View Full Version : Honda Civic / Del Sol (1992 - 2000)
- camber kits!! ingalls help!
- Need AcDelco part numbet
- obd 0 motor into obd1 car???
- Difference Between "Forced Induction" Fuel Pump and Regular One
- Will 1999 GSR Front Knuckles directly bolt onto my 97' Civic HB??? Please Help!!!!
- valve lash on d15b vtec?
- Electrical problems
- distributor problem
- Codes 20 and 23 after drive for about 5 mins? HELP
- 93 Widebody Coupe for sale w/98 ls swap obd1 ecu
- installing short throw shifter
- can you wire the iab sensor to open
- came across problem with iats
- Rough Idle..Car shakes...Help
- Wiring Issues--ECU no Light
- front end ?
- wheel hub
- DOHC VTEC Distributor Question
- Allmotor B20 nonvtec vs B16 both having the same tranny and mods
- What header is this?.
- Debating.. New and improved *with* POLL!
- OBD1 dist to OBD2b engine harness question
- don't usually post pics of the whip but...
- power source on my side mirrors
- gas smell????? WTF???????
- Del Sol Tranny Problem?
- 2000 Honda Civic
- JDM engines have VIN#'s?
- Del Sol Lock Actuator Question Please Help
- flywheel weight
- What ?'s to ask when Buying a used motor?
- 96 civic, coil overs vs. drop springs
- wiring a mini me for D16Y8 head
- Tranny/Axle Seal Leak???
- 93 honda civic dx AT
- My dizzy died
- ***Need Advice for 96 Civic Hatch**** Which one do you think look better?
- Radiator?
- 92 integra seats in a 94 civic eg?? I need help with this
- DIY: LED Gauge Cluster
- 1st popping out at launch
- Cheapest place to get EG foglights?
- Climate control/radio bezel
- will the integra side mirrors fit a 96-00 civic
- which dizzy
- 92 civic hatch BRAKE BOOSTER NEED HELP!!!!!!!!!!!!
- mount for b16 in ej1
- Center caps waNTED!!!!!
- LS throttle body - d16....will it work
- quick obd2 to obd1 p28 question, missing at startup, rich
- auto to manual on a 95 civic ex
- What ecu
- is this bad?
- 2000 teg mirrors on EK??
- I need Taillights and Tailgate ASAP for my eg hatch
- Power steering issue...
- Are 96-98 civic coupes same as 99-00 coupes?
- How to prevent overheating
- How do I check my offset??
- EK swap,help pick OBD 1 or 2 motor...
- Ek9 problem
- o2 SENSOR WIRING QUESTION for vx hatch
- good or bad?
- Valve Cover Baffle
- (97 hatch)need help with mixed bolts' tranny mount\front lca's etc
- coupe or sedan ?
- pic request
- hey just joined
- Help on fitting cruise control...
- foglight bulb replacement
- nice site guys
- Clutchmasters Stage 3 vs. Spec Stage 2
- What Timing Belt to Use and AC bracket, 97 JDM B16A in a 96 Civic EX
- GSR block?
- leaking
- CLAIRIFICATION question about camber kits.
- Will a ek9 cluster fit in a 97 civic hx?
- hey just joined
- for sale
- weird shifter problem?!!
- Car won't Crank ---Please Read---
- integra rear swaybar + 97-ish civic coupe ex
- B-series intake manifold question
- USDM DC5 Hubs and Axles on an EK (5 lug swap)
- CEL 72 Random Misfire In Cylinder 2 - Help Please
- Any idea how much it is to fix a broken ignition?
- To good to be true?
- Jackson Racing y8
- name this problem
- Are the JDM and USDM 92-95 Civic Audio Consoles the same?
- 1998 Civic Dx - Headlamps
- RAYBRIG FOGLIGHTS?? no wires, what to do??
- Energy suspension vs Mugen bushings....yes or no!!! Rear trailing arm bushings
- how much is a full k20 swap???
- whats up guys just joined the forum
- EK trunk leak question???
- Stolen Cars
- Civic 1995 Dx headlight/lights problem please help
- HP estimate?
- radiator fan
- Del Sol speedometer dead. Time to fix it!
- denji projector bulb?
- i have problem with my short shifter..
- 4dr gsr exhaust on eg hatch?
- k20 or k24
- SELLING PARTS
- h22 install help
- jdm crx del sol
- b18c, bucking, missing, sputtering and dieing. help me diagnose this POS
- rear window problem - broken and its open!
- Stearing wheel play
- problem bad mounts
- Build Up Project in Need of Some Help?
- b16 into 96 ex. NO SPARK OR FUEL HELP!
- ngk usdm and jdm spark plug question
- brake questions, i check all parts and lube it, still makes noise...
- Stuff on sale
- E brake cable question
- HELP IDLE IS PISSIN ME OFF
- DASH CONVERSION???
- a little off the subject
- How do I make an X with EM racing bars?
- B20/LS TB on a D16y8
- Wings West Side RS side skirts install , need some advice from peeps that have them
- pics of si with 17s
- anybody in indianapolis area with an si?
