View Full Version : Honda Civic / Del Sol (1992 - 2000)
- injector problem
- oem ek roof rack
- will bad struts cause camber?
- clutch alignment tool
- Will a S2K cluster fit into my eg
- mud guards not fitting
- trouble with windows
- Weird swap working almost correctly 89 b16 in a 2000 hatch w/ odb2 harness odb1 ecu
- OBD2 Donor car, Obd1 Car
- Supercharger 1.6L
- Performance Headers
- Cluster swap help!
- b18b1 power loss????
- sir cluster
- center cap questions??
- Help, bolt from valve cover stripped..
- Thinking of going turbo
- NEW!!
- Turn signal issue.
- Question about OBD1 & OBD2
- rear toe kit or not...does it matter...HELP me OUT
- Did I blow the engine? Clogged PCV, now CEL
- Walbro pressure and 'how it works' question...
- What is wrong?
- Wierd Idle Problems! Please help
- Need help with removal of alternator pulley
- cold start valve tick, is there any cure?
- Would 16x7 +42 rims with 205/40/16 tire fit a 5 lug civic?
- B18B in a 95 civic coupe
- K24 EG swap questions ???
- Cluster + interior lights problem...very pale light.help
- Help
- lsd clutch
- Harmonic Balancer question ??
- O2 sensor thread, size, etc for blanking bolt needed?
- ITR manifold
- all the lil details
- anyone do a Walbro fuel pump install? i did, unsatisfied...
- Stock B20 Vtec?
- need help with turboing my jdm d15b vtec
- Which MAP Sensor???
- eg side marker problem...
- help key stuck on 95 civic dx hatchback.
- d16y8 wiring harness on b16a4 swap
- WHAT CLUTCH KIT SHOULD I GET????? HELP
- Bracket???
- Help, wanting to change automatic to a manuel
- skunk2 stage 2 cam problemhelp asap
- Swapping Gauge clusters?
- Transporting a 30ft ladder on top of a civic?
- help for a friend
- really weird question... do you have to run a thermostat
- d16z6 help
- honda access
- LSD interchange
- b20vtec oil feed
- fuel injector problem????
- what is the best tranny for a D16Z6?
- New Brakes
- foglight switch question
- Horn wont work?
- Grinding gears.....HELP
- 00 civic ex intake fits 93 del sol?
- Easy Mods for a 2000 civic Si
- turn signals down.... help!
- will a EK hatch catback fit on my EG hatch?
- Arrrrrrrrrgggggghhhh IAC Valve scum
- Need Advice
- jerky throttle
- might as well introduce both (problem inside)...
- NEED HELP! Wiring Diagram for JDM Power Seat for EG8
- Mishimoto Carbon Fiber Intake for EG; anyone try it?
- The best catback exhaust system.
- will a 97 EX trunk lid fit a 00 Si?
- ZC motors?
- GSR OR B20vtec
- idel problem on my supercharged d16z6
- BAR' QUESTION!?
- new seats question!
- anyone ever used this clutch before?
- what is preloading???
- im new on HT hey!!!!!
- itr suspension
- need help with power windows - 96 Civic 4dr
- classifieds???
- Ek9 power folding mirrors fold in, but not out????
- MY car wont start! NO POWER! HELP!
- change my mind?
- washed/wet engine and now seems slower
- Ls/Vtec kit??
- 96 needle install
- Clutch help me out please
- How do you clean dirty trunk??
- H22 injectors in B20B???
- help findin wiring kit
- Need thoughts on buying a 93 civic...
- 3rd axle seal... still leaking wtf?
- 2000 Civic OBDII Code ( HELP! )
- GSR block on b16 head!!Help
- honda civic door question
- ac/heater control on civic 97 ex coupe
- good deal???
- Timing off?
- ctr folding mirror relay where does it mount?
- b20z into 2000 ej8
- PDF file
- crv cluster???
- emission questions?
- another overheating' problem...
- 1998 EX coupe window issues
- how to identify b series axles
- Semi-Stock GSR #'s in A EK
- ls v tec vs poor mans type-R
- rewiring gsr altenator plug in a 2000 si
- car Idling funny
- Chevy tahoe
- 95 si power steering conversion
- What size for stock Spare Tire for 1994 Del Sol VTEC
- best chip civic si
- need a pic of the fuse box on a eg.
- weird ECU with B16B!
- stock si intake
- i broke something, can this part be glued back ? pic inside
- d16z6 cold start problems
- Im helping my frind doing a turbo build & need some advice
- Bell Housing Bolts
- b16 alternator help
- high heat temperatures
- I guess an introduction would help. hug..?
- Best fitting duckbill for EG?
