View Full Version : Honda Civic / Del Sol (1992 - 2000)
- white EK's with bronze rims: post pics
- $2800 for GSR swap w/29k a good deal?
- Short Throw Bushing
- P1456 code?
- something wrong with my car?
- WTB 96-00 Civic 2Dr Trunk lid, Cyprus Green prefered
- Anyone using dart blocks!?
- 2003 Civic leaking oil
- *** SUSPENSION PROBLEM - Please help!!! ***
- 3 cylinder civic, Runs on three! Help
- A/C Pulley Growl TSB?
- Blue smoke at higher rpm's?
- distributor install d16z6
- CF hood ??
- Reverse problem?
- Brake caliper piston boot is torn
- !!! Wiper Switch Help !!!
- Where to get real JDM items, not eBay crap! ?
- Is it ok to change the odometer after engine swap?
- Help: Putting a 97 GSR complete motor into 97' EK civic/ what you guys use for a clutch fluid line t
- Pic Request: 92 Civic 3dr main relay location.
- Check outmy 92 sedan
- turbo Hondas
- Hood Pins, Really Necessary With A Carbon Fiber Hood?
- civic dx auto speedometer question?
- Car Will NOT shut OFF
- FOG LIGHT THREAD***************POST PICS**************
- Car Stolen - Gunmetal 92 civic si Hatchback - Garland, TX
- Tire size, 225-50-15
- Power Lose after intake install
- cams question?????
- 00 si rear shock bushings?
- feels like i lost horespower after using Seafoam
- d16z6 rebuilt, no spark. someone help!!!
- obd-2b gsr motor to obd-1 eg hatch
- exedy oem clutch
- witch floor mat for my civic?
- CAMBER KIT????
- CF Targa Top? ? ?
- 11.4:1 compression.......
- ITR cams in b16..motor sluggish to start???
- Best looking rims on black 99 civic coupe ? Post your pics
- Cleaning Headlights
- Big Bore Engine Integrity?
- Want me to do this write up?
- Need help with dash lights
- jdm ek4 climate control in a ej6
- o2 sensor problem??? plz help
- Runnin on three
- z6 bottom a1 head will it work...
- How To: Install Datalogging cable to your OBDI ecu
- Fog Light Question...
- Integra Cluster Install In Civic?? ABS light on??
- I need help findin this OEM Honda Accessory and....
- Weight Reduction
- Vibrating wheel...what's the problem?
- JDM s20 tranny on a USDM z6?
- ELECTRICAL PROBLEM!!!!!!
- WHAT DO YOU THINK -- WWW.JDMCUSTOMS.COM
- Need Carfax
- 411 on NO2
- HELP QUICK, IM IN THE MIDDLE OF MY SWAP
- How to on cleaning IAC valve
- Help: Putting a 97 GSR complete motor into 97' EK civic/ Need help for crank angle sensor at pulley
- usdm b16 vs. jdm b16
- How low can it go?
- Breaking up at low RPM
- need help with gsr swap in a EJ
- Anyone know if the Comptech Sway/Tie Bar Kit will Fit W/ Mugen Twinloop Exhaust?
- Vtec question
- Civic catlytic converter
- Question: Installed sway and was wondering.....
- 2005 Instrument Cluster
- taping noise, sounds bad
- obd2-b gsr motor ecu..
- any immediate dangers to breathing in bondo dust?
- Where to buy....
- Chicago Thieves
- motor mounts?
- please help . i need bodykit for an eg in ny
- Interfacing a laptop with OBDI computer
- Questions about transmissons
- carfax a vin for me please...
- Gauge clusters ...
- IAC valve location on a d16z6?
- Tune up
- fan keeps blowing fuses whats up?
- New to exhausts (quick question)
- ARC Induction Box
- LS SWAP INTO EG FOUR DOOR LX.
- using Ls trany on your EG....
- Osaka or Japan motor imports
- Team!
- Type R cams in poor mans R...few questions...
- Omnipower testpipe fitment
- 93 civic lx b18 swap
- Coilovers
- Cluster Help!!! ive searched
- OEM Lip hardware question
- How To?
- WHAT FLUID DO YOU USE ON YOUR MT ?
- 99-00 civic front end
- GSR rear seats in a civic
- Eg to Ek front swap???
- What kind of timing belt should I get?
- Got a cam, but dont know what kind it is? d224?
- Need Help!
- Need Help on getting my swap started in Socal pomona Will pay if someone can help??
- Automatic shifting Problem
- OBDII injector clips, is there a positive and negative?
- What kind of tires are good for daily drive, I just bought rims for my car and looking for tires.
- b16 idles wierd at 2k rpm
- clutch question again
- Ecu help!
- ECU Code 8, Brand new dizzy..??
- About my civic 04
- 00 civic si ecu harness.....
- phantom grey pearl hatches? anyone got pics? (searched)
- Civic 91 Hatch (EC8) - Running B13
- 94-95 civic si hatch's ?
