View Full Version : Honda Civic / Del Sol (1992 - 2000)
- How do I get a cam seal off?
- sway bars
- 15 inch wheel pics
- STOLEN! White EG STOLEN AT Riverside MALL!!!!!
- exhust question
- power window question (searched)
- Does anyone know how to bring your emissions down before i smog?
- PROBLEM: no start in cold weather
- guys i need urgent help!!!
- new guy, help please!
- whining noise on clutch release?
- head good or bad
- Help choosing the right shifter bushings??
- Center Consoles
- Headlights problem??????
- DOHC ZC swap
- taking out power steering
- How do I test my clutch?
- 98ls parts fit auto to manual swap?
- finishing up motor swap?? evap?
- Am I on the right track?
- Why so bad gas mileage?
- HELP!!! car turned off wile driving!
- lookin for pics diy headlights already searched need help
- damn it tranny back in now this, help could it be slave or master cylinder???
- EMERGENCY..PLEASE HELP...Brake lights wont turn on when i step on the Brakes??
- B18C won't start
- drive fine, jerks then cut off on me!! HELP!!
- b16a2 will not start
- Guesstimate the whp/tq of this setup...
- Does anyone autocross?
- EK Front End On 93 Civic Si Hatch??
- Electrical Problem (not sure tho)
- Oil Change
- Best bulbs for 99-00 OEM Fogs?
- this is my last foglights Q
- Honda Stock CD Player
- EG INTERIOR CONVERTED INTO A DC INTERIOR
- Which Trans Is LSD????
- 92 h22 prelude walbro on 98 cx h22???
- 3 sick hatches at muchas gracias last night.
- I ran into a mail box
- 99 Si Gas Mileage Questions...28mpg
- changing trans. fluid with (synthetic)?
- D16z6
- Confused with V-tec
- horrible grinding type rubbing noise when turning right only??
- Is a t70 to big of turbo?
- Passwordjdm headlights
- Heat Shield
- wiring alternator
- Problems with ECU?
- best engine for 98 hatch cx?
- night sidemarker pics!
- need advice on tranny grinding
- mugen del slow.......lol pics.
- Coolent leaking BAD!
- 92 civic with D16Z6 swa. Question about warming up the ecu
- radiators helpful comments only please
- civic lip
- 75.5mm head gasket
- GSR Leather in a VX
- HX Sway Bar onto a DX
- oil pressure gauge problem!
- Clutch trouble
- Ideling problem!!
- y7 distributor on jdm b16?
- Quick help!!!!
- wire harness plug-ins go where?
- Is this my service connector??
- Help with suspension..
- 2 Clutch Master Cylinders + Low Pedal Engagement Point = No Drive K24a2 EK Hatch
- my car
- Tacho TCS and CEL not working after JDM SIR manual swap?
- is this possibole
- b16a3 in 1996 ?
- Need Help on Car Idlering
- Quick question about micropolish.
- My Password Strut bar is bad
- where to get dealer repair manual???
- AEM v2
- need help with coolant leak
- Tips on how to mount 99-00 CTR Rear lip??????????????
- Need Help ASAP
- got a quick question?
- axles spline 's
- 92 civic ex conversion
- How to quote someone in your sig
- my jg 65 mm throttle got a question!
- do recaros ?
- Pics of 15" wheels
- clutch problem??
- so my rack is going bad... where can i find a new one
- hello 15 inch wheels post your pics
- Tiny scratches on headlights
- 94 civic radio code
- quick question/need quick answwer
- Screeching from back left tire when braking...New brake pads or rotors/cost?
- z6 VS y8
- okay..just searched...nothing..wut is the differences between (sohc) y8 and z6 head ?
- foglights Q.....again
- How can you tell if this is for a 5spd or not
- After swap issues
- I need swap help
- Dizzy conversion.
- Crank sensor??
- quick/easy shift linkage question
- PLEASE HELP SIR-II swap
- d15b stage 3 vtec obd2 into 94 eg obd1
- Speedometer not working, rest of cluster is fine. VSS broken?
- Highbeams=vtec
- Password's J's replica intake or AEM V2?
- Will a '93 D16Z6 speedo sensor work with a 2000 Si (Y21) transmission?
- EK PART SALE 1997 EK PARTS. BLACK, CLEAN BODY. EVERYTHING IS UP FOR GRABS
- Insturctions for password fogs?
- Loosing antifreeze... Why?
- 92-95 civics fog
- cable transmission in an eg , what are the options?
- tranny bolt question
- I put a 90-93 LS pump on my b18 swap in my EG...so yeah, it can be done...
- Head gasket
- Lightbulb Size for 92-95 Climate Control?
- Quaife quick ratio steering gear kit..worth it or naw?
