View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Hiccuping b16a?
- exhaust popping
- HELP!!!!! With JDM D15b!!!!
- 92 EG Radio OEM Radio Swap Issues
- srs codes pulled up
- found this on my magnetic oil drain plug
- 1996 Civic LX - Can't decide what route (motor) to go with?
- 1996 Civic EX passenger lock not working
- Questions after an accident - Airbag related.
- obd2 help
- 94 eji civic amber corner light problem.
- just replaced fuel filter and pump in my 95 del sol - code 43
- Massive problems- 94 civic dx zc motor.
- Which AEM Intake EK/B18CR swap CARB Legal
- 93 Sol, Parasitic Battery Drain, Probably Rear Defroster??
- ITR throttle cable problem with a 2000 ex
- Does this look like good injector spray pattern
- 99 Civic Sedan Overheating & other problems
- 96 civic b20 gsr block power steering possible?
- B8 block/B7 head/stock intake manifold runs like crap at idle and below 2200 rpm
- help... Shifter not centred
- how to do a mini me swap
- headlight flickering in dark cause my sound system . help!
- hid bulb question
- Can't stop my drive plate from spinning to line my torque convertor up
- Question about engine swap into 93 Civic
- CA Civic owners How do you protect your car?
- B18A1 swap into 95 Civic EG coupe - need help with parts needed
- 98 civic EX Tranny
- D16y7 start up problem?? Pls help!!
- "jumpy" idle after i raised the idle on the TB stop screw
- 97 itr swap, 97 cx code 15 . Need some pros!
- AC gurus ... need your help 94 Civic (DX) sedan JDM d15b
- 96 civic LX keyless entry?
- How do I translate Brake depth into remaining miles
- H2b - what kind of clutch and camshafts should I get?
- limp mode problem.??
- gsr tranny wont go from 3rd to 2nd helllppp
- b18c1 eg....getting ready for ref, having problemswith obd1 parts
- b18c swapped eg with idle issues.HELP!
- Instrument lighting issue in swapped EJ6...
- doee being able to chirp tires in 2nd and 3rd indicate clutch is still good?
- 98dash harness in 00Ex? probs!! HELP!!
- Whining noise 1995 honda civic ex
- d15b8 with d15b7 head..Issue???
- Fog light relay
- Speedo cuts out w/ turn signals
- wiring delimma
- car wont get into gear stick
- engine bay wires - need some help identifying them
- Need help with '99 Honda Civic radiator
- Steering wheel play??
- have a question about a eg hatch starting
- HELP..IDENTIFING COLOR CODES FOR B16a MAIN BEARINGS..
- My Car is giving me a couple of weird problems...clutch? flywheel? crankshaft?
- 98LX exhaust
- VTEC and REV limiter quick Q's
- honda civic starting problem.. help
- help my hyperventalatin honda
- Okay I Searched - How to check surface head 'levelness'?
- 96 honda civic Lx d16y7 overheating
- Lowering Springs Dead Coils on the bottom or top?
- My Civic starts without pressing the clutch, how can I fix it back?
- 93 civic Si throwing cel code 41
- WHY DOES MY MUFFLER RATTLE ONLY AT 3000 RPM?
- Starter problems SOS!!
- B16b intake question.
- HELP!!! 96 civic catalytic problem!!!
- Clutch pedal is very soft. Do I need a new clutch?
- Loud Noise?!?
- Rules, Thread Titles, Car Information, Searching, Trial Users, and Picture Posting
- 98 Civic ex problem with the remote starter.
- Crank and Rod Bearings
- Help with piston size !? :p
- B20 EG...slight knocking only in 4th or 5th gear
- every heard of a asr tie bar? (not the subframe)
- 2000 civic si - Will these fit? xxr 002 15x9 "0" with falken 512 195/50/15
- Del sol roof question
- Replacing Headgasket on D16Y7, Do the headbolts need to be replaced?
- 1999 Civic SI - Fluid capacities
- obd2a y7, swap to eg tranny, vss/cel?
- First 97 Civic Hatch - many issues
- Power steering belt shreaded.
- Frosty headlamps
- ek gsr turbo over heating (new thermostat)
- Just swapped ECUs and car runs like crap
- 99 ex hatch w/b20 swap
- car stereo confusion with hooking it up?
- 95 Civic EX PS suction hose
- mini me swap problems
- Which emblems?
- CEL w/ codes 22 & 65. Looking for some help...
- idle problem after over rev
- Does a JDM D15B have an FITV
- 92 Civic - hooked up battery, noticed big spark, and smelled blown fuse
- 98 Civic - pulsing lights and speedometer goes crazy
- D16z6 Block Need Help Searched All Over
- Weapon R Throttle Rotor?
- 2000 coupe b18b nitrous help ?
- power steering leak 1992 civic
- looking for honda civic ex 1999 2 door parts
- 1998 Honda Civic and Crank Sensor and Check Engine
- 00 civic Start up problem (HELP PLEASE)
- tranny stuck in gear
- Am I pulling timing this bad?
- 98 Civic Ex will not rev past 5200-5500 rpms
- Is my B18C1 timing belt on right?
- Chipped p28 or not..that is the question!?
- Starter Lock-UP ?
- 98 civic sedan - what's needed to drop in a 91 Integra motor?
- Fluctuating revs in Idle
- Fuel efficient build questions - my 94 EX
- EJ1 Horn sound
- Clifford Alarm going off while driving?
- JDM GSR SWAP IN EG BOGGING WHILE DRIVING
- Blown Headgasket??
- what's an eg9 vin plate worth?
- Sluggish D16y8 what could be the problem
- Blown 15 fuse
- Possible Rod Bearing going bad in 99 Civic EX?