- HELPPPPP secondary o2 sensor
- 1700$ too much?
- How do you identify skunk 2 stage 2 cams?
- suspension technique identification help
- d15 vtec-e head on d15b8???
- 3 stage vtec ?!?!?!
- VTEC Pressure Switch Interchangeability
- steering...
- 2000 Civic ecu location?
- Clicking from Driver side dash...Searched, but came back with other results
- Questions about exhaust...........
- My Motor Bent 4 Exhaust Valves! Block Still good?
- please help me , ek civic question ..
- sup guys im a noob....
- brake question
- 1997 Auto Civic Shift Problems Shifting hard 2-3 3-2 ?
- timing issue pleaase help out
- Si Engine harness into a 99 ex, hard to do?
- B16 N/A V.S. B18 N/A (Forza mistake?)
- d16y8 into a EK DX HATCHBACK Intake Manifold Question
- Rotten Eggs, again
- best cat back exhaust for around 300 bucks
- Will a...
- search for CEL code 19. Any ideas?
- ***********NEED HELP! 96-98 HB!!! *** THANX!
- wiring harness question for a b18c5 96 cx swap
- rebuilt motor problem starting up
- starting trouble
- WTB: 94-97 Del Sol VTEC Guage Cluster
- i need to figure out where this goes....
- Bought RECARO SRDs for EK...no mounting kits. Best options?
- Brightest Headlights??? Pictures would help
- msd6al
- Engine help asap
- Installing SOHC Cam Gear
- exhaust is too loud after swap....need something more quiet.
- 92-95 Honda Civc EX Manual
- Converting a Auto to Manual and D16Y7 to a H22A or K20
- oil pressure guage! install help
- o2 sensor problem, wrong connector?? 2000 civic ex(ej8) w/ b16
- How do I test "click" an iacv
- p7 brand new factory pistons FOR SALE
- haha...really funny..."sound turbo-charged"
- power steering???
- fixing a 95 ex crash
- Choosing muffflerr!! help!!
- STOLEN: 1999 Red Civic SI, B'ham AL
- This will be fun..
- For those looking for a Double DIN Radio Block off Plate
- Dsm Injectors
- Spark is there, fuel is there, car doesnt start, timing? Pics inside
- Question: ECU wiring
- would this be a good used turbo kit??
- sway bar reinforcement plates
- vss... different on d-series trans than b-series trans?
- 99 red si for sale ****clean title***
- Automatic to Manual Conversion
- performance shops
- Question for JDM B18C5
- Starter relay switch HELP PLEASE!!!!
- FUSE problem; turn signals
- h22 in 93 civic with 93 accord tranny axle q's
- clutch noise
- where to order my kyb struts?
- I need some stock looking wide fenders...
- DIM - Do it myself - replacing inner tie rods!
- rear disc swap issue
- Any1 tryin to find jdm smoked amber corners?
- Steering Knuckle
- Type R Tranny differential noise
- quick question: whats the firing order on b18b?
- Timing belt noise after replacement
- Simple question..
- Speedo just died on me. what should i check first??
- What are these sideskirts?
- Water in spark plug chambers
- anyone have picture of ssautochrome top mount turbo manifold?
- Anybody with a vtec b series in STL area?
- PARKING LIGHT PROBLEMS
- Hood problem!! help
- Need help with pistons/rods......
- 88-91 Civic Si Front Sway Bar Fitting Onto A 92-95 Hatch
- sounds like abs is going off all the time
- 1992 EG Hatch b16 *Primary Oxygen Sensor - Heater Problem*
- ECU upgrade
- Why a chipped P28?
- Suspension set up ?
- unrelated question
- can't find anything on tranny flushing.
- crome ecu setup?
- del sol trans top
- Is a camber kit really necessary?
- Starting PROBLEM!!!!!!!!!!!!!!!
- Brake upgrade from civic stock to itr disc...PLEASE ADVISE
- SWAP: VX engine Swap in 95 EX/SI, EX/SI (sohc vtec)eng in VX
- will i still need my knock sensor on my b16 if i use a p28
- Is there a Line in for XM radio in the stock civic radio?
- d16 wont start. starter or relay?
- need help identifing this ecu and possible chip
- Changed VSS but still code 17
- Interior : Sunvisor Clips
- eg and ek rear mount the same?
- Comptech Sway Bar/Tie Bar
- anyone converted to cable clutch?
- D-series shift linkage
- help, possible missing ecu plug?
- Eg EX Cluster Swap into 95 CX-Cruise Control Flashes Periodically?Shift Light or Other?Searched...
- Where do I buy headlight Bulbs for my JDM housing??
- stage 2 cams with oversized valves question
- Brake question......NEED QUICK RESPONSE
- EM1 Si custom seat covers
- rear wheel bearing torque? 92 Si hatch
- p06 for now
- Hard to star
- rear disk brake question
- amp rating on ignition switch 96 civic
- opinion
- evap code
- another cicvic bites the dust........HAHAHA!!!
- gathers overhead mounted speakers
- del sol motor mount
- arrgh my car wont move
- I know this is bad, but how bad???
- requesting a pic of the EG optional center console