- What is a testpipe?
- door locks
- 96-98 and 99-00 headlights
- REF: Gauge Lighting Questions Answered!
- Lurching when letting gas off.
- rev limit @3800 while in neutral
- What tires for hx rims on em1?
- Honda Civic w/ 24 MPG?
- Flashing brake light?
- NRG steering lock - worth the security?
- Civic cylinder 4 randomly misfire??
- running a virgin P28 on a B16A with 12:1 compression???
- 2000 SI.. idle problem after oil change
- whats the best tech manual for a honda civic?
- tranny
- brand new battery is dieing
- 95 civic ecu problem
- Tanabe... good stuff?
- Alternator for a civic any advice?
- is it the thermostat or the radiator
- jdm pr3
- Thinking of painting steelie wheel covers...
- HOW TO INPROVE MY 98 CIVIC DX WITHOUT A SWAP?
- Help with part # + spoiler
- need insight on flywheel shaving
- DOSE ANYONE KNOW????
- What is this? Deer Whistle? Spy Device?
- 2000 Honda Civic wiring/relay problem
- UKDM Ek AUdio Console?
- Can make a new For sale thread in here???
- NOOB QUESTION
- auto to manual
- Removing axles during swap
- EP3r cluster in EK
- help with tires sizes and brand
- peeps in washington help me out
- greedy full auto timer?
- OMFG just my luck.!
- car wont start!!!
- Prelude Si Wheels??
- EG FRONT END TO EK FRONT END???
- chrome?
- Upgrades for car
- obviously wont work in my ride. So i thought just changing the internals complete ratio and LSDHydra
- Putting together B20/vtec oil leaking from coolant arm water pump?! Headgasket???
- need a LS crank in sacramento area
- more gsr swap wiring questions. Swap gurus help please.
- Body Code ????
- noob!
- Does anyone know what shifter this is?
- alignment gone bad?
- ek sunroof noise
- FS: Del Sol Seats
- Gauge Cluster
- find the short between the ECU and MAP sensor in white wire
- Anybody around the Phoenix area?
- 92 cx hatch weird linkage or tranny problem.help?
- CIVIC SI EG STOLEN!!....
- what is the best type of black to paint an EK9
- what size piping is the civic 5zigen fireball??
- b18 swap start trouble
- 92dx with b16a2swap
- dist. noise
- 99-00 Civic si aftermarket lip
- quick swap Q
- 2.5 inch catback too much?
- 92 cx going k
- 92 civic gauge cluster !!! si/sir
- coolant loss and over heating
- Type r tranny or GSR ?
- WOULD A GSR EXHAUST MANIFOLD FIT B16?
- on da phone with password jdm
- d16z6 engine with d16y8 crank pulley?
- ek h22 exhaust help
- would something stuck in pressure plate cause gear grinding?
- H22 eg, whats a good suspension setup
- je 9.1 pistons with stock b16 cams or ctr cams?
- Real Quick Question
- problem.
- Car wants to sputter or skip right as i start to accelerate cant figure out???
- exhaust decision time....
- coolant doesnt return to radiator from the overflow bottle? whats wrong?
- how to install spark plugs
- Smart to do swap this,or just boost what i have?
- radiator hoses compressed??
- megan racing springs installed, need to settle>?
- wheels
- 99-00 Civic SI Strut Bar on 99-00 Hatch?
- Top hats for my tokico illuminas??
- part#
- quick tps question
- couple of qwik questions
- civic with stock d16y7
- HELP! differences between '98 and '99 civic ex engine wiring harnesses??
- sooo I converted my EG to complete cable clutch setup...
- b16 swap trouble.
- shifter moves, car shimmies
- would you rock these
- caliper
- Comptech exhaust??
- Jdm B18c swap query.
- Valve guides
- strut bars that fit D16Y7 Ek civic
- rhd conversion w/srs question
- Rear Brake Shoes
- Those sporting a 2" or more drop and 16" wheels chime in...
- its time for boost
- CTR STRUT AND SPRINGS
- Strange sound in 1st gear
- 1999-2000 ctr crank pulley
- will jdm spec ek fog light fit
- Demolition Derby
- What's the best size rims
- Can someone verify what I think this is (Pics included)?
- Motor Mount
- ECU question
- Integra interior harness wiring issue (Dash Conversion)
- rear o2 sensor (97 ej8)?
- Minnesota 97 Civic Seadan FOR SALE!
- Just bought my first (FUEL INJECTED HONDA) NEED help
- need o2 sensor plug pinout
- Bad tensioner on GSR motor now car wont start!??! READ TIMING EXPERTS
- o-ring question
- Injector Question???
- Trouble is rear lower tie bar
- jdm carboys