- Getting Spoiler Off HELP
- recurring CODE 1 whats the deal?
- BRAKES
- what kind of front end is this?
- Help with Front Mount Air Intake
- painting CTR style grill VSM...cant find the paint anywhere
- OEM honda tac
- D16Y8 or D16Z6 whats your pick??
- bearings
- D-series valve cover (searched no luck)
- victor.m's 94 EJ1
- vtec trouble searching exhausted
- b18a1 in 95 civic ex
- interior qustion
- Question regarding 96-00 civic guage cluster install
- Aftermarket 99-00 bumpers??...
- LS/Vtec 96 Honda
- Skunk2 cam gears universal?
- sputter and my gauges flicker on and off???
- jdm d15b for sale
- one of the hundreths startup issues=(
- can i use a b16 obd1 harness on a 92-95 d15b7?
- slow power windows?
- swap questions
- Can this be a Reason why swap wont start again?
- JDM ECU throwing a code-22. How is it possible?
- LED bulbs in cluster- go,go or no,go?
- New from South Texas
- can somone help cluster question
- car bra?
- 1999 Civic D16y8 JRSC
- which timing belt?
- still grinding!!
- Shift linkages in B swap
- How to shift fast - effectively. Am I doing it wrong? Everyone should check this out!
- INTAKE MANIFOLD ?
- d16z6 rebuild
- z6 build
- Energy Suspension Motor Mount Inserts
- honda del sol seating
- cams/ redline
- Flowmasters on a Civic?
- tps problem! Help
- Hi I'm lookin for this varnish! Question from germany
- B16A is leaking oil in the distributor area
- looking for IACV but where?
- Rear suspension is too low using Tein Springs & AGX Strut
- fuel warning light
- need your guys opinion....
- buying a brake calper (question)
- Need help after V2 install
- need hel hydro to cable trans
- Car Idling Woes :(
- Pre Detonation issue
- BLACK SMOKE WITH AGGRESSIVE CAMS B16A2
- Where to get good o2 sensors
- seat rails?
- p28 chipped and tuned mpg?
- civic si NEED help VERY BADLY
- Heat wraped headers?
- JB Weld the Radiator Support on my 99 ex..
- Vtec Question
- y7/y8 w/ skunk2 cam gear timing problem
- 99-00 fogs on 97, i did front end conversion
- anyone else has wilwood brake kit?
- Calling all Del Sol brake gurus. Question about Del Sol VTEC brakes.
- car swaying when moving slowly, question
- CARBON FIBER TRUNK QUESTION
- LSD Tranny noise when i put clutch in.
- idle surge
- Confused with doing an OBD1 LS/Vtec in an OBD2a civic
- Transmission Bolts Came Loose
- What Brake Booster for the 91 Civic EX Brake Master Cylinder in 94 Hatch?
- skunk2 tb failure DESTROYED my engine what can i do.........
- Getting transmission fluid flushed at honda dealer
- i want a deep sounding exhaust.........whats good
- Jdm D15b Idle problem after engine install??? Please Help!!! Searched already!!
- Help me pass emissions guys. I need suggestions
- Swap Ek Steering Column into EG...Need Help
- I NEED HELP ON MY 95 CIVIC
- RC310 injector install :\
- Hey Im new and I need help.
- 96-00 Civic Ex (im lookin for one)
- gaguge cluter Q
- Cooling upgrades
- do u have to get ur engine bard????
- HELP!!!!! eg parking pole... light bulb is blown!!! how do i replace?!?!?!?!
- Pulleys...
- map sensor wiring...
- what ecu is this
- Blown engine
- Few question Searched but still unshur
- Seat dye
- 2000 civic si
- Honda 1999 CRV Egine Problem
- help please 2000 civic
- B20b Swap into my 97 dx
- injectors hp
- gsr rear seats in ek
- ITR vs Skunk2 springs/retainers
- so my gauges and my corners stoped working after amber bulbs in gauge install
- smoke! help!
- need wiring harness
- Timing degree for a D15B7?
- C pillar bar question.
- gsr reff questions....
- What is the purpose of the 2 large metal center console / dash bars (brace)? 92-95!
- Crashed my EG... What part is this????
- What exhaust do i use?
- What bolt ons or easy mods is there left to do? 00 Civic Si
- Oil in dizzy and question on dizzy rotor button.
- anyone know what wing / spoiler this is?
- b16a wont prime
- Head overhaul ?
- my Speedometer doesnt work. need help please
- First post, big problem
- need help deciding 2000 civic si
- Bolt Extractor Stuck in a Bolt, Stuck in a Caliper. Help!!!!
- shattered ek glass fog light :(
- Im new here need some help