- still losing coolant, need help asap!!!1
- Car Keeps cutting out at low speeds
- Exhaust
- d15 help
- 95 Si Hatch w/ b16a Q's
- HELP... CEL with IAC Valve Wiring on Wire Harness
- I CHANGED A HEADGASKET ON A SOHC AND NOW ITS...HELP
- how do u know?
- Mini Me gas questions
- Anyone have rattle problem from EK cargo cover?
- interchangable exhaust? 5thgen>6th
- Z6 head needed
- Need help instaling oem fog lights to my 99 civic ex...please help
- Fuel/Igniton Upgrades
- Adjustable Cam Gears
- Knocking in the head
- 5th generation Civic factory specs.
- 16'' or 15'' on ek hatchback?
- what is needed for 00 SI conversion?
- Need rocker arm ass. torque specs
- My car won't start, pissing me off, need help!!
- What Header? 4-2-1? 4-1? Differences
- Night at the dragstrip, now messed up car?
- BANG!
- Need Help With Idleing problem
- whats better , sir I or sir II b16 ?
- ek or eg
- Found the problem to my leaky sunroof.
- question about a tachometer
- Low voltage in 02 sensor???
- harness and back seats
- IAC Valve Wiring on Wire Harness
- Ingen intake
- code 6, 10, 16, 21, need help!
- carbon fiber hood problem.
- d15 general question
- eg9 seats in an ej1 coupe?
- hey guys wondering if any one new how much it would cost me to put a h22 in my eg hatch
- CTR steering wheel on EG hatch?
- Battery light
- b16 swap help!!!!
- Anyone have any experience with Top End Motorsports?
- crx or delsol
- agx shock question
- choice of ecus....
- 92 eg hatch rear disc brake conversion questions
- Best Swap Available For My 95 Hatchback???
- brake squeal! AHHHHHHH
- engine swap questions
- stg.1 comp clutch
- d16y8 head on d16z6 block
- s-afc application, and fuel pressure problem
- Engine Stalls
- obd0 to obd1
- valve cover seals not coming out (searched)
- honda/acura oem parts websites
- what trims and years came VTEC
- suspension problems...any help appriciated.
- HOLY COW! You Wont BELIEVE your eyes! HELP ME!!!! What did REDLINE PERFORMANCE DO????
- Anyone have success chipping a P29 ecu?
- Help with CTR headlights. Quick!
- Just got back in the game, just bought a 1999 civic hatch
- buying a eg w/ ls swap??
- obd2a to obd1 ????? Dizzy/EACV/IAT????
- what wire to tap into for constant power? (for digital tach w/shift light)
- I need a stock steel rim
- Short Shifters
- Can front 92 rotors w/abs go on a 00 w/o abs
- Wondering what exactly,(parts) would be a valve train upgrade,
- EK AIRBAG INSTALL!!!!!!!!!!
- ex thottle question
- valve cover color removal
- question about rear bracket
- b18 swap and car doesn't have any power
- chipping, 74hc273 work instead of 74hc373?
- Duel Fuel Maps? What to search for?
- Gas peddle restricter??
- eg mirrors on ek?
- DIY - Del Sol AUX lights on with parking lights.
- 96-98 Climate Control REMOVAL
- 99-00 fog lights went out and have no clue why???
- tranny fitting issues
- Properly Bleeding Coolant System
- mini me parts
- Water Pump - Anyone have a how-to?
- anyone rockin the replica seats...comments opinions brands..etc....
- cable/hydrolic question?
- Oil leaking from my distributor..
- good price for EK?
- Your thoughts on this exhaust
- Anyone Sponsered by SPORT COMPACT PRO
- carbon fiber fenders and hood for my eg
- help exhaust problem
- fuel pump install
- b16 - sensors & harness
- Anyone interested in DIY engine rebuild write-up?
- Got a free header, will this fit my 96 Hatch?
- suggestions-time for engine work should I swap? or do work on D-series. help!
- o2 sensor
- car bogs...???
- Help with slipping clutch on 99 Civic EX....!!!!!
- stupid question, just need a quick answer. Searched.
- nline Tweeter Pods?
- steering wheel vibrates at 80mph
- HELP! Brownish Grease on inside of head.
- Civic D15 rebuild
- Stock Horsepower Ratings
- ek 4-door exhaust question
- [QUESTION] Changing Dash Lights
- Greddy Evo vs. Evo 2
- sluggish and rhaspy/rattling noise
- si tranny
- Vtec solenoid question...
- Removing your window rolll handle.
- Where the hell do you buy the REAR WIPER BLADES for EG's?
- SOHC VTEC Distributor for sale
- FREE FREE FREE....come and get it
- steering Wheel Lock
- Tape residue...help
- exhaust fitting???
- looking to buy a eg
- Free stuff come and get it...
- my 96 EK smells like gas. smells like its comming from the back seat area...
- exhaust sounding a little weird....
- ls swap into eg..crv ac bracket?
- 1 wire to 4 wire o2 sensor
- temp gauge
- cf trunks
- WTB: 99-00 OEM CIVIC REAR LIP
