversion
- Best suggestion for assessing a possible valve guide issue.
- noob selling parts
- Auto->Manual Conversion. Can I use 5spd pedal assembly temporarily with auto tranny?
- 92-95 civic eg hatch parts for sale
- 1997 civic ECU codes.
- will a b16 jdm dizzy work on a d16z6 motor?
- EK h22 swap ...... ECU question
- fuel pressure problem!!! help
- HELP: clutch pedal/master cylinder/slave cylinder problem!
- Body Exterior - what is the difference between 92 to 95 Honda Hatchback, are they the same design?
- CEL #3
- gsr
- gsr/ls
- B20B SWAP 99 Hatch DX
- zex cam on d16z6
- UKDM B18C4 'P9K' ECU - Can i use Scan Gauge?
- o2 heater wires problem
- will a b18c engine fit a 1998 civic hatch
- Will EG coupe rebar fit EG sedan front?
- Easiest way to remove PCV
- quick question on integra LS alternators.. can i use a '94 alternator on a '00 motor?
- short shifters, bad for clutch and trannies?
- Noises while clutch is engaged and stalls
- civic eg rear asr subframe average prices?
- From D to B: My 94 Del Sol Si Build (56k go home)
- Disaster in Paradise
- e has a 1996 honda civic hatchback. he has bought a bodykit of ebay and now the bloke has hobodykit
- Big Brake Upgrade?
- Dome lights
- low voltage blinker problem
- Jdm ZC question
- CEL code 9
- does anyone noe how to install an aftermarket intake manifold?
- turbo dx
- i searched but couldnt find (obd 1 DOHC ZC) part
- Project Stealth DD Ferio
- need help (tanabe madalion touring exhaust or apexi ws2)
- height adjustable coilovers
- B20?
- a bit of help pls (limp mode)
- Noob transmission question.
- Any 1 know where to get a drift charm?
- 97 civic reverse light switch ?
- Help me identify the trim level of the 2000 model civic
- 1998 civic ex window wont go all the way up, goes to the top and "jumps"
- 92-95 Civic HB Third Brake Light
- splash guard vs snow
- Ek needs a power window kit conversion???
- car is sputtering and misfiring badly have searched help....
- Knocking Sound
- 96-00 civic tail lights problem
- Got a New clutch disk, does the flywheel and pressure plate need resurfacing?
- motor mount
- i cant redline my b16 anymore =[
- civic P20 VX/CX tranny VS EX?Si? MPG hybrid tranny gear set up?
- Boost Questions
- will these fit??
- jdm Sir eg molding?
- I'm not getting spark and I'm stumped
- how much thinner are the SiRs side moldings than the american counter parts
- obd2 97 civic check engine light
- Removing A/C Questions
- buying a 97 coupe need help
- Gas Gauge needle problem
- eg to ek questions!
- built and bossted b16. have some questions
- b18c1 in a ek
- 2000 ek hatch tail light gasket
- 97 civic obd1 b16a converted to obd2 idle issues
- problems with electrical
- 15x8 rims on civic?
- poor gas mileage
- 1992 Civic Hatch build up thread
- **Quick Help** 97 Civic d16y8 IDLING Problems **
- Body Shops???
- keepers keepers keepers
- What you all think?
- What exhaust system..
- lookiing for this eg build thread
- Gas Gauge (needle) Adjustment.
- Seafoam Product, how good is it?
- Question about swap
- What would you pay for this Del Sol shell?
- quick ecu question!!!
- suspension ?
- Valve lash? Zex + Crower = ? D16Y8!
- factory manual link?
- ek and eg suspension ????????
- Removed dash, re-installed, now no heat
- CTR Fenders on usdm 96-00 advantage/disadvantage...
- Oblig's EK Auto to Manual Conversion [dilemma with clutch setup]
- Guage Cluster Question
- Carboard in front of radiator?
- Noob that needs help adjusting his FPR - With pics for reference..
- tranny question
- d16y8 rocker arm assembly questions....
