- gauge fuel needle
- Which Synthetic is better: Mobil1 15w50 OR Valvoline 15w40???
- H22 or H22 type-s
- overheating issue maybe???
- whats the diff. between a d16z6 and a d16y8?
- Where are you guys putting your 4th gauge? EG.
- e-manage or Venom 400
- Tucson Peeps!! - Need a good machine shop
- the big and tedious question...swaps
- compression test done, opionions ?
- PLEASE HELP!!! Car is making Strange noise...
- jumpy speedo on auto 94 hatch
- how do i add pics?
- Rear brake Conversion
- Need help w/ no brake lights on 99 Civic DX?
- PLEASE HELP!!!
- should i turbo the d16 or go with the swap???
- CTR Cam ?'s
- cylinder "feeler" theory
- ????USDM ITR seats in a ek hatch?????
- Bseries hydro tranny parts compatible?
- S7 gauge cluster face
- high flow cat w/ o2 bung?
- Weight of my 93 hatch
- EJ6 Exhaust parts.
- d16y7 burns oil?
- megan header or dc sports header???
- CAI question
- will a p08 ecu work in my 92 hatch
- hi rpm at idle
- Lightened flywheel question
- does any one know????
- Would a chipped p28 run...
- aftermarket headers
- How can I tell if my car is prewired for VTEC?
- Engine Password???
- Help - Civic A/C Compressor's Interchangable?
- a quick del sol header question...
- 1/4 mile time with stock Gsr or any other stock B or with light mods on 96-00 civic Ex?
- Name this part....
- power window problem help!
- 96 civic ex engine swap need step by step!!!!!
- Lower control arm mount
- Questions! HELP
- Need H22 swap help
- DIY: JDM EK9 CTR DOOR PANELS!!
- d16y7 oil change
- h22 or gsr
- what manual to buy?
- code 72 and 41 on jdm gsr in 96 hatch
- How to get better MPG? Windows down or AC on?
- FS:96-00 neuspeed springs
- Best 92-95 Hatchback Model?
- Having problem With my Eg Headlight please HELP
- Exhaust and Suspension Questions
- valve adjustment for b16
- master cylinder went dry
- Question about engine swap?
- 2000 dx injector size
- need help with b16a3 left side axle
- Thermostat problem?
- type r injecters in d16y8
- d16z6 manual into my 99ex auto...
- cant hear my vtec
- code 7 on p28 chipped ecu
- apex n1 muffler question
- Transmission Noise - NEED HELP!
- engine not gettin spark - new distributor
- D15B OWNERS PLEASE HELP
- 96 civic ex coupe stolen GA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- civic head swap
- DIY intake question
- SWAPPING GS-R SEATS INTO HATCH
- Coolant Probs....TALK TO ME
- Front Drivers Side Speaker Turns off when I open door!?
- Check Engine light on...Speedometer not working...help???
- Need help with identifiing engine noise!!!!!!!!!
- OBD2-1 Conversion question.
- ppl with the magnetic oil drain plug
- problems with a/c
- interior crap
- how to tell if shocks are good when they are out of car? itr shocks???
- No Vtec? Strange Stutter?----- ECU
- I think I have a timing problem *help*
- paint on gsr leathers
- ek throwing a code
- Fogging headlights?
- i have 96 hatch putting in ls need help !!!
- WTF..A/C stays on......
- just curious, but does this sound right?
- eg si cluster into eg dx.
- WTF is this piece in my trunk?
- just put new header on, gap.....WHY!!!
- SI HEAD N PISTIONS ON D16Y7
- Newb to Honda-Tech
- 2000 Si Engine problem
- need some quick help(foglights)....
- How to bleed a clutch?
- Code check on EK?
- Finally got 1/4 times for my LS coupe
- Ive notice a lot of people dont use timing belt covers... WHY NOT do this
- My Eg DIY air duct. with pictures
- Pics of your Civic/Del Sol...No Commentary! JUST PICS!
- Antifreeze Leak
- overheating & large amounts of smoke from exhaust
- .....Broken Valve Cover Bolt.....???
- OBD 2 -> OBD 1 conversion... EVAP control????
- threw a code 65...............o2 sensor question
- No Traction @#!#!
- vtec is really loud and slow
- Spray paint the dash?
- changing the clutch
- rust on muffler
- torgue for a b16a??
- Need help with a B18A1 swap asap
- speedometer needle is acting wierd
- Valve Cover Help needed asap !
- Some Assistance
- Need Sum1 thats good with electrical BS WILL PAY IF YOU GET IT FIXED.....
- JDM eg6 Sir airbox and arm with k&N drop in
- check engine problem...
- shift linkage?
- Header/cat question on a 99 si
- Valve adjustment cost
- Gearbox question, which option would be cheaper / more beneficial ...