- Looking to buy Ek window regulator
- temperature problems
- Del Sol Too much clutch free play
- 94 Civic hatch with an LS swap -- wiring question
- no power in 3rd
- What to do,should i get rid of my EK!!
- Clunking sound on drivers side
- Fuel Pressure Regulator bad??
- Need Help 92-95 ex cluster gas and oil not reading
- del sol rear breaks
- Decibel test, anyone know where to?
- Throttle Cable 1/2 Inch too long
- Fluctuating idle help.
- dirt on top of valves lol need help
- B16 injectors obd2a
- 95 ex/b18c gsr - idle is steady at 2 grand -- Any ideas?
- Best Intake for '95 Si
- 98 Civic - 15A dash fuse 13 blows
- air assist solenoid valve question? d16y8
- B16a vtec help.
- 2000 civic dx will not start-has no power to solenoid
- 17x7.5 on a 98 civic hx
- MSD Question
- 2000 Civic LX Won't Crank
- hey can someone show me a picture where these 2 bushings go
- Stock b16a2 with litlle mods
- Axles and shift linkage compatibility question...
- Power windows
- $100 EJ1 Build
- what is this part and what does it do?
- Help with parts list for head gasket replacement D16y7
- Shaded Windshield. Can I Get Tint?
- d16y8 sawp to 1997 hb cx
- iacv unplugs engine dies stalls
- Passenger Door Unlocking Problem
- 2000 EM1 build...your opinoons please.
- Coolant Bleeding Problem After Changing Heater Matrix
- why is my skunk2 rear camber kit loosening while im driving
- timing belt tension question
- ek heater not working!! HELPP!!!
- Fuel Pump not priming Plz Help!!!
- New exhaust o2 sensor issues.. Halp!
- Which tuning system? Mac compatible?
- LS swapped 98 Civic lumpy idle at startup
- 92 Civic Fuse Box (in-dash)!!!!
- Suspension up(?)grade
- 00 civic Si , cluster, climate control lights blew out
- Swap ECU question, need help!!!
- Removing A/C belt ---any ill effects to compressor?
- Hondata s300 - Engine Coolant Temperature CEL stuck on.
- how to tell which o2 sensor goes to which plug?
- Ask Moderators Non-Technical Questions or Give Suggestions to Improve this Subforum
- harness in my ek
- Numerous check engine codes
- Late start up?
- Is there any way to tune an OBD2 Civic????
- need help with h22a jdm swap into 93 Del Sol
- d16z6 oil pan fits d15b2?
- 95 honda del sol vtec
- Oil Pressure Problem
- Stock del sol failing emissions, im completely stumped.
- Ignition Coil blown twice, what could be the cause?
- My Custom Wrapped EM1-EK Rear Seats - Type R Inspired
- help with bseries swap in my ek
- B16A2 Coolant Problem!!!!
- I need a write up on how to install b16 oil pan please
- Stuck Trunk Latch
- 94 civic b18b1 swap questions
- I am using a GSR harness in an EK, anyboby else done this yet?
- Building a EM1 or EK?
- EG6 CX Piping Size.
- IDLE Problem, almost dies, Not the IACV, No CELs
- Fuel Injector Air Control Valve and Vacuum Line Routing, 2000 Ex
- How to tell 96/97/98 bumper from 99/00?
- Help, Low Idle :S Honda civic 95 EX
- Bore the cylinders?? Should I?
- Piston rings oversize?
- 99 Civic vtec not engaging
- d16 injectors/fuel rail...
- How install a short shift?
- fuel pump wont prime,cel and oil light wont come on
- Performance Header?!?!?!?!?!!
- B18B(obd1) swap into 96 dx
- Bogging a good thing?
- stock brake lines and wilwood brakes
- trying to get motor refd/bard in Bay area CA -- HELP
- Head codes question
- How to remove the Bitch pin in less than 5 min.
- EK Sedan cat-back exhaust on EK hatchback?
- Universal Catalytic Converter ?
- D16 / B16 SWAP for Del Sol???
- 99-00 conversion
- Password:JDM
- will a non abs hub fit on an abs car
- Block heater install on 1999 Civic.
- 99 EX PCM CEL Help
- EK Civic - What are your: Coilover brand;Spring Rates;Height Drop; Driving Use type?
- 96 civic lx sedan problems w/ CC + issues
- What would buy for you EG8? Enekei 92s or XXR 521?
- Noobie Needs help picking swap for 99 hatch
- rta bushings
- Did the timing belt job cause my Crankshaft woes
- LSV Runing like pooh
- Another Honda Lost to Criminals...
- Did my ECU go bad?
- EG Hatch Taillights not working.
- Brandon - 1993 Civic delSol build
- Has this been done?
- Droning Noise 93 EX Coupe
- fuel pump problem
- 96 Civic LX head lights
- D16y8-New Intake manifold, Does it require a new tune?
- delsol vtec vs 94-2001 integra rear lca
- 97 del sol 1.6L SOHC - Misfire
- TPS nightmare Please Help!
- 95 GSR?
- 1995 Civic has "popping" noise when turning left (not cv axel)
- car wont start after head gasket install
- 98 lx header/cat help
- 96 civc 1.6L vtec, coolant resorvior full radiator coolant consumption
- 92' Civic Vs Snow
- EK Civic - Tein Type Flex - Strut bar must be removed??
- Need to change the fuel rail when changing injectors?
- School me on this craigslist modded Civic please
- 96 Civic - how to convert headlights from 60/55W to 80/100W bulbs?
- Del Sols -- Best years to buy? How hard to boost?
- possible to use 4 wire o2 on HX ECU?
- Analyze these compression numbers. Give me some ideas about motor..
- Compression calculator?
- Help with Driver side window!