- side mirror problem...need help
- obd1 ecu custom p28????
- Cat/Header
- question on hooking up vtec
- jdm lights
- D16y8 Swap....suggestions...
- Cam seal...the ones by the cam gears..Whats the part number?! I cant find it!
- Found this in my garage.
- Post Mount help......
- Looking for a thread where a guy did a how-to on installing carpet...
- regulating gasoline and air
- wanted: pic of driver side axle meeting half shaft, b-series
- Cel code 80 need help
- CAR KEEPS OVER HEATING
- Top/Front strut mounts busting
- what are these symptoms?
- help pls.
- I GOT THE CEL 5 MAP - manifold absolute pressure sensor
- Header swap
- eg clock
- -Installing a J's racing air duct on an EG-
- Si Foglights
- Where can I find a 5 lug
- 96 honda dx harness on cx hatch with gsr
- Looking to trade my 1996 Honda Accord LX Mint Condition Exterior/Interior
- Broken rear defroster
- Differ Intake Manifolds???
- wheel offset question...
- HELLLPP ELECTICAL =(
- JDM F20B swap into 99-00 Civic coupe, Can it be done?
- car isnt going into to any gears..
- need help with mallory ignition...
- engine jark while driving
- What bushings if any do i change when doing my suspension
- There's standing water in the back of my Sol and I can't figure where it's at!
- civic si rims
- Quick ! Are DC and EG/EJ Clutch master Cylinders the same?!
- Stock JDM ITR(96 spec) in EG
- Exhaust cut-off
- Stainess Steel Brake Line Question
- 92-95 JDM EG Front Bumper...
- type s rear seats into 2000 hatch
- Eg 4 door Suspension
- ex cluster
- transmissions
- b16a2 swap into 98 dx hatch harness question
- clutch help
- will a DC2 ASR Brace fit EKs?
- EK FOG WIRING! HELP!!
- oli cooler on turbo
- LS/Vtec in my EG ?....
- OEM USDM/JDM Lip
- Lower Ball Joint Snapped
- B18B swap gone awry - suggestions?
- '94 del sol S - oil leaking inside of spark plug hole!
- tranny oil question
- Some people told me dont waste money on intake manifold
- B16 swap done but i think im missing a mount...
- changed clutch, car wont start. have spark and fuel wtf
- B16/B18
- re settin computer to h22
- Want to order aftermarket pistons,but not sure about sizes
- Axel Problem
- what are these wheels called?
- where can i get decent headlights?
- Problem with Acceleration
- omni camber and coilover install help please...
- i just want to see how long this takes
- I have a CTR EK9 steering wheel.. I want a horn!
- 92-95 civic coupe front bumper
- Need your opinion on my car!!!
- minime setup question
- What else can I do to my b16 to make more power.. N/A!
- Does a gunky/oily/dirty/pealing valve cover indicate anything about the motor's health?Pics inside
- 96 itr tranny into b16a2? what are some possible pros i could be looking for?
- kaaz lsd install stock vechile sensor does not go in
- Fuel Pressure Gauge
- light
- Ecu Question
- Which clutch master/slave cylinder?
- How to connect CTR mirrors. Need HELP!
- How much travel does the shock need?
- nrg engine dampner 96-00 civic
- how to ...
- Jacobs Electronics ICE? anyone know anything about it or how it works?
- 92 VX hatch Help PLease!
- 92 civic HB B18 motor Swap
- eibach springs and struts sits uneven
- Spoon Monoblock Calipers on an EG6 4x100 Problems
- Pulsing dash lights?????
- gorlight wiring diagram needed
- Thinking of getting a chipped ECU??????
- sohc vtec decal?
- wiring diagram ecu 1.4 99
- 99-00 climate control bulbs
- Wheel fitment for 1997 honda civic hatchback?????
- apexi ws2 exhaust system anybody using it
- FERIO HELP...
- turbo fuel managment
- Does DX Coupe come with EG Clock?
- gasket spacer?
- can a d16camgear go on a d15b7 head?? need help quick