- thanks to the guys that helped me!!!
- Will DA axels from a 90-93 Integra Fit into a 92-94 CIVIC HB B series swap????
- nys emission testing
- Hey Need diagnosis. Wheel Hop=Axle pop-out??
- EG hatch exhast question
- NOob, need some help.
- Surging idle
- what car did this block come from?
- does the eg cx have a wiring for the clock?
- Any DIY's on replacing rear struts?
- How to remove airbag?
- Will CTR Side moldings fit 99-00 Civic Si?
- having problems with z6 on b7
- question on stock b16/b18 internals
- Intermediate shaft
- Yes Another C Pillar Question For All EG Hatch Owner's With C Pillar's!!!
- Exhaust Question
- ek question
- ps removal
- Help me decide on lower Rear control arms & sway bar?
- HELP ON TIMING BELT (D SERIES)
- How Much HP!!!
- 96 civic overeated died and won't start???
- AUTO CVT TRANNY FLUID HOW MUCH?
- my 2001 engine ticks
- Oil leak around camgear/timing belt
- Power windows
- help with B16a swap!!
- SRR endlinks don't fit into my SPC lower control arms!!!! :( can i use other ones?
- B18c turbo which throttlebody?
- adr wheels are they WORTH it
- Where to get OEM parts for civic.
- track only eh2 how do i gut my doors and tailgate
- Exhaust -- i gotta question
- HELP ME z6 intake manifold on b7
- Quick question about a 96EK with 99-00 front end
- Keys to keep your honda goin nonstop!!
- Squeeking Coilovers
- Cost to weld? Any info appreciated
- Fresh Prince of Watauga Texas
- Reverse lights???
- planning on swaping a gsr in my eg...help
- is megan worth it?
- gsr cams?
- Possible?
- Why do people have to hate?
- High Flow Cats?
- any local mass seller for 95 hatch parts
- HELP! 99ex clutch fit a 94 dx civic?
- swapping intake manifolds ... help plz
- White Dials?
- New Napa racing inspired High Flow Oil Filter better than OEM honda filter?
- good setup for ls/vtec?
- Is there a gasket here?
- let me get this straight...speedo related.
- RSR GT2 exhaust for 92-95 hatchback help!!!
- 01 civic ex not starting when cold.
- Upper A arm question, brake swap.
- Steering wheel noise and play
- Question about Si lip?
- hella horn install help (basic wiring)
- side moldings<<<
- lug nut ?
- EK9 power folding mirror wiring help needed!
- Civic EX - Changing the blinker speed
- 520 for a used set of Tein HA's worth it?
- NO BRAKES!!
- b16 finally running
- stock muffler wont bolt up to greddy piping
- motor swap obd1 to obd2
- Best full coilover system for EK?
- Need help finding parts-------best place to buy rhd dashboard and parts for ek----
- defective timing light? How can you tell?
- 92 Civic LX speedometer went out!
- help core support
- FULL INSTALLATION GUIDE FOR H23A IN 93 DEL SOL?
- Need a advice on O rings on the cylinderheads and also cylinder heads.
- tunings
- 97 Del Sol S Intake
- Engine question here
- Engine firing order
- Help: Wiring EG Foglights
- rear hatch
- RSX, S2000 or DC5 Steering wheel work on 98 Civic EK??
- What sensor is this?? (b16a2 obd1)
- b20
- has anyone attempted to install an ek dash into an eg?
- Engine check problem
- EK window visors help...not a noob!!
- NEED HELP FAST PLEASE
- Which fuel pump is better
- help??tire question size?
- d15z1 into an EK? Need help!
- driver side driveshaft wont pop back in.
- D16A9 is a zc ???
- Code 21 (vtec spool soleoid valve)
- Help - Fender Rolling
- Clutch Recommendations?
- camshaft pulley?
- ex ATM cluster in a cx MT ?
- anyone got pic of their vtec custom harness? (minime)
- Master Cylinder for a Civic 1999 CX
- Intake choice (EUDM B16A2)
- Any suggestions for my 95 EG?
- why does vtec not work for about the first 5-10 minutes after i start my car?
- D16Z6 - can a bad distributor cause hesitation only after engine is well warmed up?
- STOLEN HATCBACK IN SACRAMENTO, CALIFORNIA !
- Need help with tranny install!
- 99 si driver side mount install?
- Squeaking Clutch... Anyone else have this problem?
- What do I need to install Daytime Running Lights?
- repining integra cluster........
- Car finally starts after swap
- gsr brake swap problem...version#2
- A little vid of my little civic that could
- black dash question
- 1999 Honda City Mods?
- rebuilt head
- Are the EX clusters the same as the SI clusters?
- RSR GTII?
- D16Z6 into 93 Civic HB CX Question
- camshaft/cam gear
- d-series trans question
- opinion???
